Champion. Thanks. Yes, i changed the drive.
Ok, I had some errors on my boot drive so I replaced it with a brand new ssd. Thing is, the multi-report test comes back (after 15min in system) with a wear level of 64. How is one to interpret that number please?
Unfortunately this is where I must ask you to run the script from the command line and use the switches -dump emailextra which will send me a dump of the drive data so I can see what is going on.
Unfortunately not all drives report nicely.
What can you do right now? Well one thing comes to mind…
Edit the configuration file a bit, but first…
What is the output of smartctl -a /dev/sdh ID 177, 233, or whatever value represents Wear Level. What is it’s value?
If the RAW value is proper then you have an option in the config file to use the RAW value. I tried to take into account every possible manufactures way of representing the wear level data.
If you run the -config and select Advanced, Custom Drive Configuration, and answer the questions. That may fix it for you. If not, toss me the dump data.
Let us know how it goes.
Report sent, thanks mate. Information you asked for here:
> root@truenas[/mnt/tank/scripts]# smartctl -a /dev/sdh
> smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
> Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
> === START OF INFORMATION SECTION ===
> Device Model: Patriot Burst Elite 120GB
> Serial Number: PBEHHBB240906011258
> LU WWN Device Id: 0 000000 000000000
> Firmware Version: HDFED1.2
> User Capacity: 120,034,123,776 bytes [120 GB]
> Sector Size: 512 bytes logical/physical
> Rotation Rate: Solid State Device
> Form Factor: 2.5 inches
> TRIM Command: Available
> Device is: Not in smartctl database 7.3/5528
> ATA Version is: ACS-4 (minor revision not indicated)
> SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
> Local Time is: Mon Oct 7 21:58:09 2024 AWST
> SMART support is: Available - device has SMART capability.
> SMART support is: Enabled
> === START OF READ SMART DATA SECTION ===
> SMART overall-health self-assessment test result: PASSED
> General SMART Values:
> Offline data collection status: (0x00) Offline data collection activity
> was never started.
> Auto Offline Data Collection: Disabled.
> Self-test execution status: ( 0) The previous self-test routine completed
> without error or no self-test has ever
> been run.
> Total time to complete Offline
> data collection: ( 720) seconds.
> capabilities: (0x79) SMART execute Offline immediate.
> No Auto Offline data collection support.
> Suspend Offline collection upon new
> command.
> Offline surface scan supported.
> Self-test supported.
> Conveyance Self-test supported.
> Selective Self-test supported.
> SMART capabilities: (0x0003) Saves SMART data before entering
> power-saving mode.
> Supports SMART auto save timer.
> Error logging capability: (0x01) Error logging supported.
> General Purpose Logging supported.
> Short self-test routine
> recommended polling time: ( 3) minutes.
> Extended self-test routine
> recommended polling time: ( 30) minutes.
> Conveyance self-test routine
> recommended polling time: ( 10) minutes.
> SMART Attributes Data Structure revision number: 16
> Vendor Specific SMART Attributes with Thresholds:
> ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
> 1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
> 5 Reallocated_Sector_Ct 0x0013 100 100 050 Pre-fail Always - 0
> 9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 4
> 12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 5
> 160 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 0
> 161 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 128
> 163 Unknown_Attribute 0x0003 100 100 050 Pre-fail Always - 34
> 164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 5773
> 165 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 7
> 166 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 1
> 167 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 2
> 172 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 0
> 173 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 0
> 192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 2
> 194 Temperature_Celsius 0x0023 100 100 000 Pre-fail Always - 30
> 196 Reallocated_Event_Count 0x0000 100 100 000 Old_age Offline - 0
> 199 UDMA_CRC_Error_Count 0x000b 100 100 050 Pre-fail Always - 0
> 241 Total_LBAs_Written 0x0012 100 100 000 Old_age Always - 112
> 242 Total_LBAs_Read 0x0012 100 100 000 Old_age Always - 123
> 249 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 3
> SMART Error Log Version: 0
> No Errors Logged
> SMART Self-test log structure revision number 0
> Warning: ATA Specification requires self-test log structure revision number = 1
> No self-tests have been logged. [To run self-tests, use: smartctl -t]
> SMART Selective self-test log data structure revision number 0
> Note: revision number not 1 implies that no selective self-test has ever been run
> SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
> 1 0 0 Not_testing
> 2 0 0 Not_testing
> 3 0 0 Not_testing
> 4 0 0 Not_testing
> 5 0 0 Not_testing
> Selective self-test flags (0x0):
> After scanning selected spans, do NOT read-scan remainder of disk.
> If Selective self-test is pending on power-up, resume after 0 minute delay.
> The above only provides legacy SMART information - try 'smartctl -x' for more
Also i did a scrub on the boot pool via the GUI and multi-report now it reports this… Is my ssd DOA you think?
Analyzed the data, suspect the drive is either fake, poor quality control, or infant mortality. The drive is in fact reporting 64% wear level is available, and after only 4 power on hours? Advised the OP his options as I see them, and all of those have to do with replacing the drive.
