Bcm57412 not visible in truenas scale network
Infos:
Platform: Generic Edition: Community **Version:**25.10.1 - Goldeye
on DELL r720xd :slight_smile:
Problem:
I putted the two bcm57412 nic card into my server with TN and i dont`t see them in the Network dashboard/panel.
I see the card and drivers using dmesg | grep -i bcm or lspci -nnk | grep -A3 broadcom
but using ip addr ip link or ifconfig card not visible
Does someone had siomilar porblem?
I need your help :slight_smile:
Best,
Piotr
What is showing in the System, Network tab of the GUI?
soory for delayed response
my mistake :frowning: i see the card using “ip link show” or other commands
i found in “dmesg” output
78556] bnxt_en 0000:41:00.0 (unnamed net_device) (uninitialized): Device requests max timeout of 100 seconds, may trigger hung task watchdog
[ 1.778974] bnx2x 0000:01:00.0: msix capability found
[ 1.789208] bnx2x 0000:01:00.0: part number 394D4342-30383735-30305430-473030
[ 1.812266] bnxt_en 0000:41:00.0 eth0: Broadcom BCM57412 NetXtreme-E 10Gb Ethernet found at mem cc1c0000, node addr 8c:84:74:67:4a:90
[ 1.812277] bnxt_en 0000:41:00.0: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 1.813300] bnxt_en 0000:41:00.1 (unnamed net_device) (uninitialized): Device requests max timeout of 100 seconds, may trigger hung task watchdog
[ 1.851559] bnxt_en 0000:41:00.1 eth1: Broadcom BCM57412 NetXtreme-E 10Gb Ethernet found at mem cc1d0000, node addr 8c:84:74:67:4a:91
[ 1.851567] bnxt_en 0000:41:00.1: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 1.853844] bnxt_en 0000:44:00.0 (unnamed net_device) (uninitialized): Device requests max timeout of 100 seconds, may trigger hung task watchdog
[ 1.889001] bnxt_en 0000:44:00.0 eth2: Broadcom BCM57412 NetXtreme-E 10Gb Ethernet found at mem cc3c0000, node addr 8c:84:74:67:5f:80
[ 1.889009] bnxt_en 0000:44:00.0: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 1.889722] bnxt_en 0000:44:00.1 (unnamed net_device) (uninitialized): Device requests max timeout of 100 seconds, may trigger hung task watchdog”
any suggestion?
best
What transceivers are you using and are you connecting to a known, good switch? You can try sudo dmesg | grep <driver_name> and ethtool -m <interface> to see if you are seeing the SFP+ module and if the link is coming up.
How are you connecting the NIC to other devices? Are you using SFP+ transceivers, MMF or SMF, DAC, etc.
You really have to provide a bit more of information as I can only see what you post on the forum.
If you have run commands, it may be helpful to post the results back in CODE format, Preformatted Text (</>) Ctrl+e on the reply so others can get an idea of what you have run and the results of commands in a readable format.
This may help also, if you aren’t familiar with fiber. I had to make a crossover cable to make sure the transceiver was paired to a receiver, correctly.
I am using fs.com 10GB transceivers and server is connected to the fs.com switch.
I see the link is up (green light is on) on the one port of the nc and on the switch port.
See below output of the command "dmesg |grep bnx"
[    1.778556] bnxt_en 0000:41:00.0 (unnamed net_device) (uninitialized): Device requests max timeout of 100 seconds, may trigger hung task watchdog
[    1.929410] bnxt_en 0000:44:00.1 eth3: Broadcom BCM57412 NetXtreme-E 10Gb Ethernet found at mem cc3d0000, node addr 8c:84:74:67:5f:81
[    1.929421] bnxt_en 0000:44:00.1: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[    1.950004] bnx2x 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
[    1.950042] bnx2x 0000:01:00.1: msix capability found
[    1.950236] bnx2x 0000:01:00.1: part number 394D4342-30383735-30305430-473030
[    1.958660] bnxt_en 0000:41:00.0 enp65s0f0np0: renamed from eth0
[    1.958867] bnxt_en 0000:41:00.1 enp65s0f1np1: renamed from eth1
[    1.960085] bnxt_en 0000:44:00.0 enp68s0f0np0: renamed from eth2
[    2.000355] bnxt_en 0000:44:00.1 enp68s0f1np1: renamed from eth3
[    2.102418] bnx2x 0000:01:00.1: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
[    2.102480] bnx2x 0000:01:00.2: msix capability found
[    2.102729] bnx2x 0000:01:00.2: part number 394D4342-30383735-30305430-473030
[    2.263408] bnx2x 0000:01:00.2: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
[    2.263467] bnx2x 0000:01:00.3: msix capability found
[    2.263799] bnx2x 0000:01:00.3: part number 394D4342-30383735-30305430-473030
[    2.408233] bnx2x 0000:01:00.3: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
[    9.294332] bnx2x 0000:01:00.0 eno1: renamed from eth4
[    9.294682] bnx2x 0000:01:00.1 eno2: renamed from eth0
[    9.295132] bnx2x 0000:01:00.2 eno3: renamed from eth1
[    9.296040] bnx2x 0000:01:00.3 eno4: renamed from eth2
[  100.242310] bnx2x 0000:01:00.2 eno3: using MSI-X  IRQs: sp 201  fp[0] 203 ... fp[5] 208
[  100.302788] bnx2x 0000:01:00.2 eno3: NIC Link is Up, 100 Mbps full duplex, Flow control: none
see also
Best,
Not sure. It looks different from my Intel card coming up. No mention of the SFP+ module but you seem to get device names like, enp65s0f0np0
Yes I know that, but I can`t up the interfaces :( using ifconfig or ip or ethtool.
The AI old man told me :)
-turn off the PXE boot in BIOS
-update the nic cards fw
I will try....
Best,
