Checksum Errors (Pool is Not Healthy)
Hello everyone, It’s been a few months that I started getting Checksum Errors, I’ve tried scrubbing but no fix at all. A month ago I got around 500-800 Checksum Errors, that’s when I decided to research potential solutions. I’ve replaced the ‘M.2 B+M Key to SATA III 2 Ports Expansion Card’ and all SATA Cables that are connected to the motherboard. It hasn’t increased the errors yet as they been holding around the 70-85 errors. I use the NAS as a Plex server and external storage, so nothing crazy that I believe is affecting it.
I’m really new to this, I don’t have any past experience with Linux or server hosting. Just watched couple of YouTube videos and decided to give it a go. Any help or guidance would be really appreciated. Also I don’t know how forum formatting works, so if there’s anything I did wrong on this post please let me know!
My System Configuration:
  • JONSBO N2 Case
  • TrueNAS-SCALE-25.04.2.6
  • AMD Ryzen 9 5900X 12-Core Processor
  • ASUS ROG STRIX B550-I GAMING
  • Corsair 2x16GB (32GB of RAM) Running Base Speeds
  • Data Pool Running RAIDZ2
    • sda (8TB) (76 Checksum Errors)
    • sdb (8TB) (74 Checksum Errors)
    • sdc (8TB) (76 Checksum Errors)
    • sdd (8TB) (84 Checksum Errors)
    • sdf (8TB) (71 Checksum Errors)
  • Log VDEV 256GB NMVE (No Errors)
  • Crucial 128GB SATA SSD as Boot Drive
2 Hard Drives are being connect by the ‘M.2 B+M Key to SATA III 2 Ports Expansion Card’ and the rest to the motherboard SATA ports.
Some Troubleshooting After Replacing Expansion Card and SATA CABLES:
I’ve been looking at forums and did some commands that other people had luck with:
  1. I first did a Scrub using the Scrub button on the ‘Storage’ tab
  2. Then I did another Scrub but using Shell and zpool scrub $pool_name
  3. Afterwards I did zpool status -v
I noticed that some corrupted files were gone and repaired? Maybe I’m wrong but those files haven’t reappeared yet.
Pool Status
root@truenas[~]# sudo zpool status
  pool: Cubito
 state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 0B in 07:44:14 with 1 errors on Wed Feb 25 08:10:09 2026
        NAME                                      STATE     READ WRITE CKSUM
        Cubito                                    ONLINE       0     0     0
          raidz2-0                                ONLINE       0     0     0
            91d93d30-be96-46fa-9f37-8a52a0b3b7bd  ONLINE       0     0    76
            8037015c-c1d7-4450-94d2-7e294907eab0  ONLINE       0     0    71
            f851a6b9-7bf3-4362-82f4-915bcd2f73b9  ONLINE       0     0    74
            c68798b6-1d45-4089-add9-d33ce59b20fc  ONLINE       0     0    84
            dec6a5f3-d1ae-41bd-b505-cba8052a3ecd  ONLINE       0     0    76
        logs
          dc92be13-4606-4047-9cd2-d517611e0e68    ONLINE       0     0     0
errors: 1 data errors, use '-v' for a list
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:01:34 with 0 errors on Tue Feb 24 03:46:35 2026
          sde3      ONLINE       0     0     0
errors: No known data errors
Pool Status with -v command:
root@truenas[~]# sudo zpool status -v
  pool: Cubito
 state: ONLINE
        Cubito                                    ONLINE       0     0     0
        logs
        /mnt/.ix-apps/truenas_catalog/trains/community/jdownloader2/1.1.3/questions.yaml
  pool: boot-pool
 state: ONLINE
          sde3      ONLINE       0     0     0
SMART Values
sda
root@truenas[~]# sudo smartctl -a /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST8000VN004-2M2101
Serial Number:    WSD3WS13
LU WWN Device Id: 5 000c50 0dc931370
Firmware Version: SC60
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/6088
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Feb 25 11:26:36 2026 PST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  559) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 715) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       0/173690224
  3 Spin_Up_Time            0x0003   082   082   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       31
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   089   060   045    Pre-fail  Always       -       0/712601327
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21152
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       32
 18 Head_Health             0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
190 Airflow_Temperature_Cel 0x0022   061   010   040    Old_age   Always   In_the_past 39 (Min/Max 25/49 #1343)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       10
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       917
194 Temperature_Celsius     0x0022   039   090   000    Old_age   Always       -       39 (0 14 0 0 0)
