ZFS pool unmountable: invalid label
Hi!
After I rebooted my server, the pool became unmountable.
I use “zpool import”, it shows:
   pool: zpool
  state: UNAVAIL
status: One or more devices contains corrupted data.
 action: The pool cannot be imported due to damaged devices or data.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-5E
        zpool                    UNAVAIL  insufficient replicas
          raidz1-0               UNAVAIL  insufficient replicas
            sdc1                 ONLINE
            sdd1                 ONLINE
            sdi1                 ONLINE
            6057603923239297990  UNAVAIL  invalid label
            sdk1                 UNAVAIL  invalid label
It’s strange. My pool name should be “zpool4t”.
Then I use “zdb -l /dev/sdx1” for my 5 drivers
zdb -l /dev/sdd1
LABEL 0
    version: 5000
    state: 1
    txg: 3114017
    pool_guid: 17974986851045026868
    errata: 0
    hostname: 'Tower'
    top_guid: 10484232838912187944
    guid: 9613584519376571584
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 135
        metaslab_shift: 34
        ashift: 12
        asize: 20003911106560
        is_log: 0
        create_txg: 4
        children[0]:
            type: 'disk'
            guid: 9780443222822920977
            path: '/dev/sdc1'
            whole_disk: 0
            DTL: 425
            create_txg: 4
        children[1]:
            type: 'disk'
            path: '/dev/sdd1'
            whole_disk: 0
            DTL: 424
            create_txg: 4
        children[2]:
            type: 'disk'
            guid: 6499147292202988868
            path: '/dev/sdi1'
            whole_disk: 0
            DTL: 423
            create_txg: 4
        children[3]:
            type: 'disk'
            guid: 6057603923239297990
            path: '/dev/sdj1'
            whole_disk: 0
            not_present: 1
            DTL: 422
            create_txg: 4
        children[4]:
            type: 'disk'
            guid: 13162368864450388321
            path: '/dev/sdk1'
            whole_disk: 0
            DTL: 421
            create_txg: 4
    features_for_read:
        com.delphix:hole_birth
        com.delphix:embedded_data
        com.klarasystems:vdev_zaps_v2
    labels = 0 1 2 3
zdb -l /dev/sdc1
LABEL 0
    version: 5000
    state: 1
    txg: 3114017
    errata: 0
    hostname: 'Tower'
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 135
        metaslab_shift: 34
        ashift: 12
        is_log: 0
        create_txg: 4
        children[0]:
            type: 'disk'
            path: '/dev/sdc1'
            whole_disk: 0
            DTL: 425
            create_txg: 4
        children[1]:
            type: 'disk'
            path: '/dev/sdd1'
            whole_disk: 0
            DTL: 424
            create_txg: 4
        children[2]:
            type: 'disk'
            path: '/dev/sdi1'
            whole_disk: 0
            DTL: 423
            create_txg: 4
        children[3]:
            type: 'disk'
            path: '/dev/sdj1'
            whole_disk: 0
            not_present: 1
            DTL: 422
            create_txg: 4
        children[4]:
            type: 'disk'
            path: '/dev/sdk1'
            whole_disk: 0
            DTL: 421
            create_txg: 4
    features_for_read:
    labels = 0 1 2 3
zdb -l /dev/sdi1
LABEL 0
    version: 5000
    state: 1
    txg: 3114017
    errata: 0
    hostname: 'Tower'
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 135
        metaslab_shift: 34
        ashift: 12
        is_log: 0
        create_txg: 4
        children[0]:
            type: 'disk'
            path: '/dev/sdc1'
            whole_disk: 0
            DTL: 425
            create_txg: 4
        children[1]:
            type: 'disk'
            path: '/dev/sdd1'
            whole_disk: 0
            DTL: 424
            create_txg: 4
        children[2]:
            type: 'disk'
            path: '/dev/sdi1'
            whole_disk: 0
            DTL: 423
            create_txg: 4
        children[3]:
            type: 'disk'
            path: '/dev/sdj1'
            whole_disk: 0
            not_present: 1
            DTL: 422
            create_txg: 4
        children[4]:
            type: 'disk'
            path: '/dev/sdk1'
            whole_disk: 0
            DTL: 421
            create_txg: 4
    features_for_read:
    labels = 0 1 2 3
And:
zdb -l /dev/sdk1
failed to unpack label 0
failed to unpack label 1
failed to unpack label 2
failed to unpack label 3
zdb -l /dev/sdj1
Please tell me what can I do next. Thanks.
lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME
NAME  LABEL  MAJ:MIN TRAN ROTA ZONED VENDOR   MODEL               SERIAL               PARTUUID                             START           SIZE PARTTYPENAME
loop0          7:0           1 none        582975488
loop1          7:1           1 none        72441856
loop2          7:2           1 none        42949672960
loop3          7:3           1 none        1073741824
sda            8:0   usb     1 none  SanDisk' Cruzer Fit          03023403120223145222                                               30784094208
└─sda1
      UNRAID   8:1           1 none                                                    5c2c5657-01                             32    30784077824 W95 FAT32 (LBA)
sdb            8:16  sas     1 none  ATA      WDC WUH721818ALE6L4 6FG0P8AR                                                        18000207937536
└─sdb1
               8:17          1 none                                                    017f2682-29ac-45e6-a59b-caa639956351    64 18000207887872 Linux filesystem
sdc            8:32  sas     1 none  ATA      ST4000VN008-2DR166  ZDH9AX8E                                                         4000787030016
└─sdc1
      zpool    8:33          1 none                                                    f57f3e70-cd17-4eed-90e2-4ae83cc4fdc6    64  4000786980352 Linux filesystem
sdd            8:48  sas     1 none  ATA      ST4000VN008-2DR166  ZDH9C7HR                                                         4000787030016
└─sdd1
      zpool    8:49          1 none                                                    993a41f9-49f9-430f-a966-af3c8d6a13c1    64  4000786980352 Linux filesystem
sde            8:64  sas     1 none  ATA      ST18000NM000J-2TV10 ZR5AF2M0                                                        18000207937536
└─sde1
               8:65          1 none                                                    7768217a-f5b6-4875-8b42-30b246d9d560    64 18000207887872 Linux filesystem
sdf            8:80  sas     1 none  ATA      ST18000NM000J-2TV10 WR502KDM                                                        18000207937536
└─sdf1
               8:81          1 none        64 18000207887872
sdg            8:96  sas     1 none  ATA      ST6000VM000-2BC186  ZCT3R9MQ                                                         6001175126016
└─sdg1
               8:97          1 none                                                    ca4ba1df-168e-487b-9eb0-e2ac05692f4a    64  6001175076352 Linux filesystem
sdh            8:112 sas     1 none  ATA      WDC WUH721818ALE6L4 6FG0ZY8S                                                        18000207937536
└─sdh1
               8:113         1 none                                                    13b0e797-c070-4c6c-a04b-71d43490d403    64 18000207887872 Linux filesystem
sdi            8:128 sas     1 none  ATA      ST4000VN008-2DR166  ZDH8J4Y4                                                         4000787030016
└─sdi1
      zpool    8:129         1 none                                                    e812d7ce-59a5-4082-a6d7-efc1f4b4b891    64  4000786980352 Linux filesystem
sdj            8:144 sas     1 none  ATA      ST4000VN008-2DR166  ZDH8J4R4                                                         4000787030016
└─sdj1
               8:145         1 none                                                    c979ca88-3b94-45fc-9ccb-a4c2c5aef6f2    64  4000786980352 Linux filesystem
sdk            8:160 sas     1 none  ATA      ST4000VN008-2DR166  ZDH8HKB0                                                         4000787030016
└─sdk1
               8:161         1 none                                                    969fc824-447e-4b12-b60a-a611b015d790    64  4000786980352 Linux filesystem
sdl            8:176 sas     1 none  ATA      WDC WUH721818ALE6L4 6EG4JZVL                                                        18000207937536
└─sdl1
               8:177         1 none                                                    66d4c810-0425-4d7f-abc4-4d1904494d65    64 18000207887872 Linux filesystem
md1p1          9:1           1 none        18000207884288
md2p1          9:2           1 none        18000207884288
md3p1          9:3           1 none        18000207884288
md4p1          9:4           1 none        18000207884288
md5p1          9:5           1 none
zdb -lu /dev/sdk1
zdb -lu /dev/sdj1
I’m a noob. Then I have a far-fetched idea: There are three labels that look very similar. Can I cover the two damaged hard drives with them? Such as “zhack” or anything else.
I would wait for experienced posters. Do you have a backup elsewhere of all your data?
Sadly, I have no backup :sob:
@HoneyBadger This is a fresh case of label corruption for you!
(With all the community watching our favourite superhero come to the rescue.)
@gyrjmf please describe your hardware (see the Details expand in the signature of @SmallBarky) and TrueNAS software version that you’re running. Thanks :slight_smile:
I’m sorry for that. I was recommended here from the Reddit, and I’m not using TrueNAS.
I just feel that people here are skilled in this area.
Sorry again.
I have spent the past few days searching all over the internet and asking many people, but I still haven’t found a solution. That’s why I have come here to seek help, because I know the people here are very knowledgeable about ZFS. I sincerely ask for your help.
Some of the folks here may be able to assist you but since it isn’t TrueNAS, it may take longer. You should still provide as much detail about your hardware and your pool layouts.
Not knowing what you have or do not have, here is a list of commands you might try and then post the output using the code brackets </> to retain the format of the data.
zpool status -v
and what is the output of smartctl -x /dev/sdk and smartctl -x /dev/sdj
The best thing you might be able to do is mount the pool as read-only, if you are lucky.
I’m not a ZFS expert and I will not tell you that someone will solve this problem for you on his forum. It is a lot going into an unknown system/configuration.
You may have just learned the hard way about keeping important things backed up. You will read this here a lot… A NAS is not a backup. Unless of course that is all it is used for.
You have still not described your hardware, and we HATE guessing…
If I have to guess, I’d hazard that you’re using Unraid and a RAID controller for your SAS drives—because these “Linux filesystem” types on what should be ZFS partitions are looking highly suspicious. But the honest truth is that I have no idea how Unraid handles ZFS…
That sounds very dangerous for a self-described noob. And “sdj”, if that’s it, is shown by a numeric identifier in zpool import, suggesting that it is not even recognised and could be removed or physically damaged.
Oh, sorry for that. I use Unraid on Dell R730xd and HBA card.
