I’ve run into an issue after upgrading from 13.0-U6 to 24.04.2.5. The pool is not locked, and there are no unlock to be found anywhere in the GUI.
When I click the pool in the GUI, only option presented is to export the pool.
I did go through the preparation page, before the upgrade. and to my knowledge, I don’t believe it was encrypted with GELI encryption.
Thank you for the response and the references. Ones I imported the pool, it appears to be working fine. No warnings or alerts, and the pool is available upon reboot as well.
I also successfully updated from 24.04 to 24.10, and everything still appear to be working fine.
I had the same issue after upgrading to 24.04 form Core, but exporting/re-importing pools had no effect. Re-uploading my config from before the migration fixed it. Just wanted to comment in case it helps anyone in my situation who found this thread.
