Sata Bios settings for Truenas Scale
I installed TrueNAS Scale and my hard drives in my Nas are not showing, or showing correctly. I believe its a bios setting. I have the Sata drives running as AHCI, But should I rum them as Raid, or IDE. Also connected to my system is 2 HBA cards with a total of 20 3TB sas drives. Only these show correctly, But the 10 2TB sata drives in the server are either not shown, or show without serial numbers and volume. I am running Sca;e 22.12.4.2.Electric Eel. In a few mins I am upgrading to 25.10.01
Have you created any pools or are you staring off new? I would try to go to 25.04 or 25.10, depending on your risk category. To do a diagnose, we will need a complete, detailed hardware list and how everything is attached together. The HBA cards need to be flashed to ‘IT Mode’. You can usually check them with one of the following commands for LSI / Broadcom cards. No hardware RAID. ZFS does software equivelent of RAID with its mirrors and Raid-Z(1,2,3).
sudo sas2flash -list
sudo sas3flash -list
sudo storcli show all
