sda:
sudo smartctl -x /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST12000NM0127
Serial Number: ZJV4A37N
LU WWN Device Id: 5 000c50 0b55ff089
Firmware Version: G005
User Capacity: 12,000,138,625,024 bytes [12.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Nov 19 17:33:01 2025 CET
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2], Master PW ID: 0xfffd
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 567) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1083) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 076 064 044 - 41261230
3 Spin_Up_Time PO---- 091 090 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 15
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 320
7 Seek_Error_Rate POSR-- 080 060 045 - 103624711
9 Power_On_Hours -O--CK 098 098 000 - 2388
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 15
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 090 090 000 - 10
188 Command_Timeout -O--CK 100 100 000 - 0
190 Airflow_Temperature_Cel -O---K 073 045 040 - 27 (Min/Max 26/27)
192 Power-Off_Retract_Count -O--CK 100 100 000 - 87
193 Load_Cycle_Count -O--CK 100 100 000 - 109
194 Temperature_Celsius -O---K 027 055 000 - 27 (0 25 0 0 0)
195 Hardware_ECC_Recovered -O-RC- 008 004 000 - 41261230
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
200 Multi_Zone_Error_Rate PO---K 100 100 001 - 0
240 Head_Flying_Hours ------ 100 253 000 - 2377 (58 51 0)
241 Total_LBAs_Written ------ 100 253 000 - 17706733904
242 Total_LBAs_Read ------ 100 253 000 - 41928883564
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x04 GPL R/O 256 Device Statistics log
0x04 SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x13 GPL R/O 1 SATA NCQ Send and Receive log
0x15 GPL R/W 1 Rebuild Assist log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 768 Current Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 24 Device vendor specific log
0xa2 GPL VS 16320 Device vendor specific log
0xa4 GPL,SL VS 160 Device vendor specific log
0xa6 GPL VS 192 Device vendor specific log
0xa8-0xa9 GPL,SL VS 136 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xad GPL VS 16 Device vendor specific log
0xaf GPL,SL VS 1 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc1 GPL,SL VS 8 Device vendor specific log
0xc3 GPL,SL VS 32 Device vendor specific log
0xc9 GPL,SL VS 8 Device vendor specific log
0xca GPL,SL VS 16 Device vendor specific log
0xd1 GPL VS 336 Device vendor specific log
0xd2 GPL VS 10000 Device vendor specific log
0xd4 GPL VS 2048 Device vendor specific log
0xda GPL,SL VS 1 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
Device Error Count: 10
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 10 [9] occurred at disk power-on lifetime: 971 hours (40 days + 11 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 53 00 00 00 00 10 d0 8b 98 00 00 Error: UNC at LBA = 0x10d08b98 = 282102680
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 00 00 60 00 01 80 0e 09 40 40 00 20:04:26.044 READ FPDMA QUEUED
60 00 00 02 a0 00 00 10 d0 89 c8 40 00 20:04:26.044 READ FPDMA QUEUED