Based on my limited understanding, the current version of TrueNAS is based on the Linux kernel and uses OpenZFS, which is also the case for Unraid, so they share some similarities
They’re all SATA drives. I have already made a complete backup of the images of all my hard drives, so now I can experiment boldly.
zpool status -v
no pools available
The drives appear to be fine.
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.24-Unraid] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH8HKB0
LU WWN Device Id: 5 000c50 0c41f08cf
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5706
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Aug 11 02:46:43 2025 CST
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (  581) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 616) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   084   064   044    -    240131423
  3 Spin_Up_Time            PO----   094   093   000    -    0
  4 Start_Stop_Count        -O--CK   099   099   020    -    1780
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   093   060   045    -    2150614475
  9 Power_On_Hours          -O--CK   087   087   000    -    12248 (183 141 0)
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    300
184 End-to-End_Error        -O--CK   100   100   099    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   099   000    -    0 0 2
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   069   056   040    -    31 (Min/Max 29/31)
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count -O--CK   100   100   000    -    0
193 Load_Cycle_Count        -O--CK   001   001   000    -    634365
194 Temperature_Celsius     -O---K   031   044   000    -    31 (0 17 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
240 Head_Flying_Hours       ------   100   253   000    -    10487h+35m+26.307s
241 Total_LBAs_Written      ------   100   253   000    -    32730380692
242 Total_LBAs_Read         ------   100   253   000    -    297102691196
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    512  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS    8160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xb0       GPL     VS    9048  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS      16  Device vendor specific log
0xd1       GPL     VS     136  Device vendor specific log
0xd2       GPL     VS   10000  Device vendor specific log
0xd3       GPL     VS    1920  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%     11912         -
# 2  Extended offline    Aborted by host               90%     11912         -
# 3  Short offline       Completed without error       00%     11881         -
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     29/31 Celsius
Lifetime    Min/Max Temperature:     17/44 Celsius
Under/Over Temperature Limit Count:   0/1
SCT Temperature History Version:     2
Temperature Sampling Period:         3 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:      0/ 0 Celsius
Min/Max Temperature Limit:            0/ 0 Celsius
Temperature History Size (Index):    128 (12)
Index    Estimated Time   Temperature Celsius
  13    2025-08-05 21:07    27  ********
  14    2025-08-05 22:06     ?  -
  15    2025-08-05 23:05    29  **********
  16    2025-08-06 00:04    32  *************
  17    2025-08-06 01:03    31  ************
  18    2025-08-06 02:02    31  ************
  19    2025-08-06 03:01    31  ************
  20    2025-08-06 04:00    33  **************
  21    2025-08-06 04:59    33  **************
  22    2025-08-06 05:58    34  ***************
  23    2025-08-06 06:57    33  **************
 ...    ..(  2 skipped).    ..  **************
  26    2025-08-06 09:54    33  **************
  27    2025-08-06 10:53    32  *************
  28    2025-08-06 11:52    32  *************
  29    2025-08-06 12:51    33  **************
 ...    ..(  3 skipped).    ..  **************
  33    2025-08-06 16:47    33  **************
  34    2025-08-06 17:46    32  *************
  37    2025-08-06 20:43    32  *************
  38    2025-08-06 21:42    30  ***********
  39    2025-08-06 22:41    31  ************
  40    2025-08-06 23:40    32  *************
  41    2025-08-07 00:39    33  **************
  42    2025-08-07 01:38    34  ***************
  43    2025-08-07 02:37    34  ***************
  44    2025-08-07 03:36    34  ***************
  45    2025-08-07 04:35    33  **************
  46    2025-08-07 05:34    33  **************
  47    2025-08-07 06:33    34  ***************
 ...    ..(  2 skipped).    ..  ***************
  50    2025-08-07 09:30    34  ***************
  51    2025-08-07 10:29    33  **************
  52    2025-08-07 11:28    32  *************
 ...    ..(  7 skipped).    ..  *************
  60    2025-08-07 19:20    32  *************
  61    2025-08-07 20:19    31  ************
  62    2025-08-07 21:18    30  ***********
  63    2025-08-07 22:17    30  ***********
  64    2025-08-07 23:16    31  ************
  65    2025-08-08 00:15    32  *************
  66    2025-08-08 01:14    32  *************
  67    2025-08-08 02:13    34  ***************
  68    2025-08-08 03:12     ?  -
  69    2025-08-08 04:11    32  *************
  70    2025-08-08 05:10     ?  -
  71    2025-08-08 06:09    29  **********
  72    2025-08-08 07:08     ?  -
  73    2025-08-08 08:07    28  *********
  74    2025-08-08 09:06     ?  -
  75    2025-08-08 10:05    30  ***********
  76    2025-08-08 11:04     ?  -
  77    2025-08-08 12:03    29  **********
  78    2025-08-08 13:02    33  **************
  79    2025-08-08 14:01    34  ***************
  80    2025-08-08 15:00    33  **************
  81    2025-08-08 15:59    34  ***************
  84    2025-08-08 18:56    34  ***************
  85    2025-08-08 19:55    32  *************
  86    2025-08-08 20:54    33  **************
  87    2025-08-08 21:53    31  ************
  88    2025-08-08 22:52    32  *************
 ...    ..(  4 skipped).    ..  *************
  93    2025-08-09 03:47    32  *************
  94    2025-08-09 04:46    31  ************
  95    2025-08-09 05:45    32  *************
  96    2025-08-09 06:44    30  ***********
  97    2025-08-09 07:43     ?  -
  98    2025-08-09 08:42    29  **********
  99    2025-08-09 09:41    31  ************
 100    2025-08-09 10:40    30  ***********
 101    2025-08-09 11:39    32  *************
 102    2025-08-09 12:38    33  **************
 103    2025-08-09 13:37    33  **************
 104    2025-08-09 14:36    33  **************
 105    2025-08-09 15:35    31  ************
 106    2025-08-09 16:34    34  ***************
 107    2025-08-09 17:33    31  ************
 108    2025-08-09 18:32    32  *************
 109    2025-08-09 19:31    31  ************
 110    2025-08-09 20:30    31  ************
 111    2025-08-09 21:29    31  ************
 112    2025-08-09 22:28    30  ***********
 113    2025-08-09 23:27    29  **********
 114    2025-08-10 00:26    30  ***********
 115    2025-08-10 01:25    31  ************
 116    2025-08-10 02:24    32  *************
 121    2025-08-10 07:19    32  *************
 122    2025-08-10 08:18    31  ************
 123    2025-08-10 09:17    30  ***********
 124    2025-08-10 10:16    31  ************
 125    2025-08-10 11:15    31  ************
 126    2025-08-10 12:14    30  ***********
   1    2025-08-10 15:11    30  ***********
   2    2025-08-10 16:10    29  **********
   3    2025-08-10 17:09    29  **********
   4    2025-08-10 18:08    31  ************
   5    2025-08-10 19:07    32  *************
   8    2025-08-10 22:04    32  *************
   9    2025-08-10 23:03    31  ************
  10    2025-08-11 00:02    31  ************
  11    2025-08-11 01:01     ?  -
  12    2025-08-11 02:00    29  **********
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             300  ---  Lifetime Power-On Resets
0x01  0x010  4           12248  ---  Power-on Hours
0x01  0x018  6     32730460900  ---  Logical Sectors Written
0x01  0x020  6       218697397  ---  Number of Write Commands
0x01  0x028  6    297102690776  ---  Logical Sectors Read
0x01  0x030  6      1096767873  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4      3636966187  N--  Spindle Motor Power-on Hours
0x03  0x010  4      3636955382  N--  Head Flying Hours
0x03  0x018  4          634365  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4               1  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               2  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              31  ---  Current Temperature
0x05  0x010  1              30  ---  Average Short Term Temperature
0x05  0x018  1              30  ---  Average Long Term Temperature
0x05  0x020  1              44  ---  Highest Temperature
0x05  0x028  1               0  ---  Lowest Temperature
0x05  0x030  1              41  ---  Highest Average Short Term Temperature
0x05  0x038  1              22  ---  Lowest Average Short Term Temperature
0x05  0x040  1              34  ---  Highest Average Long Term Temperature
0x05  0x048  1              26  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              70  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4            4351  ---  Number of Hardware Resets
0x06  0x010  4            2417  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
Serial Number:    ZDH8J4R4
LU WWN Device Id: 5 000c50 0c41f7c44
Local Time is:    Mon Aug 11 02:46:59 2025 CST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 633) minutes.
