Wifi connection as a secondary
Hi, I have just installed a new TrueNAS and I was trying to setup a VM with 2 interfaces. My problem is that my box doesn’t have 2 ethernet interfaces, so for the secondary I could use the Wifi.
It will used only to access my IOT stuff that I have on a separate network, so if I lose connection, then I really not mind.
I have already enabled developer mode, and I guess I need to go into the middleware network package so I can remove the wifi filtering.
Any pointers or help could be useful
I just realised that the drivers are not even available in the kernel :cry:
Not very familiar with truenas VMs, but perhaps you can PCI(e) passthrough your wifi card directly to the VM. And then deal with it within a VM.
