Need help understanding if I should RMA a drive
I’ve had a FreeNAS/TrueNAS system running for 12 years, and never had a drive failure in that time.
In 2024, I built a new pool with 4x 8TB WD Red Plus drives, did SMART long tests and burn in testing with the drives and they all passed.
Earlier this month, during the scheduled scrub, one drive threw several uncorrectable read errors. I put the drive on a new SATA cable and a different port on the HBA, rebooted and scrubbed again. Still had uncorrectable read errors.
Ran a SMART long test on the drive, which came back fine. Scrubbed again, and again uncorrectable read errors.
Seems like the drive is no longer reliable, but am I missing something? I thought scrubbing would reconstruct the bad blocks and write them to new parts of the drive, so it would eventually migrate data off the bad part of the drive. But instead, the drive is being put into the FAULTED state and the pool is degraded
The system is a supermicro X10SL7-F with an integrated LSI 2308 flashed with IT firmware. It has 32GB DDR3 ECC memory, and an Intel(R) Xeon(R) CPU E3-1270L v4 @ 3.00GHz.
The four data drives are in a RAID-Z2.
The SMART output for the drive in question:
sudo smartctl -a -x /dev/da0
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Device Model:     WDC WD80EFPX-68C4ZN0
Serial Number:    [redacted]
LU WWN Device Id: 5 0014ee 26b9718fc
Firmware Version: 81.00A81
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5640 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Mar 30 21:33:35 2026 PDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x02) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (12284) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 799) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x0039) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   183   183   021    -    7833
  4 Start_Stop_Count        -O--CK   100   100   000    -    20
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   088   088   000    -    9307
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    20
192 Power-Off_Retract_Count -O--CK   200   200   000    -    18
193 Load_Cycle_Count        -O--CK   200   200   000    -    62
194 Temperature_Celsius     -O---K   120   110   000    -    32
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   200   200   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O    310  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa1  GPL,SL  VS      16  Device vendor specific log
0xa3-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      80  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 73 (device log contains only the most recent 24 errors)
        CR     = Command Register
        FEATR  = Features Register
        COUNT  = Count (was: Sector Count) Register
        LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
        LH     = LBA High (was: Cylinder High) Register    ]   LBA
        LM     = LBA Mid (was: Cylinder Low) Register      ] Register
        LL     = LBA Low (was: Sector Number) Register     ]
        DV     = Device (was: Device/Head) Register
        DC     = Device Control Register
        ER     = Error register
        ST     = Status register
Error 73 [0] occurred at disk power-on lifetime: 9279 hours (386 days + 15 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 08 00 00 46 40 22 90 40 00  Error: UNC at LBA = 0x46402290 = 1178608272
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 01 00 00 20 00 00 46 41 6f 10 40 00  1d+00:25:15.292  READ FPDMA QUEUED
  60 01 00 00 18 00 00 46 41 6e 10 40 00  1d+00:25:15.292  READ FPDMA QUEUED
  60 01 00 00 10 00 00 46 41 6d 10 40 00  1d+00:25:15.292  READ FPDMA QUEUED
  60 01 00 00 00 00 00 46 41 6c 10 40 00  1d+00:25:15.292  READ FPDMA QUEUED
  60 00 80 00 08 00 00 46 41 6b 90 40 00  1d+00:25:15.292  READ FPDMA QUEUED
Error 72 [23] occurred at disk power-on lifetime: 9279 hours (386 days + 15 hours)
