My disks failed with various symptoms
My dataLA pool is a RAIDz1 with 4x 1TB + 1x 500GB (Im expanding pool capacity). All system install on a Z210 machine with 16GB of ECC RAM.
Yesterday:
  • My sde disk got error “Self-Test Log error count increased from 0 to 1” and failed long SMART test.
Today:
  • My sdf disk got error “8 Offline uncorrectable sectors” and “8 Currently unreadable (pending) sectors” and run long SMART test very long.
  • My dataLA pool DEGRADED when my sdb FAULTED with no error, and 4 remaining disks got 6 checksum error.
After restart the system:
  • My dataLA pool ONLINE but my sdb got 1 read error, and my sdf got 2 write error (increase to 14 write error after 14 hours).
  • My sde disk still failed long SMART test. My sdf disk still running long SMART test.
zpool status -v output:
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:20 with 0 errors on Thu Feb 13 03:45:21 2025
          sda3      ONLINE       0     0     0
errors: No known data errors
  pool: dataLA
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
  scan: resilvered 196M in 00:00:25 with 0 errors on Mon Feb 17 02:51:48 2025
        NAME                                      STATE     READ WRITE CKSUM
        dataLA                                    ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            1daccfc5-60b8-4d46-be50-684694ba7f0c  ONLINE       0    12     0
            417798ef-f387-4a06-b167-0ed4311f1d47  ONLINE       0     0     0
            08d59905-2668-4c4a-b6a4-4ed8d3377956  ONLINE       0     0     0
            e8e7e069-009d-4ad6-b8d2-e1ca2d25ae9c  ONLINE       0     0     0
            d4794722-9120-4190-9f63-5cc1a5c028ce  ONLINE       1     0     0
smartctl -x /dev/sdb output:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107+truenas] (local build)
Device Model:     TOSHIBA MQ04ABF100
Serial Number:    X8TFW69ST
LU WWN Device Id: 5 000039 8d4b88410
Firmware Version: JU0C0J
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Zoned Device:     Device managed zones
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is:    Mon Feb 17 16:05:29 2025 +07
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     1 (minimum power consumption with standby)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (  120) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 170) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   050    -    0
  2 Throughput_Performance  P-S---   100   100   050    -    0
  3 Spin_Up_Time            POS--K   100   100   001    -    416
  4 Start_Stop_Count        -O--CK   100   100   000    -    54675
  5 Reallocated_Sector_Ct   PO--CK   100   100   050    -    0
  7 Seek_Error_Rate         PO-R--   100   100   050    -    0
  8 Seek_Time_Performance   P-S---   100   100   050    -    0
  9 Power_On_Hours          -O--CK   093   093   000    -    2944
 10 Spin_Retry_Count        PO--CK   253   100   030    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    1693
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    665
192 Power-Off_Retract_Count -O--CK   100   100   000    -    301
193 Load_Cycle_Count        -O--CK   088   088   000    -    127405
194 Temperature_Celsius     -O---K   100   100   000    -    33 (Min/Max 14/49)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O--CK   100   100   000    -    0
198 Offline_Uncorrectable   ----CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   253   000    -    3
220 Disk_Shift              -O----   100   100   000    -    0
222 Loaded_Hours            -O--CK   096   096   000    -    1902
223 Load_Retry_Count        -O--CK   100   100   000    -    0
224 Load_Friction           -O---K   100   100   000    -    0
226 Load-in_Time            -OS--K   100   100   000    -    186
240 Head_Flying_Hours       P-----   100   100   001    -    0
254 Free_Fall_Sensor        -O--CK   100   100   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O     51  Comprehensive SMART error log
0x03       GPL     R/O     64  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      2  Device Statistics Notification
