Reporting and general settings display the correct local time. Dashboard is displaying UTC.
You cut off the timezone info in your image
Why does that matter? You can work it out from the image anyway. 21-10= +11. But ot is irrelevant.
It’s to determin if there’s a problem with the TZ your bios should be set to and the TZ the truenas gui uses.
The bios time should be set to UTC and the gui TZ should be set to your actual TZ.
