TrueNAS Scale Pool not working or showing up
So I was out of town and had my TrueNAS Server (24.10.2.4) throw hard drive errors. I sent over someone I thought was knowledgeable in TrueNAS, but I was wrong. He started pulling out the wrong hard drives while it was on and then just putting them back in and then didn’t fix a thing and caused problems.
When I got back I had this error from my SMB " SMB shares have path-related configuration issues that may impact service stability: SecretData: Path does not exist."
Also I had to export the pool (MainNAS) from the shell. It doesn’t show a path to MainNAS anymore either.
Next I changed the hard drives and let them resilver (been 8 days, finally done).
MY ZFS Health is bad. I am getting checksum errors.I have this message too " Critical
Pool MainNAS state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected."
I have 8 drives and RAIDZ2 in it.
I can provide any information needed.
My 2 main questions are, Is the data gone forever? And if the answer is no, then how can I recover the server…
Here is my zpool status
root@truenas[~]# zpool status -v
  pool: MainNAS
 state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: resilvered 8.51T in 1 days 16:06:16 with 6 errors on Tue Sep 23 01:31:51 2025
        NAME                                      STATE     READ WRITE CKSUM
        MainNAS                                   ONLINE       0     0     0
          raidz2-0                                ONLINE       0     0     0
            b280a980-dfe3-4fdc-ae6f-c3eea97fe9ac  ONLINE       0     0 83.6K
            sdc1                                  ONLINE       0     0 83.6K
            sdf2                                  ONLINE       0     0 83.6K
            sde2                                  ONLINE       0     0 83.6K
            0eb843ed-2c1b-4755-b134-f5eda82a893e  ONLINE       0     0 47.5K
            sdg2                                  ONLINE       0     0 83.6K
            fce004e2-1ea5-4e85-82b4-8629a74deccd  ONLINE       0     0 61.2K
            d0d7281e-b043-45ef-9335-730c13a2994b  ONLINE       0     0 83.6K
        /var/db/system/netdata/dbengine-tier1/datafile-1-0000000083.ndf
        /var/db/system/netdata/dbengine/datafile-1-0000000589.ndf
        /var/db/system/netdata/dbengine/journalfile-1-0000000589.njf
        MainNAS/MediaData/SecretData:/Movies/Eight and a Half (1963) Criterion.SDR.2160p.UHD.BluRay.x265.HEVC.FLAC-SARTRE/Eight.and.a.Half.1963.Criterion.SDR.2160p.UHD.BluRay.x265.HEVC.FLAC-SARTRE.mkv
  pool: boot-pool
 state: ONLINE
status: One or more features are enabled on the pool despite not being
        requested by the 'compatibility' property.
action: Consider setting 'compatibility' to an appropriate value, or
        adding needed features to the relevant file in
        /etc/zfs/compatibility.d or /usr/share/zfs/compatibility.d.
  scan: scrub repaired 0B in 00:00:18 with 0 errors on Thu Sep 18 03:45:19 2025
        boot-pool    ONLINE       0     0     0
          nvme0n1p2  ONLINE       0     0     0
errors: No known data errors
Pls provide complete server details. Also how the drives are connected, and if this is a virtual instance or bare metal.
Also on my dashboard the CPU Overview (AMD Ryzen 7 2700X Eight-Core Processor), Memory (32GB) and Interface show absolutely nothing.
Checksum errors like this can stem from bad cabling, overheating/failing controller or failing PSU.
Do the checksum error counters increase? If not, it might have been a transient issue. Error counters can be reset using zpool clear.
Did you check if data is missing? I know the SMB share seems to be broken, but take a look at the list of datasets and space usage. Maybe post zfs list -r MainNAS here.
TrueNAS Scale 24.10.2.4
It is bare metal.
32GB
8 x 12TB Hard drives (all CMR, Seagate, Toshiba, WD NAS Drives)
1 256GB NVME (boot)
Asus TUF GAMING X570-PLUS (WI-FI) Motherboard
The checksum errors go up.
