Install Plex on TrueNas Community edition 25.10.0.1 Need Help Please :(
I’ve been trying to configure Plex within the community version of Truenas 25.10.0.1 for a week now. I’ve tried countless methods and tutorials, but I always end up with the same problem.
I’m following these steps:
  1. I install Truenas from scratch and use the `trunas_admin` user to connect to it.
  2. I create a new user, `plex_user`, which is an SMB user.
  3. I create a new pool named `NAS01`.
  4. I create a dataset of type `APPS` named `PLEX`.
3.1) I create a dataset of type `APPS` within the `plex` dataset and name it `PLEX_DATA`.
3.2) I create a dataset of type `APPS` within the `plex` dataset and name it `PLEX_CONFIG`.
  1. I create a generic dataset named `PLEX_MEDIA`.
  2. I go to the shared option and define a Windows SMB resource, choosing the PLEX_MEDIA dataset.
  3. I go to the System - Services section and edit the SMB resource, giving it the name I want to use to view it in Windows and the name of the network where my machines are located.
  4. I connect from Windows with the PLEX user and the defined password, and I can see the shared resource without problems. I can copy, create, or delete files. I place any movie in this folder on Windows.
  5. I proceed to install Plex. I set the time zone, the IP address of the server (IP xxx.xxx.xxx.xxx/24), the Plex claim, leaving the user and group (568) unchanged, and select Host Network.
8.1) In Plex Data Storage, I select Host, enter the path to the PLEX_DATA dataset, check the ACL box, and select the Force option.
8.2) I leave the logs and the transcoder in temporary mode.
  1. I follow the same steps as in 8.1) but for Plex configuration storage, obviously using the PLEX_CONFIG dataset.
  2. I add additional storage, select the host, enter the path to the PLEX_MEDIA dataset, and check the ACL box.
  3. I proceed with the installation… and upon completion, I restart the Truenas server.
  4. I access the Plex UI via //IP_servidor_truenas:32400/web and enter my Plex username and password, then select a name for the server.
  5. I’m going to attach folders, I select movies and go to search for folders, then I go to the root directory, from there I look for the PLEX_MEDIA folder, which has a movie I added through Windows. I see the movie and click “Add.”
  6. :sleepy_face: :sleepy_face: Problem: when I go to the Plex server and double-click on “Library,” the movies folder says it’s empty, and I don’t know how to get Plex to see the movies.
Can someone please help me? I’m going crazy.
Assuming you are using the Plex app from from the TrueNAS library (and not some other Docker container), perhaps this will help:
  • In my installation I specified User-ID 568 and Group-ID 568 in the corresponding fields in the “User and Group Configuration” section for the app. This is the “apps” user. Then I gave that user-id and group-id read permission on the dataset, where my media is stored. I also checked that this user has access to the “apps” dataset (where my Plex config data and others reside). FWIW I don’t have the ACL options checked.
I hope that this might help a bit…
P.S.: A separate issue for Plex is that - once you get the app to work - you should probably enable the “Hostpath” option. If you don’t, Plex might use a Relay server, even for internal connection, because its internal IP-Address in the container is different from the IP-address that clients in the network need to use to contact it.
I was struggling with this too!!
I followed your step by step procedure and the solution provided and it worked like a charm. Thanks for documenting your process - greatly appreciated!!
me to… struggling with this to… The problem is that people can’t explain it in a way that others can understand.