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O  32768  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa7       GPL     VS       8  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (64 sectors)
Device Error Count: 3
        CR     = Command Register
        FEATR  = Features Register
        COUNT  = Count (was: Sector Count) Register
        LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
        LH     = LBA High (was: Cylinder High) Register    ]   LBA
        LM     = LBA Mid (was: Cylinder Low) Register      ] Register
        LL     = LBA Low (was: Sector Number) Register     ]
        DV     = Device (was: Device/Head) Register
        DC     = Device Control Register
        ER     = Error register
        ST     = Status register
Error 3 [2] occurred at disk power-on lifetime: 728 hours (30 days + 8 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  84 -- 41 00 b8 00 00 33 03 cd bf 40 00  Error: ABRT
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  2f 00 00 00 01 00 00 00 00 00 10 e0 00     01:38:36.779  READ LOG EXT
  61 00 08 00 b8 00 00 33 03 cd b8 40 00     01:38:36.779  WRITE FPDMA QUEUED
  61 00 08 00 b0 00 00 34 ec 81 50 40 00     01:38:36.779  WRITE FPDMA QUEUED
  61 00 08 00 a8 00 00 34 bf 52 00 40 00     01:38:36.778  WRITE FPDMA QUEUED
  61 00 08 00 a0 00 00 34 e7 f5 e0 40 00     01:38:36.778  WRITE FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 728 hours (30 days + 8 hours)
  84 -- 41 00 40 00 00 34 ed 55 0f 40 00  Error: ABRT
  2f 00 00 00 01 00 00 00 00 00 10 e0 00     01:36:25.043  READ LOG EXT
  61 00 08 00 40 00 00 34 ed 55 08 40 00     01:36:25.043  WRITE FPDMA QUEUED
  61 00 08 00 38 00 00 34 f3 3e e0 40 00     01:36:25.043  WRITE FPDMA QUEUED
  61 00 08 00 30 00 00 34 f2 3a c8 40 00     01:36:25.042  WRITE FPDMA QUEUED
  61 00 08 00 28 00 00 34 f7 b8 00 40 00     01:36:25.042  WRITE FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 728 hours (30 days + 8 hours)
  84 -- 41 00 70 00 00 35 01 ff 67 40 00  Error: ABRT
  2f 00 00 00 01 00 00 00 00 00 10 e0 00     01:36:00.791  READ LOG EXT
  61 00 08 00 70 00 00 35 01 ff 60 40 00     01:36:00.791  WRITE FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 a0 00     01:36:00.790  FLUSH CACHE EXT
  61 00 08 00 60 00 00 33 f7 37 e8 40 00     01:35:56.386  WRITE FPDMA QUEUED
  61 00 08 00 58 00 00 34 6b 1c 68 40 00     01:35:56.385  WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%      2844         -
# 2  Short offline       Completed without error       00%      2796         -
# 3  Short offline       Completed without error       00%      1923         -
# 4  Short offline       Completed without error       00%      1899         -
# 5  Extended offline    Completed without error       00%      1895         -
# 6  Short offline       Completed without error       00%      1875         -
# 7  Short offline       Completed without error       00%      1851         -
# 8  Short offline       Completed without error       00%      1827         -
# 9  Extended offline    Completed without error       00%      1805         -
#10  Extended offline    Completed without error       00%      1781         -
#11  Extended offline    Completed without error       00%      1757         -
#12  Extended offline    Completed without error       00%      1733         -
#13  Extended offline    Completed without error       00%      1709         -
#14  Extended offline    Aborted by host               30%      1686         -
#15  Extended offline    Completed without error       00%      1673         -
#16  Extended offline    Completed without error       00%      1649         -
#17  Extended offline    Completed without error       00%      1625         -
#18  Extended offline    Completed without error       00%      1593         -
#19  Extended offline    Completed without error       00%      1571         -
SCT Status Version:                  3
SCT Version (vendor specific):       1 (0x0001)
Device State:                        Active (0)
Current Temperature:                    33 Celsius
Power Cycle Min/Max Temperature:     32/33 Celsius
Lifetime    Min/Max Temperature:     14/49 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:            0/60 Celsius
