Vdev Offline - Disks with exported pools like david-g
I am at a loss. I have 2 pools on truenas one is my backup which is raid z1 and the other is all my movies which was on a 2 disk stripe.
I had one disk reporting errors so I replaced it and resilvered it. Few days later the drive I replaced started to fail and now is not working at all.
I go in and the drive removed itself from the pool and is stuck on disks with exported pools.
I tried the things that were posted for David but they do not seem to be working.
Halp!!
Welcome to TrueNAS
Last login: Wed Oct  8 19:38:48 PDT 2025 on pts/0
root@MyNAS[~]# sudo lsblk -o NAME,MODEL,SERIAL,LABEL,UUID,PARTUUID,TYPE
NAME   MODEL                SERIAL          LABEL     UUID                                 PARTUUID                             TYPE
sda    WDC WD20EADS-00R6B0  WD-WCAVY4777407        disk
├─sda1        6df05036-d156-11ec-a065-7824af37586a part
└─sda2                                      Main      9173209862511049985                  6e144544-d156-11ec-a065-7824af37586a part
sdb    CT480BX500SSD1       2122E5A54D73        disk
├─sdb1                                                74FA-1C09                            c621c460-d0a0-11ec-8098-7824af37586a part
├─sdb2                                      boot-pool 4318886864942293986                  c62a4a61-d0a0-11ec-8098-7824af37586a part
└─sdb3        c6266c71-d0a0-11ec-8098-7824af37586a part
sdc    WDC WD20EADS-00R6B0  WD-WCAVY1956418        disk
├─sdc1        6ddeea2f-d156-11ec-a065-7824af37586a part
└─sdc2                                      Main      9173209862511049985                  6e211148-d156-11ec-a065-7824af37586a part
sdd    WDC WD20EADS-11R6B1  WD-WCAVY2518515        disk
├─sdd1        6dcdc5e9-d156-11ec-a065-7824af37586a part
└─sdd2                                      Main      9173209862511049985                  6dff06ea-d156-11ec-a065-7824af37586a part
sde    ST2000DM006-2DM164   Z8E0FL0W        disk
├─sde1        6d4a4c7c-d156-11ec-a065-7824af37586a part
└─sde2                                      Main      9173209862511049985                  6d567132-d156-11ec-a065-7824af37586a part
sdf    HGST HDS5C4040ALE630 PL2331LAGGH8RJ        disk
├─sdf1        23eaf55c-d1af-11ec-8a08-7824af37586a part
└─sdf2                                      Media     12220323433134146488                 23ff3a02-d1af-11ec-8a08-7824af37586a part
sdg    WDC WD30EZRX-00AZ6B0 WD-WCC070093399        disk
sdh    WDC WD40EFPX-68C6CN0 WD-WXK2AA2RD61V        disk
root@MyNAS[~]# ```
We’re going to to need your current hardware details, pool & VDEV setup and OS version.
What did you attempt to do? What is your current pool(s) status?
Results from the following may help. Post back using Preformatted text like you did with LSBLK
sudo zpool status -v
sudo zpool import
Browse some other threads and do the Tutorial by the Bot to get your forum trust level up and post images and links
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
Hey Barky,
I have looked at other threads and other places online.
I am still new to truenas although I have been using it for over a year lol.
I have rebooted and tried some commands found in another thread where he had a similar experience to me but they didnt seem to work.
root@MyNAS[~]# sudo zpool status -v
  pool: Main
 state: ONLINE
  scan: resilvered 7.32G in 2 days 00:42:00 with 0 errors on Wed Oct  8 18:09:23 2025
        Main        ONLINE       0     0     0
          raidz1-0  ONLINE       0     0     0
            sde2    ONLINE       0     0     0
            sdd2    ONLINE       0     0     0
            sdc2    ONLINE       0     0     0
            sda2    ONLINE       0     0     0
errors: No known data errors
  pool: boot-pool
 state: ONLINE
status: One or more features are enabled on the pool despite not being
        requested by the 'compatibility' property.
action: Consider setting 'compatibility' to an appropriate value, or
        adding needed features to the relevant file in
        /etc/zfs/compatibility.d or /usr/share/zfs/compatibility.d.
  scan: scrub repaired 0B in 00:01:17 with 0 errors on Mon Oct  6 03:46:19 2025
        NAME                                     STATE     READ WRITE CKSUM
        boot-pool                                ONLINE       0     0     0
          ata-CT480BX500SSD1_2122E5A54D73-part2  ONLINE       0     0     0
errors: No known data errors```
root@MyNAS[~]# sudo zpool import
  pool: Media
 state: UNAVAIL
status: One or more devices contains corrupted data.
action: The pool cannot be imported due to damaged devices or data.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-5E
        Media                                   UNAVAIL  insufficient replicas
          sdf2                                  ONLINE
          1cde6491-a43e-4eb5-bf29-9b018770dbe0  UNAVAIL```
I have a feeling I may be cooked.
even though the drive was not full so I dont think it went into the second drive in the stripe.
I also know they are not recommended since this kind of thing can happen.
Try powering off and reseating the drive cables, power and data, for your Media pool. It looks like you replaced a disk off the MAIN pool (Raid-Z1) because it is reporting ‘resilvered 7.32G’ under zpool status, above.
did you replace a disk on the Media pool also?
I have reset all the cables and even added a pcie sata setup with 6 ports to make sure the mb was not acting up. that is the current setup.