Welcome to TrueNAS
Last login: Tue Sep 23 15:14:53 CDT 2025 on pts/11
root@truenas[~]# zfs list -r MainNAS
NAME                                                       USED  AVAIL  REFER  MOUNTPOINT
MainNAS                                                   49.5T  12.5T   239K  /MainNAS
MainNAS/.system                                           2.03G  12.5T  1.47G  legacy
MainNAS/.system/configs-18223eeaa8704d9bbd5b2bfcbad77410  61.4M  12.5T  61.4M  legacy
MainNAS/.system/configs-a62da19985ae44c39132517d2464c41d  86.1M  12.5T  85.7M  legacy
MainNAS/.system/cores                                      109M   915M   109M  legacy
MainNAS/.system/netdata-18223eeaa8704d9bbd5b2bfcbad77410   186M  12.5T   186M  legacy
MainNAS/.system/nfs                                        222K  12.5T   222K  legacy
MainNAS/.system/rrd-18223eeaa8704d9bbd5b2bfcbad77410      49.1M  12.5T  49.1M  legacy
MainNAS/.system/rrd-a62da19985ae44c39132517d2464c41d      72.5M  12.5T  34.1M  legacy
MainNAS/.system/samba4                                    2.32M  12.5T  1.66M  legacy
MainNAS/.system/services                                   205K  12.5T   205K  legacy
MainNAS/.system/syslog-18223eeaa8704d9bbd5b2bfcbad77410   2.08M  12.5T  2.08M  legacy
MainNAS/.system/syslog-a62da19985ae44c39132517d2464c41d   7.67M  12.5T  7.67M  legacy
MainNAS/.system/webui                                      205K  12.5T   205K  legacy
MainNAS/MediaData                                         49.5T  12.5T   205K  /MainNAS/MediaData
MainNAS/MediaData/SecretData                              49.5T  12.5T  49.5T  /MainNAS/MediaData/SecretData
MainNAS/MediaData/TVShows                                  205K  12.5T   205K  /MainNAS/MediaData/TVShows
MainNAS/iocage                                            12.7M  12.5T  11.5M  /MainNAS/iocage
MainNAS/iocage/download                                    205K  12.5T   205K  /MainNAS/iocage/download
MainNAS/iocage/images                                      205K  12.5T   205K  /MainNAS/iocage/images
MainNAS/iocage/jails                                       205K  12.5T   205K  /MainNAS/iocage/jails
MainNAS/iocage/log                                         205K  12.5T   205K  /MainNAS/iocage/log
MainNAS/iocage/releases                                    205K  12.5T   205K  /MainNAS/iocage/releases
MainNAS/iocage/templates                                   205K  12.5T   205K  /MainNAS/iocage/templates
root@truenas[~]# 2025 Sep 23 15:17:18 truenas Process 1336148 (netdata) of user 999 dumped core.
Stack trace of thread 1336148:
Mountpoints are a bit odd. But you should be able to see your data if you browse /MainNAS/MediaData.
Could you please check the Path in your share configuration?
Your pool did manage to resilver 8.51T, so I’d guess your data is likely OK (except for the files with permament errors).
If checksum counters go up on all drives that does indicate hardware error, but probably not the hard drives themselves.
This is the SMB PATH
/mnt/MainNAS/MediaData/SecretData
When I save or edit I get this
[EINVAL] sharingsmb_update.path_local: Path does not exist.
It looks like you or your “TrueNAS expert” changed the pool mountpoint.
Set the correct mountpoint using this command:
  • zfs set mountpoint=/mnt/MainNAS MainNAS
Afterwards, check using zfs list -r MainNAS that all mountpoints start with /mnt/MainNAS (you can ignore the legacy values).
Might have to restart SMB after that.
EDIT: Reading some other posts, that might not be the best procedure to fix mountpoints in TrueNAS. At least according to this post: Imported pool mounting in wrong location after upgrade (/mnt/mnt/spinpool)
Yeah I won’t let him touch any of my electronics anymore, not even the TV remote.
It won’t let me restart SMB
Is there something I need to redirect?
If I delete the SMB and start a new one, will it erase the data?
And when going to datasets in GUI it gives out errors (which I assume are due to mounting)
I think I was wrong, TrueNAS sometimes uses altroot during import.
What error did you get in the GUI?
Can you check if anything is mounted at all? I.e. check the following output:
  • mount | grep MainNAS
Also can you check dmesg output?
As was previously suggested by @Farout, check cabling / heat / etc.
