Most CPU widgets greyed out
With TrueNAS SCALE ElectricEel-24.10.1, all CPU widgets are greyed out, except for Model and Overview. Why, and how do I get them enabled? I wanted to use some of those others, since this release has removed the (most useful!) graph at the bottom of the Overview widget.
Edit the widget and choose the same options that are already selected and save it, that should fix it
That neither brings back the graph, nor makes the four other CPU widget types selectable.
ok then delete the widgets and set them up fresh.
I’ve deleted all dashboard widgets, saved, then re-added them back and saved. No change to either issue. Still no graph in the overview widget, and only overview and model are selectable - the other four are greyed out.