  40 -- 51 00 00 00 00 42 4c 72 70 40 00  Error: UNC at LBA = 0x424c7270 = 1112306288
  60 00 b8 00 18 00 00 42 4c 81 b0 40 00  1d+00:24:21.576  READ FPDMA QUEUED
  60 01 00 00 10 00 00 42 4c 80 b0 40 00  1d+00:24:21.576  READ FPDMA QUEUED
  60 01 00 00 08 00 00 42 4c 7f b0 40 00  1d+00:24:21.576  READ FPDMA QUEUED
  60 01 00 00 00 00 00 42 4c 7e b0 40 00  1d+00:24:21.576  READ FPDMA QUEUED
  60 01 00 00 18 00 00 42 4c 7d b0 40 00  1d+00:24:21.575  READ FPDMA QUEUED
Error 71 [22] occurred at disk power-on lifetime: 9279 hours (386 days + 15 hours)
  40 -- 51 00 b8 00 00 38 c0 36 f8 40 00  Error: UNC at LBA = 0x38c036f8 = 952121080
  60 00 20 00 08 00 00 38 c3 a1 50 40 00  1d+00:22:14.112  READ FPDMA QUEUED
  60 01 00 00 00 00 00 38 c3 a0 50 40 00  1d+00:22:14.112  READ FPDMA QUEUED
  60 01 00 00 18 00 00 38 c3 9f 50 40 00  1d+00:22:14.111  READ FPDMA QUEUED
  60 01 00 00 10 00 00 38 c3 9e 50 40 00  1d+00:22:14.111  READ FPDMA QUEUED
  60 01 00 00 08 00 00 38 c3 9d 50 40 00  1d+00:22:14.111  READ FPDMA QUEUED
Error 70 [21] occurred at disk power-on lifetime: 9279 hours (386 days + 15 hours)
  40 -- 51 00 18 00 00 2a c0 2f f8 40 00  Error: UNC at LBA = 0x2ac02ff8 = 717238264
  60 00 80 00 00 00 00 2a c4 b9 d0 40 00  1d+00:19:25.835  READ FPDMA QUEUED
  60 00 88 00 10 00 00 2a c4 b9 48 40 00  1d+00:19:25.831  READ FPDMA QUEUED
  60 01 00 00 08 00 00 2a c4 b8 48 40 00  1d+00:19:25.831  READ FPDMA QUEUED
  60 00 a0 00 00 00 00 2a c4 b7 a0 40 00  1d+00:19:25.831  READ FPDMA QUEUED
  60 01 00 00 20 00 00 2a c4 b6 a0 40 00  1d+00:19:25.830  READ FPDMA QUEUED
Error 69 [20] occurred at disk power-on lifetime: 9279 hours (386 days + 15 hours)
  40 -- 51 00 b8 00 00 0f c0 36 f8 40 00  Error: UNC at LBA = 0x0fc036f8 = 264255224
  60 01 00 00 20 00 00 0f cb 5f 18 40 00  1d+00:13:17.062  READ FPDMA QUEUED
  60 01 00 00 18 00 00 0f cb 5e 18 40 00  1d+00:13:17.062  READ FPDMA QUEUED
  60 01 00 00 10 00 00 0f cb 5d 18 40 00  1d+00:13:17.062  READ FPDMA QUEUED
  60 01 00 00 00 00 00 0f cb 5c 18 40 00  1d+00:13:17.062  READ FPDMA QUEUED
  60 00 80 00 08 00 00 0f cb 5b 98 40 00  1d+00:13:17.062  READ FPDMA QUEUED
Error 68 [19] occurred at disk power-on lifetime: 9279 hours (386 days + 15 hours)
  40 -- 51 00 a0 00 00 09 c6 85 f8 40 00  Error: UNC at LBA = 0x09c685f8 = 164005368
  60 01 00 00 20 00 00 09 cc 32 00 40 00  1d+00:11:43.751  READ FPDMA QUEUED
  60 01 00 00 18 00 00 09 cc 31 00 40 00  1d+00:11:43.751  READ FPDMA QUEUED
  60 01 00 00 10 00 00 09 cc 30 00 40 00  1d+00:11:43.751  READ FPDMA QUEUED
  60 01 00 00 00 00 00 09 cc 2f 00 40 00  1d+00:11:43.751  READ FPDMA QUEUED
  60 00 80 00 08 00 00 09 cc 2e 80 40 00  1d+00:11:43.751  READ FPDMA QUEUED
Error 67 [18] occurred at disk power-on lifetime: 9260 hours (385 days + 20 hours)
  40 -- 51 00 00 00 00 37 7b cb 88 40 00  Error: UNC at LBA = 0x377bcb88 = 930859912
  60 00 80 00 00 00 00 37 7f 5e b0 40 00     05:15:01.009  READ FPDMA QUEUED
  60 00 80 00 00 00 00 37 7f 5d a8 40 00     05:15:01.008  READ FPDMA QUEUED
  60 00 80 00 00 00 00 37 7f 5c a0 40 00     05:15:01.007  READ FPDMA QUEUED
  60 00 80 00 00 00 00 37 7f 5b 98 40 00     05:15:01.004  READ FPDMA QUEUED
  60 00 80 00 00 00 00 37 7f 5a 90 40 00     05:15:01.004  READ FPDMA QUEUED
Error 66 [17] occurred at disk power-on lifetime: 9260 hours (385 days + 20 hours)
  40 -- 51 00 00 00 00 3f e7 53 a8 40 00  Error: UNC at LBA = 0x3fe753a8 = 1072124840
  60 00 80 00 00 00 00 40 dd 22 b0 40 00     05:14:54.597  READ FPDMA QUEUED
  60 00 80 00 08 00 00 40 dd 21 a8 40 00     05:14:54.595  READ FPDMA QUEUED
  60 00 80 00 00 00 00 40 dd 20 a0 40 00     05:14:54.595  READ FPDMA QUEUED
  60 00 80 00 08 00 00 40 dd 1f 98 40 00     05:14:54.595  READ FPDMA QUEUED
  60 00 80 00 00 00 00 40 dd 1e 90 40 00     05:14:54.595  READ FPDMA QUEUED
SMART Error Log Version: 1
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%      9298         -