When running mount
root@truenas[~]# mount | grep MainNAS
MainNAS/.system on /var/db/system type zfs (rw,relatime,xattr,noacl,casesensitive)
MainNAS/.system/cores on /var/db/system/cores type zfs (rw,relatime,xattr,noacl,casesensitive)
MainNAS/.system/nfs on /var/db/system/nfs type zfs (rw,relatime,xattr,noacl,casesensitive)
MainNAS/.system/samba4 on /var/db/system/samba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
MainNAS/.system/configs-18223eeaa8704d9bbd5b2bfcbad77410 on /var/db/system/configs-18223eeaa8704d9bbd5b2bfcbad77410 type zfs (rw,relatime,xattr,noacl,casesensitive)
MainNAS/.system/netdata-18223eeaa8704d9bbd5b2bfcbad77410 on /var/db/system/netdata type zfs (rw,relatime,xattr,noacl,casesensitive)
MainNAS/.system/cores on /var/lib/systemd/coredump type zfs (rw,relatime,xattr,noacl,casesensitive)
the dmesg output is long and looks like BUS errors… Here is a small sample
[349299.698164] sd 0:0:0:0: [sdb] tag#19 Sense Key : Medium Error [current]
[349299.698168] sd 0:0:0:0: [sdb] tag#19 Add. Sense: Read retries exhausted
[349299.698172] sd 0:0:0:0: [sdb] tag#19 CDB: Read(16) 88 00 00 00 00 00 06 22 c6 b0 00 00 01 e0 00 00
[349299.698175] critical medium error, dev sdb, sector 102942856 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[349299.698599] zio pool=MainNAS vdev=/dev/sdb2 error=61 type=1 offset=50558951424 size=245760 flags=1074267304
[349299.699038] ata1: EH complete
[349302.848897] ata1.00: exception Emask 0x0 SAct 0x80004800 SErr 0x0 action 0x0
[349302.849342] ata1.00: irq_stat 0x40000008
[349302.849770] ata1.00: failed command: READ FPDMA QUEUED
[349302.850203] ata1.00: cmd 60/30:f8:60:c8:22/00:00:06:00:00/40 tag 31 ncq dma 24576 in
                         res 43/40:30:88:c8:22/00:00:06:00:00/40 Emask 0x408 (media error) <F>
[349302.851102] ata1.00: status: { DRDY SENSE ERR }
[349302.851550] ata1.00: error: { UNC }
[349303.266119] ata1.00: configured for UDMA/133
[349303.266147] sd 0:0:0:0: [sdb] tag#31 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[349303.266153] sd 0:0:0:0: [sdb] tag#31 Sense Key : Medium Error [current]
[349303.266157] sd 0:0:0:0: [sdb] tag#31 Add. Sense: Read retries exhausted
[349303.266161] sd 0:0:0:0: [sdb] tag#31 CDB: Read(16) 88 00 00 00 00 00 06 22 c8 60 00 00 00 30 00 00
[349303.266164] critical medium error, dev sdb, sector 102942856 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[349303.266656] zio pool=MainNAS vdev=/dev/sdb2 error=61 type=1 offset=50559172608 size=24576 flags=1605801
[349303.267161] ata1: EH complete
[351267.830251] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[351267.830265] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[351267.831139] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[351267.831530] pcieport 0000:00:01.2:    [12] Timeout
[351352.113269] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8534 of 11377 items, 6553600 file size, 767 bytes per hash table item), suggesting rotation.
[351352.113279] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[352343.998874] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[352343.998887] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[352343.999787] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[352344.000210] pcieport 0000:00:01.2:    [12] Timeout
[354398.409143] ata1.00: exception Emask 0x10 SAct 0x20082 SErr 0x90202 action 0xe frozen
[354398.409604] ata1.00: irq_stat 0x00400000, PHY RDY changed
[354398.410039] ata1: SError: { RecovComm Persist PHYRdyChg 10B8B }
[354398.410470] ata1.00: failed command: READ FPDMA QUEUED
[354398.410898] ata1.00: cmd 60/58:08:50:5a:8d/00:00:7b:02:00/40 tag 1 ncq dma 45056 in
                         res 40/00:01:01:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[354398.411774] ata1.00: status: { DRDY }
[354398.412199] ata1.00: failed command: READ FPDMA QUEUED
[354398.412629] ata1.00: cmd 60/98:38:30:53:8d/01:00:7b:02:00/40 tag 7 ncq dma 208896 in
                         res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[354398.413501] ata1.00: status: { DRDY }
[354398.413923] ata1.00: failed command: READ FPDMA QUEUED
[354398.414348] ata1.00: cmd 60/58:88:38:5b:8d/00:00:7b:02:00/40 tag 17 ncq dma 45056 in
                         res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[354398.415240] ata1.00: status: { DRDY }
[354398.415689] ata1: hard resetting link
[354399.141128] ata1: SATA link down (SStatus 0 SControl 300)
[354404.249586] ata1: hard resetting link
[354404.563911] ata1: SATA link down (SStatus 0 SControl 300)
[354404.563929] ata1: limiting SATA link speed to <unknown>
[354409.625475] ata1: hard resetting link
[354409.941226] ata1: SATA link down (SStatus 0 SControl 3F0)
[354409.941242] ata1.00: disable device
[354409.941689] sd 0:0:0:0: [sdb] tag#1 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=11s
