Transmission won't start
Hi, as the title says, my transmission hasn’t started for a month now. Before that, it was working well. I’ve tried reinstalling it a few times, but the issue remains the same. I don’t see any error messages—just that the app is deploying. However, it’s been a few days, so I don’t think I need to wait any longer.
Warmly
Same Transmission deployment problem happened to me on Truenas 24.04.2 but this was after I moved the ix-applications dataset to a different pool. So I switched to installing Deluge which has worked flawlessly for several weeks now.
Hi, thanks for the tip! Deluge is working for me.
If anyone knows how to get Transmission working again, I’m open to suggestions, but for now, Deluge is doing the job.
Warmly
You’re not getting replies because you didn’t provide any details to build on.
  • What specific version of SCALE are you running?
  • What happened a month ago? Did you update something, restart, change your network in some way?
  • How did you install Transmission? Official app, custom app, in a docker jail, VM?
At this point we don’t know much more than that you can’t use Transmission and that you run some version of SCALE.
Yes, sorry I didn’t provide more details earlier. I’m running TrueNAS Scale Dragonfish-24.04.2.5. When it arrived, I deleted every snapshot of my ixapplication folder, and since then, one of my Nextcloud instances hasn’t worked properly—just like Transmission. I installed Transmission using the official app.
Warmly
this is my “Related Kubernetes Events”:
2024-12-29 19:05:39 Error: ImagePullBackOff
2024-12-29 19:05:39 Back-off pulling image “ghcr.io/onedr0p/transmission:4.0.5”
2024-12-29 19:05:38 Add eth0 [172.16.107.214/16] from ix-net
2024-12-29 19:05:38 Pulling image “ghcr.io/onedr0p/transmission:4.0.5”
2024-12-29 19:05:38 Failed to pull image “ghcr.io/onedr0p/transmission:4.0.5”: rpc error: code = Unknown desc = failed to pull and unpack image “ghcr.io/onedr0p/transmission:4.0.5”: failed to resolve reference “ghcr.io/onedr0p/transmission:4.0.5”: failed to authorize: failed to fetch anonymous token: unexpected status from GET request to https://ghcr.io/token?scope=repository%3Aonedr0p%2Ftransmission%3Apull&service=ghcr.io: 403 Forbidden
2024-12-29 19:05:38 Error: ErrImagePull
2024-12-29 19:05:37 Scaled up replica set transmission-fdbcdf5d8 to 1
2024-12-29 19:05:37 Successfully assigned ix-transmission/transmission-fdbcdf5d8-dg5bw to ix-truenas
2024-12-29 19:05:37 Created pod: transmission-fdbcdf5d8-dg5bw
Transmission was dropped by that maintainer (onedr0p) back in March:
Since 24.04.2 Kubernetes-based apps are likely not being maintained anymore you are not going to be able to get a replacement app through official means.
Either upgrade to 24.10.X and it’s Docker-based apps or install Transmission as a Custom App using a container that is maintained, linuxserver has one for example.
Hi, thanks! I hadn’t noticed that.
I’ve upgraded to 24.10.X, so now it’s working (and it also allowed me to do some other things. I’m not entirely sure why I updated but, why not ? :joy:).
Warmly