# 2  Short offline       Completed without error       00%      9253         -
# 3  Short offline       Completed without error       00%      9151         -
# 4  Extended offline    Completed without error       00%      9025         -
# 5  Short offline       Completed without error       00%      8983         -
# 6  Short offline       Completed without error       00%      8816         -
# 7  Short offline       Completed without error       00%      8649         -
# 8  Short offline       Completed without error       00%      8481         -
# 9  Short offline       Completed without error       00%      8313         -
#10  Short offline       Completed without error       00%      8145         -
#11  Short offline       Completed without error       00%      7977         -
#12  Short offline       Completed without error       00%      7809         -
#13  Short offline       Completed without error       00%      7642         -
#14  Short offline       Completed without error       00%      7474         -
#15  Extended offline    Completed without error       00%       103         -
#16  Extended offline    Completed without error       00%        13         -
#17  Conveyance offline  Completed without error       00%         0         -
#18  Short offline       Completed without error       00%         0         -
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
Device State:                        Active (0)
Current Temperature:                    32 Celsius
Power Cycle Min/Max Temperature:     31/39 Celsius
Lifetime    Min/Max Temperature:     21/42 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (193)
Index    Estimated Time   Temperature Celsius
 194    2026-03-30 13:36    32  *************
 ...    ..(  5 skipped).    ..  *************
 200    2026-03-30 13:42    32  *************
 201    2026-03-30 13:43    33  **************
 202    2026-03-30 13:44    33  **************
 203    2026-03-30 13:45    32  *************
 ...    ..(  4 skipped).    ..  *************
 208    2026-03-30 13:50    32  *************
 209    2026-03-30 13:51    33  **************
 210    2026-03-30 13:52    33  **************
 211    2026-03-30 13:53    32  *************
 212    2026-03-30 13:54    32  *************
 213    2026-03-30 13:55    33  **************
 214    2026-03-30 13:56    32  *************
 215    2026-03-30 13:57    32  *************
 216    2026-03-30 13:58    33  **************
 217    2026-03-30 13:59    32  *************
 218    2026-03-30 14:00    33  **************
 219    2026-03-30 14:01    32  *************
 ...    ..( 19 skipped).    ..  *************
 239    2026-03-30 14:21    32  *************
 240    2026-03-30 14:22    33  **************
 241    2026-03-30 14:23    32  *************
 242    2026-03-30 14:24    32  *************
 243    2026-03-30 14:25    32  *************
 244    2026-03-30 14:26    33  **************
 245    2026-03-30 14:27    32  *************
 246    2026-03-30 14:28    33  **************
 247    2026-03-30 14:29    33  **************
 248    2026-03-30 14:30    32  *************
 249    2026-03-30 14:31    32  *************
 250    2026-03-30 14:32    33  **************
 251    2026-03-30 14:33    32  *************
 ...    ..(  3 skipped).    ..  *************
 255    2026-03-30 14:37    32  *************
 256    2026-03-30 14:38    33  **************
 257    2026-03-30 14:39    32  *************
 ...    ..( 24 skipped).    ..  *************
 282    2026-03-30 15:04    32  *************
 283    2026-03-30 15:05    33  **************
 284    2026-03-30 15:06    32  *************
 285    2026-03-30 15:07    32  *************
 286    2026-03-30 15:08    32  *************
 287    2026-03-30 15:09    33  **************
 288    2026-03-30 15:10    32  *************
 289    2026-03-30 15:11    33  **************
 290    2026-03-30 15:12    32  *************
 ...    ..(302 skipped).    ..  *************
 115    2026-03-30 20:15    32  *************
 116    2026-03-30 20:16    34  ***************