[354409.941695] sd 0:0:0:0: [sdb] tag#1 Sense Key : Illegal Request [current]
[354409.941699] sd 0:0:0:0: [sdb] tag#1 Add. Sense: Unaligned write command
[354409.941704] sd 0:0:0:0: [sdb] tag#1 CDB: Read(16) 88 00 00 00 00 02 7b 8d 5a 50 00 00 00 58 00 00
[354409.941707] I/O error, dev sdb, sector 10662795856 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 2
[354409.942136] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=5457203929088 size=45056 flags=1074267304
[354409.942594] sd 0:0:0:0: [sdb] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=11s
[354409.942598] sd 0:0:0:0: [sdb] tag#7 Sense Key : Illegal Request [current]
[354409.942602] sd 0:0:0:0: [sdb] tag#7 Add. Sense: Unaligned write command
[354409.942606] sd 0:0:0:0: [sdb] tag#7 CDB: Read(16) 88 00 00 00 00 02 7b 8d 53 30 00 00 01 98 00 00
[354409.942608] I/O error, dev sdb, sector 10662794032 op 0x0:(READ) flags 0x0 phys_seg 25 prio class 2
[354409.942662] sd 0:0:0:0: rejecting I/O to offline device
[354409.943060] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=5457202995200 size=208896 flags=1074267304
[354409.943517] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[354409.943996] sd 0:0:0:0: [sdb] tag#17 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=11s
[354409.944085] I/O error, dev sdb, sector 10662796880 op 0x0:(READ) flags 0x0 phys_seg 3 prio class 2
[354409.944093] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=5457204453376 size=45056 flags=1074267304
[354409.944107] I/O error, dev sdb, sector 10662798576 op 0x0:(READ) flags 0x0 phys_seg 20 prio class 2
[354409.944112] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=5457205321728 size=208896 flags=1074267304
[354409.944137] I/O error, dev sdb, sector 4194960 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[354409.944142] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=270336 size=8192 flags=721089
[354409.944163] I/O error, dev sdb, sector 23437769360 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[354409.944167] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=11997990363136 size=8192 flags=721089
[354409.944184] I/O error, dev sdb, sector 23437769872 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[354409.944189] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=11997990625280 size=8192 flags=721089
[354409.944522] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=5 offset=0 size=0 flags=1049728
[354409.945126] sd 0:0:0:0: [sdb] tag#17 Sense Key : Illegal Request [current]
[354409.952389] sd 0:0:0:0: [sdb] tag#17 Add. Sense: Unaligned write command
[354409.952395] sd 0:0:0:0: [sdb] tag#17 CDB: Read(16) 88 00 00 00 00 02 7b 8d 5b 38 00 00 00 58 00 00
[354409.952398] I/O error, dev sdb, sector 10662796088 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 2
[354409.952404] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=5457204047872 size=45056 flags=1074267304
[354409.952420] ata1: EH complete
[354409.954136] ata1.00: detaching (SCSI 0:0:0:0)
[354410.375787] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8533 of 11377 items, 6553600 file size, 768 bytes per hash table item), suggesting rotation.
[354410.375798] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[354410.408359] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=270336 size=8192 flags=721601
[354410.408922] zio pool=MainNAS vdev=/dev/sdb2 error=5 type=1 offset=11997990363136 size=8192 flags=721601
[354417.061512] ata1: link is slow to respond, please be patient (ready=0)
[354421.305620] ata1: found unknown device (class 0)
[354421.465606] ata1: softreset failed (device not ready)
[354427.209765] ata1: link is slow to respond, please be patient (ready=0)
[354428.461779] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[354428.462533] ata1.00: ATA-11: WDC WD120EFGX-68CPHN0, 85.00B85, max UDMA/133
[354428.501949] ata1.00: 23437770752 sectors, multi 16: LBA48 NCQ (depth 32), AA
[354428.532463] ata1.00: Features: NCQ-sndrcv NCQ-prio
[354428.603064] ata1.00: configured for UDMA/133
[354428.603241] scsi 0:0:0:0: Direct-Access     ATA      WDC WD120EFGX-68 0B85 PQ: 0 ANSI: 5
[354428.604267] sd 0:0:0:0: Attached scsi generic sg0 type 0
[354428.604825] sd 0:0:0:0: [sdb] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB)
[354428.605348] sd 0:0:0:0: [sdb] 4096-byte physical blocks
[354428.605910] sd 0:0:0:0: [sdb] Write Protect is off
[354428.606435] sd 0:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[354428.606482] sd 0:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[354428.607074] sd 0:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[354428.650572]  sdb: sdb1
[354428.650753] sd 0:0:0:0: [sdb] Attached SCSI removable disk
[357556.991412] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8534 of 11377 items, 6553600 file size, 767 bytes per hash table item), suggesting rotation.
