Installing HAOS (Home Assistant OS) in a VM
HAOS will only use the serial console if the VM does not have a VGA device in my experience.
Did you write the RAW image to the ZVOL with dd?
The second console screen shot above looks like the EFI shell so the VM has not yet booted from the virtual disk drive.
I decided to try a different CPU option, as in the logs I saw a lot of warnings that seemed to point at the CPU (like 2026-01-21T16:38:57.459318Z qemu-system-x86_64: warning: This feature depends on other features that were not requested:). My CPU is an EPYC 7713. Instead of using Host Passthrough or Host Model, I swapped it to kvm64 and I do now see it working in the Serial Shell (still no display, but that’s not an issue for me).
I remove the display devices from all “Unixy” VMs after initial installation. Serial console is just better.
Thanks for your work on this, Troy. I had a play around this afternoon and was able to both create a fresh install per your instructions and restore from a recent backup saved out from HAOS, as well as use them for a base to ingest my entire backed up Hyper-V HAOS install (from a .vmdk).
Hi everyone! I am trying to follow aloong in order to create my home assistant VM. So far, I have only created VMs from iso files, so these steps are new to me.
I have created my Zvol, and made sure the size is correct. I downloaded the file, and ran the second command (creating the raw if i understand correctly). Now, at the last step, i run into an issue.
the path for my zvol is Apps and VMs/Zvols_VMs/HomeAssistant. i suspect the spaces (why did i use spaces?) are the issue. the command i was trying to run was: sudo qemu-img convert -p -O raw haos_ova-18.3.qcow2 “/dev/zvol/Apps and VMs/Zvols_VMs/HomeAssistant”.
this gave the following problem: no such file or directory. anyone can assist me?
  • Don’t uses spaces. I did not think the GUI allowed spaces.
  • When you create a VM there is a Disk import feature, unfortunately it is only available when you create a VM, but I would have used this to import the Virtual disk. (v25.10+)
  • I would have Apps and VM as separate datasets in the root of your pool. I have sided on apps and vms just in-case there are every path issues, but mixed case seems to work fine for most things.
As to the issue above I am not sure.
yeah, the spaces are pretty cursed. sadly i have it setup like this years ago. not sure how to correct the name without breaking all my apps and vms.
the exact error is “truenas% sudo qemu-img convert -p -O raw haos_ova-18.3.qcow2 “/dev/zvol/Apps and VMs/Zvols_VMs/HomeAssistant”
qemu-img: /dev/zvol/Apps and VMs/Zvols_VMs/HomeAssistant: error while converting raw: Could not create ‘/dev/zvol/Apps and VMs/Zvols_VMs/HomeAssistant’: No such file or directory”
so it appears the command understands the spaces in my path (i think)
to answer your questions better: Apps and VMs iis my dataset (just like tank for my storage). the Zvols_VMs is a subdataset in there (not sure how yyou call those), in there are all my other zvols from my VMs
stupid question, is the Zvol already created? if not this is why it is failing. You need to create the Zvol first.
yeah, the zvol is created
If you’re using the zsh shell (TrueNAS default); try using a plus sign and instead of quotes.
sudo qemu-img convert -p -O raw haos_ova-18.3.qcow2 /dev/zvol/Apps+and+VMs/Zvols_VMs/HomeAssistant
I prefer to use raw files instead of zvols.
Just an option that is much easier to handle, copy, move.