Temperature History Size (Index):    478 (214)
Index    Estimated Time   Temperature Celsius
 215    2025-02-17 08:08    36  *****************
 216    2025-02-17 08:09    36  *****************
 217    2025-02-17 08:10    36  *****************
 218    2025-02-17 08:11    37  ******************
 ...    ..(  7 skipped).    ..  ******************
 226    2025-02-17 08:19    37  ******************
 227    2025-02-17 08:20    36  *****************
 228    2025-02-17 08:21    37  ******************
 229    2025-02-17 08:22    37  ******************
 230    2025-02-17 08:23    37  ******************
 231    2025-02-17 08:24    36  *****************
 232    2025-02-17 08:25    36  *****************
 233    2025-02-17 08:26    37  ******************
 234    2025-02-17 08:27    37  ******************
 235    2025-02-17 08:28    37  ******************
 236    2025-02-17 08:29    36  *****************
 237    2025-02-17 08:30    36  *****************
 238    2025-02-17 08:31    37  ******************
 ...    ..(  2 skipped).    ..  ******************
 241    2025-02-17 08:34    37  ******************
 242    2025-02-17 08:35    36  *****************
 243    2025-02-17 08:36    37  ******************
 246    2025-02-17 08:39    37  ******************
 247    2025-02-17 08:40    36  *****************
 248    2025-02-17 08:41    37  ******************
 ...    ..( 29 skipped).    ..  ******************
 278    2025-02-17 09:11    37  ******************
 279    2025-02-17 09:12    38  *******************
 280    2025-02-17 09:13    37  ******************
 ...    ..( 27 skipped).    ..  ******************
 308    2025-02-17 09:41    37  ******************
 309    2025-02-17 09:42    38  *******************
 310    2025-02-17 09:43    38  *******************
 311    2025-02-17 09:44    38  *******************
 312    2025-02-17 09:45    37  ******************
 313    2025-02-17 09:46    38  *******************
 314    2025-02-17 09:47    38  *******************
 315    2025-02-17 09:48    37  ******************
 318    2025-02-17 09:51    37  ******************
 319    2025-02-17 09:52     ?  -
 320    2025-02-17 09:53     ?  -
 321    2025-02-17 09:54     ?  -
 322    2025-02-17 09:55    37  ******************
 352    2025-02-17 10:25    37  ******************
 353    2025-02-17 10:26    38  *******************
 354    2025-02-17 10:27    38  *******************
 355    2025-02-17 10:28    37  ******************
 356    2025-02-17 10:29    37  ******************
 357    2025-02-17 10:30    37  ******************
 358    2025-02-17 10:31    38  *******************
 359    2025-02-17 10:32    37  ******************
 ...    ..( 17 skipped).    ..  ******************
 377    2025-02-17 10:50    37  ******************
 378    2025-02-17 10:51    38  *******************
 379    2025-02-17 10:52    37  ******************
 380    2025-02-17 10:53    37  ******************
 381    2025-02-17 10:54    37  ******************
 382    2025-02-17 10:55    38  *******************
 ...    ..(  6 skipped).    ..  *******************
 389    2025-02-17 11:02    38  *******************
 390    2025-02-17 11:03    37  ******************
 391    2025-02-17 11:04    37  ******************
 392    2025-02-17 11:05    38  *******************
 393    2025-02-17 11:06    38  *******************
 394    2025-02-17 11:07    38  *******************
 395    2025-02-17 11:08    37  ******************
 396    2025-02-17 11:09    37  ******************
 397    2025-02-17 11:10    38  *******************
 398    2025-02-17 11:11    38  *******************
 399    2025-02-17 11:12    38  *******************
 400    2025-02-17 11:13    37  ******************
 401    2025-02-17 11:14    37  ******************
 402    2025-02-17 11:15    38  *******************
 403    2025-02-17 11:16    38  *******************
 404    2025-02-17 11:17    37  ******************
 ...    ..( 10 skipped).    ..  ******************
 415    2025-02-17 11:28    37  ******************
 416    2025-02-17 11:29    36  *****************
 417    2025-02-17 11:30    37  ******************
