Today I tried to install Truenas Scale on the SSD and here’s the error:
I can finish the installation, I go to the page but when I write the password, it shows me that it is not the right one…
I am French, and when I wrote the password before installation, I was careful to put a password corresponding to a “Qwerty” keyboard.
My config :
PNY XLR8 CS3030 M.2 NVMe
CORSAIR VENGEANCE DDR5 32Go
MSI Pro B650M-P
Corsair RM850e
Fractal Design Node 804
Is my configuration not compatible?
Wouldn’t RAM be incompatible?
Ty
Did you manually make an account with the user name admin during the install process?
Since version 24.10 TrueNAS SCALE doesn’t use that username by default anymore, it uses truenas_admin.
Describes the web interface, logging in to the TrueNAS web interface for the first time, changing from root to the admin user, and navigating through the UI.
I looked at tutorials that were less than a year old, and they said the username was “Admin.”
It works with truenas_admin, but should I be concerned about errors during installation?
Thank you
I wouldn’t worry about it unless you experience actual issues. The messages look benign.