47 00 00 00 01 00 00 00 00 06 30 a0 00 20:04:26.042 READ LOG DMA EXT
47 00 00 00 01 00 00 00 00 00 30 a0 00 20:04:26.041 READ LOG DMA EXT
47 00 00 00 01 00 00 00 00 00 00 a0 00 20:04:26.041 READ LOG DMA EXT
Error 9 [8] occurred at disk power-on lifetime: 971 hours (40 days + 11 hours)
40 -- 53 00 00 00 00 10 d0 8b 90 00 00 Error: UNC at LBA = 0x10d08b90 = 282102672
60 00 00 00 18 00 01 e6 b8 af 18 40 00 20:04:22.428 READ FPDMA QUEUED
60 00 00 00 60 00 01 80 0e 09 40 40 00 20:04:22.428 READ FPDMA QUEUED
60 00 00 02 a0 00 00 10 d0 89 c8 40 00 20:04:22.428 READ FPDMA QUEUED
61 00 00 00 10 00 04 fb 68 6f a0 40 00 20:04:22.428 WRITE FPDMA QUEUED
60 00 00 00 58 00 01 98 c3 d5 60 40 00 20:04:22.427 READ FPDMA QUEUED
Error 8 [7] occurred at disk power-on lifetime: 971 hours (40 days + 11 hours)
40 -- 53 00 00 00 00 10 d0 8b 98 00 00 Error: WP at LBA = 0x10d08b98 = 282102680
61 00 00 00 10 00 04 fb 68 6f a0 40 00 20:04:22.312 WRITE FPDMA QUEUED
60 00 00 00 18 00 01 e6 b8 af 18 40 00 20:04:18.832 READ FPDMA QUEUED
60 00 00 00 58 00 01 98 c3 d5 60 40 00 20:04:18.806 READ FPDMA QUEUED
60 00 00 00 60 00 01 80 0e 09 40 40 00 20:04:18.770 READ FPDMA QUEUED
60 00 00 02 a0 00 00 10 d0 89 c8 40 00 20:04:18.770 READ FPDMA QUEUED
Error 7 [6] occurred at disk power-on lifetime: 969 hours (40 days + 9 hours)
40 -- 53 00 00 00 00 14 0f 9c 30 00 00 Error: UNC at LBA = 0x140f9c30 = 336567344
60 00 00 00 48 00 01 95 15 2b 20 40 00 18:23:56.473 READ FPDMA QUEUED
60 00 00 00 60 00 01 b2 69 bb e0 40 00 18:23:56.473 READ FPDMA QUEUED
60 00 00 00 28 00 01 8a 72 f4 90 40 00 18:23:56.472 READ FPDMA QUEUED
60 00 00 07 a0 00 00 14 0f 96 20 40 00 18:23:52.949 READ FPDMA QUEUED
60 00 00 07 d0 00 00 14 0f 8e 50 40 00 18:23:52.911 READ FPDMA QUEUED
Error 6 [5] occurred at disk power-on lifetime: 969 hours (40 days + 9 hours)
40 -- 53 00 00 00 00 14 02 b8 78 00 00 Error: WP at LBA = 0x1402b878 = 335722616
61 00 00 00 10 00 04 fb 67 37 90 40 00 18:23:31.408 WRITE FPDMA QUEUED
60 00 00 07 e0 00 00 14 02 b3 08 40 00 18:23:31.407 READ FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 a0 00 18:23:31.372 FLUSH CACHE EXT
61 00 00 00 10 00 04 fb 67 37 80 40 00 18:23:31.002 WRITE FPDMA QUEUED
60 00 00 00 48 00 00 14 02 b2 c0 40 00 18:23:31.000 READ FPDMA QUEUED
Error 5 [4] occurred at disk power-on lifetime: 969 hours (40 days + 9 hours)
40 -- 53 00 00 00 00 11 64 ed 60 00 00 Error: UNC at LBA = 0x1164ed60 = 291827040
60 00 00 00 58 00 01 b2 43 d9 80 40 00 18:22:57.313 READ FPDMA QUEUED
60 00 00 00 58 00 01 d1 55 9f d0 40 00 18:22:57.313 READ FPDMA QUEUED
61 00 00 00 10 00 04 fb 67 34 10 40 00 18:22:57.313 WRITE FPDMA QUEUED
60 00 00 00 38 00 01 7c ee 41 50 40 00 18:22:57.313 READ FPDMA QUEUED
60 00 00 00 10 00 01 7b 89 8c e0 40 00 18:22:57.313 READ FPDMA QUEUED
Error 4 [3] occurred at disk power-on lifetime: 969 hours (40 days + 9 hours)
40 -- 53 00 00 00 00 11 64 d8 10 00 00 Error: UNC at LBA = 0x1164d810 = 291821584
60 00 00 08 00 00 00 11 64 d5 90 40 00 18:22:48.182 READ FPDMA QUEUED
61 00 00 00 10 00 04 fb 67 33 80 40 00 18:22:48.182 WRITE FPDMA QUEUED
