Which drive is offline?
The dashboard says 1 drive is offline, but it looks like 3 are having issues (sde, sdg, sdm). I have cold spares, so I figured I’d swap out the one that’s offline first, then let it rebuild, then tackle the next problems.
Bu I don’t see which drive is offline.
Image upload isn’t working. Color me surprised that this terrible forum software doesn’t work. :-/
I guess there’s no way to edit a post to get rid of a typoe. The dashboard says 1 disk has errors, and the notifications say:
Critical
Device: /dev/sdg [SAT], ATA error count increased from 0 to 1.
2024-12-29 00:18:13 (America/Los_Angeles)
Dismiss
cancel
Critical
Device: /dev/sdm [SAT], ATA error count increased from 1 to 149.
2024-12-29 00:18:14 (America/Los_Angeles)
Dismiss
cancel
Critical
Device: /dev/sde [SAT], 8 Currently unreadable (pending) sectors.
2024-12-31 14:18:13 (America/Los_Angeles)
Dismiss
cancel
Critical
Device: /dev/sde [SAT], 8 Offline uncorrectable sectors.
Dismiss
cancel
Critical
Device: /dev/sdg [SAT], 1 Currently unreadable (pending) sectors.
2025-01-07 21:18:13 (America/Los_Angeles)
Dismiss
cancel
Critical
Device: /dev/sdg [SAT], ATA error count increased from 1 to 8.
Dismiss
Open a shell and run:
sudo zpool status
That should tell you which drive is offline.
Also, all those drives having issues at the same time feels like a controller error, odd for every drive to be having issues.
I have 14 drives. It is strange that 3 are having an issue, but that’s not all of the drives.
There’s no way to do it in the web gui???
It says no errors and all the drives are online. Why would the web UI and the command line disagree???
I can’t copy out of the web based CLI, and I can’t upload a screenshot, so there’s that too.
The web UI for zpool says the same thing as the CLI.
Notifications say this:
Critical
Dismiss
cancel
Critical
Dismiss
cancel
Critical
Dismiss
cancel
Critical
Dismiss
cancel
Critical
Dismiss
cancel
Critical
Dismiss
cancel
Critical
Device: /dev/sdo [SAT], 5 Currently unreadable (pending) sectors (changed +4).
2025-01-10 08:04:44 (America/Los_Angeles)
Dismiss
cancel
Critical
Device: /dev/sdo [SAT], ATA error count increased from 8 to 13.
Dismiss
cancel
Critical
Device: /dev/sdi [SAT], 8 Currently unreadable (pending) sectors.
Dismiss
cancel
Critical
Device: /dev/sdi [SAT], 8 Offline uncorrectable sectors.
Dismiss
notifications_active
Info
Scrub of pool ‘zPool’ finished.
2024-12-29 04:44:18 (America/Los_Angeles)
Dismiss
Info
Scrub of pool ‘boot-pool’ finished.
2025-01-09 03:45:09 (America/Los_Angeles)
Dismiss
Info
Scrub of pool ‘boot-pool’ started.
2025-01-09 03:45:01 (America/Los_Angeles)
Dismiss
Can you please run the following commands in a shell (System Settings / Shell) and post the output here with the output of each command in a separate </> box:
  • lsblk -bo NAME,MODEL,ROTA,PTTYPE,TYPE,START,SIZE,PARTTYPENAME,PARTUUID
  • lspci
  • sudo sas2flash -list
  • sudo sas3flash -list
  • sudo zpool status -v
Thank you. With this detailed diagnostic information we will have a chance to work out what the problem is and what the cause is.
P.S. Please put your signature in a concertina like in my signature so we don’t have to keep scrolling past reams of duplicated signature.
I tamed my sig, but idk how to make a concertina.
Like I just said, I can’t copy out of the interface, idk why. CTRL + INS + C doesn’t copy the text.
I enabled SSH, but PuTTY is having a weird response. As soon as I enter the username, it errors out and mentions a key, which I’ve never seen PuTTY do before.
The SSH credentials in Backup Credentials > SSH Connections looks like an outbound connection, presumably meant for backing up data or something. Not the local SSH server for incoming connections.
How many posts do I have to make before I can upload a screenshot?
[details=Summary line]
Put your details here
[/details]
Just use the Shell in the UI under System Settings (with the cog symbol)
IS THERE SOME REASON YOU ARE IGNORING ME WHEN I TELL YOU THAT I CAN’T GET INFORMATION OUT OF THE WEB GUI?
I got SSH working. However, Truenas, PuTTY, and forum metadata DO NOT play nice. The SSH client in PowerShell worked fine. I couldn’t find any others on the internet.
