Unable to use WD disks: Error: [Errno 16] Device or resource busy: '/dev/sda'
I am unable to create a pool, nor can I wipe any of my 4 disks.
The message I get:
Disk Type:
HDD
Description:
N/A
Model:
WDC_WD40EFPX-68C6CN0
Transfer Mode:
Auto
Rotation Rate (RPM):
5400
HDD Standby:
ALWAYS ON
Adv. Power Management:
DISABLED
Enable S.M.A.R.T.:
true
S.M.A.R.T. extra options:
N/A
lsof | grep /dev/sda
has no output.
The disk was used before in another configuration. Not sure how to format it in truenas.
Hardware used is Ugreen DXP 4800 Plus
Take it out, put it in a windows box and use diskpart / “choose disk” / clean on it
Thanks this worked but I am bit surprised that truenas does not have this basic tools on board.
It does, you just have to use the command line.
