Okay, it is hard to run a RAM test as I’d need to boot from a USB and I don’t have a screen attached to the PC. Without unplugging everything and moving the PC I guess the alternative is PXE but I don’t have that setup too.
I use an external PSU to power the drives. The orginal link from Ali Express has expired, but it looks like this:
I would assume this isn’t recommend.
I’ve made custom wires & repaired my own PSUs, & neither of those are recommended. With that in mind, I’d still not recommend using whatever that is for my data until I’ve opened it up & confirmed my suspicions of its quality.
Given your NAS’ form factor we’re already colouring outside the lines. I mean, you could just find a normal PSU & keep the startup pins shorted so it always stays powered on & use that to power your drives. I’d rate it a few steps less sketchy.
Is there any chance you could move a screen/keyboard TO the system instead of the other way around to test the RAM?
Anyway, I’m still more likely to blame your sata controller than anything else. You’ve chosen to play on hardmode with this specific hardware setup (and then added virtualization on top to increase the challenge further); I salute your dedication.
Haha okay.
I’m edging closer to my bare metal setup, so will close this down now as it is working as is probably to do with the SATA controller.
I haven’t bought a montior that could go down there so haven’t ran the RAM test still, but going to leave it as it is.
Thanks all for your help, appricate it a lot.