I think I got these in the same order as you requested them:
admin@truenas[~]$ lsblk -bo NAME,MODEL,ROTA,PTTYPE,TYPE,START,SIZE,PARTTYPENAME,PARTUUID
NAME     MODEL   ROTA PTTYPE TYPE     START           SIZE PARTTYPENAME             PARTUUID
sda      WDC WUH    1 gpt    disk           14000519643136
└─sda1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 5d64fc93-6e46-48d4-b69e-d94d9dceb84csdb      WDC WUH    1 gpt    disk           14000519643136
└─sdb1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 25ec455c-a629-4300-b16d-09deaa3a88a0sdc      TOSHIBA    1 gpt    disk           14000519643136
└─sdc1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 0278dd80-3622-46b5-8a8f-4fa4b6b6142bsdd      TOSHIBA    1 gpt    disk           14000519643136
└─sdd1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 41644b00-0499-4742-9d4e-a8e76f823d61sde      WDC WUH    1 gpt    disk           14000519643136
└─sde1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 1851ae7d-b04d-4ce7-a718-5a8aefbcbb2bsdf      WDC WUH    1 gpt    disk           14000519643136
└─sdf1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 8c7742ef-a8a0-4dc3-b974-316e43d8a15asdg      TOSHIBA    1 gpt    disk           14000519643136
└─sdg1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 6406fd6a-053c-4195-babe-f088281483f8sdh      TOSHIBA    1 gpt    disk           14000519643136
└─sdh1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS c9e772ad-f118-4e92-b5bd-c872033b71a1sdi      WDC WUH    1 gpt    disk           14000519643136
└─sdi1              1 gpt    part      4096 14000516501504 Solaris /usr & Apple ZFS dbcd4be4-2531-454e-ae32-ef388712df7asdj      TOSHIBA    1 gpt    disk           14000519643136
└─sdj1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 176b57a1-a3bc-4bc2-b1ce-390c2d4da6c8sdk      SanDisk    0 gpt    disk             128035676160
├─sdk1              0 gpt    part      4096        1048576 BIOS boot                f1eb4c83-ddc8-45bc-b59a-5909fba158b5├─sdk2              0 gpt    part      6144      536870912 EFI System               84d5455d-9b3d-4d74-a64a-df269a20e05c├─sdk3              0 gpt    part  34609152   110315773440 Solaris /usr & Apple ZFS 6ecbfa39-b644-4021-bcaa-5c7e684f174d└─sdk4              0 gpt    part   1054720    17179869184 Linux swap               646e196c-7554-4fbe-8f45-45f26bdf5938  └─sdk4            0        crypt             17179869184
sdl      WDC WUH    1 gpt    disk           14000519643136
└─sdl1              1 gpt    part      4096 14000516501504 Solaris /usr & Apple ZFS b6014162-d311-47ac-b63c-6e6a72c4f07fsdm      TOSHIBA    1 gpt    disk           14000519643136
└─sdm1              1 gpt    part      4096 14000516497920 Solaris /usr & Apple ZFS 5fc7e2f4-0dde-4895-8f1a-432ca652f35esdn      WDC WUH    1 gpt    disk           14000519643136
└─sdn1              1 gpt    part      4096 14000516501504 Solaris /usr & Apple ZFS 1a4e3a70-25d0-4c61-91bd-9f76014d1ae3sdo      WDC WUH    1        disk           14000519643136
└─sdo1              1        part      4096 14000516501504                          59d09ab8-9597-4f79-be46-6e770e16dd34aaaadadadadmadmadmiadadmiadmiadmiadmadmadmiadadmadmiadadadadmadmaadadminadmadmiadmadmadmaadmaadadaaadadaadaaadaaaaadaaaaaaaaaaaaaaaadmin@truenas[~]$
admin@truenas[~]$ lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03)
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
03:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
04:00.0 USB controller: ASMedia Technology Inc. Device 3241
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
06:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
06:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
06:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
07:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
08:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
09:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c9)
09:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
09:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
09:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
09:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
09:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
0a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
0a:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
admin@truenas[~]$ sudo sas2flash -list
[sudo] password for admin:
LSI Corporation SAS2 Flash Utility
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved
        Adapter Selected is a LSI SAS: SAS2008(B2)
        Controller Number              : 0
        Controller                     : SAS2008(B2)
        PCI Address                    : 00:01:00:00
        SAS Address                    : 5003005-7-01a8-08b0
        NVDATA Version (Default)       : 14.01.00.08
        NVDATA Version (Persistent)    : 14.01.00.08
        Firmware Product ID            : 0x2213 (IT)
        Firmware Version               : 20.00.07.00
        NVDATA Vendor                  : LSI
        NVDATA Product ID              : SAS9211-8i
        BIOS Version                   : 07.39.02.00
        UEFI BSD Version               : 07.27.01.01
        FCODE Version                  : N/A
        Board Name                     : SAS9211-8i
        Board Assembly                 : ARTofSERVER
        Board Tracer Number            : N/A
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
admin@truenas[~]$ sudo sas3flash -list
Avago Technologies SAS3 Flash Utility
Version 16.00.00.00 (2017.05.02)
Copyright 2008-2017 Avago Technologies. All rights reserved.
