I expanded my pool with one 10TB disk on April 16. The pool was a 4-wide RAIDZ2 of 4TB drives (sda/sdb/sdd/sde), and I added a 10TB Seagate IronWolf (sdf), making it 5-wide RAIDZ2. The expansion completed cleanly.
A scrub on May 23 reported 1 checksum error each on sde (WD Red Plus 4TB) and sdf (the new Seagate 10TB). RAIDZ2 self-healed 4 KiB on each. I ran another scrub today; it finished with errors: 0 but the per-vdev checksum_errors counters on those two disks still read 1 (cumulative, since I have not run zpool clear).
truenas_admin@truenas[~]$ zpool status
pool: app-pool
state: ONLINE
scan: scrub repaired 0B in 00:04:27 with 0 errors on Sun May 3 00:04:29 2026
NAME STATE READ WRITE CKSUM
app-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
a1512966-cdc8-44ab-81e7-9f1f23139ae2 ONLINE 0 0 0
08c884da-b05a-491d-a576-cbc866f87752 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:06 with 0 errors on Sat May 23 03:45:08 2026
boot-pool ONLINE 0 0 0
nvme0n1p3 ONLINE 0 0 0
pool: zfs_tank
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: scrub repaired 0B in 13:46:29 with 0 errors on Sun May 24 05:55:12 2026
expand: expanded raidz2-0 copied 10.5T in 13:25:06, on Fri Apr 17 06:33:55 2026
zfs_tank ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
6a169351-6031-41d5-ad2a-9681142190c5 ONLINE 0 0 0
a006e053-c865-4330-8861-e21e4a3e37a6 ONLINE 0 0 0
b7d78b79-cb70-4afe-b9d0-8e4b2282fb18 ONLINE 0 0 0
707c32af-4e4e-4fc7-b000-dd5b52f75158 ONLINE 0 0 1
ff3c3a00-9f71-4b6b-87e6-c56deb4c6854 ONLINE 0 0 1
SMART on both affected disks is clean:
truenas_admin@truenas[~]$ sudo smartctl -a /dev/sde
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.18.13-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: WDC WD40EFPX-68C6CN0
Serial Number: WD-WX42D459ZK85
LU WWN Device Id: 5 0014ee 216cced69
Firmware Version: 81.00A81
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun May 24 16:51:20 2026 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (37980) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 396) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3039) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 210 209 021 Pre-fail Always - 2500
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 6125
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2916
194 Temperature_Celsius 0x0022 115 108 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 659 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The above only provides legacy SMART information - try 'smartctl -x' for more
truenas_admin@truenas[~]$ sudo smartctl -a /dev/sdf
Model Family: Seagate IronWolf
Device Model: ST10000VN0004-1ZD101
Serial Number: ZA2B6ZRJ
LU WWN Device Id: 5 000c50 0b60914a1
Firmware Version: SC60
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 7200 rpm
Device is: In smartctl database 7.3/5528
Local Time is: Sun May 24 16:51:29 2026 CEST
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
power-saving mode.
recommended polling time: ( 855) minutes.
SCT capabilities: (0x50bd) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 083 064 044 Pre-fail Always - 216082552
3 Spin_Up_Time 0x0003 087 086 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 95
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 090 060 045 Pre-fail Always - 924437387
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3724 (155 11 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 94
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 095 095 000 Old_age Always - 5
190 Airflow_Temperature_Cel 0x0022 064 057 040 Old_age Always - 36 (Min/Max 24/40)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 1693
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 8
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 105
194 Temperature_Celsius 0x0022 036 043 000 Old_age Always - 36 (0 17 0 0 0)
195 Hardware_ECC_Recovered 0x001a 008 001 000 Old_age Always - 216082552
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Pressure_Limit 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 3681h+11m+59.924s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 26490828127
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 57971797184
No Errors Logged
# 1 Short offline Completed without error 00% 2381 -
# 2 Short offline Completed without error 00% 2156 -
# 3 Short offline Completed without error 00% 1473 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Hardware: TianBei WTR MAX, Ryzen 7 PRO 8845HS, 32 GB non-ECC RAM, TrueNAS SCALE 26.0.0-BETA.1.