  1 Raw_Read_Error_Rate     POSR--   071   064   044    -    12675414
  3 Spin_Up_Time            PO----   095   093   000    -    0
  4 Start_Stop_Count        -O--CK   099   099   020    -    1885
  7 Seek_Error_Rate         POSR--   092   060   045    -    1478686172
  9 Power_On_Hours          -O--CK   087   087   000    -    12245 (98 132 0)
188 Command_Timeout         -O--CK   100   100   000    -    0 0 0
190 Airflow_Temperature_Cel -O---K   069   052   040    -    31 (Min/Max 29/31)
193 Load_Cycle_Count        -O--CK   001   001   000    -    299007
194 Temperature_Celsius     -O---K   031   048   000    -    31 (0 17 0 0 0)
240 Head_Flying_Hours       ------   100   253   000    -    8096h+25m+35.624s
241 Total_LBAs_Written      ------   100   253   000    -    32729928919
242 Total_LBAs_Read         ------   100   253   000    -    304911664205
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Short offline       Completed without error       00%     11909         -
# 2  Short offline       Aborted by host               90%      8708         -
Lifetime    Min/Max Temperature:     16/48 Celsius
Temperature History Size (Index):    128 (112)
 113    2025-08-05 21:07    31  ************
 114    2025-08-05 22:06    31  ************
 115    2025-08-05 23:05    30  ***********
 116    2025-08-06 00:04    31  ************
 117    2025-08-06 01:03    32  *************
 118    2025-08-06 02:02    33  **************
 ...    ..(  8 skipped).    ..  **************
 127    2025-08-06 10:53    33  **************
   0    2025-08-06 11:52    32  *************
   9    2025-08-06 20:43    32  *************
  10    2025-08-06 21:42    31  ************
  11    2025-08-06 22:41    31  ************
  12    2025-08-06 23:40    31  ************
  13    2025-08-07 00:39    32  *************
  14    2025-08-07 01:38    33  **************
  23    2025-08-07 10:29    33  **************
  24    2025-08-07 11:28     ?  -
  25    2025-08-07 12:27    33  **************
  26    2025-08-07 13:26     ?  -
  27    2025-08-07 14:25    30  ***********
  28    2025-08-07 15:24     ?  -
  29    2025-08-07 16:23    28  *********
  30    2025-08-07 17:22     ?  -
  31    2025-08-07 18:21    30  ***********
  32    2025-08-07 19:20    32  *************
  33    2025-08-07 20:19    31  ************
  34    2025-08-07 21:18    31  ************
  35    2025-08-07 22:17    32  *************
  38    2025-08-08 01:14    32  *************
  39    2025-08-08 02:13    31  ************
  40    2025-08-08 03:12    32  *************
  44    2025-08-08 07:08    32  *************
  45    2025-08-08 08:07    31  ************
  46    2025-08-08 09:06     ?  -
  47    2025-08-08 10:05    29  **********
  48    2025-08-08 11:04    32  *************
  49    2025-08-08 12:03    34  ***************
  50    2025-08-08 13:02    33  **************
  51    2025-08-08 14:01    33  **************
  52    2025-08-08 15:00    34  ***************
  53    2025-08-08 15:59    33  **************
  54    2025-08-08 16:58    33  **************
  55    2025-08-08 17:57    32  *************
  56    2025-08-08 18:56    32  *************
  57    2025-08-08 19:55    31  ************
  58    2025-08-08 20:54    32  *************
 ...    ..(  6 skipped).    ..  *************
  65    2025-08-09 03:47    32  *************
  66    2025-08-09 04:46    31  ************
  67    2025-08-09 05:45    31  ************
  68    2025-08-09 06:44     ?  -
  69    2025-08-09 07:43    29  **********
  70    2025-08-09 08:42    31  ************
  71    2025-08-09 09:41    30  ***********
  72    2025-08-09 10:40    33  **************
  73    2025-08-09 11:39    32  *************
  74    2025-08-09 12:38    31  ************
  75    2025-08-09 13:37    31  ************
  76    2025-08-09 14:36    33  **************
  77    2025-08-09 15:35    31  ************
  78    2025-08-09 16:34    32  *************
  79    2025-08-09 17:33    30  ***********
  80    2025-08-09 18:32    31  ************
  81    2025-08-09 19:31    30  ***********
  82    2025-08-09 20:30    31  ************
  83    2025-08-09 21:29    30  ***********
  84    2025-08-09 22:28    29  **********
  85    2025-08-09 23:27    30  ***********
  86    2025-08-10 00:26    31  ************
  87    2025-08-10 01:25    31  ************
  88    2025-08-10 02:24    32  *************
  89    2025-08-10 03:23    31  ************
  90    2025-08-10 04:22    31  ************
  91    2025-08-10 05:21    32  *************
  92    2025-08-10 06:20    31  ************
  93    2025-08-10 07:19    31  ************
  94    2025-08-10 08:18    30  ***********
  99    2025-08-10 13:13    30  ***********
 100    2025-08-10 14:12    29  **********
 101    2025-08-10 15:11    29  **********
 102    2025-08-10 16:10    29  **********
 103    2025-08-10 17:09    31  ************
 104    2025-08-10 18:08    31  ************
 105    2025-08-10 19:07    32  *************
 106    2025-08-10 20:06    32  *************
 107    2025-08-10 21:05    32  *************
 108    2025-08-10 22:04    31  ************
 109    2025-08-10 23:03    31  ************
 110    2025-08-11 00:02    30  ***********
 111    2025-08-11 01:01     ?  -
 112    2025-08-11 02:00    29  **********
0x01  0x010  4           12245  ---  Power-on Hours
0x01  0x018  6     32730044903  ---  Logical Sectors Written
0x01  0x020  6       218158908  ---  Number of Write Commands
0x01  0x028  6    304911663787  ---  Logical Sectors Read
0x01  0x030  6       993053293  ---  Number of Read Commands
0x03  0x008  4       374504314  N--  Spindle Motor Power-on Hours
0x03  0x010  4       374496332  N--  Head Flying Hours
0x03  0x018  4          299007  ---  Head Load Events
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  0x018  1              28  ---  Average Long Term Temperature
0x05  0x020  1              48  ---  Highest Temperature
0x05  0x030  1              44  ---  Highest Average Short Term Temperature
0x05  0x038  1              20  ---  Lowest Average Short Term Temperature
0x05  0x040  1              36  ---  Highest Average Long Term Temperature
0x05  0x048  1              23  ---  Lowest Average Long Term Temperature
0x06  0x008  4            3851  ---  Number of Hardware Resets
0x06  0x010  4            2414  ---  Number of ASR Events
                                ||__ D supports DSN
Right now, the lack of a pool being listed is of course concerning. Also the fact that you have no recent SMART tests on your drives is concerning.
You might want to run a SMART Long test on all your drives. Use smartctl -t long /dev/sd? where ?=the letter like sda, sdb, etc.
These tests will take a long time, over 11 hours. May sure they complete without error. I suspect you will have some significant errors, but maybe not.
Good luck.
I tested all these drives yesterday. Completed without error
This is sdj disk’s first 102400 bytes:
00000000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001c0  02 00 ee ff ff ff 01 00  00 00 ff ff ff ff 00 00  |................|
000001d0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 55 aa  |..............U.|
00000200  45 46 49 20 50 41 52 54  00 00 01 00 5c 00 00 00  |EFI PART....\...|
00000210  e8 07 34 17 00 00 00 00  01 00 00 00 00 00 00 00  |..4.............|
00000220  af be c0 d1 01 00 00 00  22 00 00 00 00 00 00 00  |........".......|