        No Avago SAS adapters found! Limited Command Set Available!
        ERROR: Command Not allowed without an adapter!
        ERROR: Couldn't Create Command -list
        Exiting Program.
admin@truenas[~]$ sudo zpool status -v
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:08 with 0 errors on Thu Jan  9 06:45:09 2025
          sdk3      ONLINE       0     0     0
errors: No known data errors
  pool: zPool
 state: ONLINE
  scan: scrub repaired 0B in 04:44:14 with 0 errors on Sun Dec 29 07:44:18 2024
        NAME                                      STATE     READ WRITE CKSUM
        zPool                                     ONLINE       0     0     0
          raidz2-0                                ONLINE       0     0     0
            1851ae7d-b04d-4ce7-a718-5a8aefbcbb2b  ONLINE       0     0     0
            0278dd80-3622-46b5-8a8f-4fa4b6b6142b  ONLINE       0     0     0
            25ec455c-a629-4300-b16d-09deaa3a88a0  ONLINE       0     0     0
            c9e772ad-f118-4e92-b5bd-c872033b71a1  ONLINE       0     0     0
            176b57a1-a3bc-4bc2-b1ce-390c2d4da6c8  ONLINE       0     0     0
            8c7742ef-a8a0-4dc3-b974-316e43d8a15a  ONLINE       0     0     0
            41644b00-0499-4742-9d4e-a8e76f823d61  ONLINE       0     0     0
          raidz2-1                                ONLINE       0     0     0
            5d64fc93-6e46-48d4-b69e-d94d9dceb84c  ONLINE       0     0     0
            6406fd6a-053c-4195-babe-f088281483f8  ONLINE       0     0     0
            5fc7e2f4-0dde-4895-8f1a-432ca652f35e  ONLINE       0     0     0
            b6014162-d311-47ac-b63c-6e6a72c4f07f  ONLINE       0     0     0
            1a4e3a70-25d0-4c61-91bd-9f76014d1ae3  ONLINE       0     0     0
            59d09ab8-9597-4f79-be46-6e770e16dd34  ONLINE       0     0     0
            dbcd4be4-2531-454e-ae32-ef388712df7a  ONLINE       0     0     0
Looking over this data, I don’t see much of anything useful, and it completely contradicts the notifications that are complaining of issues.
The errors you mentioned in your initial posts are SMART errors and you haven’t posted the smart reports.
Run sudo smartctl -a /dev/sdX on each drive.
Replace X with the corresponding device name (/dev/sda, /dev/sdb, and so on).
To clarify, I say each drive intentionally, since it’s been more than a week since those errors were generated, there’s a fair chance you rebooted your server. When you do that the device names can move around so suddenly sda (and so on) refers to a different disk than it used to.
I’ll add that your lsblk is almost nonsensical, not sure what happened there but maybe the formatting broke it, the NAME column makes that apparent.
Yeah, I took the server down the other day, moved it to my workbench, and fired it up last night. I have 2 cold standby drives and was trying to figure out which drives I need to swap out.
“Run these random commands for random/no reason” is getting old though, what are your commands supposed to do and why are we running them?
lsblk looks fine to me, just says the drives are online though, which the web GUI also says.
You said you couldn’t see any errors in your previously assembled and posted data.
Since the alerts refer to SMART errors, running smartctl will let you identify which disks are the actual drives that are running into issues. It will uniquely do so by also showing you the serial number, lessening the risk of you pulling the wrong drives, if it comes to that.
smartctl is a basic tool.
Google it if you want to see sample output so you can make an informed choice of if it will be helpful or not.
This is what the lsblk should have looked like, if it was formatted correctly.
Especially note the dashes at the beginning of each row denoting each device and clearly letting you see any partitions. Your post does not look like that. In fact it suggests that sda1, sdb1, sdc1 and so on are all partitions of sda. That is nonsensical.