195 Hardware_ECC_Recovered  0x001a   082   064   000    Old_age   Always       -       0/173690224
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       21058h+21m+43.185s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       46898250668
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       792346579365
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     21072         -
# 2  Short offline       Completed without error       00%     20904         -
# 3  Short offline       Completed without error       00%     20736         -
# 4  Extended offline    Completed without error       00%     20580         -
# 5  Short offline       Completed without error       00%     20568         -
# 6  Short offline       Completed without error       00%     20400         -
# 7  Short offline       Completed without error       00%     20232         -
# 8  Short offline       Completed without error       00%     20064         -
# 9  Short offline       Completed without error       00%     19896         -
#10  Short offline       Completed without error       00%     19728         -
#11  Short offline       Completed without error       00%     19560         -
#12  Short offline       Completed without error       00%     19392         -
#13  Short offline       Completed without error       00%     19392         -
#14  Short offline       Completed without error       00%     19224         -
#15  Extended offline    Completed without error       00%     19092         -
#16  Short offline       Completed without error       00%     19056         -
#17  Short offline       Completed without error       00%     18888         -
#18  Short offline       Completed without error       00%     18720         -
#19  Short offline       Completed without error       00%     18592         -
#20  Short offline       Completed without error       00%     18443         -
#21  Short offline       Completed without error       00%     18275         -
The above only provides legacy SMART information - try 'smartctl -x' for more
sdb
root@truenas[~]# sudo smartctl -a /dev/sdb
Device Model:     ST8000VN004-3CP101
Serial Number:    WWZ2CHFL
LU WWN Device Id: 5 000c50 0e719ad86
Local Time is:    Wed Feb 25 11:28:14 2026 PST
                                        been run.
data collection:                (  567) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 712) minutes.
  1 Raw_Read_Error_Rate     0x000f   077   064   044    Pre-fail  Always       -       0/45081776
  3 Spin_Up_Time            0x0003   090   090   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       32
  7 Seek_Error_Rate         0x000f   087   060   045    Pre-fail  Always       -       0/539971567
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21153
190 Airflow_Temperature_Cel 0x0022   056   026   000    Old_age   Always       -       44 (Min/Max 25/56)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       12
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       920
194 Temperature_Celsius     0x0022   044   074   000    Old_age   Always       -       44 (0 14 0 0 0)
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       1
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       21057h+25m+04.338s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       46894959927
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       792196069344
No Errors Logged
# 9  Short offline       Completed without error       00%     20010         -
#10  Short offline       Completed without error       00%     19897         -
#11  Short offline       Completed without error       00%     19729         -
#12  Short offline       Completed without error       00%     19561         -
#13  Short offline       Completed without error       00%     19393         -
#14  Short offline       Completed without error       00%     19392         -
#15  Short offline       Completed without error       00%     19224         -
#16  Extended offline    Completed without error       00%     19092         -
#17  Short offline       Completed without error       00%     19056         -
#18  Short offline       Completed without error       00%     18888         -
#19  Short offline       Completed without error       00%     18720         -
#20  Short offline       Completed without error       00%     18593         -
#21  Short offline       Completed without error       00%     18443         -
sdc
root@truenas[~]# sudo smartctl -a /dev/sdc
Model Family:     Seagate Exos 7E10
Device Model:     ST8000NM017B-2TJ103
Serial Number:    WWZ0EGRR
LU WWN Device Id: 5 000c50 0e4cb5543
Firmware Version: SN01
Local Time is:    Wed Feb 25 11:29:40 2026 PST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 695) minutes.