 ...    ..(  3 skipped).    ..  ***************
 120    2026-03-30 20:20    34  ***************
 121    2026-03-30 20:21    33  **************
 ...    ..( 55 skipped).    ..  **************
 177    2026-03-30 21:17    33  **************
 178    2026-03-30 21:18    32  *************
 179    2026-03-30 21:19    33  **************
 180    2026-03-30 21:20    32  *************
 181    2026-03-30 21:21    33  **************
 ...    ..(  6 skipped).    ..  **************
 188    2026-03-30 21:28    33  **************
 189    2026-03-30 21:29    32  *************
 190    2026-03-30 21:30    32  *************
 191    2026-03-30 21:31    33  **************
 192    2026-03-30 21:32    32  *************
 193    2026-03-30 21:33    32  *************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 3) ==
0x01  0x008  4              20  ---  Lifetime Power-On Resets
0x01  0x010  4            9307  ---  Power-on Hours
0x01  0x018  6     37956671534  ---  Logical Sectors Written
0x01  0x020  6       240083682  ---  Number of Write Commands
0x01  0x028  6     63507810914  ---  Logical Sectors Read
0x01  0x030  6       268922765  ---  Number of Read Commands
0x01  0x038  6      3440428928  ---  Date and Time TimeStamp
0x02  =====  =               =  ===  == Free-Fall Statistics (rev 1) ==
0x02  0x010  4               0  ---  Overlimit Shock Events
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4            9273  ---  Spindle Motor Power-on Hours
0x03  0x010  4            8232  ---  Head Flying Hours
0x03  0x018  4              81  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              18  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4              73  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              32  ---  Current Temperature
0x05  0x010  1              35  ---  Average Short Term Temperature
0x05  0x018  1              35  ---  Average Long Term Temperature
0x05  0x020  1              42  ---  Highest Temperature
0x05  0x028  1              23  ---  Lowest Temperature
0x05  0x030  1              39  ---  Highest Average Short Term Temperature
0x05  0x038  1              23  ---  Lowest Average Short Term Temperature
0x05  0x040  1              37  ---  Highest Average Long Term Temperature
0x05  0x048  1              25  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             117  ---  Number of Hardware Resets
0x06  0x010  4              16  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x010  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            0  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4       186164  Vendor specific
I used to have problems with a Supermicro A2SDi-H-TF 4 8T disks in a small box case with a SFX power supply. There were random disk errors. It turned out the power supply was the problem. Not enough power. After installing a new 350W SFX power supply (the original only had 150W) all problems vanished.
Your systems also seems to be quite old. Maybe check your power supply. They are the #2 hardware failure cause, after #1 disk drives.
The power supply is a 550w ATX unit from Seasonic that’s newer than the rest of the system (2017). How would I check the power supply? Check the voltages with a multimeter? It seems to be running all other drives just fine.
It’s difficult. A multimeter won’t catch all problems. The easiest way is to borrow a spare psu from another system and see if the error persist.
All Drive manufacturers have their own tools to check their drives in order to prevent RMAing good drives. For WDC ist’s Kitfox.
I put the drive into a different system with different cables and PSU, but unfortunately the system doesn’t have a SAS controller, only a SATA controller. I ran badblocks on the drive and found no faults. I put it back into my TrueNAS system, even on the SATA controller instead of SAS HBA with a different port port on the PSU and different power cable, and it threw errors on scrub.