60 00 00 00 40 00 01 8b 79 e5 a0 40 00 18:22:48.181 READ FPDMA QUEUED
60 00 00 00 40 00 01 d1 a0 33 d0 40 00 18:22:46.049 READ FPDMA QUEUED
60 00 00 00 50 00 01 c5 83 2e 70 40 00 18:22:46.039 READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 969 hours (40 days + 9 hours)
40 -- 53 00 00 00 00 11 64 9d 08 00 00 Error: UNC at LBA = 0x11649d08 = 291806472
60 00 00 00 08 00 01 c8 13 0e 80 40 00 18:22:41.831 READ FPDMA QUEUED
60 00 00 00 38 00 01 7d 79 6b 90 40 00 18:22:41.831 READ FPDMA QUEUED
60 00 00 08 00 00 00 11 64 95 90 40 00 18:22:38.276 READ FPDMA QUEUED
60 00 00 01 80 00 04 5e 4f 35 80 40 00 18:22:38.218 READ FPDMA QUEUED
60 00 00 01 80 00 04 5e 4f 31 80 40 00 18:22:38.217 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 2322 -
# 2 Extended offline Completed without error 00% 2293 -
# 3 Short offline Completed without error 00% 2154 -
# 4 Short offline Completed without error 00% 1986 -
# 5 Short offline Completed without error 00% 1818 -
# 6 Short offline Completed without error 00% 1649 -
# 7 Extended offline Completed without error 00% 1549 -
# 8 Short offline Completed without error 00% 1481 -
# 9 Short offline Completed without error 00% 1313 -
#10 Short offline Completed without error 00% 1145 -
#11 Extended offline Completed without error 00% 996 -
#12 Short offline Completed without error 00% 977 -
#13 Extended offline Aborted by host 90% 976 -
#14 Extended offline Completed without error 00% 829 -
#15 Short offline Completed without error 00% 809 -
#16 Short offline Completed without error 00% 641 -
#17 Short offline Completed without error 00% 477 -
#18 Short offline Completed without error 00% 311 -
#19 Extended offline Completed without error 00% 93 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
Device State: Active (0)
Current Temperature: 27 Celsius
Power Cycle Min/Max Temperature: 26/27 Celsius
Lifetime Min/Max Temperature: 25/55 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 10 01 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 3 minutes
Temperature Logging Interval: 59 minutes
Min/Max recommended Temperature: 10/40 Celsius
Min/Max Temperature Limit: 5/60 Celsius
Temperature History Size (Index): 128 (21)
Index Estimated Time Temperature Celsius
22 2025-11-14 12:04 28 *********
23 2025-11-14 13:03 29 **********
... ..( 2 skipped). .. **********
26 2025-11-14 16:00 29 **********
27 2025-11-14 16:59 28 *********
28 2025-11-14 17:58 29 **********
29 2025-11-14 18:57 29 **********
30 2025-11-14 19:56 28 *********
31 2025-11-14 20:55 28 *********
32 2025-11-14 21:54 29 **********
33 2025-11-14 22:53 33 **************
... ..( 2 skipped). .. **************
36 2025-11-15 01:50 33 **************
37 2025-11-15 02:49 32 *************
... ..( 6 skipped). .. *************
44 2025-11-15 09:42 32 *************
45 2025-11-15 10:41 31 ************
46 2025-11-15 11:40 32 *************
... ..( 3 skipped). .. *************
50 2025-11-15 15:36 32 *************
51 2025-11-15 16:35 31 ************
52 2025-11-15 17:34 29 **********
53 2025-11-15 18:33 28 *********
