This is not a TrueNAS question although it comes up because of a new feature request so I need to ask.
If a person uses an m.2 type WiFi adapter for a WiFi connection (there are so many of them these days). Is that card able to handle a lot of continuous traffic? Will it overheat? Is there a brand that is capable and what brands to stay away from.
I’m asking because I don’t know if these devices are capable of continuous high throughput.
I’m not buying one, I have a nice Asus router running Merlin firmware, very nice, and my NAS is currently using Ethernet. But is is just a question out of left field.
It wouldn’t work. People forget that Wi-Fi advertised speeds are just theoretical, not practical.
TrueNAS (CORE or SCALE) often moves large, continuous datasets. Wi-Fi, even the best, is prone to fluctuations, interference, and sudden drops. This can cause:
Failed transfers
Broken SMB/NFS mounts
Sync corruption on long rsync/ZFS replication jobs
I suspect that antennas and their placement will matter a lot, possibly even more than the adapter chip itself. Which is why a wired access point is likely a better idea than Wi-Fi hardware in the NAS, stashed away in the basement where its noise does not matter…
