Curious TrueNAS error messages
So if my TrueNAS starts spamming me with the following error, I presume it means the TrueNAS PSU is likely on the way out?
  • Sensor: ‘ATX+5VSB’ had an ‘Assertion Event’ (Lower Critical - going low ; Sensor Reading = 4.71 Volts ; Threshold = 4.71 Volts)
Yes, see:
PC troubleshooting-5V Standby power - Page 1
Thank you, @Samuel_Tai ! The PSU (A X-400 Seasonic for which I cannot even find the purchase receipt!) is now heading off into retirement. Sadly, a titanium 400W Seasonic is not made so I had to buy a bigger one that now happily does its duty.
The NAS rebooted without any fuss, the datasets are happy, and the only ??? is whether I should do something with this warning or ignore it:
Warning
IPMI System Event Log low space left: 40680 bytes free (24822 bytes used).
2026-08-03 22:58:21 (America/New_York)
I presume this is a leftover from when the IPMI was spamming the log with 4.71V on the +5V bus warnings. Question is: will it delete itself, do I need to give it a nudge, or should I just dismiss it?
The log won’t auto-delete so you need to take a trip to IPMI.
