Degraded pool with no errors
I’m running TrueNAS scale and have a pool that TrueNAS reports as degraded. The two disks in the pool pass both short and extended SMART tests, however. How can I tell what the issue is?
zpool status is a good start.
Oh and post you system specs - cos otherwise we are guessing
TrueNAS 24.10.0
ASRock Rack X470D4U w/ AMD 3600X
32GB ECC RAM
Pool in question is two 6TB spinners.
pool: butternut
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Replace the faulted device, or use ‘zpool clear’ to mark the device
repaired.
scan: scrub repaired 0B in 09:23:07 with 0 errors on Sun Jun 1 09:23:11 2025
    NAME                                      STATE     READ WRITE CKSUM
    butternut                                 DEGRADED     0     0     0
      mirror-0                                DEGRADED     0     0     0
        d0a3fdb5-fa66-11eb-a822-7085c2fdcbaa  ONLINE       0     0     0
        04ace58e-2d8b-4caf-a1d1-3f0fb5a6c499  FAULTED     20     0     7  too many errors
errors: No known data errors
Mind providing the output of those tests? I can pass an exam with a 51/100; wouldn’t necessarily mean I’m a great rocket surgeon.
If you want to risk it & see if it was just a random flap:
zpool clear #poolname
But considering it is a mirror with only 1 disk of redundancy, it might be worth investigating further.
As for posting images, check your dms. Usually a bot sends you a tutorial & once you get that done, you unlock some features & trust on the forum.
Edit: also considering you have read & checksum errors in your zpool status, this is indeed a degraded pool with errors.
How can I print the SMART output? I’m just looking at the results in the GUI, but I’m guessing there is more info that than somewhere. In the GUI on the pool, it says “Failed S.M.A.R.T. Tests: 0”
Okay, sounds like a new disk or two might be in my future. Anything I should check before I start to replace disks?
Here is output of smartctl -l selftest /dev/ada0
edit - I have no insert key on my keyboard so I can’t copy it, nor am I allowed to upload images yet. Here’s an imgur link.
edit - I can’t share links either.
Switched back to my Mac. Here is the output, with the link in the output removed so I can post it.
`root@truenas[~]# smartctl -l selftest /dev/sde
1 Extended offline Completed without error 00% 37379 -
2 Short offline Completed without error 00% 21887 -`
Check your private messages; a bot should have sent you a tutorial, which once complete you can post images/links
Edit:
Output of:
smartctl -a /dev/sde
Plx & ty
[quote=“Fleshmauler, post:8, topic:45371, full:true”]
Check your private messages; a bot should have sent you a tutorial, which once complete you can post images/links[/quote]
I did get the bot message, but no mention of a tutorial in it. It links to the trust levels, and that documentation page says even at trust level 0 where all users start, you should be able to post up to 1 image and 2 links. So, I’m not sure what’s going on. At least I can just copy/paste from my Mac.
root@truenas[~]# smartctl -a /dev/sde
Model Family:     Western Digital Ultrastar (He10/12)
Device Model:     WDC WD80EMAZ-00WJTA0
Serial Number:    7HKJ8SMN
LU WWN Device Id: 5 000cca 257f1ad57
Firmware Version: 83.H0A83
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5706
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Jun  8 17:04:24 2025 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1114) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   129   129   054    Old_age   Offline      -       112
  3 Spin_Up_Time            0x0007   148   148   024    Pre-fail  Always       -       447 (Average 444)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       231
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   093   093   000    Old_age   Always       -       50454
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       231
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       2317
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       2317
194 Temperature_Celsius     0x0002   166   166   000    Old_age   Always       -       39 (Min/Max 19/50)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       1
SMART Error Log Version: 1
ATA Error Count: 77 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 77 occurred at disk power-on lifetime: 45231 hours (1884 days + 15 hours)
  ER ST SC SN CL CH DH
  40 41 00 00 00 00 00  Error: UNC at LBA = 0x00000000 = 0
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 00 b0 4c 36 40 00   6d+12:23:28.544  READ FPDMA QUEUED
  61 00 10 b0 34 36 40 00   6d+12:23:21.606  WRITE FPDMA QUEUED
  61 00 08 b0 24 36 40 00   6d+12:23:21.606  WRITE FPDMA QUEUED
  61 00 10 b0 3b 36 40 00   6d+12:23:21.604  WRITE FPDMA QUEUED
  61 00 08 b0 3a 36 40 00   6d+12:23:21.604  WRITE FPDMA QUEUED
