I was giving my server an overhaul (replacing a failing drive, adding a bunch of new drives, cleaning the dust out while i was at it) and thought it would be a good idea to do a fresh install… and now i have stumbled upon the “black screen problem”.
I can find a bunch of posts describing the problem, several years old even, but havent found an actual solution.
problem: after selecting install on the grub screen the screen goes black and nothing happens.
at least that is what happened when trying to install TrueNAS-SCALE-25.04.2.6
when trying to install TrueNAS-SCALE-25.10.3 i dont even get the grub menu, screen stays black for 1 minute when you expect the grub screen then server starts rebooting.
having tried some of the ‘solutions’ i have come across already i have managed to get the following result (with TrueNAS-SCALE-25.10.3)
after selecting install on the grub screen i get a screen that reads as follows:
error: file ‘/vmlinuz’ not found.
error: you need to load the kernel first.
Press any key to continue…
then after a fraction of a second the grub screen appears for a smaller fraction of a second then this screen again etc…
it alternates back and forth between the black screen with the error message and the blue grub screen about twice a second.
nothing i do makes any difference at this point, cant select anything else on the grub screen or actally press enter to continue on the following screen, it just keeps flashing the two back and forth.
The ‘solutions’ i have found suggest using older hardware for example, where their solution quotes hardware newer then what i am using. but more importantly, i am using hardware that has been running truenas for years already, i did not have this problem the last time i installed from scratch and no hardware has changed since then except the SAS HBA.
The posts i found regarding ‘vmlinuz’ are all about already installed systems that get stuck when rebooting, whith the last resort solution to do a fresh install, which is what i am already trying to do.
Anyone have an idea what to try to get this machine working again?
Thank you.
mobo: ASRock Rack X570D4U-2L2T
cpu: AMD R7 3700X
memory: 4x 32GB ECC
HBA: LSI 9300
expander: adaptec 82885T
boot drive: m.2 sata crucial MX500
hard drives: none (all remain disconnected until install succeeds)