 418    2025-02-17 11:31    37  ******************
 419    2025-02-17 11:32    36  *****************
 ...    ..(  4 skipped).    ..  *****************
 424    2025-02-17 11:37    36  *****************
 425    2025-02-17 11:38    35  ****************
 ...    ..( 23 skipped).    ..  ****************
 449    2025-02-17 12:02    35  ****************
 450    2025-02-17 12:03    34  ***************
 451    2025-02-17 12:04    34  ***************
 452    2025-02-17 12:05    34  ***************
 453    2025-02-17 12:06    35  ****************
 454    2025-02-17 12:07    34  ***************
 472    2025-02-17 12:25    34  ***************
 473    2025-02-17 12:26    35  ****************
 474    2025-02-17 12:27    35  ****************
 475    2025-02-17 12:28    34  ***************
 476    2025-02-17 12:29    34  ***************
 477    2025-02-17 12:30    34  ***************
   0    2025-02-17 12:31    35  ****************
   1    2025-02-17 12:32    34  ***************
 ...    ..( 20 skipped).    ..  ***************
  22    2025-02-17 12:53    34  ***************
  23    2025-02-17 12:54    33  **************
  24    2025-02-17 12:55    34  ***************
  32    2025-02-17 13:03    34  ***************
  33    2025-02-17 13:04    33  **************
  34    2025-02-17 13:05    34  ***************
  35    2025-02-17 13:06    34  ***************
  36    2025-02-17 13:07    33  **************
  39    2025-02-17 13:10    33  **************
  40    2025-02-17 13:11    34  ***************
  41    2025-02-17 13:12    33  **************
 ...    ..( 35 skipped).    ..  **************
  77    2025-02-17 13:48    33  **************
  78    2025-02-17 13:49    32  *************
  79    2025-02-17 13:50    33  **************
  80    2025-02-17 13:51    33  **************
  81    2025-02-17 13:52    33  **************
  82    2025-02-17 13:53    32  *************
  83    2025-02-17 13:54    32  *************
  84    2025-02-17 13:55    33  **************
  91    2025-02-17 14:02    33  **************
  92    2025-02-17 14:03    32  *************
  93    2025-02-17 14:04    32  *************
  94    2025-02-17 14:05    33  **************
  95    2025-02-17 14:06    33  **************
  96    2025-02-17 14:07    32  *************
  99    2025-02-17 14:10    32  *************
 100    2025-02-17 14:11    33  **************
 101    2025-02-17 14:12    32  *************
 ...    ..( 12 skipped).    ..  *************
 114    2025-02-17 14:25    32  *************
 115    2025-02-17 14:26    33  **************
 116    2025-02-17 14:27    33  **************
 117    2025-02-17 14:28    32  *************
 ...    ..( 16 skipped).    ..  *************
 134    2025-02-17 14:45    32  *************
 135    2025-02-17 14:46    33  **************
 136    2025-02-17 14:47    32  *************
 137    2025-02-17 14:48    32  *************
 138    2025-02-17 14:49    32  *************
 139    2025-02-17 14:50    33  **************
 ...    ..(  3 skipped).    ..  **************
 143    2025-02-17 14:54    33  **************
 144    2025-02-17 14:55    34  ***************
 ...    ..(  9 skipped).    ..  ***************
 154    2025-02-17 15:05    34  ***************
 155    2025-02-17 15:06    35  ****************
 156    2025-02-17 15:07    34  ***************
 157    2025-02-17 15:08    34  ***************
 158    2025-02-17 15:09    34  ***************
 159    2025-02-17 15:10    35  ****************
 170    2025-02-17 15:21    35  ****************
 171    2025-02-17 15:22    36  *****************
 172    2025-02-17 15:23    36  *****************
 173    2025-02-17 15:24    35  ****************
 174    2025-02-17 15:25    36  *****************
 175    2025-02-17 15:26    36  *****************
 176    2025-02-17 15:27    35  ****************
 ...    ..( 14 skipped).    ..  ****************
 191    2025-02-17 15:42    35  ****************
 192    2025-02-17 15:43    34  ***************
 193    2025-02-17 15:44    34  ***************
 194    2025-02-17 15:45    35  ****************
 197    2025-02-17 15:48    35  ****************
 198    2025-02-17 15:49    34  ***************
 ...    ..(  3 skipped).    ..  ***************