... ..( 10 skipped). .. *********
64 2025-11-16 05:22 28 *********
65 2025-11-16 06:21 27 ********
66 2025-11-16 07:20 28 *********
... ..( 18 skipped). .. *********
85 2025-11-17 02:01 28 *********
86 2025-11-17 03:00 27 ********
87 2025-11-17 03:59 27 ********
88 2025-11-17 04:58 28 *********
89 2025-11-17 05:57 27 ********
90 2025-11-17 06:56 27 ********
91 2025-11-17 07:55 27 ********
92 2025-11-17 08:54 28 *********
... ..( 9 skipped). .. *********
102 2025-11-17 18:44 28 *********
103 2025-11-17 19:43 29 **********
104 2025-11-17 20:42 28 *********
105 2025-11-17 21:41 28 *********
106 2025-11-17 22:40 27 ********
109 2025-11-18 01:37 27 ********
110 2025-11-18 02:36 26 *******
117 2025-11-18 09:29 26 *******
118 2025-11-18 10:28 27 ********
125 2025-11-18 17:21 27 ********
126 2025-11-18 18:20 26 *******
... ..( 4 skipped). .. *******
3 2025-11-18 23:15 26 *******
4 2025-11-19 00:14 27 ********
5 2025-11-19 01:13 26 *******
6 2025-11-19 02:12 26 *******
7 2025-11-19 03:11 25 ******
... ..( 5 skipped). .. ******
13 2025-11-19 09:05 25 ******
14 2025-11-19 10:04 26 *******
18 2025-11-19 14:00 26 *******
19 2025-11-19 14:59 27 ********
20 2025-11-19 15:58 ? -
21 2025-11-19 16:57 26 *******
SCT Error Recovery Control:
Read: 40 (4.0 seconds)
Write: 40 (4.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 15 --- Lifetime Power-On Resets
0x01 0x010 4 2388 --- Power-on Hours
0x01 0x018 6 17703601664 --- Logical Sectors Written
0x01 0x020 6 110131384 --- Number of Write Commands
0x01 0x028 6 41928842312 --- Logical Sectors Read
0x01 0x030 6 44912624 --- Number of Read Commands
0x01 0x038 6 - --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 2388 --- Spindle Motor Power-on Hours
0x03 0x010 4 2388 --- Head Flying Hours
0x03 0x018 4 109 --- Head Load Events
0x03 0x020 4 320 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 87 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 27 --- Current Temperature
0x05 0x010 1 26 --- Average Short Term Temperature
0x05 0x018 1 28 --- Average Long Term Temperature
0x05 0x020 1 55 --- Highest Temperature
0x05 0x028 1 25 --- Lowest Temperature
0x05 0x030 1 51 --- Highest Average Short Term Temperature
0x05 0x038 1 25 --- Lowest Average Short Term Temperature
0x05 0x040 1 38 --- Highest Average Long Term Temperature
0x05 0x048 1 28 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 5 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 72 --- Number of Hardware Resets
0x06 0x010 4 19 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
0xff ===== = = === == Vendor Specific Statistics (rev 1) ==
0xff 0x008 7 0 --- Vendor Specific
0xff 0x018 7 0 --- Vendor Specific
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 2 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
sdb:
sudo smartctl -x /dev/sdb
Serial Number: ZJV16W9S
LU WWN Device Id: 5 000c50 0b153b94b
Local Time is: Wed Nov 19 17:28:39 2025 CET
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 575) seconds.
command.
power-saving mode.
recommended polling time: (1108) minutes.