00000230  8e be c0 d1 01 00 00 00  46 00 f9 d2 4f bd 2a 4c  |........F...O.*L|
00000240  a5 58 0a 40 11 4a 10 81  02 00 00 00 00 00 00 00  |.X.@.J..........|
00000250  80 00 00 00 80 00 00 00  3f a4 64 be 00 00 00 00  |........?.d.....|
00000260  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000400  af 3d c6 0f 83 84 72 47  8e 79 3d 69 d8 47 7d e4  |.=....rG.y=i.G}.|
00000410  88 ca 79 c9 94 3b fc 45  9c cb a4 c2 c5 ae f6 f2  |..y..;.E........|
00000420  40 00 00 00 00 00 00 00  8e be c0 d1 01 00 00 00  |@...............|
00000430  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00004e00  6a c4 1c 5d 98 91 0d 3d  9c 45 da 9e ba 63 00 5c  |j..]...=.E...c.\|
00004e10  48 78 c4 19 9f c8 8a 1f  8f a3 7f 83 08 cf 7a 71  |Hx............zq|
00004e20  89 a4 1d cd e7 d2 32 e1  27 ad d4 fa 0e 03 99 eb  |......2.'.......|
00004e30  f7 83 50 50 11 2d 79 be  3c b4 f1 e3 8f d9 3b 9f  |..PP.-y.<.....;.|
00004e40  d9 b0 f3 67 87 90 e0 5d  ff f9 f0 60 61 55 1a 2e  |...g...]...`aU..|
00004e50  81 52 af 73 ee 25 ad c7  01 6e ce 6b 01 8d 49 74  |.R.s.%...n.k..It|
00004e60  9c 9e ed 7e e9 3b f3 a2  8e 45 a0 39 0f cd 96 6b  |...~.;...E.9...k|
00004e70  90 3c a7 b4 5a 6f 72 ba  08 6b 58 1f 35 42 2a c6  |.<..Zor..kX.5B*.|
00004e80  4f f4 51 a2 a1 48 6e 89  e9 36 6d c8 3b 12 ec 3a  |O.Q..Hn..6m.;..:|
00004e90  ad 89 2f 37 ab 1a de 63  2f ef 74 ee c7 a9 51 d1  |../7...c/.t...Q.|
00004ea0  ae 63 ad 92 1b 78 98 f1  b6 40 bb fa 22 07 f3 22  |.c...x...@..".."|
00004eb0  95 b7 46 a3 ca 2b 16 85  40 41 0a c5 f3 61 c7 ad  |..F..+..@A...a..|
00004ec0  53 fb 1b 65 ac c9 55 ee  73 c1 02 a0 29 fe 53 15  |S..e..U.s...).S.|
00004ed0  8f 1f ad 8d 77 de 15 ef  6b f3 1b d8 44 96 e3 aa  |....w...k...D...|
00004ee0  5a 2a dc 10 7b 96 da 3c  8b f2 3d 38 a4 81 f3 2c  |Z*..{..<..=8...,|
00004ef0  58 41 f5 54 73 45 9d 73  c5 fd e8 2a be c6 30 50  |XA.TsE.s...*..0P|
00004f00  9e 4f 8f a0 29 ed 4a e9  2f 32 03 ca 13 d8 5b 7a  |.O..).J./2....[z|
00004f10  ae 9d 58 e6 88 73 22 90  0a 43 6c 41 5b 17 c4 1a  |..X..s"..ClA[...|
00004f20  27 5e f9 ef 63 9f 57 23  6c 27 97 70 f5 a8 5b 7b  |'^..c.W#l'.p..[{|
00004f30  5d a9 0f 37 ae ff 8b b2  c8 ca d9 28 8e 5b b2 46  |]..7.......(.[.F|
00004f40  be 80 40 38 e4 ee bb 2c  d2 82 c1 72 5a 11 4f 4b  |..@8...,...rZ.OK|
00004f50  54 e2 b9 f1 24 96 53 3d  33 81 f1 50 2e 1a 04 71  |T...$.S=3..P...q|
00004f60  80 f9 bf 66 69 9c 6f 22  44 d0 69 bb ad 93 84 98  |...fi.o"D.i.....|
00004f70  74 af 67 32 b9 8f 65 f3  4b 0f f4 85 ef b5 ba ff  |t.g2..e.K.......|
00004f80  e1 da 9e 9e 32 96 a9 19  b8 4f 43 f7 f6 4c 1c 0f  |....2....OC..L..|
00004f90  ce d2 67 b6 e3 e3 8d 27  1e 27 98 4c 73 37 5c ff  |..g....'.'.Ls7\.|
00004fa0  ab 16 ca 64 7d 91 c0 6d  ae 60 f0 1a 43 12 e6 f4  |...d}..m.`..C...|
00004fb0  d6 e8 ba c2 9b 2f e6 ce  07 08 6a 8d 28 62 a7 31  |...../....j.(b.1|
00004fc0  e9 3d 4b 9b 5b 19 18 13  d2 a9 c1 08 ce 62 12 8c  |.=K.[........b..|
00004fd0  12 64 e3 43 bb e3 59 1c  57 7f cd b9 72 65 47 ab  |.d.C..Y.W...reG.|
00004fe0  b8 fe 61 c1 08 c2 ec 25  8e b9 1c 89 df 6d d2 a7  |..a....%.....m..|
00004ff0  36 a7 10 52 2a 21 2d aa  98 31 d1 77 42 fd a3 a9  |6..R*!-..1.wB...|
00005000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000bfd0  00 00 00 00 00 00 00 00  11 7a 0c b1 7a da 10 02  |.........z..z...|
0000bfe0  3f 2a 6e 7f 80 8f f4 97  fc ce aa 58 16 9f 90 af  |?*n........X....|
0000bff0  8b b4 6d ff 57 ea d1 cb  ab 5f 46 0d db 92 c6 6e  |..m.W...._F....n|
0000c000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00019000
sdk
00000210  e6 49 39 03 00 00 00 00  01 00 00 00 00 00 00 00  |.I9.............|
00000230  8e be c0 d1 01 00 00 00  48 cd 2e fd 76 8a e0 42  |........H...v..B|
00000240  87 7e fa 25 86 ed 79 70  02 00 00 00 00 00 00 00  |.~.%..yp........|
00000250  80 00 00 00 80 00 00 00  1b 95 0b a7 00 00 00 00  |................|
00000410  24 c8 9f 96 7e 44 12 4b  b6 0a a6 11 b0 15 d7 90  |$...~D.K........|
00004e00  6a c4 1c 5d 9e 91 0d 3d  9c 45 da 9e ba 63 00 5c  |j..]...=.E...c.\|
00004ff0  36 a7 10 52 2a 21 2d aa  98 31 d1 77 51 6f 43 be  |6..R*!-..1.wQoC.|
00019000
sdc
00000210  b7 35 4b 6f 00 00 00 00  01 00 00 00 00 00 00 00  |.5Ko............|
00000230  8e be c0 d1 01 00 00 00  d9 e2 65 56 a9 c9 fb 49  |..........eV...I|
00000240  95 be 75 19 ff 1e 52 02  02 00 00 00 00 00 00 00  |..u...R.........|
00000250  80 00 00 00 80 00 00 00  a8 75 15 8f 00 00 00 00  |.........u......|
00000410  70 3e 7f f5 17 cd ed 4e  90 e2 4a e8 3c c4 fd c6  |p>.....N..J.<...|
00009000  41 42 33 42 00 00 00 02  ff ff ff ff ff ff ff ff  |AB3B............|
00009010  00 00 00 00 00 00 00 08  00 00 00 01 00 2e fd f4  |................|
00009020  e3 af 0a 26 e3 46 41 b0  8a ab 6a 52 ab 0e 40 8b  |...&.FA...jR..@.|
00009030  00 00 00 00 2f b9 ca c2  00 00 00 0a 00 00 00 06  |..../...........|
00009040  00 00 00 18 0e 8e 05 db  02 b4 c6 a0 0b d9 3f 53  |..............?S|
00009050  05 47 67 80 09 46 9e 73  05 47 67 80 09 46 9e 73  |.Gg..F.s.Gg..F.s|
00009090  07 51 2d 6c 07 3c d8 87  07 51 32 fa 07 3c d2 f9  |.Q-l.<...Q2..<..|
000090a0  07 51 32 fa 07 3c d2 f9  07 51 62 da 07 3c a3 19  |.Q2..<...Qb..<..|
000090b0  07 51 62 da 07 3c a3 19  07 51 62 da 07 3c a3 19  |.Qb..<...Qb..<..|
000090e0  07 8b 70 27 07 02 95 cc  07 8b 70 27 07 02 95 cc  |..p'......p'....|
00009a70  07 8b 70 27 07 02 95 cc  05 d5 b7 ca 08 b8 4e 29  |..p'..........N)|
00009a80  05 d5 b7 ca 08 b8 4e 29  05 d5 b7 ca 08 b8 4e 29  |......N)......N)|
00009b20  05 d5 b7 ca 08 b8 4e 29  00 00 00 00 00 00 00 00  |......N)........|
00009b30  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c000  01 01 00 00 00 00 00 00  00 00 00 01 00 00 00 24  |...............$|
0000c010  00 00 00 20 00 00 00 07  76 65 72 73 69 6f 6e 00  |... ....version.|
0000c020  00 00 00 08 00 00 00 01  00 00 00 00 00 00 13 88  |................|
0000c030  00 00 00 24 00 00 00 20  00 00 00 04 6e 61 6d 65  |...$... ....name|
0000c040  00 00 00 09 00 00 00 01  00 00 00 05 7a 70 6f 6f  |............zpoo|
0000c050  6c 00 00 00 00 00 00 24  00 00 00 20 00 00 00 05  |l......$... ....|
0000c060  73 74 61 74 65 00 00 00  00 00 00 08 00 00 00 01  |state...........|
0000c070  00 00 00 00 00 00 00 01  00 00 00 20 00 00 00 20  |........... ... |
0000c080  00 00 00 03 74 78 67 00  00 00 00 08 00 00 00 01  |....txg.........|
0000c090  00 00 00 00 00 2f 84 21  00 00 00 28 00 00 00 28  |...../.!...(...(|
0000c0a0  00 00 00 09 70 6f 6f 6c  5f 67 75 69 64 00 00 00  |....pool_guid...|
0000c0b0  00 00 00 08 00 00 00 01  f9 73 fb 4e 32 db 2c 34  |.........s.N2.,4|
0000c0c0  00 00 00 24 00 00 00 20  00 00 00 06 65 72 72 61  |...$... ....erra|
0000c0d0  74 61 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |ta..............|
0000c0e0  00 00 00 00 00 00 00 28  00 00 00 28 00 00 00 08  |.......(...(....|
0000c0f0  68 6f 73 74 6e 61 6d 65  00 00 00 09 00 00 00 01  |hostname........|
0000c100  00 00 00 05 54 6f 77 65  72 00 00 00 00 00 00 24  |....Tower......$|
0000c110  00 00 00 28 00 00 00 08  74 6f 70 5f 67 75 69 64  |...(....top_guid|
0000c120  00 00 00 08 00 00 00 01  91 7f 7a 38 19 d8 9e 28  |..........z8...(|
0000c130  00 00 00 20 00 00 00 20  00 00 00 04 67 75 69 64  |... ... ....guid|
0000c140  00 00 00 08 00 00 00 01  87 bb 1d 4a ca 3c a3 11  |...........J.<..|
0000c150  00 00 00 2c 00 00 00 28  00 00 00 0d 76 64 65 76  |...,...(....vdev|
0000c160  5f 63 68 69 6c 64 72 65  6e 00 00 00 00 00 00 08  |_children.......|
