Solved - Upgrade 13.0-u6.2 to 13.3 directly?
Stupid question, is it safe to upgrade Core from 13.0-u6.2 to whatever the latest 13.3 directly (by USB since the train is not listed)? Or should I go to 13.0-u6.4 and then switch trains to 13.3.
I’m having some issues deleting files from an SMB share and one of the fixes in a previous post suggest going up to 13.3 which fixed the problem for that user. This is the first time needing to delete files since upgrading from 11.x to 13.0 back in August. For the time being, I renamed the folders to zzz- to push them to the bottom (alpha sort) and get them out of the way while I figure this out.
Possibly unrelated, MC keeps freezing on when I try to use it. My thoughts were to try MC where I had direct access to change permissions and delete.
There’s no train for 13.3. Only update option is to download the update file and select update via manual file.
I guess that solves that, I have the tar file and the iso (just in case).
I think I’m going to update to 13.0-u6.4 first and see if it solves my issue. If not I’ll upload the tar file and go to 13.3-u1