 202    2025-02-17 15:53    34  ***************
 203    2025-02-17 15:54    33  **************
 204    2025-02-17 15:55    34  ***************
 205    2025-02-17 15:56     ?  -
 206    2025-02-17 15:57    33  **************
 213    2025-02-17 16:04    33  **************
 214    2025-02-17 16:05    32  *************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4            1693  ---  Lifetime Power-On Resets
0x01  0x010  4            2944  ---  Power-on Hours
0x01  0x018  6     10976283219  ---  Logical Sectors Written
0x01  0x020  6       154524318  ---  Number of Write Commands
0x01  0x028  6     16597824161  ---  Logical Sectors Read
0x01  0x030  6       178848761  ---  Number of Read Commands
0x01  0x038  6     10601426879  ---  Date and Time TimeStamp
0x02  =====  =               =  ===  == Free-Fall Statistics (rev 1) ==
0x02  0x010  4             665  ---  Overlimit Shock Events
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4            2098  ---  Spindle Motor Power-on Hours
0x03  0x010  4            1902  ---  Head Flying Hours
0x03  0x018  4          127405  ---  Head Load Events
0x03  0x020  4               0  -D-  Number of Reallocated Logical Sectors
0x03  0x028  4             288  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4             301  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              33  ---  Current Temperature
0x05  0x010  1              34  N--  Average Short Term Temperature
0x05  0x018  1              32  N--  Average Long Term Temperature
0x05  0x020  1              49  ---  Highest Temperature
0x05  0x028  1              14  ---  Lowest Temperature
0x05  0x030  1              44  N--  Highest Average Short Term Temperature
0x05  0x038  1              24  N--  Lowest Average Short Term Temperature
0x05  0x040  1              34  N--  Highest Average Long Term Temperature
0x05  0x048  1              31  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4           49595  ---  Number of Hardware Resets
0x06  0x010  4            1598  ---  Number of ASR Events
0x06  0x018  4               3  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0003  4            0  R_ERR response for device-to-host data FIS
0x0004  4            0  R_ERR response for host-to-device data FIS
0x0005  4            0  R_ERR response for non-data FIS
0x0006  4            0  R_ERR response for device-to-host non-data FIS
0x0007  4            0  R_ERR response for host-to-device non-data FIS
0x0008  4            0  Device-to-host non-data FIS retries
0x0009  4            0  Transition from drive PhyRdy to drive PhyNRdy
0x000a  4            0  Device-to-host register FISes sent due to a COMRESET
0x000b  4            0  CRC errors within host-to-device FIS
0x000d  4            0  Non-CRC errors within host-to-device FIS
0x000f  4            0  R_ERR response for host-to-device data FIS, CRC
0x0010  4            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  4            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  4            0  R_ERR response for host-to-device non-data FIS, non-CRC
smartctl -x /dev/sdf output:
Model Family:     Seagate Mobile HDD
Device Model:     ST1000LM035-1RK172
Serial Number:    WDEK06F4
LU WWN Device Id: 5 000c50 0ab2c29dc
Firmware Version: SDM2
ATA Version is:   ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Mon Feb 17 16:09:06 2025 +07
APM level is:     128 (minimum power consumption without standby)
DSN feature is:   Unavailable
See vendor-specific Attribute list for marginal Attributes.
                                        was never started.
Self-test execution status:      ( 248) Self-test routine in progress...
                                        80% of test remaining.
data collection:                (    0) seconds.
capabilities:                    (0x71) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        command.
                                        No Offline surface scan supported.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        ( 164) minutes.
Conveyance self-test routine
SCT capabilities:              (0x3035) SCT Status supported.