SCT capabilities:              (0x70bd) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   080   064   044    Pre-fail  Always       -       0/93401760
  3 Spin_Up_Time            0x0003   092   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       36
  7 Seek_Error_Rate         0x000f   087   060   045    Pre-fail  Always       -       0/538497058
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       37
190 Airflow_Temperature_Cel 0x0022   053   013   000    Old_age   Always       -       47 (Min/Max 25/60)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       13
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       925
194 Temperature_Celsius     0x0022   047   087   000    Old_age   Always       -       47 (0 10 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       21053h+36m+32.075s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       46888658695
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       830597697109
No Errors Logged
# 2  Short offline       Completed without error       00%     20905         -
# 3  Short offline       Completed without error       00%     20737         -
# 5  Short offline       Completed without error       00%     20569         -
# 6  Short offline       Completed without error       00%     20401         -
# 7  Short offline       Completed without error       00%     20233         -
# 8  Short offline       Completed without error       00%     20065         -
# 9  Short offline       Completed without error       00%     19897         -
#10  Short offline       Completed without error       00%     19729         -
#11  Short offline       Completed without error       00%     19561         -
#12  Short offline       Completed without error       00%     19393         -
#19  Short offline       Completed without error       00%     18593         -
sdd
root@truenas[~]# sudo smartctl -a /dev/sdd
Serial Number:    WWZ2C6Q0
LU WWN Device Id: 5 000c50 0e719e6f4
Local Time is:    Wed Feb 25 11:30:07 2026 PST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 701) minutes.
  1 Raw_Read_Error_Rate     0x000f   076   064   044    Pre-fail  Always       -       0/43836096
  3 Spin_Up_Time            0x0003   089   089   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       33
  7 Seek_Error_Rate         0x000f   087   060   045    Pre-fail  Always       -       0/534924326
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       34
190 Airflow_Temperature_Cel 0x0022   054   014   000    Old_age   Always       -       46 (Min/Max 25/59)
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       921
194 Temperature_Celsius     0x0022   046   086   000    Old_age   Always       -       46 (0 15 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       21055h+45m+32.023s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       46890309442
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       791958860670
No Errors Logged
#15  Extended offline    Completed without error       00%     19091         -
sdf
root@truenas[~]# sudo smartctl -a /dev/sdf
Serial Number:    WWZ0EHYW
LU WWN Device Id: 5 000c50 0e4cb5b9c
Local Time is:    Wed Feb 25 11:30:56 2026 PST
                                        been run.
                                        command.
                                        power-saving mode.
  1 Raw_Read_Error_Rate     0x000f   080   064   044    Pre-fail  Always       -       0/111051144
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       34
  7 Seek_Error_Rate         0x000f   087   060   045    Pre-fail  Always       -       0/543777794
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       36
190 Airflow_Temperature_Cel 0x0022   055   023   000    Old_age   Always       -       45 (Min/Max 25/58)
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       926
194 Temperature_Celsius     0x0022   045   077   000    Old_age   Always       -       45 (0 15 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       21059h+46m+12.228s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       46888961847
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       891062186704
No Errors Logged
My whole NAS and Truenas config is being held by hopes and dreams but thank you in advance for any help. I would honestly maybe pay someone to help me fix Truenas config since I feel like its messy. This is my first time using Linux and doing any self hosting homelab.
Also thank you to user ‘terrehbyte’ I used his forum post as a guideline to make this post.
Welcome to the forums.
In my signature is a link to Drive troubleshooting flowcharts. Give this a try. It should help fix or at least narrow down the problem.
Good luck. And if you have a question, just ask.
Also, you do have one corrupt file that is listed in your zpool status output. That file needs to be deleted. If you have a backup copy then paste it in.
I’m making an assumption that you have your pcie slot available - any chance you’re willing to pick up an HBA for around the same cost that you got this M.2 port multiplier?
Most of the drive you have are seagate, which requires some additional translation for smart values:
smartctl -a /dev/sdx -v 1,raw48:54 -v 7,raw48:54 -v 195,raw48:54
In the above example, values 1, 7, and 195 are translated to something humanly readable. Change & add/remove -v #value here#,raw48:54 as needed. For some drives you’d want to translate pending/current sectors, raw read errors, reallocated sector, etc etc. The value # aren’t set in stone as 1/7/195 - these are just the values for my seagate drives.