0000c170  00 00 00 01 00 00 00 00  00 00 00 01 00 00 07 10  |................|
0000c180  00 00 00 38 00 00 00 09  76 64 65 76 5f 74 72 65  |...8....vdev_tre|
0000c190  65 00 00 00 00 00 00 13  00 00 00 01 00 00 00 00  |e...............|
0000c1a0  00 00 00 01 00 00 00 24  00 00 00 20 00 00 00 04  |.......$... ....|
0000c1b0  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 05  |type............|
0000c1c0  72 61 69 64 7a 00 00 00  00 00 00 20 00 00 00 20  |raidz...... ... |
0000c1d0  00 00 00 02 69 64 00 00  00 00 00 08 00 00 00 01  |....id..........|
0000c1e0  00 00 00 00 00 00 00 00  00 00 00 20 00 00 00 20  |........... ... |
0000c1f0  00 00 00 04 67 75 69 64  00 00 00 08 00 00 00 01  |....guid........|
0000c200  91 7f 7a 38 19 d8 9e 28  00 00 00 24 00 00 00 20  |..z8...(...$... |
0000c210  00 00 00 07 6e 70 61 72  69 74 79 00 00 00 00 08  |....nparity.....|
0000c220  00 00 00 01 00 00 00 00  00 00 00 01 00 00 00 2c  |...............,|
0000c230  00 00 00 28 00 00 00 0e  6d 65 74 61 73 6c 61 62  |...(....metaslab|
0000c240  5f 61 72 72 61 79 00 00  00 00 00 08 00 00 00 01  |_array..........|
0000c250  00 00 00 00 00 00 00 87  00 00 00 2c 00 00 00 28  |...........,...(|
0000c260  00 00 00 0e 6d 65 74 61  73 6c 61 62 5f 73 68 69  |....metaslab_shi|
0000c270  66 74 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |ft..............|
0000c280  00 00 00 22 00 00 00 24  00 00 00 20 00 00 00 06  |..."...$... ....|
0000c290  61 73 68 69 66 74 00 00  00 00 00 08 00 00 00 01  |ashift..........|
0000c2a0  00 00 00 00 00 00 00 0c  00 00 00 24 00 00 00 20  |...........$... |
0000c2b0  00 00 00 05 61 73 69 7a  65 00 00 00 00 00 00 08  |....asize.......|
0000c2c0  00 00 00 01 00 00 12 31  86 04 00 00 00 00 00 24  |.......1.......$|
0000c2d0  00 00 00 20 00 00 00 06  69 73 5f 6c 6f 67 00 00  |... ....is_log..|
0000c2e0  00 00 00 08 00 00 00 01  00 00 00 00 00 00 00 00  |................|
0000c2f0  00 00 00 28 00 00 00 28  00 00 00 0a 63 72 65 61  |...(...(....crea|
0000c300  74 65 5f 74 78 67 00 00  00 00 00 08 00 00 00 01  |te_txg..........|
0000c310  00 00 00 00 00 00 00 04  00 00 05 6c 00 00 00 c0  |...........l....|
0000c320  00 00 00 08 63 68 69 6c  64 72 65 6e 00 00 00 14  |....children....|
0000c330  00 00 00 05 00 00 00 00  00 00 00 01 00 00 00 20  |............... |
0000c340  00 00 00 20 00 00 00 04  74 79 70 65 00 00 00 09  |... ....type....|
0000c350  00 00 00 01 00 00 00 04  64 69 73 6b 00 00 00 20  |........disk... |
0000c360  00 00 00 20 00 00 00 02  69 64 00 00 00 00 00 08  |... ....id......|
0000c370  00 00 00 01 00 00 00 00  00 00 00 00 00 00 00 20  |............... |
0000c380  00 00 00 20 00 00 00 04  67 75 69 64 00 00 00 08  |... ....guid....|
0000c390  00 00 00 01 87 bb 1d 4a  ca 3c a3 11 00 00 00 28  |.......J.<.....(|
0000c3a0  00 00 00 28 00 00 00 04  70 61 74 68 00 00 00 09  |...(....path....|
0000c3b0  00 00 00 01 00 00 00 09  2f 64 65 76 2f 73 64 63  |......../dev/sdc|
0000c3c0  31 00 00 00 00 00 00 28  00 00 00 28 00 00 00 0a  |1......(...(....|
0000c3d0  77 68 6f 6c 65 5f 64 69  73 6b 00 00 00 00 00 08  |whole_disk......|
0000c3e0  00 00 00 01 00 00 00 00  00 00 00 00 00 00 00 20  |............... |
0000c3f0  00 00 00 20 00 00 00 03  44 54 4c 00 00 00 00 08  |... ....DTL.....|
0000c400  00 00 00 01 00 00 00 00  00 00 01 a9 00 00 00 28  |...............(|
0000c410  00 00 00 28 00 00 00 0a  63 72 65 61 74 65 5f 74  |...(....create_t|
0000c420  78 67 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |xg..............|
0000c430  00 00 00 04 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c440  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c450  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 04  |type............|
0000c460  64 69 73 6b 00 00 00 20  00 00 00 20 00 00 00 02  |disk... ... ....|
0000c470  69 64 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |id..............|
0000c480  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c490  67 75 69 64 00 00 00 08  00 00 00 01 85 6a 50 2f  |guid.........jP/|
0000c4a0  77 a2 8c c0 00 00 00 28  00 00 00 28 00 00 00 04  |w......(...(....|
0000c4b0  70 61 74 68 00 00 00 09  00 00 00 01 00 00 00 09  |path............|
0000c4c0  2f 64 65 76 2f 73 64 64  31 00 00 00 00 00 00 28  |/dev/sdd1......(|
0000c4d0  00 00 00 28 00 00 00 0a  77 68 6f 6c 65 5f 64 69  |...(....whole_di|
0000c4e0  73 6b 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |sk..............|
0000c4f0  00 00 00 00 00 00 00 20  00 00 00 20 00 00 00 03  |....... ... ....|
0000c500  44 54 4c 00 00 00 00 08  00 00 00 01 00 00 00 00  |DTL.............|
0000c510  00 00 01 a8 00 00 00 28  00 00 00 28 00 00 00 0a  |.......(...(....|
0000c520  63 72 65 61 74 65 5f 74  78 67 00 00 00 00 00 08  |create_txg......|
0000c530  00 00 00 01 00 00 00 00  00 00 00 04 00 00 00 00  |................|
0000c540  00 00 00 00 00 00 00 00  00 00 00 01 00 00 00 20  |............... |
0000c550  00 00 00 20 00 00 00 04  74 79 70 65 00 00 00 09  |... ....type....|
0000c560  00 00 00 01 00 00 00 04  64 69 73 6b 00 00 00 20  |........disk... |
0000c570  00 00 00 20 00 00 00 02  69 64 00 00 00 00 00 08  |... ....id......|
0000c580  00 00 00 01 00 00 00 00  00 00 00 02 00 00 00 20  |............... |
0000c590  00 00 00 20 00 00 00 04  67 75 69 64 00 00 00 08  |... ....guid....|
0000c5a0  00 00 00 01 5a 31 9c 07  3e b3 75 44 00 00 00 28  |....Z1..>.uD...(|
0000c5b0  00 00 00 28 00 00 00 04  70 61 74 68 00 00 00 09  |...(....path....|
0000c5c0  00 00 00 01 00 00 00 09  2f 64 65 76 2f 73 64 69  |......../dev/sdi|
0000c5d0  31 00 00 00 00 00 00 28  00 00 00 28 00 00 00 0a  |1......(...(....|
0000c5e0  77 68 6f 6c 65 5f 64 69  73 6b 00 00 00 00 00 08  |whole_disk......|
0000c5f0  00 00 00 01 00 00 00 00  00 00 00 00 00 00 00 20  |............... |
0000c600  00 00 00 20 00 00 00 03  44 54 4c 00 00 00 00 08  |... ....DTL.....|
0000c610  00 00 00 01 00 00 00 00  00 00 01 a7 00 00 00 28  |...............(|
0000c620  00 00 00 28 00 00 00 0a  63 72 65 61 74 65 5f 74  |...(....create_t|
0000c630  78 67 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |xg..............|
0000c640  00 00 00 04 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c650  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c660  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 04  |type............|
0000c670  64 69 73 6b 00 00 00 20  00 00 00 20 00 00 00 02  |disk... ... ....|
0000c680  69 64 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |id..............|
0000c690  00 00 00 03 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c6a0  67 75 69 64 00 00 00 08  00 00 00 01 54 10 ee ac  |guid........T...|
0000c6b0  72 b0 e3 c6 00 00 00 28  00 00 00 28 00 00 00 04  |r......(...(....|
0000c6c0  70 61 74 68 00 00 00 09  00 00 00 01 00 00 00 09  |path............|
0000c6d0  2f 64 65 76 2f 73 64 6a  31 00 00 00 00 00 00 28  |/dev/sdj1......(|
0000c6e0  00 00 00 28 00 00 00 0a  77 68 6f 6c 65 5f 64 69  |...(....whole_di|
0000c6f0  73 6b 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |sk..............|
0000c700  00 00 00 00 00 00 00 28  00 00 00 28 00 00 00 0b  |.......(...(....|
0000c710  6e 6f 74 5f 70 72 65 73  65 6e 74 00 00 00 00 08  |not_present.....|
0000c720  00 00 00 01 00 00 00 00  00 00 00 01 00 00 00 20  |............... |
0000c730  00 00 00 20 00 00 00 03  44 54 4c 00 00 00 00 08  |... ....DTL.....|