[357556.991421] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[360997.600828] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[360997.600845] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[360997.601724] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[360997.602078] pcieport 0000:00:01.2:    [12] Timeout
[361305.068833] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8534 of 11377 items, 6553600 file size, 767 bytes per hash table item), suggesting rotation.
[361305.068845] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[361863.460645] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[361863.460657] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[361863.461388] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[361863.461772] pcieport 0000:00:01.2:    [12] Timeout
[365015.160107] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8533 of 11377 items, 6553600 file size, 768 bytes per hash table item), suggesting rotation.
[365015.160118] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[368792.350588] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8533 of 11377 items, 6553600 file size, 768 bytes per hash table item), suggesting rotation.
[368792.350597] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[370311.861467] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[370311.861481] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[370311.862206] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[370311.862584] pcieport 0000:00:01.2:    [12] Timeout
[371820.418998] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[371820.419010] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[371820.419717] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[371820.420090] pcieport 0000:00:01.2:    [12] Timeout
[372316.367106] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8534 of 11377 items, 6553600 file size, 767 bytes per hash table item), suggesting rotation.
[372316.367117] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[376100.787510] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8533 of 11377 items, 6553600 file size, 768 bytes per hash table item), suggesting rotation.
[376100.787522] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[379733.344574] systemd-journald[811]: Data hash table of /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal has a fill level at 75.0 (8535 of 11377 items, 6553600 file size, 767 bytes per hash table item), suggesting rotation.
[379733.344586] systemd-journald[811]: /var/log/journal/307cf3a6682e44f8ae785b09498d37b3/system.journal: Journal header limits reached or header out-of-date, rotating.
[380484.188229] pcieport 0000:00:01.2: AER: Corrected error message received from 0000:00:00.0
[380484.188253] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[380484.189320] pcieport 0000:00:01.2:   device [1022:1453] error status/mask=00001000/00006000
[380484.189723] pcieport 0000:00:01.2:    [12] Timeout
[383406.241985] systemd-journald[811]: Data h
If I can get the pool recovered I will replace the hardware this weekend. I am trying to figure what data is left or not before replacing hardware. Though if I have to replace hardware first, I can get on that.
When trying to access dataset in Gui I get CallError
[ENOENT] Path /MainNAS not found
[EFAULT] Failed retreiving USER quotas for MainNAS
Don’t think I would proceed with the current hardware setup. At least check if all cables are connected properly.
Also I use this case
SilverStone Technology CS380 8-Bay Compact ATX Tower case, CS380B-X V2.0, Black
I would add potentially bad RAM to that list, although the medium errors in that dmesg are concerning. The output of smartctl -a /dev/sdX from the drives may shed some light on if that Silverstone case is acting like an oven, they have a habit of doing that.
My line of thinking is that until the hardware issue has been solved I would avoid doing anything more with the drives on the software layer. Something is causing a large number of checksum errors, any further activity may hit critical metadata sections causing the pool to become unusable.
