Good morning, I have a problem with TrueNAS SCALE 23.10. One of the pools literally “moved” its location; it is usually mounted at /mnt/pool, but now it has moved to /pool. I saw that there is a zfs set mountpoint command, but I am concerned about the well-being of the VMs mounted on this pool. Do you have any suggestions, advice, or help? Thank you in advance.