0000c740  00 00 00 01 00 00 00 00  00 00 01 a6 00 00 00 28  |...............(|
0000c750  00 00 00 28 00 00 00 0a  63 72 65 61 74 65 5f 74  |...(....create_t|
0000c760  78 67 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |xg..............|
0000c770  00 00 00 04 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c780  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c790  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 04  |type............|
0000c7a0  64 69 73 6b 00 00 00 20  00 00 00 20 00 00 00 02  |disk... ... ....|
0000c7b0  69 64 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |id..............|
0000c7c0  00 00 00 04 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c7d0  67 75 69 64 00 00 00 08  00 00 00 01 b6 aa 20 be  |guid.......... .|
0000c7e0  b8 3a 21 61 00 00 00 28  00 00 00 28 00 00 00 04  |.:!a...(...(....|
0000c7f0  70 61 74 68 00 00 00 09  00 00 00 01 00 00 00 09  |path............|
0000c800  2f 64 65 76 2f 73 64 6b  31 00 00 00 00 00 00 28  |/dev/sdk1......(|
0000c810  00 00 00 28 00 00 00 0a  77 68 6f 6c 65 5f 64 69  |...(....whole_di|
0000c820  73 6b 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |sk..............|
0000c830  00 00 00 00 00 00 00 20  00 00 00 20 00 00 00 03  |....... ... ....|
0000c840  44 54 4c 00 00 00 00 08  00 00 00 01 00 00 00 00  |DTL.............|
0000c850  00 00 01 a5 00 00 00 28  00 00 00 28 00 00 00 0a  |.......(...(....|
0000c860  63 72 65 61 74 65 5f 74  78 67 00 00 00 00 00 08  |create_txg......|
0000c870  00 00 00 01 00 00 00 00  00 00 00 04 00 00 00 00  |................|
0000c880  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 c8  |................|
0000c890  00 00 00 40 00 00 00 11  66 65 61 74 75 72 65 73  |...@....features|
0000c8a0  5f 66 6f 72 5f 72 65 61  64 00 00 00 00 00 00 13  |_for_read.......|
0000c8b0  00 00 00 01 00 00 00 00  00 00 00 01 00 00 00 2c  |...............,|
0000c8c0  00 00 00 28 00 00 00 16  63 6f 6d 2e 64 65 6c 70  |...(....com.delp|
0000c8d0  68 69 78 3a 68 6f 6c 65  5f 62 69 72 74 68 00 00  |hix:hole_birth..|
0000c8e0  00 00 00 01 00 00 00 00  00 00 00 30 00 00 00 30  |...........0...0|
0000c8f0  00 00 00 19 63 6f 6d 2e  64 65 6c 70 68 69 78 3a  |....com.delphix:|
0000c900  65 6d 62 65 64 64 65 64  5f 64 61 74 61 00 00 00  |embedded_data...|
0000c910  00 00 00 01 00 00 00 00  00 00 00 34 00 00 00 30  |...........4...0|
0000c920  00 00 00 1d 63 6f 6d 2e  6b 6c 61 72 61 73 79 73  |....com.klarasys|
0000c930  74 65 6d 73 3a 76 64 65  76 5f 7a 61 70 73 5f 76  |tems:vdev_zaps_v|
0000c940  32 00 00 00 00 00 00 01  00 00 00 00 00 00 00 00  |2...............|
0000c950  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00019000
sdd
00000210  24 37 66 2c 00 00 00 00  01 00 00 00 00 00 00 00  |$7f,............|
00000230  8e be c0 d1 01 00 00 00  fa 89 4d 2a 08 07 23 47  |..........M*..#G|
00000240  92 ff 5d f7 d7 85 63 bc  02 00 00 00 00 00 00 00  |..]...c.........|
00000250  80 00 00 00 80 00 00 00  59 eb c1 a1 00 00 00 00  |........Y.......|
00000410  f9 41 3a 99 f9 49 0f 43  a9 66 af 3c 8d 6a 13 c1  |.A:..I.C.f.<.j..|
00005000  eb 52 90 00 00 00 00 00  00 00 00 00 02 08 00 00  |.R..............|
00005010  00 00 00 00 00 f8 00 00  3f 00 ff 00 28 00 00 00  |........?...(...|
00005020  00 00 00 00 80 00 80 00  66 be c0 d1 01 00 00 00  |........f.......|
00005030  13 58 d6 0d 00 00 00 00  fd 00 00 00 00 00 00 00  |.X..............|
00005040  f6 00 00 00 01 00 00 00  6c df 50 9c 3b ee 8c 4a  |........l.P.;..J|
00005050  00 00 00 00 fa 33 c0 8e  d0 bc 00 7c fb 68 c0 07  |.....3.....|.h..|
00005060  1f 1e 68 66 00 cb 88 16  0e 00 66 81 3e 03 00 4e  |..hf......f.>..N|
00005070  54 46 53 75 15 b4 41 bb  aa 55 cd 13 72 0c 81 fb  |TFSu..A..U..r...|
00005080  55 aa 75 06 f7 c1 01 00  75 03 e9 dd 00 1e 83 ec  |U.u.....u.......|
00005090  18 68 1a 00 b4 48 8a 16  0e 00 8b f4 16 1f cd 13  |.h...H..........|
000050a0  9f 83 c4 18 9e 58 1f 72  e1 3b 06 0b 00 75 db a3  |.....X.r.;...u..|
000050b0  0f 00 c1 2e 0f 00 04 1e  5a 33 db b9 00 20 2b c8  |........Z3... +.|
000050c0  66 ff 06 11 00 03 16 0f  00 8e c2 ff 06 16 00 e8  |f...............|
000050d0  4b 00 2b c8 77 ef b8 00  bb cd 1a 66 23 c0 75 2d  |K.+.w......f#.u-|
000050e0  66 81 fb 54 43 50 41 75  24 81 f9 02 01 72 1e 16  |f..TCPAu$....r..|
000050f0  68 07 bb 16 68 70 0e 16  68 09 00 66 53 66 53 66  |h...hp..h..fSfSf|
00005100  55 16 16 16 68 b8 01 66  61 0e 07 cd 1a 33 c0 bf  |U...h..fa....3..|
00005110  28 10 b9 d8 0f fc f3 aa  e9 5f 01 90 90 66 60 1e  |(........_...f`.|
00005120  06 66 a1 11 00 66 03 06  1c 00 1e 66 68 00 00 00  |.f...f.....fh...|
00005130  00 66 50 06 53 68 01 00  68 10 00 b4 42 8a 16 0e  |.fP.Sh..h...B...|
00005140  00 16 1f 8b f4 cd 13 66  59 5b 5a 66 59 66 59 1f  |.......fY[ZfYfY.|
00005150  0f 82 16 00 66 ff 06 11  00 03 16 0f 00 8e c2 ff  |....f...........|
00005160  0e 16 00 75 bc 07 1f 66  61 c3 a0 f8 01 e8 09 00  |...u...fa.......|
00005170  a0 fb 01 e8 03 00 f4 eb  fd b4 01 8b f0 ac 3c 00  |..............<.|
00005180  74 09 b4 0e bb 07 00 cd  10 eb f2 c3 0d 0a 41 20  |t.............A |
00005190  64 69 73 6b 20 72 65 61  64 20 65 72 72 6f 72 20  |disk read error |
000051a0  6f 63 63 75 72 72 65 64  00 0d 0a 42 4f 4f 54 4d  |occurred...BOOTM|
000051b0  47 52 20 69 73 20 6d 69  73 73 69 6e 67 00 0d 0a  |GR is missing...|
000051c0  42 4f 4f 54 4d 47 52 20  69 73 20 63 6f 6d 70 72  |BOOTMGR is compr|
000051d0  65 73 73 65 64 00 0d 0a  50 72 65 73 73 20 43 74  |essed...Press Ct|
000051e0  72 6c 2b 41 6c 74 2b 44  65 6c 20 74 6f 20 72 65  |rl+Alt+Del to re|
000051f0  73 74 61 72 74 0d 0a 00  8c a9 be d6 00 00 55 aa  |start.........U.|
00005200  07 00 42 00 4f 00 4f 00  54 00 4d 00 47 00 52 00  |..B.O.O.T.M.G.R.|
00005210  04 00 24 00 49 00 33 00  30 00 00 d4 00 00 00 24  |..$.I.3.0......$|
00005220  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00005250  00 00 00 00 00 00 eb 22  90 90 05 00 4e 00 54 00  |......."....N.T.|
00005260  4c 00 44 00 52 00 00 00  00 00 00 00 00 00 00 00  |L.D.R...........|
00005270  00 00 00 00 00 00 00 00  00 00 66 0f b7 06 0b 00  |..........f.....|
00005280  66 0f b6 1e 0d 00 66 f7  e3 66 a3 52 02 66 8b 0e  |f.....f..f.R.f..|
00005290  40 00 80 f9 00 0f 8f 0e  00 f6 d9 66 b8 01 00 00  |@..........f....|
000052a0  00 66 d3 e0 eb 08 90 66  a1 52 02 66 f7 e1 66 a3  |.f.....f.R.f..f.|
000052b0  66 02 66 0f b7 1e 0b 00  66 33 d2 66 f7 f3 66 a3  |f.f.....f3.f..f.|
000052c0  56 02 e8 95 04 66 8b 0e  4e 02 66 89 0e 26 02 66  |V....f..N.f..&.f|
000052d0  03 0e 66 02 66 89 0e 2a  02 66 03 0e 66 02 66 89  |..f.f..*.f..f.f.|
000052e0  0e 2e 02 66 03 0e 66 02  66 89 0e 3e 02 66 03 0e  |...f..f.f..>.f..|
000052f0  66 02 66 89 0e 46 02 66  b8 90 00 00 00 66 8b 0e  |f.f..F.f.....f..|
00005300  26 02 e8 83 09 66 0b c0  0f 84 5e fe 66 a3 32 02  |&....f....^.f.2.|
00005310  66 b8 a0 00 00 00 66 8b  0e 2a 02 e8 6a 09 66 a3  |f.....f..*..j.f.|
00005320  36 02 66 b8 b0 00 00 00  66 8b 0e 2e 02 e8 58 09  |6.f.....f.....X.|
00005330  66 a3 3a 02 66 a1 32 02  66 0b c0 0f 84 2b fe 67  |f.:.f.2.f....+.g|
00005340  80 78 08 00 0f 85 22 fe  67 66 8d 50 10 67 03 42  |.x....".gf.P.g.B|
00005350  04 67 66 0f b6 48 0c 66  89 0e 72 02 67 66 8b 48  |.gf..H.f..r.gf.H|
00005360  08 66 89 0e 6e 02 66 a1  6e 02 66 0f b7 0e 0b 00  |.f..n.f.n.f.....|
00005370  66 33 d2 66 f7 f1 66 a3  76 02 66 a1 46 02 66 03  |f3.f..f.v.f.F.f.|
00005380  06 6e 02 66 a3 4a 02 66  83 3e 36 02 00 0f 84 1d  |.n.f.J.f.>6.....|
