Can't access gui after power outage, can ssh to hosted vm
Truenas Scale 25.10.4 : Had a power blip today that set the UPS to screaming and had to power it off. Truenas came back up, and boot screen shows all is normal, but not accessible over the network. Hosted Debian VM is accessible via ssh, but not via VNC - connection refused.
Other IP’s configured on the host interface are also not accessible. Everything is on the same subnet.
Any thoughts on what is causing the failure?
How is your network configured on truenas? DHCP or static ip? if it’s dhcp it may be that the reboot triggered a ip lease renewal and it now has a different ip then before.
Connect a screen and keyboard to your trueans and see what ip is shown there.
Static IP on a single subnet network.
I figured it out, there was a bridge interface configured it, I deleted it and now I can ping the default gateway.
Still fighting this. Trying to setup a bridge interface, but everytime I do I lose connection to the webgui. I’ve tried creating just the bridge with the NIC as part of it and assigning IP’s to the bridge, but it’s not working.
I feel like creating a bridge only works from the command line and keyboard attached to the computer. Not the webgui.
If I remember this right.
Nope, definitely works from the GUI, did it multiple times on each Version of trurnas
Edit:
You just have to open the webui again on another browser window and accept the pending change
