Thats just from ethernet, the only way I’m connected right now
I thought the default gateway (192.168.12.1) was my my routers IP I’m i wrong or did they finally block that too
Said that was an invalid request so i took out the -c and its pinging but my computer cant ping it, maybe a restart on my computer? I’m going to go ahead and do that.
Also how do I end the never ending ping loop
Truenas can ping but my computer can not ping. I got on another computer to and it connected no problem and it can ping the router on that one too. That computer is on wifi but its crappy
157 did not work dhcp changed it to 223 I went to HTTP://192.168.12.223 and I can connect to the web interface through there so now I just need to figure out whats up with my main PC not connecting. Thats was the main problem and now that its solved Thank you I was about ready to give and see if windows could connect to the internet the internet
I went and installed TrueNas Scale 22.02.4, When I installed 22.02 earlier it didn’t ask me if I want a fresh install and it did this time
However, changing from 157 to 223 is kinda strange. I thought 157 was a static IP. If it’s really DHCP, there is no (big) problem.
According to your ip a output, your truenas NIC didn’t have a default gateway specified. This means that your truenas won’t have internet access. However, if I were wrong and your NIC is actually set to DHCP, everything should be fine now.
Well, now it is time for a reboot . At least I didn’t notice anything unusual in your ipconfig. But I’m not a network guy.
