Truenas Scale UPS configuration example SNMPV2
Hello
I’m struggling with a simple UPS configuration using snmpv2. Since there are no options in the UI to add an snmpv2 community string I expect a config is required in “Auxiliary Parameters (ups.conf)”. However I could not find any examples what info is required there and in what form. According to the NUT docs i added
community = MYCOMMUNITYSTRING
snmp_version = v2
but I still dont seem to get a connection. The reporting=> ups is also not showing any infos.
Some general questions I could not find answered in the docs are:
  • how do I verify that the ups is connected at all?
  • where can I find the logs for the UPS NUT service to troubleshoot?
  • what is the “monitor user”? Is it the user used to connect to the UPS?
Thanks in advance for clearing some of my frustration. It seems to be such an easy task but I burned too much time and am starting to questioning this setup.