Sample lsblk
% lsblk -bo NAME,MODEL,ROTA,PTTYPE,TYPE,START,SIZE,PARTTYPENAME,PARTUUID
sda         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sda1                                   1 gpt    part      128     2147418624 Linux swap               ce373728-6e01-4a81-ab39-ab4690cc2934
│ └─md127                                1        raid1             2145320960
│   └─md127                              1        crypt             2145320960
└─sda2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS 102863d2-f629-4a97-b24d-1ba9750cbe8c
sdb         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sdb1                                   1 gpt    part      128     2147418624 Linux swap               93444cbc-a748-4417-a17e-77dfabdcb5fd
│ └─md124                                1        raid1             2145320960
│   └─md124                              1        crypt             2145320960
└─sdb2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS 886b9e9c-dc83-41ec-922c-2ebb2ce9fc2e
sdc         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sdc1                                   1 gpt    part      128     2147418624 Linux swap               25b211ef-517f-4e6d-91c6-43eb69810680
└─sdc2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS b162e6ac-15ec-4bfd-b7ee-504dcc4a7ed2
sdd         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sdd1                                   1 gpt    part      128     2147418624 Linux swap               a9758214-1b31-4c8b-a68d-753a3ecf1d9a
└─sdd2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS 51de2c11-2c4b-406c-a51a-30419d7349f8
sde         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sde1                                   1 gpt    part      128     2147418624 Linux swap               607087a4-4ab1-48f2-b7d6-44fad514f5f0
└─sde2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS d0128e36-a1ff-41b9-b401-e0b8d0007209
sdf         Samsung SSD 870 EVO 4TB      0 gpt    disk           4000787030016
├─sdf1                                   0 gpt    part      128     2147418624 Linux swap               3949722c-1119-4c56-ba67-a4ae8fb434a1
│ └─md126                                0        raid1             2145320960
│   └─md126                              0        crypt             2145320960
└─sdf2                                   0 gpt    part  4194432  3998639463936 Solaris /usr & Apple ZFS cd4db217-58f9-45d3-8b28-f18a88940b0e
sdg         Samsung SSD 850 EVO 500GB    0 gpt    disk            500107862016
├─sdg1                                   0 gpt    part      128     2147418624 Linux swap               30bd6f17-d3cf-40b1-ac29-eb6c9e916c44
└─sdg2                                   0 gpt    part  4194432   497960295936 Solaris /usr & Apple ZFS d183bbea-3039-40a1-a4fd-fac5c2f63409
sdh         Samsung SSD 850 EVO 500GB    0 gpt    disk            500107862016
├─sdh1                                   0 gpt    part      128     2147418624 Linux swap               1e7b0527-8847-4531-89b0-72c191fe1546
└─sdh2                                   0 gpt    part  4194432   497960295936 Solaris /usr & Apple ZFS d10851f3-2073-489a-8c84-f25b21ccbe8e
sdi         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sdi1                                   1 gpt    part      128     2147418624 Linux swap               74bacaf2-9741-4ad9-9553-9209d98f5567
│ └─md125                                1        raid1             2145320960
│   └─md125                              1        crypt             2145320960
└─sdi2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS f6c21b17-94ea-4ec5-8c1d-34cebbd30a84
sdj         Samsung SSD 870 EVO 4TB      0 gpt    disk           4000787030016
├─sdj1                                   0 gpt    part      128     2147418624 Linux swap               3770da47-a1cf-4241-a622-2c0d19d640d1
└─sdj2                                   0 gpt    part  4194432  3998639463936 Solaris /usr & Apple ZFS e892aeae-d461-4efd-a482-ec1efee4c125
sdk         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sdk1                                   1 gpt    part      128     2147418624 Linux swap               df06af8d-16e3-424c-b270-44dddbd10957
└─sdk2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS 1fe48be2-df53-4deb-a374-2742b2fe59d8
sdl         Samsung SSD 850 PRO 128GB    0        disk            128035676160
sdm         TOSHIBA MG09ACA18TE          1 gpt    disk          18000207937536
├─sdm1                                   1 gpt    part      128     2147418624 Linux swap               b95e958f-747e-48af-8581-3485033e0e39
└─sdm2                                   1 gpt    part  4194432 17998060371456 Solaris /usr & Apple ZFS bad53db8-a22c-41d8-97fb-ad3192082e14
sdn         SuperMicro SSD               0        disk             31675383808
sdo         Samsung SSD 850 PRO 128GB    0 gpt    disk            128035676160
├─sdo1                                   0 gpt    part     4096        1048576 BIOS boot                605cee57-25da-481e-9737-2f2f16e58d25
├─sdo2                                   0 gpt    part     6144      536870912 EFI System               45b75913-4911-4cb2-b244-59056a39e6ab
└─sdo3                                   0 gpt    part  1054720   127495642624 Solaris /usr & Apple ZFS 9abb11c3-74d1-479e-b992-33eada081798
sdp         SuperMicro SSD               0        disk             31675383808
nvme1n1     INTEL SSDPEK1A118GA          0 gpt    disk            118410444800
└─nvme1n1p1                              0 gpt    part       40   118410407424 Solaris /usr & Apple ZFS 5923f15f-cbad-4e19-b9fa-83d7d8808c61
nvme0n1     INTEL SSDPEK1A118GA          0 gpt    disk            118410444800
└─nvme0n1p1                              0 gpt    part       40   118410407424 Solaris
admin@truenas[~]$ sudo smartctl -a /dev/sda
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.63-production+truenas] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Ultrastar DC HC530
Device Model:     WDC  WUH721414ALE604
Serial Number:    9JHDHHLT
LU WWN Device Id: 5 000cca 258d3c627
Firmware Version: LDGSW2L0
User Capacity:    14,000,519,643,136 bytes [14.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5319
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Jan 10 13:55:33 2025 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (  101) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1492) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   001    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   136   136   054    Pre-fail  Offline      -       96
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       384 (Average 381)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       27
  5 Reallocated_Sector_Ct   0x0033   100   100   001    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   001    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   094   094   000    Old_age   Always       -       42205
 10 Spin_Retry_Count        0x0013   100   100   001    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       18
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1749
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       1749
194 Temperature_Celsius     0x0002   060   060   000    Old_age   Always       -       34 (Min/Max 15/45)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     35044         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sdb
Serial Number:    9JGJ0WVT
LU WWN Device Id: 5 000cca 258c7494f
Local Time is:    Fri Jan 10 13:56:47 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1465) minutes.