The 4 main disks raidz1 are on that card. I did replace one of the drives for media a 3tb that was reporting errors to a 4tb “refurb” from WD and that is the one that does not even show up anymore. I since changed that to the other one I got to see if that would help but it just shows it as available.
So on the main backup I have 4 2tb drives and Media had 2 a 4tb which is the one showing disks with exported pools and was 3tb changed to the other 4tb that failed
The Media pool. You say striped so that was something like a 3TB + 3TB for 6TB of space in the Pool? If a drive fails in that configuration of a VDEV, the entire pool is lost.
Check on the model of the PCIe SATA card. We recommend HBA cards and not ‘port expanders’. If the SATA card is a SATA switch, it may be okay.
What’s all the noise about HBA’s, and why can’t I use a RAID controller?
Multiply your problems with SATA Port Multipliers and cheap SATA controllers
So the pci-e I used is this 10Gtek 6-Port PCIe Expansion Card, PCIe x4 to 6X SATA 3.0 (6Gbps)
And yes the media was 2 drive stripe both 4tb after I replaced one 3tb with a new 4tb which is what failed.
I just took the media drives and put them back on the mobo to make sure that was not interfering with my issue and its the same.
I took the drive that stopped showing up and plugged it back in and it still does not show up.
sda    HGST HDS5C4040ALE630 PL2331LAGGH8RJ        disk
├─sda1        23eaf55c-d1af-11ec-8a08-7824af37586a part
└─sda2                                      Media     12220323433134146488                 23ff3a02-d1af-11ec-8a08-7824af37586a part
sdc    WDC WD20EADS-11R6B1  WD-WCAVY2518515        disk
├─sdc1        6dcdc5e9-d156-11ec-a065-7824af37586a part
└─sdc2                                      Main      9173209862511049985                  6dff06ea-d156-11ec-a065-7824af37586a part
sdd    WDC WD30EZRX-00AZ6B0 WD-WCC070093399        disk
sde    WDC WD20EADS-00R6B0  WD-WCAVY4777407        disk
├─sde1        6df05036-d156-11ec-a065-7824af37586a part
└─sde2                                      Main      9173209862511049985                  6e144544-d156-11ec-a065-7824af37586a part
sdf    ST2000DM006-2DM164   Z8E0FL0W        disk
├─sdf1        6d4a4c7c-d156-11ec-a065-7824af37586a part
└─sdf2                                      Main      9173209862511049985                  6d567132-d156-11ec-a065-7824af37586a part
sdg    WDC WD40EFPX-68C6CN0 WD-WXK2AA2RD61V        disk
sdh    WDC WD20EADS-00R6B0  WD-WCAVY1956418        disk
├─sdh1        6ddeea2f-d156-11ec-a065-7824af37586a part
└─sdh2                                      Main      9173209862511049985                  6e211148-d156-11ec-a065-7824af37586a part
root@MyNAS[~]# ```
From what I am seeing here the pcie is not a issue "yet" I will look into switching to a HBA though
I have literally no idea what happened. I let it sit running since my last reply and it fixed itself.
I quickly added the other drive I had on standby and will see what it does in the am
sda    WDC WD40EFPX-68C6CN0 WD-WX62DA3C17LV        disk
└─sda1                                      Media     12220323433134146488                 1cde6491-a43e-4eb5-bf29-9b018770dbe0 part
sdb    HGST HDS5C4040ALE630 PL2331LAGGH8RJ        disk
├─sdb1        23eaf55c-d1af-11ec-8a08-7824af37586a part
└─sdb2                                      Media     12220323433134146488                 23ff3a02-d1af-11ec-8a08-7824af37586a part
sdc    WDC WD30EZRX-00AZ6B0 WD-WCC070093399        disk
sdd    CT480BX500SSD1       2122E5A54D73        disk
├─sdd1                                                74FA-1C09                            c621c460-d0a0-11ec-8098-7824af37586a part
├─sdd2                                      boot-pool 4318886864942293986                  c62a4a61-d0a0-11ec-8098-7824af37586a part
└─sdd3        c6266c71-d0a0-11ec-8098-7824af37586a part
sde    WDC WD20EADS-11R6B1  WD-WCAVY2518515        disk
├─sde1        6dcdc5e9-d156-11ec-a065-7824af37586a part
└─sde2                                      Main      9173209862511049985                  6dff06ea-d156-11ec-a065-7824af37586a part
sdf    WDC WD20EADS-00R6B0  WD-WCAVY1956418        disk
├─sdf1        6ddeea2f-d156-11ec-a065-7824af37586a part
└─sdf2                                      Main      9173209862511049985                  6e211148-d156-11ec-a065-7824af37586a part
sdg    WDC WD20EADS-00R6B0  WD-WCAVY4777407        disk
├─sdg1        6df05036-d156-11ec-a065-7824af37586a part
└─sdg2                                      Main      9173209862511049985                  6e144544-d156-11ec-a065-7824af37586a part
sdh    ST2000DM006-2DM164   Z8E0FL0W        disk
├─sdh1        6d4a4c7c-d156-11ec-a065-7824af37586a part
└─sdh2                                      Main      9173209862511049985                  6d567132-d156-11ec-a065-7824af37586a part
sdi    WDC WD40EFPX-68C6CN0 WD-WXK2AA2RD61V        disk
└─sdi1                                      Media     12220323433134146488                 74a8b252-8954-4d9e-980b-901cbaac7266 part
root@MyNAS[~]#