Error 76 occurred at disk power-on lifetime: 45231 hours (1884 days + 15 hours)
  60 00 08 b0 34 36 40 00   6d+12:23:21.225  READ FPDMA QUEUED
  60 10 28 10 26 81 40 00   6d+12:23:14.284  READ FPDMA QUEUED
  60 10 20 10 24 81 40 00   6d+12:23:14.284  READ FPDMA QUEUED
  60 10 18 10 12 00 40 00   6d+12:23:14.284  READ FPDMA QUEUED
  60 00 10 b0 3c 36 40 00   6d+12:23:14.284  READ FPDMA QUEUED
Error 75 occurred at disk power-on lifetime: 45231 hours (1884 days + 15 hours)
  60 00 08 b0 24 36 40 00   6d+12:23:14.281  READ FPDMA QUEUED
  60 00 00 b0 1c 36 40 00   6d+12:23:00.429  READ FPDMA QUEUED
  60 00 10 b0 14 36 40 00   6d+12:23:00.257  READ FPDMA QUEUED
  60 00 08 b0 0c 36 40 00   6d+12:23:00.257  READ FPDMA QUEUED
  60 00 00 b0 04 36 40 00   6d+12:23:00.257  READ FPDMA QUEUED
Error 74 occurred at disk power-on lifetime: 41056 hours (1710 days + 16 hours)
  60 00 08 78 f1 08 40 00  23d+11:50:54.576  READ FPDMA QUEUED
  60 00 08 78 e9 08 40 00  23d+11:50:46.927  READ FPDMA QUEUED
  60 10 00 10 12 00 40 00  23d+11:50:46.927  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  23d+11:50:46.924  READ LOG EXT
Error 73 occurred at disk power-on lifetime: 41056 hours (1710 days + 16 hours)
  60 00 00 78 e1 08 40 00  23d+11:50:46.924  READ FPDMA QUEUED
  60 10 08 10 12 00 40 00  23d+11:50:39.774  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  23d+11:50:39.750  READ LOG EXT
  61 10 00 10 26 81 40 00  23d+11:50:32.827  WRITE FPDMA QUEUED
# 1  Extended offline    Completed without error       00%     37379         -
# 2  Short offline       Completed without error       00%     21887         -
The above only provides legacy SMART information - try 'smartctl -x' for more
Alright, so seems you had 1 crc error; most of the time this is due to wiring/hba/port.
Would recommend just reseating the sata data cable, clearing the error, and running a scrub. If it happens again, replace the sata data cable, run a scrub.
If it you’re using an HBA make sure it has good airflow (slap a fan on it). If you’re connected directly connected to motherboard, try connecting to a different sata port if available.
Might not hurt reseating sata power.
This is the least bad kind of error & there is a good chance your disk is ok.
Roger, thank you!
I do have an LSI 9207. Will need to check if this pool is plugged into that or directly into the motherboard. I think I moved all my drives over to the HBA but I can’t say for sure. Things are probably due for a vacuum in there anyway.
HBA has good airflow. with a couple 120mm fans blowing over the motherboard :sunglasses:
Looking back over my notes I’d been meaning to 3D print the fan bracket for the 9207 but didn’t get around to it. Good reminder to do that.
Just don’t get too happy - least bad doesn’t mean good :stuck_out_tongue: still investigate & try to mitigate. If errors keep coming back, regardless of wires or ports, get a replacement
and
make the extended test WAY out of date.
You need to run a SMART Extended test. smartctl -t long /dev/sde then wait 19 hours and then check the results. Your drive has over 50,000 hours on it. It very well could be failing.
Good point.
Roger that. Just started it.
For the future:
  1. Schedule weekly short tests
  2. Schedule monthly long tests
  3. Implement @joeschmuck’s Multi-Report script so you get an email of disk status once a week.
@Protopia You had me losing my mind when you posted the line above. I thought I had missed something. Thankfully I didn’t, mind is restored. No more heart attack in session :laughing:
Just to explain the line:
The first 100 = The Current Value
The Second 100 = The Worst Value is has ever been. 100 is no problems.
The 005 value is the Threshold at which the previous values should never reach. If either one reaches 005 or lower, the drive has really failed bad.
Pre-fail = This is a line of data/values are used to identify failures in advance. Meaning, if the values starts to drop, you can expect the drive to be failing and total failure is coming.
The last “0” zero = The RAW value and tells you, in this case, how many sectors are removed from the LBA table, or simply put, bad sectors.
Cheers
Hello, I’m new to Truenas, so forgive me for my ignorance and also for jumping in and hijacking OP’s thread. I just set my unit up and implemented weekly and monthly SMART tests exactly like this, but I’m a little frustrated that there is no way to see the results without going to command line. Is there ANY solution for easily viewing these results without resorting to a script or shell?
You could add the Scrutiny Application and it is all GUI. I don’t know if it will report errors, but TrueNAS does report any errors that pop up in realtime.
Hope this helps.
EDIT: TrueNAS does not currently test NVMe drives, just in case you have some of those.