1 Raw_Read_Error_Rate POSR-- 081 063 044 - 133554558
3 Spin_Up_Time PO---- 090 090 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 33
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 928
7 Seek_Error_Rate POSR-- 088 060 045 - 669353257
9 Power_On_Hours -O--CK 086 086 000 - 12584
12 Power_Cycle_Count -O--CK 100 100 020 - 32
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 4295032833
190 Airflow_Temperature_Cel -O---K 071 046 040 - 29 (Min/Max 28/29)
192 Power-Off_Retract_Count -O--CK 100 100 000 - 353
193 Load_Cycle_Count -O--CK 100 100 000 - 545
194 Temperature_Celsius -O---K 029 054 000 - 29 (0 21 0 0 0)
195 Hardware_ECC_Recovered -O-RC- 009 004 000 - 133554558
197 Current_Pending_Sector -O--C- 100 100 000 - 8
198 Offline_Uncorrectable ----C- 100 100 000 - 8
240 Head_Flying_Hours ------ 100 253 000 - 12558 (154 94 0)
241 Total_LBAs_Written ------ 100 253 000 - 39619356744
242 Total_LBAs_Read ------ 100 253 000 - 1154462233525
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
# 1 Short offline Completed without error 00% 12518 -
# 2 Extended offline Completed without error 00% 12489 -
# 3 Short offline Completed without error 00% 12350 -
# 4 Short offline Completed without error 00% 12182 -
# 5 Short offline Completed without error 00% 12129 -
# 6 Short offline Completed without error 00% 12014 -
# 7 Short offline Completed without error 00% 11845 -
# 8 Extended offline Completed without error 00% 11745 -
# 9 Short offline Completed without error 00% 11677 -
#10 Short offline Completed without error 00% 11509 -
#11 Short offline Completed without error 00% 11341 -
#12 Short offline Completed without error 00% 11173 -
#13 Extended offline Completed without error 00% 11026 -
#14 Short offline Completed without error 00% 11006 -
#15 Short offline Completed without error 00% 10837 -
#16 Short offline Completed without error 00% 10673 -
#17 Short offline Completed without error 00% 10507 -
#18 Short offline Completed without error 00% 10256 -
#19 Short offline Completed without error 00% 10197 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Current Temperature: 29 Celsius
Power Cycle Min/Max Temperature: 28/29 Celsius
Lifetime Min/Max Temperature: 21/54 Celsius
Vendor specific:
00 00 22 01 00 00 00 00 00 00 00 00 00 00 00 00
Temperature History Size (Index): 128 (47)
48 2025-11-14 12:04 31 ************
... ..( 8 skipped). .. ************
57 2025-11-14 20:55 31 ************
58 2025-11-14 21:54 32 *************
59 2025-11-14 22:53 36 *****************
60 2025-11-14 23:52 37 ******************
61 2025-11-15 00:51 36 *****************
... ..( 3 skipped). .. *****************
65 2025-11-15 04:47 36 *****************
66 2025-11-15 05:46 35 ****************
70 2025-11-15 09:42 35 ****************
71 2025-11-15 10:41 34 ***************
72 2025-11-15 11:40 35 ****************
76 2025-11-15 15:36 35 ****************
77 2025-11-15 16:35 34 ***************
78 2025-11-15 17:34 31 ************
79 2025-11-15 18:33 30 ***********
... ..( 42 skipped). .. ***********
122 2025-11-17 12:50 30 ***********
123 2025-11-17 13:49 31 ************
126 2025-11-17 16:46 31 ************
127 2025-11-17 17:45 30 ***********
0 2025-11-17 18:44 31 ************
1 2025-11-17 19:43 32 *************
2 2025-11-17 20:42 30 ***********
5 2025-11-17 23:39 30 ***********
6 2025-11-18 00:38 29 **********
9 2025-11-18 03:35 29 **********
10 2025-11-18 04:34 28 *********
14 2025-11-18 08:30 28 *********
15 2025-11-18 09:29 29 **********
... ..( 4 skipped). .. **********
20 2025-11-18 14:24 29 **********
21 2025-11-18 15:23 30 ***********