  1 Raw_Read_Error_Rate     POSR--   066   055   006    -    103946669
  3 Spin_Up_Time            PO----   100   099   000    -    0
  4 Start_Stop_Count        -O--CK   055   055   020    -    46563
  5 Reallocated_Sector_Ct   PO--CK   100   100   036    -    0
  7 Seek_Error_Rate         POSR--   086   060   045    -    376615497
  9 Power_On_Hours          -O--CK   093   093   000    -    6563 (219 149 0)
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   097   097   020    -    3633
184 End-to-End_Error        -O--CK   100   100   099    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   099   000    -    55835426853
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   059   034   040    Past 41 (Min/Max 41/41 #15)
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    133
192 Power-Off_Retract_Count -O--CK   100   100   000    -    960
193 Load_Cycle_Count        -O--CK   069   069   000    -    62320
194 Temperature_Celsius     -O---K   041   066   000    -    41 (0 20 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
240 Head_Flying_Hours       ------   100   253   000    -    5182 (232 0 0)
241 Total_LBAs_Written      ------   100   253   000    -    28181093287
242 Total_LBAs_Read         ------   100   253   000    -    33223266802
254 Free_Fall_Sensor        -O--CK   001   001   000    -    5
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    512  Current Device Internal Status Data log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS    8160  Device vendor specific log
0xa8       GPL,SL  VS     136  Device vendor specific log
0xa9       GPL,SL  VS       1  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xb0       GPL     VS    8920  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL,SL  VS      16  Device vendor specific log
0xc2       GPL,SL  VS     240  Device vendor specific log
0xc3       GPL,SL  VS       8  Device vendor specific log
0xc4       GPL,SL  VS      24  Device vendor specific log
0xc9       GPL,SL  VS       1  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xd3       GPL     VS    1920  Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
# 1  Extended offline    Self-test routine in progress 80%      6563         -
# 2  Short offline       Completed without error       00%      6476         -
# 3  Short offline       Completed without error       00%      6412         -
# 4  Short offline       Completed without error       00%      6388         -
# 5  Extended offline    Completed without error       00%      6385         -
# 6  Short offline       Completed without error       00%      6364         -
# 7  Short offline       Completed without error       00%      6340         -
# 8  Short offline       Completed without error       00%      6316         -
# 9  Extended offline    Completed without error       00%      6295         -
#10  Extended offline    Completed without error       00%      6271         -
#11  Extended offline    Completed without error       00%      6247         -
#12  Extended offline    Completed without error       00%      6223         -
#13  Extended offline    Completed without error       00%      6199         -
#14  Extended offline    Completed without error       00%      6178         -
#15  Extended offline    Completed without error       00%      6164         -
#16  Extended offline    Completed without error       00%      6140         -
#17  Extended offline    Completed without error       00%      6116         -
#18  Extended offline    Completed without error       00%      6083         -
#19  Extended offline    Completed without error       00%      6062         -
SCT Version (vendor specific):       522 (0x020a)
Current Temperature:                    41 Celsius
Power Cycle Min/Max Temperature:     41/41 Celsius
Lifetime    Min/Max Temperature:     20/67 Celsius
Specified Max Operating Temperature:    37 Celsius
Temperature Logging Interval:        30 minutes
Min/Max recommended Temperature:     14/55 Celsius
Min/Max Temperature Limit:           10/60 Celsius
Temperature History Size (Index):    128 (101)
 102    2025-02-15 00:30    37  ******************
 103    2025-02-15 01:00    37  ******************
 104    2025-02-15 01:30     ?  -
 105    2025-02-15 02:00    29  **********
 106    2025-02-15 02:30    40  *********************
 107    2025-02-15 03:00    40  *********************
 108    2025-02-15 03:30    44  *************************
 109    2025-02-15 04:00    43  ************************
 110    2025-02-15 04:30    42  ***********************
 ...    ..(  2 skipped).    ..  ***********************
 113    2025-02-15 06:00    42  ***********************
 114    2025-02-15 06:30    41  **********************
 ...    ..( 12 skipped).    ..  **********************
 127    2025-02-15 13:00    41  **********************
   0    2025-02-15 13:30    42  ***********************
 ...    ..(  3 skipped).    ..  ***********************
   4    2025-02-15 15:30    42  ***********************
   5    2025-02-15 16:00    41  **********************
   6    2025-02-15 16:30    42  ***********************
   7    2025-02-15 17:00    42  ***********************