root@truenas[~]# smartctl -a /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Toshiba N300/MN NAS HDD
Device Model:     TOSHIBA HDWG21C
Serial Number:    X0B0A00FFPBG
LU WWN Device Id: 5 000039 a78ca0f93
Firmware Version: 0601
User Capacity:    12,000,138,625,024 bytes [12.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5852
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Sep 23 18:20:11 2025 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (  120) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1211) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       7246
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       74
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   021   021   000    Old_age   Always       -       31996
 10 Spin_Retry_Count        0x0033   100   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       74
 23 Helium_Condition_Lower  0x0023   100   087   075    Pre-fail  Always       -       0
 24 Helium_Condition_Upper  0x0023   100   100   075    Pre-fail  Always       -       0
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       34
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       55
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       75
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       31 (Min/Max 14/77)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       2228225
222 Loaded_Hours            0x0032   021   021   000    Old_age   Always       -       31996
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       596
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     31983         -
# 2  Short offline       Completed without error       00%     31959         -
# 3  Short offline       Completed without error       00%     31935         -
# 4  Short offline       Completed without error       00%     31911         -
# 5  Short offline       Completed without error       00%     31887         -
# 6  Short offline       Completed without error       00%     31862         -
# 7  Short offline       Completed without error       00%     31838         -
# 8  Short offline       Completed without error       00%     31814         -
# 9  Short offline       Completed without error       00%     31791         -
#10  Short offline       Completed without error       00%     31768         -
#11  Short offline       Completed without error       00%     31744         -
#12  Short offline       Completed without error       00%     31720         -
#13  Short offline       Completed without error       00%     31696         -
#14  Short offline       Completed without error       00%     31692         -
#15  Short offline       Completed without error       00%     31675         -
#16  Short offline       Completed without error       00%     31651         -
#17  Short offline       Completed without error       00%     31627         -
#18  Short offline       Completed without error       00%     31603         -
#19  Short offline       Completed without error       00%     31579         -
#20  Short offline       Completed without error       00%     31555         -
#21  Short offline       Completed without error       00%     31531         -
The above only provides legacy SMART information - try 'smartctl -x' for more
root@truenas[~]#
root@truenas[~]# smartctl -a /dev/sdb
Model Family:     Seagate IronWolf
Device Model:     ST12000VN0008-2YS101
Serial Number:    ZRT05CS0
LU WWN Device Id: 5 000c50 0e3e2b399
Firmware Version: SC60
ATA Version is:   ACS-4 (minor revision not indicated)
Local Time is:    Tue Sep 23 18:20:37 2025 CDT
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  559) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        (1048) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       148241266
  3 Spin_Up_Time            0x0003   093   090   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       26
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   089   060   045    Pre-fail  Always       -       729529553
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       7799
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       26
 18 Head_Health             0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       0 3 3
190 Airflow_Temperature_Cel 0x0022   070   032   000    Old_age   Always       -       30 (Min/Max 28/30)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       12
193 Load_Cycle_Count        0x0032   089   089   000    Old_age   Always       -       22656
194 Temperature_Celsius     0x0022   030   068   000    Old_age   Always       -       30 (0 23 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Pressure_Limit          0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       6166h+10m+08.801s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       69415101325
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       153539837592375
No Errors Logged
# 1  Short offline       Completed without error       00%      7786         -
# 2  Short offline       Completed without error       00%      7762         -
# 3  Short offline       Completed without error       00%      7738         -
# 4  Short offline       Completed without error       00%      7714         -
# 5  Short offline       Completed without error       00%      7690         -
# 6  Short offline       Completed without error       00%      7665         -
# 7  Short offline       Completed without error       00%      7641         -
# 8  Short offline       Completed without error       00%      7617         -
# 9  Short offline       Completed without error       00%      7593         -
#10  Short offline       Completed without error       00%      7571         -
#11  Short offline       Completed without error       00%      7547         -
#12  Short offline       Completed without error       00%      7523         -
#13  Short offline       Completed without error       00%      7499         -
#14  Short offline       Completed without error       00%      7494         -
#15  Short offline       Completed without error       00%      7477         -
#16  Short offline       Completed without error       00%      7453         -
#17  Short offline       Completed without error       00%      7429         -
#18  Short offline       Completed without error       00%      7405         -
#19  Short offline       Completed without error       00%      7381         -
#20  Short offline       Completed without error       00%      7357         -
#21  Short offline       Completed without error       00%      7333         -
smartctl -a /dev/sdc
Model Family:     Western Digital Red Plus
Device Model:     WDC WD120EFGX-68CPHN0
Serial Number:    WD-B00L9H2D
LU WWN Device Id: 5 0014ee 2c183e8e4
Firmware Version: 85.00B85
ATA Version is:   ACS-4 published, ANSI INCITS 529-2018
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Sep 23 18:20:59 2025 CDT
Warning! SMART Attribute Thresholds Structure error: invalid SMART checksum.
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (27764) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 929) minutes.
recommended polling time:        (   6) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0024   100   100   000    Old_age   Offline      -       0
  3 Spin_Up_Time            0x0027   179   179   021    Pre-fail  Always       -       12033
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       14
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0024   100   100   000    Old_age   Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       123
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       14
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       10
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       3
194 Temperature_Celsius     0x0022   118   086   000    Old_age   Always       -       34
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   100   000    Old_age   Offline      -       0
No Errors Logged
# 1  Short offline       Completed without error       00%       110         -
# 2  Short offline       Completed without error       00%        86         -
# 3  Short offline       Completed without error       00%        62         -
# 4  Short offline       Completed without error       00%        38         -
# 5  Short offline       Completed without error       00%        14         -
# 6  Short offline       Completed without error       00%         2         -
# 7  Short offline       Completed without error       00%         0         -
root@truenas[~]# smartctl -a /dev/sdd
Serial Number:    WD-B00L9YRD
LU WWN Device Id: 5 0014ee 216d899b7
Local Time is:    Tue Sep 23 18:21:28 2025 CDT
                                        was never started.