  2 Throughput_Performance  0x0005   137   137   054    Pre-fail  Offline      -       92
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       391 (Average 390)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       26
  9 Power_On_Hours          0x0012   094   094   000    Old_age   Always       -       45408
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       23
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1878
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       1878
194 Temperature_Celsius     0x0002   060   060   000    Old_age   Always       -       34 (Min/Max 17/50)
No Errors Logged
# 1  Short offline       Completed without error       00%     37635         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sdc
Model Family:     Toshiba MG07ACA... Enterprise Capacity HDD
Device Model:     TOSHIBA MG07ACA14TEY
Serial Number:    Y840A0AJFFHG
LU WWN Device Id: 5 000039 908c87eaf
Firmware Version: 4902
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Jan 10 13:57:21 2025 EST
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  120) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        (1382) minutes.
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       7818
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       21
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       40484
 10 Spin_Retry_Count        0x0033   100   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       20
 23 Helium_Condition_Lower  0x0023   100   100   075    Pre-fail  Always       -       0
 24 Helium_Condition_Upper  0x0023   100   100   075    Pre-fail  Always       -       0
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       100
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       33 (Min/Max 15/43)
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       1835021
222 Loaded_Hours            0x0032   007   007   000    Old_age   Always       -       37205
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       591
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
ATA Error Count: 1
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 30907 hours (1287 days + 19 hours)
  ER ST SC SN CL CH DH
  04 51 00 00 00 00 00
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  e5 00 00 00 00 00 00 00      00:07:16.406  CHECK POWER MODE
  b4 11 00 70 79 72 00 00      00:07:13.679  SANITIZE DEVICE
  e5 00 00 00 00 00 00 00      00:07:13.679  CHECK POWER MODE
  b4 00 00 01 00 00 00 00      00:07:13.678  SANITIZE DEVICE
  b4 00 00 00 00 00 00 00      00:07:13.678  SANITIZE DEVICE
# 1  Short offline       Completed without error       00%     26455         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sdd
Serial Number:    Y810A05JFFHG
LU WWN Device Id: 5 000039 908c80dec
Local Time is:    Fri Jan 10 13:57:57 2025 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1386) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       7839
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       27
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       41290
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       26
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       24
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       227
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       31 (Min/Max 15/42)
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       18481158
222 Loaded_Hours            0x0032   007   007   000    Old_age   Always       -       37508
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       590
ATA Error Count: 1
Error 1 occurred at disk power-on lifetime: 31713 hours (1321 days + 9 hours)
  04 53 00 00 00 00 00
  e5 00 00 00 00 00 00 00      00:14:26.905  CHECK POWER MODE
  b4 11 00 70 79 72 00 00      00:14:24.236  SANITIZE DEVICE
  e5 00 00 00 00 00 00 00      00:14:24.236  CHECK POWER MODE
  b4 00 00 01 00 00 00 00      00:14:24.235  SANITIZE DEVICE
  b4 00 00 00 00 00 00 00      00:14:24.235  SANITIZE DEVICE
# 1  Short offline       Completed without error       00%     27538         -
# 2  Short offline       Completed without error       00%     18630         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sde
Serial Number:    9JHMBEJT
LU WWN Device Id: 5 000cca 258d6e57c
Local Time is:    Fri Jan 10 13:58:21 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1380) minutes.
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       390 (Average 388)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       34
  9 Power_On_Hours          0x0012   094   094   000    Old_age   Always       -       43047
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       25
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1557
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       1557
194 Temperature_Celsius     0x0002   062   062   000    Old_age   Always       -       33 (Min/Max 17/48)
No Errors Logged
# 1  Short offline       Completed without error       00%     35272         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sdf
Serial Number:    9JGJ3UJT
LU WWN Device Id: 5 000cca 258c7544a
Local Time is:    Fri Jan 10 13:59:19 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1462) minutes.