22 2025-11-18 16:22 29 **********
25 2025-11-18 19:19 29 **********
26 2025-11-18 20:18 28 *********
29 2025-11-18 23:15 28 *********
30 2025-11-19 00:14 29 **********
31 2025-11-19 01:13 28 *********
35 2025-11-19 05:09 28 *********
36 2025-11-19 06:08 27 ********
37 2025-11-19 07:07 28 *********
38 2025-11-19 08:06 27 ********
39 2025-11-19 09:05 28 *********
42 2025-11-19 12:02 28 *********
43 2025-11-19 13:01 29 **********
44 2025-11-19 14:00 29 **********
45 2025-11-19 14:59 29 **********
46 2025-11-19 15:58 ? -
47 2025-11-19 16:57 28 *********
0x01 0x008 4 32 --- Lifetime Power-On Resets
0x01 0x010 4 12584 --- Power-on Hours
0x01 0x018 6 39616113719 --- Logical Sectors Written
0x01 0x020 6 304456579 --- Number of Write Commands
0x01 0x028 6 1154426769949 --- Logical Sectors Read
0x01 0x030 6 17743864019 --- Number of Read Commands
0x03 0x008 4 3659751734 N-- Spindle Motor Power-on Hours
0x03 0x010 4 3659751734 N-- Head Flying Hours
0x03 0x018 4 545 --- Head Load Events
0x03 0x020 4 928 --- Number of Reallocated Logical Sectors
0x03 0x028 4 1 --- Read Recovery Attempts
0x03 0x038 4 8 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 353 --- Number of High Priority Unload Events
0x04 0x008 4 1 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 1 --- Resets Between Cmd Acceptance and Completion
0x05 0x008 1 29 --- Current Temperature
0x05 0x010 1 28 --- Average Short Term Temperature
0x05 0x018 1 30 --- Average Long Term Temperature
0x05 0x020 1 54 --- Highest Temperature
0x05 0x028 1 27 --- Lowest Temperature
0x05 0x030 1 50 --- Highest Average Short Term Temperature
0x05 0x038 1 28 --- Lowest Average Short Term Temperature
0x05 0x040 1 47 --- Highest Average Long Term Temperature
0x05 0x048 1 30 --- Lowest Average Long Term Temperature
0x06 0x008 4 368 --- Number of Hardware Resets
0x06 0x010 4 94 --- Number of ASR Events
||__ D supports DSN
Index LBA Hours
0 457168800 12574
1 457168801 12574
2 457168802 12574
3 457168803 12574
4 457168804 12574
5 457168805 12574
6 457168806 12574
7 457168807 12574
sdc:
sudo smartctl -x /dev/sdc
Serial Number: ZJV16R96
LU WWN Device Id: 5 000c50 0b14e9f1f
Local Time is: Wed Nov 19 17:32:11 2025 CET
been run.
command.
power-saving mode.
recommended polling time: (1099) minutes.
1 Raw_Read_Error_Rate POSR-- 079 064 044 - 75461254
4 Start_Stop_Count -O--CK 100 100 020 - 35
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 088 060 045 - 648355836
12 Power_Cycle_Count -O--CK 100 100 020 - 33
188 Command_Timeout -O--CK 100 099 000 - 4295032833
190 Airflow_Temperature_Cel -O---K 073 048 040 - 27 (Min/Max 25/27)
192 Power-Off_Retract_Count -O--CK 100 100 000 - 342
193 Load_Cycle_Count -O--CK 100 100 000 - 548
194 Temperature_Celsius -O---K 027 052 000 - 27 (0 22 0 0 0)
195 Hardware_ECC_Recovered -O-RC- 008 001 000 - 75461254
240 Head_Flying_Hours ------ 100 253 000 - 12560 (33 234 0)
241 Total_LBAs_Written ------ 100 253 000 - 39551778572
242 Total_LBAs_Read ------ 100 253 000 - 1153728002887
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
# 1 Short offline Completed without error 00% 12517 -
# 5 Short offline Completed without error 00% 12014 -
# 6 Short offline Completed without error 00% 11845 -
# 7 Extended offline Completed without error 00% 11744 -
# 8 Short offline Completed without error 00% 11677 -
# 9 Short offline Completed without error 00% 11509 -
#10 Short offline Completed without error 00% 11341 -
#11 Short offline Completed without error 00% 11173 -
#12 Extended offline Completed without error 00% 11025 -
#13 Short offline Completed without error 00% 11005 -
