How do you have the TrueNAS VM set up in Proxmox? Do you have a HBA and are you passing through the entire controller? Did you blacklist the controller so Proxmox will not mount the TrueNAS ZFS system?
3 weeks ago I fubared and erased all my data on both servers.
Luckily my personal data wa on a 3rd nas box.
My proxmox server was corrupted by a power failure
Hence i rebuilt it from bare metal with proxmox 8. Once up and running i updated to proxmox 9.
I installed all my VM (truenas, home assistant, opnsense(not active)) and cts
onc e everything up in proxmox I passed all the drives to truenas and the usbs to home assistant. That was 3 weeks ago.
Since then i have been loading all my media (454 cds, 110 DVD 160 LPs) . I have only done 60 cd to date.
To your point
No no changes to proxmox sine rebuild. No changes to truenas installation. Prior to this issue. I noticed that a dataset did not have a recycle bin. I edited the dataset and added the recycle bin. To ensure access i opened the dataset ACL and re accepted all the existing acl.
Then I rebooted truenas (from the truenas cli) and this is when all hell broke loose.
So far i created the vm and when i fo to start it the installation shell will not accept my keyboard input.
Things are getting from bad to worse
I am trying a fresh/new install of truenas and once i have the vm configured and i start the vm the console gives me so many boot errors and no keyboard has access to the console regardless if the keyboard is connected to the server or if i’m trying to connect via a web interface from my desktop pc