Before @winnielinnie gets a chance to suggest it; any chance you’ve recently run a few passes of memtest?
ZFS doing its best to keep things alive :slight_smile:
Thank you for your reply, I have in the past deleted files that I can see but when it comes to ‘/mnt/…’ I don’t know where to find that location and have never been able to delete those files. The only things I’ve download have been Plex and Tailscale :sob:
Thank you for your reply! I have a ‘TPLink 2.5GB NIC PCIE’. I willing to sacrifice the speeds if it means that buying an HBA card will solve my problems :smiling_face_with_tear:
I have done a memtest on this specific ram and everything works no errors about a year ago but I’ll run it again overnight just in case.
I read it multiple times, this is a whole new language to me, I’m sorry :sob: . Do you mean the ID# ATTRIBUTE_NAME? The numbers on the left side? Because if so it would be 1, 5, and 197?
Yee! You managed to understand my nonsense! I’d also add 198 for some of these drives.
The poorly worded explination was just that the left collumn values aren’t always universal for every drive vs the values we’re trying to translate.
In the data you provided earlier, the file you would need to be in it’s directory is:
cd /mnt/.ix-apps/truenas_catalog/trains/community/jdownloader2/1.1.3
To delete it rm -f /mnt/.ix-apps/truenas_catalog/trains/community/jdownloader2/1.1.3/questions.yaml
The check to see if the file was really deleted.
I don’t see anything obviously wrong with the physical drives.
If after deleting the corrupt file,
and clearing the zpool errors zpool clear Cubito
and scrubbing the pool again zpool scrub Cubito
displays zpool status -v more errors then it is time to validate your system stability.
Validate your system stability:
  1. Run Memtest86+ (free), ensure it completes “5 Complete Passes”. One is never enough.
  2. Run a CPU stress test like Prime95 or similar for 4 hours. You can use The Ultimate Boot CD (UBCD) which is a bootable ISO, and it has the CPU stress tests and it has an older version of MemTest86+ as well, and that would be fine too.
  3. If these pass, it is time to update the post here, and be precise with what you had done so we are not making assumptions. Read Joe’s Rules, it can help you with what might need to be posted and understanding about assumptions. At least you were clear that Linux is not your OS to dabble in.
Hope that helps.
Jokes apart: i would schedule a memtest at least 3-4 times per year on a repurpose gaming rig as nas (at least if you are storing into it not only media and movies).
just asking, are you benefiting from the log vdev? Not better to use it to run apps?
IT WORKED! THANK YOU SO MUCH :sob:
I will still validate the stability, I just wanted to have my pool healthy before I started copying files from my external drives I have piling up.
Noted! I will start doing it more often. Thank you!
I’ll be honest, I don’t know :sob: It was an extra NVME that I had laying around. I saw people talking about cache and “better or faster transfer speeds”. I just want faster transfer speeds from my PC to the NAS to be honest. Do you recommend keep it or setting it up differently?
I doubt your SLOG is doing anything since you mentioned transfers from your PC. Guessing you are using SMB. SLOG is not a write cache. You only need it for sync writes. So databases, Block storage (iSCSI, zvols for VMs), and NFS.
If your LOG device is actually a L2ARC, you probably can get rid of it also. Take a look at the sudo arc_summary statistics and see if it is used much.
It’s use should be covered in the TrueNAS Documenation, Hardware Section, I think.
@SmallBarky Great advice. We see this kind of thing often, YouTube strikes again.
@Fabian13x I’m glad it worked out for you. I suspect the original cause was either an unstable system or sudden loss of power or improper reboot. Many people make the mistake thinking that if the hardware passed testing after they put it together, that is should be good forever. Unfortunately that isn’t the case. I test my hardware out a few times a year, just when I feel like it, so no set schedule.
If you do not have an UPS, get one. They are invaluable for protecting your hardware and data.