                                        been run.
data collection:                (26804) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 919) minutes.
  3 Spin_Up_Time            0x0027   175   175   021    Pre-fail  Always       -       12241
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       12
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       270
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       12
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       8
194 Temperature_Celsius     0x0022   119   079   000    Old_age   Always       -       33
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
No Errors Logged
# 1  Short offline       Completed without error       00%       257         -
# 2  Short offline       Completed without error       00%       233         -
# 3  Short offline       Completed without error       00%       209         -
# 4  Short offline       Completed without error       00%       185         -
# 5  Short offline       Completed without error       00%       161         -
# 6  Short offline       Completed without error       00%       136         -
# 7  Short offline       Completed without error       00%       112         -
# 8  Short offline       Completed without error       00%        88         -
# 9  Short offline       Completed without error       00%        64         -
#10  Short offline       Completed without error       00%        42         -
#11  Short offline       Completed without error       00%        18         -
smartctl -a /dev/sde
Model Family:     Seagate IronWolf Pro
Device Model:     ST12000NE0008-2JL101
Serial Number:    ZHZ6GFCM
LU WWN Device Id: 5 000c50 0c570779a
Firmware Version: EN01
Local Time is:    Tue Sep 23 18:21:51 2025 CDT
See vendor-specific Attribute list for marginal Attributes.
                                        been run.
data collection:                (  567) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        (1173) minutes.
  1 Raw_Read_Error_Rate     0x000f   084   064   044    Pre-fail  Always       -       237538462
  3 Spin_Up_Time            0x0003   092   089   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       74
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       954238849
  9 Power_On_Hours          0x0032   064   064   000    Old_age   Always       -       31999
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       74
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       0 6 6
190 Airflow_Temperature_Cel 0x0022   067   020   040    Old_age   Always   In_the_past 33 (101 104 33 29 0)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       51
193 Load_Cycle_Count        0x0032   084   084   000    Old_age   Always       -       33825
194 Temperature_Celsius     0x0022   033   080   000    Old_age   Always       -       33 (0 15 0 0 0)
195 Hardware_ECC_Recovered  0x001a   084   064   000    Old_age   Always       -       237538462
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       29380h+54m+26.432s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       110005009133
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1559756645964
No Errors Logged
# 1  Short offline       Completed without error       00%     31985         -
# 2  Short offline       Completed without error       00%     31961         -
# 3  Short offline       Completed without error       00%     31937         -
# 4  Short offline       Completed without error       00%     31913         -
# 5  Short offline       Completed without error       00%     31889         -
# 6  Short offline       Completed without error       00%     31865         -
# 7  Short offline       Completed without error       00%     31841         -
# 8  Short offline       Completed without error       00%     31817         -
# 9  Short offline       Completed without error       00%     31793         -
#10  Short offline       Completed without error       00%     31771         -
#11  Short offline       Completed without error       00%     31747         -
#12  Short offline       Completed without error       00%     31723         -
#13  Short offline       Completed without error       00%     31699         -
#14  Short offline       Completed without error       00%     31694         -
#15  Short offline       Completed without error       00%     31677         -
#16  Short offline       Completed without error       00%     31653         -
#17  Short offline       Completed without error       00%     31629         -
#18  Short offline       Completed without error       00%     31605         -
#19  Short offline       Completed without error       00%     31581         -
#20  Short offline       Completed without error       00%     31557         -
#21  Short offline       Completed without error       00%     31533         -
root@truenas[~]# smartctl -a /dev/sdf
Serial Number:    ZHZ6GF1H
LU WWN Device Id: 5 000c50 0c5702da4
Local Time is:    Tue Sep 23 18:22:11 2025 CDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1174) minutes.
