Disk Error: Offline uncorrectable sectors
I received errors on the disks.
I will start by saying that I always do the monthly long smart tests and the short ones more often.
The errors are these:
Device: /dev/ada3, 8 Currently unreadable (pending) sectors.
CRITICAL
Device: /dev/ada3, 8 Offline uncorrectable sectors.
CRITICAL
Device: /dev/ada3, 24 Currently unreadable (pending) sectors.
CRITICAL
Device: /dev/ada3, 24 Offline uncorrectable sectors.
What do you say to do? Does the disk need to be changed? Do I have to do a long smart disk test first? How do I do it?
Thanks
Try the Drive Troubleshooting Flowcharts in my link below. It should get you to the answer fairly quickly.
If you have a problem with the flowchart or could recommend improvement, please let me know.