   8    2025-02-15 17:30    41  **********************
   9    2025-02-15 18:00    40  *********************
  10    2025-02-15 18:30    40  *********************
  11    2025-02-15 19:00    40  *********************
  12    2025-02-15 19:30    41  **********************
  13    2025-02-15 20:00    43  ************************
  14    2025-02-15 20:30    43  ************************
  15    2025-02-15 21:00    44  *************************
  16    2025-02-15 21:30    44  *************************
  17    2025-02-15 22:00    43  ************************
 ...    ..( 25 skipped).    ..  ************************
  43    2025-02-16 11:00    43  ************************
  44    2025-02-16 11:30    44  *************************
  45    2025-02-16 12:00    44  *************************
  46    2025-02-16 12:30    45  **************************
  47    2025-02-16 13:00    45  **************************
  48    2025-02-16 13:30    45  **************************
  49    2025-02-16 14:00    46  ***************************
 ...    ..(  2 skipped).    ..  ***************************
  52    2025-02-16 15:30    46  ***************************
  53    2025-02-16 16:00    47  ****************************
 ...    ..(  2 skipped).    ..  ****************************
  56    2025-02-16 17:30    47  ****************************
  57    2025-02-16 18:00    45  **************************
  58    2025-02-16 18:30    43  ************************
  59    2025-02-16 19:00    43  ************************
  60    2025-02-16 19:30    42  ***********************
  61    2025-02-16 20:00    42  ***********************
  62    2025-02-16 20:30    41  **********************
  63    2025-02-16 21:00    41  **********************
  64    2025-02-16 21:30    43  ************************
  65    2025-02-16 22:00    42  ***********************
  66    2025-02-16 22:30    41  **********************
  67    2025-02-16 23:00     ?  -
  68    2025-02-16 23:30    42  ***********************
  69    2025-02-17 00:00    42  ***********************
  70    2025-02-17 00:30     ?  -
  71    2025-02-17 01:00    42  ***********************
  72    2025-02-17 01:30    43  ************************
  73    2025-02-17 02:00    42  ***********************
  74    2025-02-17 02:30    43  ************************
  75    2025-02-17 03:00     ?  -
  76    2025-02-17 03:30    43  ************************
  77    2025-02-17 04:00     ?  -
  78    2025-02-17 04:30    42  ***********************
  79    2025-02-17 05:00     ?  -
  80    2025-02-17 05:30    42  ***********************
  81    2025-02-17 06:00    41  **********************
  82    2025-02-17 06:30    41  **********************
  83    2025-02-17 07:00    40  *********************
  96    2025-02-17 13:30    40  *********************
  97    2025-02-17 14:00    41  **********************
  98    2025-02-17 14:30     ?  -
  99    2025-02-17 15:00    41  **********************
 100    2025-02-17 15:30     ?  -
 101    2025-02-17 16:00    41  **********************
SCT Error Recovery Control command not supported
0x01  0x008  4            3633  ---  Lifetime Power-On Resets
0x01  0x010  4            6563  ---  Power-on Hours
0x01  0x018  6     28251496458  ---  Logical Sectors Written
0x01  0x020  6       346823740  ---  Number of Write Commands
0x01  0x028  6     33239342656  ---  Logical Sectors Read
0x01  0x030  6       414518437  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  0x008  4            3087  ---  Spindle Motor Power-on Hours
0x03  0x010  4             695  ---  Head Flying Hours
0x03  0x018  4           62320  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4              27  ---  Read Recovery Attempts
0x04  0x008  4             780  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              32  ---  Resets Between Cmd Acceptance and Completion
                                ||__ D supports DSN
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
What can I do now? What info do you guys need to help me solve this mess?
Tks you all of you guys.
You can start here:
Specifically I need zpool status -v smartctl -x /dev/sdf smartctl -x /dev/sdb and place those individually in code brackets.
Tks, Ive just update my post as your recommendation
This is an SMR drive and is highly not recommended for any NAS use, especially ZFS.
I do not see anything actually wrong with this drive.
This drive also is SMR.
And the same here, I see nothing wrong with the drive.
Your problem is you are running SMR drives with a ZFS file system. The Zpool errors are a direct result of that.
You can run a scrub zpool scrub dataLA and if no files are corrupt, then run zpool clear dataLA to clear the errors however they will come back.
Tks you for your information
Whoaaa. Please explain.
I know SMR drives are slow, and resilver takes an age. Don’t use them.
I didn’t know they could introduce scrub errors. Wut?
I didn’t say that. I said using SMR drives will cause the ZFS errors to come back. A scrub is a read operation, it is during write operations that things go bad.
They are slow for one reason, the way SMR drives write data.