  1 Raw_Read_Error_Rate     0x000f   083   064   044    Pre-fail  Always       -       202029102
  3 Spin_Up_Time            0x0003   091   089   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       75
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       913467413
  9 Power_On_Hours          0x0032   064   064   000    Old_age   Always       -       31998
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       75
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       0 7 7
190 Airflow_Temperature_Cel 0x0022   067   017   040    Old_age   Always   In_the_past 33 (107 197 33 29 0)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       53
193 Load_Cycle_Count        0x0032   083   083   000    Old_age   Always       -       34063
194 Temperature_Celsius     0x0022   033   083   000    Old_age   Always       -       33 (0 15 0 0 0)
195 Hardware_ECC_Recovered  0x001a   083   064   000    Old_age   Always       -       202029102
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       29361h+22m+10.245s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       110004125085
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1559726314030
No Errors Logged
# 6  Short offline       Completed without error       00%     31864         -
# 7  Short offline       Completed without error       00%     31840         -
# 8  Short offline       Completed without error       00%     31816         -
# 9  Short offline       Completed without error       00%     31792         -
#10  Short offline       Completed without error       00%     31770         -
#11  Short offline       Completed without error       00%     31746         -
#12  Short offline       Completed without error       00%     31722         -
#13  Short offline       Completed without error       00%     31698         -
#14  Short offline       Completed without error       00%     31693         -
#15  Short offline       Completed without error       00%     31691         -
#16  Short offline       Completed without error       00%     31676         -
#17  Short offline       Completed without error       00%     31652         -
#18  Short offline       Completed without error       00%     31628         -
#19  Short offline       Completed without error       00%     31604         -
#20  Short offline       Completed without error       00%     31580         -
#21  Short offline       Completed without error       00%     31556         -
type or paste code heroot@truenas[~]# smartctl -a /dev/sdg
Serial Number:    80D0A08AFPBG
LU WWN Device Id: 5 000039 a58cbd288
Local Time is:    Tue Sep 23 18:22:29 2025 CDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1223) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       7228
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       76
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       76
 23 Helium_Condition_Lower  0x0023   100   100   075    Pre-fail  Always       -       0
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       32
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       57
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       77
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       32 (Min/Max 14/77)
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       236978185
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       595
No Errors Logged
#14  Short offline       Completed without error       00%     31691         -
smartctl -a /dev/sdh
Serial Number:    X010A00AFPBG
LU WWN Device Id: 5 000039 a78c822b5
Local Time is:    Tue Sep 23 18:26:56 2025 CDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1209) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       7077
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       78
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       77
 23 Helium_Condition_Lower  0x0023   100   081   075    Pre-fail  Always       -       0
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       41
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       58
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       79
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       33 (Min/Max 14/79)
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       151388161
ATA Error Count: 65535 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 65535 occurred at disk power-on lifetime: 8913 hours (371 days + 9 hours)
  When the command that caused the error occurred, the device was in standby mode.
  ER ST SC SN CL CH DH
  04 41 98 18 c2 2d 40  Error: ABRT at LBA = 0x002dc218 = 2998808
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 01 30 81 00 40 40 00  47d+08:19:00.642  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  47d+08:19:00.642  READ LOG EXT
  60 01 20 81 00 40 40 00  47d+08:19:00.283  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  47d+08:19:00.283  READ LOG EXT
  60 01 10 81 00 40 40 00  47d+08:18:59.925  READ FPDMA QUEUED
Error 65534 occurred at disk power-on lifetime: 8913 hours (371 days + 9 hours)
  2f 00 01 10 00 00 00 00  47d+08:18:59.925  READ LOG EXT
  60 01 00 81 00 40 40 00  47d+08:18:59.566  READ FPDMA QUEUED
Error 65533 occurred at disk power-on lifetime: 8913 hours (371 days + 9 hours)
  2f 00 01 10 00 00 00 00  47d+08:18:59.566  READ LOG EXT
  60 01 f0 81 00 40 40 00  47d+08:18:59.208  READ FPDMA QUEUED
Error 65532 occurred at disk power-on lifetime: 8913 hours (371 days + 9 hours)
  2f 00 01 10 00 00 00 00  47d+08:18:59.208  READ LOG EXT
  60 01 e0 81 00 40 40 00  47d+08:18:58.850  READ FPDMA QUEUED
Error 65531 occurred at disk power-on lifetime: 8913 hours (371 days + 9 hours)
  2f 00 01 10 00 00 00 00  47d+08:18:58.850  READ LOG EXT
  60 01 d0 81 00 40 40 00  47d+08:18:58.491  READ FPDMA QUEUED
# 6  Short offline       Completed without error       00%     31863         -
# 7  Short offline       Completed without error       00%     31839         -
# 8  Short offline       Completed without error       00%     31815         -
#12  Short offline       Completed without error       00%     31721         -
#13  Short offline       Completed without error       00%     31697         -
#16  Short offline       Completed without error       00%     31652         -
Here are the HD Readouts