00005390  00 66 83 3e 3a 02 00 0f  84 cf fd 66 8b 1e 3a 02  |.f.>:......f..:.|
000053a0  1e 07 66 8b 3e 4a 02 66  a1 2e 02 e8 e0 01 66 0f  |..f.>J.f......f.|
000053b0  b7 0e 00 02 66 b8 02 02  00 00 e8 22 08 66 0b c0  |....f......".f..|
000053c0  0f 85 16 00 66 0f b7 0e  5a 02 66 b8 5c 02 00 00  |....f...Z.f.\...|
000053d0  e8 0c 08 66 0b c0 0f 84  42 0c 67 66 8b 00 1e 07  |...f....B.gf....|
000053e0  66 8b 3e 3e 02 e8 3f 06  66 a1 3e 02 66 bb 20 00  |f.>>..?.f.>.f. .|
000053f0  00 00 66 b9 00 00 00 00  66 ba 00 00 00 00 e8 e4  |..f.....f.......|
00005400  00 66 85 c0 0f 85 23 00  66 a1 3e 02 66 bb 80 00  |.f....#.f.>.f...|
00005410  00 00 66 b9 00 00 00 00  66 ba 00 00 00 00 e8 c4  |..f.....f.......|
00005420  00 66 0b c0 0f 85 44 00  e9 f1 0b 66 33 d2 66 b9  |.f....D....f3.f.|
00005430  80 00 00 00 66 a1 3e 02  e8 ca 08 66 0b c0 0f 84  |....f.>....f....|
00005440  da 0b 1e 07 66 8b 3e 3e  02 e8 db 05 66 a1 3e 02  |....f.>>....f.>.|
00005450  66 bb 80 00 00 00 66 b9  00 00 00 00 66 ba 00 00  |f.....f.....f...|
00005460  00 00 e8 80 00 66 0b c0  0f 84 b0 0b 67 66 0f b7  |.....f......gf..|
00005470  58 0c 66 81 e3 ff 00 00  00 0f 85 a5 0b 66 8b d8  |X.f..........f..|
00005480  68 00 20 07 66 2b ff 66  a1 3e 02 e8 00 01 68 00  |h. .f+.f.>....h.|
00005490  20 07 66 2b ff 66 a1 3e  02 e8 ac 0a 8a 16 0e 00  | .f+.f.>........|
000054a0  b8 e8 03 8e c0 8d 36 0b  00 2b c0 68 00 20 50 cb  |......6..+.h. P.|
000054b0  06 1e 66 60 66 8b da 66  0f b6 0e 0d 00 66 f7 e1  |..f`f..f.....f..|
000054c0  66 a3 11 00 66 8b c3 66  f7 e1 a3 16 00 8b df 83  |f...f..f........|
000054d0  e3 0f 8c c0 66 c1 ef 04  03 c7 50 07 e8 3e fc 66  |....f.....P..>.f|
000054e0  61 90 1f 07 c3 67 03 40  14 67 66 83 38 ff 0f 84  |a....g.@.gf.8...|
000054f0  4c 00 67 66 39 18 0f 85  33 00 66 0b c9 0f 85 0a  |L.gf9...3.f.....|
00005500  00 67 80 78 09 00 0f 85  23 00 c3 67 3a 48 09 0f  |.g.x....#..g:H..|
00005510  85 1a 00 66 8b f0 67 03  70 0a e8 97 06 66 51 1e  |...f..g.p....fQ.|
00005520  07 66 8b fa f3 a7 66 59  0f 85 01 00 c3 67 66 83  |.f....fY.....gf.|
00005530  78 04 00 0f 84 07 00 67  66 03 40 04 eb ab 66 2b  |x......gf.@...f+|
00005540  c0 c3 66 8b f3 e8 6c 06  67 66 03 00 67 f7 40 0c  |..f...l.gf..g.@.|
00005550  02 00 0f 85 34 00 67 66  8d 50 10 67 3a 4a 40 0f  |....4.gf.P.g:J@.|
00005560  85 18 00 67 66 8d 72 42  e8 49 06 66 51 1e 07 66  |...gf.rB.I.fQ..f|
00005570  8b fb f3 a7 66 59 0f 85  01 00 c3 67 83 78 08 00  |....fY.....g.x..|
00005580  0f 84 06 00 67 03 40 08  eb c2 66 33 c0 c3 67 80  |....g.@...f3..g.|
00005590  7b 08 00 0f 85 1c 00 06  1e 66 60 67 66 8d 53 10  |{........f`gf.S.|
000055a0  67 66 8b 0a 66 8b f3 67  03 72 04 f3 a4 66 61 90  |gf..f..g.r...fa.|
000055b0  1f 07 c3 66 50 67 66 8d  53 10 66 85 c0 0f 85 0a  |...fPgf.S.f.....|
000055c0  00 67 66 8b 4a 08 66 41  eb 11 90 67 66 8b 42 18  |.gf.J.fA...gf.B.|
000055d0  66 33 d2 66 f7 36 52 02  66 8b c8 66 2b c0 66 5e  |f3.f.6R.f..f+.f^|
000055e0  e8 01 00 c3 06 1e 66 60  67 80 7b 08 01 0f 84 03  |......f`g.{.....|
000055f0  00 e9 76 fb 66 83 f9 00  0f 85 06 00 66 61 90 1f  |..v.f.......fa..|
00005600  07 c3 66 53 66 50 66 51  66 56 66 57 06 e8 91 04  |..fSfPfQfVfW....|
00005610  66 8b d1 07 66 5f 66 5e  66 59 66 85 c0 0f 84 34  |f...f_f^fYf....4|
00005620  00 66 3b ca 0f 8d 03 00  66 8b d1 e8 82 fe 66 2b  |.f;.....f.....f+|
00005630  ca 66 8b da 66 8b c2 66  0f b6 16 0d 00 66 f7 e2  |.f..f..f.....f..|
00005640  66 0f b7 16 0b 00 66 f7  e2 66 03 f8 66 58 66 03  |f.....f..f..fXf.|
00005650  c3 66 5b eb 9f 66 85 f6  0f 84 0e fb 66 51 66 57  |.f[..f......fQfW|
00005660  06 67 66 0f b6 43 09 66  85 c0 0f 84 20 00 66 d1  |.gf..C.f.... .f.|
00005670  e0 66 2b e0 66 8b fc 66  54 66 56 67 66 0f b7 73  |.f+.f..fTfVgf..s|
00005680  0a 66 03 f3 66 8b c8 f3  a4 66 5e eb 03 90 66 50  |.f..f....f^...fP|
00005690  66 50 67 66 8b 03 66 50  67 66 8b 43 18 66 50 67  |fPgf..fPgf.C.fPg|
000056a0  66 8b 56 20 66 85 d2 0f  84 0b 00 66 8b fe 1e 07  |f.V f......f....|
000056b0  66 8b c2 e8 71 03 66 8b  c6 66 5a 66 59 66 42 66  |f...q.f..fZfYfBf|
000056c0  51 66 56 e8 3f 06 66 85  c0 0f 84 9d fa 66 5e 66  |QfV.?.f......f^f|
000056d0  59 66 8b fe 1e 07 e8 4e  03 66 8b c6 66 8b d9 66  |Yf.....N.f..f..f|
000056e0  59 66 5a 66 51 66 56 66  d1 e9 e8 f8 fd 66 85 c0  |YfZfQfVf.....f..|
000056f0  0f 84 76 fa 66 5e 66 59  66 03 e1 07 66 5f 66 59  |..v.f^fYf...f_fY|
00005700  66 8b d0 66 58 66 5b 66  8b da e9 f5 fe 06 1e 66  |f..fXf[f.......f|
00005710  60 26 67 66 0f b7 5f 04  26 67 66 0f b7 4f 06 66  |`&gf.._.&gf..O.f|
00005720  0b c9 0f 84 44 fa 66 03  df 66 83 c3 02 66 81 c7  |....D.f..f...f..|
00005730  fe 01 00 00 66 49 66 0b  c9 0f 84 17 00 26 67 8b  |....fIf......&g.|
00005740  03 26 67 89 07 66 83 c3  02 66 81 c7 00 02 00 00  |.&g..f...f......|
00005750  66 49 eb e2 66 61 90 1f  07 c3 06 1e 66 60 66 b8  |fI..fa......f`f.|
00005760  01 00 00 00 66 a3 22 02  66 a1 1e 02 66 03 06 66  |....f.".f...f..f|
00005770  02 66 a3 6a 02 66 03 06  66 02 66 a3 4e 02 66 a1  |.f.j.f..f.f.N.f.|
00005780  30 00 66 0f b6 1e 0d 00  66 f7 e3 66 8b 1e 4e 02  |0.f.....f..f..N.|
00005790  66 89 07 66 a3 11 00 83  c3 04 66 a1 56 02 66 89  |f..f......f.V.f.|
000057a0  07 a3 16 00 83 c3 04 66  89 1e 4e 02 66 8b 1e 1e  |.......f..N.f...|
000057b0  02 1e 07 e8 67 f9 66 8b  fb e8 51 ff 66 a1 1e 02  |....g.f...Q.f...|
000057c0  66 bb 20 00 00 00 66 b9  00 00 00 00 66 ba 00 00  |f. ...f.....f...|
000057d0  00 00 e8 10 fd 66 0b c0  0f 84 19 01 66 8b d8 1e  |.....f......f...|
000057e0  07 66 8b 3e 1a 02 66 33  c0 e8 a2 fd 66 8b 1e 1a  |.f.>..f3....f...|
000057f0  02 66 81 3f 80 00 00 00  0f 84 eb 00 03 5f 04 eb  |.f.?........._..|
00005800  f0 66 53 66 8b 47 10 66  f7 26 56 02 66 50 66 33  |.fSf.G.f.&V.fPf3|
00005810  d2 66 0f b6 1e 0d 00 66  f7 f3 66 52 e8 dc 00 66  |.f.....f..fR...f|
00005820  0b c0 0f 84 44 f9 66 8b  0e 56 02 66 0f b6 1e 0d  |....D.f..V.f....|
00005830  00 66 f7 e3 66 5a 66 03  c2 66 8b 1e 4e 02 66 89  |.f..fZf..f..N.f.|
00005840  07 83 c3 04 66 0f b6 06  0d 00 66 2b c2 66 3b c1  |....f.....f+.f;.|
00005850  0f 86 03 00 66 8b c1 66  89 07 66 2b c8 66 5a 0f  |....f..f..f+.fZ.|
00005860  84 75 00 66 03 c2 66 50  66 33 d2 66 0f b6 1e 0d  |.u.f..fPf3.f....|
00005870  00 66 f7 f3 66 51 e8 82  00 66 59 66 0b c0 0f 84  |.f..fQ...fYf....|
00005880  e8 f8 66 0f b6 1e 0d 00  66 f7 e3 66 8b 1e 4e 02  |..f.....f..f..N.|
00005890  66 8b 17 83 c3 04 66 03  17 66 3b d0 0f 85 15 00  |f.....f..f;.....|
000058a0  66 0f b6 06 0d 00 66 3b  c1 0f 86 03 00 66 8b c1  |f.....f;.....f..|
000058b0  66 01 07 eb a5 83 c3 04  66 89 1e 4e 02 66 89 07  |f.......f..N.f..|
000058c0  83 c3 04 66 0f b6 06 0d  00 66 3b c1 0f 86 03 00  |...f.....f;.....|
000058d0  66 8b c1 66 89 07 eb 82  83 c3 04 66 ff 06 22 02  |f..f.......f..".|
000058e0  66 89 1e 4e 02 66 5b 03  5f 04 66 81 3f 80 00 00  |f..N.f[._.f.?...|
000058f0  00 0f 84 0c ff 66 61 90  1f 07 c3 66 8b d0 66 8b  |.....fa....f..f.|
00005900  0e 22 02 66 8b 36 6a 02  66 03 36 66 02 66 52 66  |.".f.6j.f.6f.fRf|
00005910  51 66 52 66 8b 1e 6a 02  66 8b 3e 56 02 66 8b 04  |QfRf..j.f.>V.f..|
00005920  66 a3 11 00 83 c6 04 66  8b 04 a3 16 00 83 c6 04  |f......f........|
00005930  1e 07 e8 e8 f7 66 2b f8  0f 84 08 00 f7 26 0b 00  |.....f+......&..|
00005940  03 d8 eb d9 66 8b 3e 6a  02 1e 07 e8 bf fd 66 a1  |....f.>j......f.|
00005950  6a 02 66 bb 80 00 00 00  66 b9 00 00 00 00 66 8b  |j.f.....f.....f.|