Here’s what dmesg shows:
(da3:mps0:0:3:0): READ(16). CDB: 88 00 00 00 00 03 7b 43 c9 20 00 00 00 80 00 00
(da3:mps0:0:3:0): CAM status: SCSI Status Error
(da3:mps0:0:3:0): SCSI status: Check Condition
(da3:mps0:0:3:0): SCSI sense: MEDIUM ERROR asc:11,0 (Unrecovered read error)
(da3:mps0:0:3:0): Info: 0x37b43c954
(da3:mps0:0:3:0): Error 5, Unretryable error
(da3:mps0:0:3:0): READ(10). CDB: 28 00 47 48 f0 f0 00 00 80 00
(da3:mps0:0:3:0): Info: 0x4748f144
(da3:mps0:0:3:0): READ(10). CDB: 28 00 61 57 b5 48 00 00 80 00
(da3:mps0:0:3:0): Info: 0x6157b554
(da3:mps0:0:3:0): READ(10). CDB: 28 00 b8 eb d7 c8 00 00 80 00
(da3:mps0:0:3:0): Info: 0xb8ebd7e4
(da3:mps0:0:3:0): READ(16). CDB: 88 00 00 00 00 01 57 79 c3 f8 00 00 00 80 00 00
(da3:mps0:0:3:0): Info: 0x15779c41c
(da3:mps0:0:3:0): READ(16). CDB: 88 00 00 00 00 03 78 70 11 d8 00 00 00 80 00 00
(da3:mps0:0:3:0): Info: 0x3787011fc
mps0: Controller reported scsi ioc terminated tgt 3 SMID 286 loginfo 31080000
mps0: Controller reported scsi ioc terminated tgt 3 SMID 621 loginfo 31080000
(da3:mps0:0:3:0): READ(10). CDB: 28 00 09 cb a4 c8 00 01 00 00
mps0: Controller reported scsi ioc terminated tgt 3 SMID 1910 loginfo 31080000
(da3:mps0:0:3:0): CAM status: CCB request completed with an error
(da3:mps0:0:3:0): Retrying command, 3 more tries remain
(da3:mps0:0:3:0): READ(10). CDB: 28 00 09 cb a5 c8 00 01 00 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 09 cb a6 c8 00 00 98 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 09 cb a3 c8 00 01 00 00
(da3:mps0:0:3:0): Info: 0x9cba3fc
mps0: Controller reported scsi ioc terminated tgt 3 SMID 1511 loginfo 31080000
(da3:mps0:0:3:0): READ(10). CDB: 28 00 23 e8 4f 48 00 01 00 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 23 e8 4e 48 00 01 00 00
(da3:mps0:0:3:0): Info: 0x23e84eac
mps0: Controller reported scsi ioc terminated tgt 3 SMID 1389 loginfo 31080000
mps0: Controller reported scsi ioc terminated tgt 3 SMID 195 loginfo 31080000
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 44 7d 30 00 01 00 00
mps0: Controller reported scsi ioc terminated tgt 3 SMID 1787 loginfo 31080000
mps0: Controller reported scsi ioc terminated tgt 3 SMID 1894 loginfo 31080000
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 44 7e 30 00 01 00 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 44 7f 30 00 01 00 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 44 80 30 00 01 00 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 44 7c 30 00 01 00 00
(da3:mps0:0:3:0): Info: 0x33447cdc
mps0: Controller reported scsi ioc terminated tgt 3 SMID 1645 loginfo 31080000
mps0: Controller reported scsi ioc terminated tgt 3 SMID 736 loginfo 31080000
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 71 3a 98 00 01 00 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 71 3b 98 00 00 88 00
(da3:mps0:0:3:0): READ(10). CDB: 28 00 33 71 39 f8 00 00 a0 00
(da3:mps0:0:3:0): Info: 0x33713a14
I’m hoping to diagnose this without having to resort to using Windows to test the drive. I suspect that something with the SAS part of the drive is broken, but not the SATA part?
Not sure what you mean here: This is a SATA drive, it has no “SAS part”.
You’ve ruled out cables and PSU by testing it in a different system. It’s the drive.
:lemon:
RMA time.