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       386 (Average 383)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       30
  9 Power_On_Hours          0x0012   094   094   000    Old_age   Always       -       44228
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       19
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1658
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       1658
194 Temperature_Celsius     0x0002   058   058   000    Old_age   Always       -       36 (Min/Max 17/45)
No Errors Logged
# 1  Short offline       Completed without error       00%     36500         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sdg
Serial Number:    Y880A0C1FFHG
LU WWN Device Id: 5 000039 908c8d22e
Local Time is:    Fri Jan 10 13:59:58 2025 EST
                                        been run.
                                        command.
                                        power-saving mode.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       8038
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       41498
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       225
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       31 (Min/Max 16/39)
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       17170438
222 Loaded_Hours            0x0032   007   007   000    Old_age   Always       -       37535
ATA Error Count: 1
Error 1 occurred at disk power-on lifetime: 31921 hours (1330 days + 1 hours)
  e5 00 00 00 00 00 00 00      00:02:54.046  CHECK POWER MODE
  b4 11 00 70 79 72 00 00      00:02:51.421  SANITIZE DEVICE
  e5 00 00 00 00 00 00 00      00:02:51.421  CHECK POWER MODE
  b4 00 00 01 00 00 00 00      00:02:51.420  SANITIZE DEVICE
  b4 00 00 00 00 00 00 00      00:02:51.420  SANITIZE DEVICE
# 1  Short offline       Completed without error       00%     27518         -
# 2  Short offline       Completed without error       00%     18629         -
admin@truenas[~]$
admin@truenas[~]$ sudo smartctl -a /dev/sdh
Serial Number:    Y890A08UFFHG
LU WWN Device Id: 5 000039 908c8db37
Local Time is:    Fri Jan 10 14:00:26 2025 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1378) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       8041
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       37
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       41023
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       36
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       34
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       201
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       33 (Min/Max 15/41)
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       69206024
222 Loaded_Hours            0x0032   007   007   000    Old_age   Always       -       37398
No Errors Logged
# 1  Short offline       Completed without error       00%     27264         -
# 2  Short offline       Completed without error       00%     18419         -
# 3  Short offline       Completed without error       00%     18353         -
# 4  Short offline       Completed without error       00%     18353         -
admin@truenas[~]$ sudo smartctl -a /dev/sdi
Device Model:     WDC  WUH721414ALN6L4
Serial Number:    9RH9DH5C
LU WWN Device Id: 5 000cca 264d25dba
Firmware Version: LDGNW2L0
Sector Size:      4096 bytes logical/physical
Device is:        Not in smartctl database 7.3/5319
Local Time is:    Fri Jan 10 14:00:29 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1425) minutes.
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       383 (Average 382)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       15
  9 Power_On_Hours          0x0012   099   099   000    Old_age   Always       -       11334
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       15
 22 Unknown_Attribute       0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       485
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       485
194 Temperature_Celsius     0x0002   060   060   000    Old_age   Always       -       34 (Min/Max 17/44)
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       8
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       8
No Errors Logged
# 1  Short offline       Completed without error       00%         8         -
admin@truenas[~]$ sudo smartctl -a /dev/sdj
Serial Number:    Y880A07TFFHG
LU WWN Device Id: 5 000039 908c8cec4
Local Time is:    Fri Jan 10 14:00:32 2025 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1381) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       7857
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       226
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       33 (Min/Max 15/42)
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       148
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       85721093
222 Loaded_Hours            0x0032   007   007   000    Old_age   Always       -       37503
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       592
