I am not sure what is causing the problem with getting stuck at the white Cursor.
Yes. This looks more ideal and feasible method. I have asked for a network switch so that I can connect both my NAS and laptop systems on the same network. Hope that time I should be able to connect to NAS server using laptop web browser.
This method seems overhead each time, I need to configure and switch back. Currently, we are using wifi mode on laptop for internet/ethernet( though I have LAN port also as optional).
I will go for router switch. Thanks.
True NAS core 12 and True NAS core 13-Beta are installing fine.
but True NAS Core TrueNAS-13.0-U6.1 and TrueNAS-13.0-U6.2 are not installing even after BIOS update.
So I will experiment my functionalities on True NAS Core 13-Beta version for few months, then I will install the stable released version in coming months. Is it fine?, whats yours thoughts on this.
Any thoughts behind, why are you recommending True NAS Scale instead of True NAS Core?
I recommended Scale because I thought it would work with your motherboard network card, Intel 219-v model
Finally, I was able to resolve the issue of white cursor and black screen and I can install TrueNAS core 13_U6.2 also successfully.
Referred to the below thread ![]()
where it says, you need to disable serial port in the BIOS before installation, so that installation works fine.
I can not worked 219-v
TrueNAS CORE 13.3 Release
asrock Z790-itx i7-13900T
pciconf -lv
none7@pci0:0:31:6: class=0x020000 rev=0x11 hdr=0x00 vendor=0x8086 device=0x0dc8 subvendor=0x1849 subdevice=0x0dc8
vendor = 'Intel Corporation'
class = network
subclass = ethernet
igc0@pci0:3:0:0: class=0x020000 rev=0x04 hdr=0x00 vendor=0x8086 device=0x125c subvendor=0x8086 subdevice=0x0000
device = 'Ethernet Controller I226-V'
class = network
subclass = ethernet
bootmessage
em0: <Intel(R) I219-V RPL(22)> mem 0x70e00000-0x70e1ffff at device 31.6 on pci0
em0: Setup init failure
em0: Setup of Shared code failed, error -5
em0: IFDI_ATTACH_PRE failed 6
device_attach: em0 attach returned 6
