TrueNAS 25.10 Instances section is not visible in main UI
TrueNAS 25.10.0 Enterprise, fresh install
  • midclt call virt.global.config shows state “INITIALIZED” with pool set to RAIDZ2-pool
  • incusd is running (ps aux | grep incus shows the daemon)
  • Containers work fine via CLI (incus launch, incus list all functional)
  • Default profile was missing root disk device (had to manually add it)
  • The “Instances” menu item never appears in the sidebar, even after middleware restart and browser hard refresh
  • Direct navigation to /ui/instances or /ui/virtualization redirects to signin
When I’m adding container with cli it is running and works fine, but I need a UI to manage it
root@truenas[/home/truenas_admin]# incus profile device add default root disk path=/ pool=default
Device root added to default root@truenas[/home/truenas_admin]# incus launch images:ubuntu/noble HK-VHR01
Launching HK-VHR01 root@truenas[/home/truenas_admin]# incus config set HK-VHR01 limits.cpu=4
incus config set HK-VHR01 limits.memory=20GB
root@truenas[/home/truenas_admin]# incus list
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS |
| HK-VHR01 | RUNNING | 10.157.143.15 (eth0) | fd42:9e8b:30b3:8b88:1266:6aff:feb0:e54a (eth0) | CONTAINER | 0 |
Regards,
MarvinFS
You’re looking for the Containers and Virtual Machines screens in 25.10. Direct paths would be /ui/containers and /ui/vm.
Thank you. That helped I was able to initialize and add the container but it is still not showing on the menu al the left. Something I can do about it?
/ui/containers
Containers
Experimental
Initialized
Name
Autostart
CPU
RAM
Disk I/O
Controls
VN-VHR01
Running
Yes
N/A
N/A
N/A
It should be there. You could try a hard refresh (ctrl+F5) to clear cached cookies from your browser. That’s known to create some UI misbehavior after an upgrade.
I have already tried restarting the server and different PC (clean) to accessthe UI
Tha’t’s all I see in the menu
Dashboard
Storage
Datasets
Shares
Data Protection
Credentials
Reporting
System
Missing Containers VMs and Apps
wasn’t the container section disabled in enterprise because it was still labeled experimental?
Oh wait did you say this is an Enterprise system? Virtualization features are not enabled by default in Enterprise unless licensed.
Oh ghm… :slight_smile:
That is what I see under the license - how can I tell if that’s licensed? I mean it kinda works only when I access it directly not via UI. We probably can fetch different license that’s not a problem, but I need to know which one
Platform: Generic
Edition: Enterprise
Version: 25.10.0 - Goldeye
Support License: Bronze Contract, Expires on 2026-03-04
Hostname: truenas
Features:
Contract Type:Bronze
Expiration Date:2026-03-04 (expires in 19 days)
Model:M30
System Serial:123456789
Licensed Serials:
Additional Hardware:NONE
You would have to contact Enterprise support to discuss adding virtualization features to your license: TrueNAS Customer Support | Open Enterprise Storage.
Thank you very much for swift and detailed support