ATA Error Count: 149 (device log contains only the most recent five errors)
Error 149 occurred at disk power-on lifetime: 41012 hours (1708 days + 20 hours)
  84 41 00 f7 17 46 40  Error: ICRC, ABRT at LBA = 0x004617f7 = 4593655
  60 f0 10 e8 1f 46 40 00  35d+10:26:02.388  READ FPDMA QUEUED
  60 f0 08 f8 17 46 40 00  35d+10:26:02.384  READ FPDMA QUEUED
  60 e8 00 10 10 46 40 00  35d+10:26:02.384  READ FPDMA QUEUED
  60 e8 10 20 08 46 40 00  35d+10:26:02.329  READ FPDMA QUEUED
  60 f0 08 30 00 46 40 00  35d+10:26:02.327  READ FPDMA QUEUED
Error 148 occurred at disk power-on lifetime: 41012 hours (1708 days + 20 hours)
  84 41 08 bf c2 eb 40  Error: ICRC, ABRT at LBA = 0x00ebc2bf = 15450815
  60 f0 00 c0 c2 eb 40 00  35d+10:25:54.090  READ FPDMA QUEUED
  60 e8 08 d8 ba eb 40 00  35d+10:25:54.086  READ FPDMA QUEUED
  60 e8 00 e8 b2 eb 40 00  35d+10:25:54.082  READ FPDMA QUEUED
  60 f0 08 f8 aa eb 40 00  35d+10:25:54.078  READ FPDMA QUEUED
  60 f0 00 08 a3 eb 40 00  35d+10:25:54.074  READ FPDMA QUEUED
Error 147 occurred at disk power-on lifetime: 41012 hours (1708 days + 20 hours)
  84 41 10 c7 1c b4 40  Error: ICRC, ABRT at LBA = 0x00b41cc7 = 11803847
  60 80 10 48 15 b4 40 00  35d+10:25:50.898  READ FPDMA QUEUED
  60 38 08 10 15 b4 40 00  35d+10:25:50.898  READ FPDMA QUEUED
  60 38 00 d8 14 b4 40 00  35d+10:25:50.898  READ FPDMA QUEUED
  60 80 10 58 0d b4 40 00  35d+10:25:50.894  READ FPDMA QUEUED
  60 30 08 28 0d b4 40 00  35d+10:25:50.894  READ FPDMA QUEUED
Error 146 occurred at disk power-on lifetime: 41012 hours (1708 days + 20 hours)
  84 41 08 ff ac aa 40  Error: ICRC, ABRT at LBA = 0x00aaacff = 11185407
  60 f0 00 00 ad aa 40 00  35d+10:25:48.873  READ FPDMA QUEUED
  60 e8 08 18 a5 aa 40 00  35d+10:25:48.870  READ FPDMA QUEUED
  60 e8 00 28 9d aa 40 00  35d+10:25:48.866  READ FPDMA QUEUED
  60 f0 08 38 95 aa 40 00  35d+10:25:48.862  READ FPDMA QUEUED
  60 f0 00 48 8d aa 40 00  35d+10:25:48.858  READ FPDMA QUEUED
Error 145 occurred at disk power-on lifetime: 41012 hours (1708 days + 20 hours)
  84 41 08 47 23 a1 40  Error: ICRC, ABRT at LBA = 0x00a12347 = 10560327
  60 f0 00 38 2b a1 40 00  35d+10:25:46.960  READ FPDMA QUEUED
  60 e8 10 50 23 a1 40 00  35d+10:25:46.956  READ FPDMA QUEUED
  60 e8 08 60 1b a1 40 00  35d+10:25:46.956  READ FPDMA QUEUED
  60 f0 00 70 13 a1 40 00  35d+10:25:46.948  READ FPDMA QUEUED
  60 e8 08 88 0b a1 40 00  35d+10:25:46.944  READ FPDMA QUEUED
# 1  Short offline       Completed without error       00%     27552         -
admin@truenas[~]$ sudo smartctl -a /dev/sdl
Serial Number:    9RHUA20C
LU WWN Device Id: 5 000cca 264d99a90
Local Time is:    Fri Jan 10 14:00:36 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1560) minutes.
  1 Raw_Read_Error_Rate     0x000b   100   100   001    Pre-fail  Always       -       65536
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       382 (Average 381)
  5 Reallocated_Sector_Ct   0x0033   100   100   001    Pre-fail  Always       -       3
  9 Power_On_Hours          0x0012   099   099   000    Old_age   Always       -       11333
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       488
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       488
194 Temperature_Celsius     0x0002   057   057   000    Old_age   Always       -       37 (Min/Max 17/44)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       3
No Errors Logged
admin@truenas[~]$ sudo smartctl -a /dev/sdm
Serial Number:    Y870A03ZFFHG
LU WWN Device Id: 5 000039 908c8c0de
Local Time is:    Fri Jan 10 14:00:38 2025 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1395) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       8001
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       41244
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       31 (Min/Max 15/39)
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       52428803
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       593
ATA Error Count: 1
Error 1 occurred at disk power-on lifetime: 31667 hours (1319 days + 11 hours)
  e5 00 00 00 00 00 00 00      00:12:31.297  CHECK POWER MODE
  b4 11 00 70 79 72 00 00      00:12:28.208  SANITIZE DEVICE
  e5 00 00 00 00 00 00 00      00:12:28.207  CHECK POWER MODE
  b4 00 00 01 00 00 00 00      00:12:28.207  SANITIZE DEVICE
  b4 00 00 00 00 00 00 00      00:12:28.206  SANITIZE DEVICE
# 1  Short offline       Completed without error       00%     27546         -
admin@truenas[~]$ sudo smartctl -a /dev/sdn
Serial Number:    9JH45NBT
LU WWN Device Id: 5 000cca 258cffe39
Local Time is:    Fri Jan 10 14:00:41 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1477) minutes.
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       393 (Average 392)
No Errors Logged
admin@truenas[~]$ sudo smartctl -a /dev/sdo
Serial Number:    9RHPHNMC
LU WWN Device Id: 5 000cca 264d7de1a
Local Time is:    Fri Jan 10 14:00:43 2025 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1464) minutes.
