Let me preface this by saying I am trying to get my NAS up and running again and will of course then upgrade to current community edition. I had a boot looping system but have now resolved that (removed some memory sticks).
On boot the IP is reported as http://192.168.8.108/
When attempting to access that from my browser I get “This site can’t be reached. 192.168.8.108 took too long to respond.”
My server is connected via its LAN1 port to the LAN3 port on my GL.iNet GL-MT6000 router.
On the server LAN1 port the activity/link LED is solid green, speed LED is orange flashing - according to the manual this means (green led) 100Mbps connection active, orange LED would be 100Mbps connection speed. HOWEVER it does not indicate in the manual whether the orange LED should be blinking or solid. However, to me this indicates that there is an active connection between the server and router?
From the shell CLI I tried ping -c 4 1.1.1.1 and this results in ‘no route to host.’ I understand from this that the server has no internet connnection BUT I am unsure whether it is supposed to.
Looking in my router settings:
There is no device listed at 192.168.8.108
There is one other LAN (as opposed to WLAN) device listed as unknown at http://192.168.8.224 but when I attempt to connect to that IP I actually get a GUI for "Asrock Rack’ (clearly my server mobo) asking for a username and password. I have absolutely no idea what that might be as I have not come across this before. Yes I have double checked that I am pluigegd intgo LAN1 and not the IPMI port.
Router settings
- The router is currently using WAN DNS. All DNS requests are being directed to the DNS server address configured on the WAN intereface.
- Manual DNS is Off.
- Main Network VLAN ID : 1 Router IP 192.168.8.1 Netmask 255.255.255.0
- DHCP server is Enabled, assigning in this range: 192.168.8.100 - 192.168.8.249
(I note that the IP reported by the server is outside this range but not sure what that indicates, if anything) - There are several reserved/static IPs but they do NOT include 192.168.8.108
- The LAN3 port is showing as 1000 Mbps full duplex specification. Also shows VLAN mode ‘standard’ and does not have a MAC address indicated.
- Network Acceleration is Enabled (Hardware Acceleartion)
- SSH is Enabled
- Remote Access Control (Allow Ping from WAN, HTTPS Remote Access, SSH Remote Access) are all Disabled.
- NAT mode is Disabled
Other Troubleshooting
I have tried several ethernet cables - no change.
As I cannot reach the server via my browser, I do not know how to provide lspci or ipconfig -a reports, sorry. If someone can guide me on that I’ll happily do it.
I would be very appreciative if someone can assist me with this. Thank you.
