hello,
i booted my truenas …during the boot and inside the dmesg i can see the following
da0: quirks=0x140<RETRY_BUSY,STRICT_UNMAP>
ses0: pass1,ada0 in 'Slot 00', SATA Slot: scbus33 target 0
ses0: pass2,ada1 in 'Slot 01', SATA Slot: scbus34 target 0
ses0: pass3,ada2 in 'Slot 05', SATA Slot: scbus38 target 0
Root mount waiting for: ada
ahcich35: Timeout on slot 9 port 0
ahcich35: is 00000000 cs 00000200 ss 00000000 rs 00000200 tfd d0 serr 00000000 cmd 0004c917
(ada2:ahcich35:0:0:0): SETFEATURES ENABLE RCACHE. ACB: ef aa 00 00 00 40 00 00 00 00 00 00
(ada2:ahcich35:0:0:0): CAM status: Command timeout
(ada2:ahcich35:0:0:0): Retrying command, 0 more tries remain
ahcich35: AHCI reset: device not ready after 31000ms (tfd = 00000080)
ahcich35: Timeout on slot 10 port 0
ahcich35: is 00000000 cs 00000400 ss 00000000 rs 00000400 tfd 80 serr 00000000 cmd 0004ca17
(aprobe0:ahcich35:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
(aprobe0:ahcich35:0:0:0): CAM status: Command timeout
(aprobe0:ahcich35:0:0:0): Retrying command, 0 more tries remain
intsmb0: <Intel PIIX4 SMBUS Interface> port 0x1040-0x104f at device 7.3 on pci0
intsmb0: intr SMI disabled revision 0
smbus0: <System Management Bus> on intsmb0
after some time it booted, and i unlocked the root zfs.
Is it possible to say what Ada ie specific drive is it? One of the 3 in raid1?
Is it possible that files on that zfs got corrupted?
I used Jail for a backup, the last one 6months ago, but now when i login into that jail i shows files from 2022.
Any idea what is that?
Thank you