  1 Raw_Read_Error_Rate     0x000b   100   100   001    Pre-fail  Always       -       15
  3 Spin_Up_Time            0x0007   081   081   001    Pre-fail  Always       -       389 (Average 386)
194 Temperature_Celsius     0x0002   062   062   000    Old_age   Always       -       33 (Min/Max 17/39)
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       29
ATA Error Count: 16 (device log contains only the most recent five errors)
Error 16 occurred at disk power-on lifetime: 11333 hours (472 days + 5 hours)
  40 43 00 00 00 00 00  Error: UNC at LBA = 0x00000000 = 0
  60 1c 58 84 ff bb 40 08      02:50:15.381  READ FPDMA QUEUED
  60 1c 50 44 00 00 40 08      02:50:12.296  READ FPDMA QUEUED
  60 1c 10 c4 fe bb 40 08      02:50:12.280  READ FPDMA QUEUED
  60 1c 08 84 fe bb 40 08      02:50:12.280  READ FPDMA QUEUED
  60 1c f0 44 02 00 40 08      02:50:12.277  READ FPDMA QUEUED
Error 15 occurred at disk power-on lifetime: 11331 hours (472 days + 3 hours)
  60 1c 10 84 ff bb 40 08      00:07:35.533  READ FPDMA QUEUED
  60 1c 00 44 00 00 40 08      00:07:32.449  READ FPDMA QUEUED
  60 1c f0 c4 fe bb 40 08      00:07:32.437  READ FPDMA QUEUED
  60 1c b0 84 fe bb 40 08      00:07:32.436  READ FPDMA QUEUED
  60 1c b0 44 02 00 40 08      00:07:32.431  READ FPDMA QUEUED
Error 14 occurred at disk power-on lifetime: 11331 hours (472 days + 3 hours)
  60 1c 98 84 ff bb 40 08      00:06:01.951  READ FPDMA QUEUED
  60 1c 90 44 00 00 40 08      00:05:58.866  READ FPDMA QUEUED
  60 1c 48 c4 fe bb 40 08      00:05:58.865  READ FPDMA QUEUED
  60 1c 40 84 fe bb 40 08      00:05:58.863  READ FPDMA QUEUED
  60 1c f0 44 02 00 40 08      00:05:58.861  READ FPDMA QUEUED
Error 13 occurred at disk power-on lifetime: 11331 hours (472 days + 3 hours)
  60 01 d0 8e ff bb 40 08      00:01:18.209  READ FPDMA QUEUED
  ef 05 fe 00 00 00 40 08      00:01:15.132  SET FEATURES [Enable APM]
  47 00 01 30 08 00 a0 08      00:01:15.132  READ LOG DMA EXT
  47 00 01 30 00 00 a0 08      00:01:15.131  READ LOG DMA EXT
  47 00 01 00 00 00 a0 08      00:01:15.131  READ LOG DMA EXT
Error 12 occurred at disk power-on lifetime: 11331 hours (472 days + 3 hours)
  60 01 b8 8e ff bb 40 08      00:01:14.776  READ FPDMA QUEUED
  60 01 b0 a4 ff bb 40 08      00:01:11.695  READ FPDMA QUEUED
  60 01 a8 ab ff bb 40 08      00:01:11.687  READ FPDMA QUEUED
  60 01 20 b6 ff bb 40 08      00:01:11.679  READ FPDMA QUEUED
  60 01 a0 ce ff bb 40 08      00:01:11.672  READ FPDMA QUEUED
admin@truenas[~]$
sda      WDC WUH721414ALE604            1 gpt    disk           14000519643136
sdb      WDC WUH721414ALE604            1 gpt    disk           14000519643136
sdc      TOSHIBA MG07ACA14TEY           1 gpt    disk           14000519643136
sdd      TOSHIBA MG07ACA14TEY           1 gpt    disk           14000519643136
sde      WDC WUH721414ALE604            1 gpt    disk           14000519643136
sdf      WDC WUH721414ALE604            1 gpt    disk           14000519643136
sdg      TOSHIBA MG07ACA14TEY           1 gpt    disk           14000519643136
sdh      TOSHIBA MG07ACA14TEY           1 gpt    disk           14000519643136
sdi      WDC WUH721414ALN6L4            1 gpt    disk           14000519643136
sdj      TOSHIBA MG07ACA14TEY           1 gpt    disk           14000519643136
sdk      SanDisk X400 M.2 2280 128GB    0 gpt    disk             128035676160
sdl      WDC WUH721414ALN6L4            1 gpt    disk           14000519643136
sdm      TOSHIBA MG07ACA14TEY           1 gpt    disk           14000519643136
sdn      WDC WUH721414ALN6L4            1 gpt    disk           14000519643136
sdo      WDC WUH721414ALN6L4            1        disk           14000519643136
admin@truenas[~]$
