Plex stuck on deploying
No I didn’t enable ACL, and my datasets are smb shares
your screenshots above on the thread show you selected Enable ACL
Oops , so they do sorry. I unticked ACL after to see if it made any difference, but the update button was disabled when ACL was enabled
I have the same problem. Have to stop the app and restart the app. Seems it is trying to deploy before the system is “ready”. There is no setting to delay this. Hoping it is fixed in the upcoming docker implementation.
I desperation, I installed Emby server, and it works just fine. It runs continuosly , loads the webgui, my media shows up and works.
So easy after all the trials and tribulations trying to get Plex to work for 3 days
Noted …
