Super beginner here when it comes to servers/linux stuff, I tried to add as much info as I could. I am having issues connecting to my truenas after I switched out my iec cable for a different one. When I try to connect from either device, I get the error “The network path was not found”. When I shut down the server, i see that it is not visible in the Network tab for Windows, and when it’s on, I see it, so I know it’s at least… visible.
My setup is as follows: Ethernet to Switch. Switch Ethernet port 1 - Truenas Server, port 2 Windows 11 desktop.
Things I can do/have done:
• I can access the gui through the web browser. (IP address is within the range of the IP Distribution provided by my ISP, Optimum.
• I tried connecting to the truenas via my windows 11 desktop and my MacBook pro (via Wi-Fi, but can do ethernet if needed), both devices I was able to connect and transfer files to prior to the iec cable swap.
• I pinged the ip address of the server via my windows desktop and everything came over correct (it sent 4 pings, it received 4, and there were no displayed errors.
• I unplugged the ethernet cable going between the truenas and the switch
• Restarted truenas server, also have shutdown and rebooted.
• Tried to renew DHCP lease and it wasn’t working.
When I go into the Network Configuration in the TrueNas, the hostname and domain are populated, but the remaining 5 fields are all empty string. I unfortunately didn’t look in this field when the server was running to see what should be in these fields, if anything.
What steps do I take to resolve this? Is there a field that’s blank that shouldn’t be so I can connect back into the server? I reached out to Optimum to see if I could have the capability to manually assign an IP and since I’m using their router, the answer was no.
I truly appreciate all the assistance on resolving this. Thanks!
Specs:
Truenas Scale 25.10.2.1
i7 6700k
32gb DDR 4 RAM
Gigabyte Z170x Ud3 Motherboard
Corsair CX 500 PSU