#14 Short offline Completed without error 00% 10837 -
#15 Short offline Completed without error 00% 10673 -
#16 Short offline Completed without error 00% 10506 -
#17 Short offline Completed without error 00% 10256 -
#18 Short offline Completed without error 00% 10197 -
#19 Extended offline Aborted by host 90% 10196 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Power Cycle Min/Max Temperature: 25/27 Celsius
Lifetime Min/Max Temperature: 21/53 Celsius
Vendor specific:
00 00 13 01 00 00 00 00 00 00 00 00 00 00 00 00
Temperature History Size (Index): 128 (48)
49 2025-11-14 12:04 28 *********
58 2025-11-14 20:55 28 *********
59 2025-11-14 21:54 29 **********
60 2025-11-14 22:53 33 **************
61 2025-11-14 23:52 33 **************
62 2025-11-15 00:51 32 *************
69 2025-11-15 07:44 32 *************
70 2025-11-15 08:43 31 ************
... ..( 7 skipped). .. ************
78 2025-11-15 16:35 31 ************
79 2025-11-15 17:34 28 *********
... ..( 5 skipped). .. *********
85 2025-11-15 23:28 28 *********
86 2025-11-16 00:27 27 ********
92 2025-11-16 06:21 27 ********
93 2025-11-16 07:20 28 *********
102 2025-11-16 16:11 28 *********
103 2025-11-16 17:10 27 ********
104 2025-11-16 18:09 27 ********
105 2025-11-16 19:08 28 *********
106 2025-11-16 20:07 28 *********
107 2025-11-16 21:06 28 *********
108 2025-11-16 22:05 27 ********
118 2025-11-17 07:55 27 ********
119 2025-11-17 08:54 28 *********
1 2025-11-17 18:44 28 *********
2 2025-11-17 19:43 29 **********
3 2025-11-17 20:42 28 *********
4 2025-11-17 21:41 28 *********
5 2025-11-17 22:40 27 ********
6 2025-11-17 23:39 27 ********
7 2025-11-18 00:38 27 ********
8 2025-11-18 01:37 26 *******
11 2025-11-18 04:34 26 *******
12 2025-11-18 05:33 25 ******
13 2025-11-18 06:32 25 ******
14 2025-11-18 07:31 26 *******
18 2025-11-18 11:27 26 *******
19 2025-11-18 12:26 27 ********
24 2025-11-18 17:21 27 ********
25 2025-11-18 18:20 26 *******
31 2025-11-19 00:14 26 *******
32 2025-11-19 01:13 25 ******
41 2025-11-19 10:04 25 ******
42 2025-11-19 11:03 26 *******
46 2025-11-19 14:59 26 *******
47 2025-11-19 15:58 ? -
48 2025-11-19 16:57 25 ******
0x01 0x008 4 33 --- Lifetime Power-On Resets
0x01 0x018 6 39546824847 --- Logical Sectors Written
0x01 0x020 6 302597295 --- Number of Write Commands
0x01 0x028 6 1153690510650 --- Logical Sectors Read
0x01 0x030 6 18396765447 --- Number of Read Commands
0x03 0x008 4 2337691102 N-- Spindle Motor Power-on Hours
0x03 0x010 4 2337691102 N-- Head Flying Hours
0x03 0x018 4 548 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x040 4 342 --- Number of High Priority Unload Events
0x05 0x010 1 25 --- Average Short Term Temperature
0x05 0x020 1 52 --- Highest Temperature
0x05 0x030 1 49 --- Highest Average Short Term Temperature
0x05 0x040 1 46 --- Highest Average Long Term Temperature
0x06 0x008 4 403 --- Number of Hardware Resets
0x06 0x010 4 95 --- Number of ASR Events
||__ D supports DSN
No Defects Logged
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
zpool status:
sudo zpool status -v
pool: Main
state: ONLINE
scan: scrub repaired 192K in 06:51:03 with 0 errors on Sat Nov 1 06:51:06 2025
NAME STATE READ WRITE CKSUM
Main ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
bf2401b4-77e1-4ee2-887e-3d307d55bc7f ONLINE 0 0 0
0fd699ce-5fc1-4ccb-aae3-4d0e33b67deb ONLINE 0 0 0
333c9540-76db-4ca1-8312-a3e9824a9900 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:22 with 0 errors on Sun Nov 16 03:45:23 2025
boot-pool ONLINE 0 0 0
nvme0n1p3 ONLINE 0 0 0
I added also sda as I rebooted the nas.
Thank you for your fast response