00005960  d1 e8 81 fb 66 0b c0 0f  84 ff f7 66 8b d8 66 58  |....f......f..fX|
00005970  66 56 e8 2c 01 66 5e 66  0b c0 0f 84 05 00 66 5b  |fV.,.f^f......f[|
00005980  66 5b c3 66 59 66 5a e2  84 66 33 c0 c3 06 1e 66  |f[.fYfZ..f3....f|
00005990  60 66 50 66 51 66 33 d2  66 0f b6 1e 0d 00 66 f7  |`fPfQf3.f.....f.|
000059a0  f3 66 52 66 57 e8 53 ff  66 5f 66 0b c0 0f 84 b9  |.fRfW.S.f_f.....|
000059b0  f7 66 0f b6 1e 0d 00 66  f7 e3 66 5a 66 03 c2 66  |.f.....f..fZf..f|
000059c0  a3 11 00 66 59 66 0f b6  1e 0d 00 66 3b cb 0f 8e  |...fYf.....f;...|
000059d0  13 00 89 1e 16 00 66 2b  cb 66 58 66 03 c3 66 50  |......f+.fXf..fP|
000059e0  66 51 eb 14 90 66 58 66  03 c1 66 50 89 0e 16 00  |fQ...fXf..fP....|
000059f0  66 b9 00 00 00 00 66 51  06 66 57 8b df 83 e3 0f  |f.....fQ.fW.....|
00005a00  8c c0 66 c1 ef 04 03 c7  50 07 e8 10 f7 66 5f 07  |..f.....P....f_.|
00005a10  66 03 3e 52 02 66 59 66  58 66 83 f9 00 0f 8f 70  |f.>R.fYfXf.....p|
00005a20  ff 66 61 90 1f 07 c3 06  1e 66 60 66 f7 26 56 02  |.fa......f`f.&V.|
00005a30  66 8b 0e 56 02 e8 55 ff  e8 d2 fc 66 61 90 1f 07  |f..V..U....fa...|
00005a40  c3 06 1e 66 60 66 f7 26  72 02 66 8b 1e 36 02 66  |...f`f.&r.f..6.f|
00005a50  8b 0e 72 02 66 8b 36 2a  02 1e 07 66 8b 3e 46 02  |..r.f.6*...f.>F.|
00005a60  e8 81 fb e8 a7 fc 66 61  90 1f 07 c3 66 50 66 53  |......fa....fPfS|
00005a70  66 51 66 8b 1e 4a 02 66  8b c8 66 c1 e8 03 66 83  |fQf..J.f..f...f.|
00005a80  e1 07 66 03 d8 66 b8 01  00 00 00 66 d3 e0 67 84  |..f..f.....f..g.|
00005a90  03 0f 84 04 00 f8 eb 02  90 f9 66 59 66 5b 66 58  |..........fYf[fX|
00005aa0  c3 67 80 7b 08 01 0f 84  04 00 66 2b c0 c3 67 66  |.g.{......f+..gf|
00005ab0  8d 73 10 67 66 8b 56 08  66 3b c2 0f 87 0b 00 67  |.s.gf.V.f;.....g|
00005ac0  66 8b 16 66 3b c2 0f 83  04 00 66 2b c0 c3 67 03  |f..f;.....f+..g.|
00005ad0  5e 10 66 2b f6 67 80 3b  00 0f 84 3e 00 e8 81 00  |^.f+.g.;...>....|
00005ae0  66 03 f1 e8 39 00 66 03  ca 66 3b c1 0f 8c 21 00  |f...9.f..f;...!.|
00005af0  66 8b d1 66 50 67 66 0f  b6 0b 66 8b c1 66 83 e0  |f..fPgf...f..f..|
00005b00  0f 66 c1 e9 04 66 03 d9  66 03 d8 66 43 66 58 eb  |.f...f..f..fCfX.|
00005b10  c4 66 2b c8 66 2b c2 66  03 c6 c3 66 2b c0 c3 66  |.f+.f+.f...f+..f|
00005b20  2b c9 67 8a 0b 80 e1 0f  66 83 f9 00 0f 85 04 00  |+.g.....f.......|
00005b30  66 2b c9 c3 66 53 66 52  66 03 d9 67 66 0f be 13  |f+..fSfRf..gf...|
00005b40  66 49 66 4b 66 83 f9 00  0f 84 0d 00 66 c1 e2 08  |fIfKf.......f...|
00005b50  67 8a 13 66 4b 66 49 eb  eb 66 8b ca 66 5a 66 5b  |g..fKfI..f..fZf[|
00005b60  c3 66 53 66 52 66 2b d2  67 8a 13 66 83 e2 0f 66  |.fSfRf+.g..f...f|
00005b70  2b c9 67 8a 0b c0 e9 04  66 83 f9 00 0f 85 08 00  |+.g.....f.......|
00005b80  66 2b c9 66 5a 66 5b c3  66 03 da 66 03 d9 67 66  |f+.fZf[.f..f..gf|
00005b90  0f be 13 66 49 66 4b 66  83 f9 00 0f 84 0d 00 66  |...fIfKf.......f|
00005ba0  c1 e2 08 67 8a 13 66 4b  66 49 eb eb 66 8b ca 66  |...g..fKfI..f..f|
00005bb0  5a 66 5b c3 66 0b c9 0f  85 01 00 c3 66 51 66 56  |Zf[.f.......fQfV|
00005bc0  67 83 3e 61 0f 8c 0c 00  67 83 3e 7a 0f 8f 04 00  |g.>a....g.>z....|
00005bd0  67 83 2e 20 66 83 c6 02  e2 e6 66 5e 66 59 c3 66  |g.. f.....f^fY.f|
00005be0  50 66 51 66 8b d0 66 a1  32 02 67 66 8d 58 10 67  |PfQf..f.2.gf.X.g|
00005bf0  03 43 04 67 66 8d 40 10  66 8b da e8 44 f9 66 0b  |.C.gf.@.f...D.f.|
00005c00  c0 0f 84 05 00 66 59 66  59 c3 66 a1 36 02 66 0b  |.....fYfY.f.6.f.|
00005c10  c0 0f 85 08 00 66 59 66  59 66 33 c0 c3 66 8b 16  |.....fYfYf3..f..|
00005c20  36 02 67 66 8d 52 10 67  66 8b 42 18 66 33 d2 66  |6.gf.R.gf.B.f3.f|
00005c30  f7 36 6e 02 66 33 f6 66  50 66 56 66 58 66 5e 66  |.6n.f3.fPfVfXf^f|
00005c40  3b c6 0f 84 3a 00 66 56  66 40 66 50 66 48 e8 1b  |;...:.fVf@fPfH..|
00005c50  fe 72 e8 e8 eb fd 66 5a  66 5e 66 59 66 5b 66 53  |.r....fZf^fYf[fS|
00005c60  66 51 66 56 66 52 66 a1  46 02 67 66 8d 40 18 e8  |fQfVfRf.F.gf.@..|
00005c70  d0 f8 66 0b c0 74 c4 66  59 66 59 66 59 66 59 c3  |..f..t.fYfYfYfY.|
00005c80  66 59 66 59 66 33 c0 c3  66 51 66 50 66 b8 05 00  |fYfYf3..fQfPf...|
00005c90  00 00 1e 07 66 8b f9 e8  8d fd 66 8b c1 66 bb 20  |....f.....f..f. |
00005ca0  00 00 00 66 b9 00 00 00  00 66 ba 00 00 00 00 e8  |...f.....f......|
00005cb0  33 f8 66 5b 66 59 66 85  c0 0f 85 15 00 66 8b c1  |3.f[fYf......f..|
00005cc0  66 0f b7 0e 10 02 66 ba  12 02 00 00 e8 16 f8 eb  |f.....f.........|
00005cd0  33 90 66 33 d2 66 8b c1  66 8b cb 66 50 66 53 e8  |3.f3.f..f..fPfS.|
00005ce0  23 00 66 5b 66 5f 66 0b  c0 0f 84 17 00 1e 07 e8  |#.f[f_f.........|
00005cf0  35 fd 66 8b c7 66 0f b7  0e 10 02 66 ba 12 02 00  |5.f..f.....f....|
00005d00  00 e8 e1 f7 c3 66 52 66  51 66 bb 20 00 00 00 66  |.....fRfQf. ...f|
00005d10  b9 00 00 00 00 66 ba 00  00 00 00 e8 c7 f7 66 0b  |.....f........f.|
00005d20  c0 0f 84 63 00 66 8b d8  1e 07 66 8b 3e 1a 02 66  |...c.f....f.>..f|
00005d30  33 c0 e8 59 f8 1e 07 66  8b 1e 1a 02 66 59 66 5a  |3..Y...f....fYfZ|
00005d40  26 66 39 0f 0f 85 0c 00  26 66 39 57 08 0f 84 31  |&f9.....&f9W...1|
00005d50  00 eb 13 90 26 66 83 3f  ff 0f 84 2f 00 26 83 7f  |....&f.?.../.&..|
00005d60  04 00 0f 84 26 00 26 66  0f b7 47 04 03 d8 8b c3  |....&.&f..G.....|
00005d70  25 00 80 74 cb 8c c0 05  00 08 8e c0 81 e3 ff 7f  |%..t............|
00005d80  eb be 26 66 8b 47 10 c3  66 59 66 5a 66 33 c0 c3  |..&f.G..fYfZf3..|
00005d90  66 50 66 51 66 8b c7 66  c1 e8 04 06 59 03 c8 51  |fPfQf..f....Y..Q|
00005da0  07 66 83 e7 0f 66 59 66  58 c3 60 06 be bd 0d bf  |.f...fYfX.`.....|
00005db0  00 20 1e 07 b9 0d 00 90  f3 a5 07 61 c3 01 23 45  |. .........a..#E|
00005dc0  67 89 ab cd ef fe dc ba  98 76 54 32 10 f0 e1 d2  |g........vT2....|
00005dd0  c3 00 00 00 00 20 20 60  8b 36 18 20 26 8a 05 88  |.....  `.6. &...|
00005de0  04 47 46 66 ff 06 14 20  81 fe 60 20 75 06 e8 5b  |.GFf... ..` u..[|
00005df0  00 be 20 20 e2 e6 89 36  18 20 61 c3 66 60 8b 36  |..  ...6. a.f`.6|
00005e00  18 20 b0 80 88 04 46 32  c0 81 fe 60 20 75 06 e8  |. ....F2...` u..|
00005e10  3a 00 be 20 20 81 fe 58  20 75 e9 66 33 c0 66 a3  |:..  ..X u.f3.f.|
00005e20  58 20 66 a1 14 20 66 c1  e0 03 66 0f c8 66 a3 5c  |X f.. f...f..f.\|
00005e30  20 e8 18 00 bb 00 20 66  8b 07 66 0f c8 66 89 07  | ..... f..f..f..|
00005e40  83 c3 04 81 fb 34 20 75  ee 66 61 c3 66 60 bb 20  |.....4 u.fa.f`. |
00005e50  20 66 8b 07 66 0f c8 66  89 07 83 c3 04 81 fb 60  | f..f..f.......`|
00005e60  20 75 ee bb 00 20 66 8b  0f 66 8b 57 04 66 8b 77  | u... f..f.W.f.w|
00005e70  08 66 8b 7f 0c 66 8b 6f  10 bb 20 20 c7 06 1a 20  |.f...f.o..  ... |
00005e80  30 0f c6 06 1c 20 14 90  53 8b 1e 1a 20 ff 17 66  |0.... ..S... ..f|
00005e90  03 47 02 5b 66 03 e8 66  03 2f 66 8b c1 66 c1 c0  |.G.[f..f./f..f..|
00005ea0  05 66 03 c5 66 8b ef 66  8b fe 66 8b f2 66 c1 c6  |.f..f..f..f..f..|
00005eb0  1e 66 8b d1 66 8b c8 66  8b 07 66 33 47 08 66 33  |.f..f..f..f3G.f3|
00005ec0  47 20 66 33 47 34 66 d1  c0 66 89 47 40 83 c3 04  |G f3G4f..f.G@...|
00005ed0  fe 0e 1c 20 75 b2 83 06  1a 20 06 81 3e 1a 20 48  |... u.... ..>. H|
00005ee0  0f 75 9f bb 00 20 66 01  0f 66 01 57 04 66 01 77  |.u... f..f.W.f.w|
00005ef0  08 66 01 7f 0c 66 01 6f  10 66 61 c3 66 8b c6 66  |.f...f.o.fa.f..f|
00005f00  33 c7 66 23 c2 66 33 c7  c3 66 8b c2 66 33 c6 66  |3.f#.f3..f..f3.f|
00005f10  33 c7 c3 66 53 66 8b c2  66 23 c6 66 8b da 66 23  |3..fSf..f#.f..f#|
00005f20  df 66 0b c3 66 8b de 66  23 df 66 0b c3 66 5b c3  |.f..f..f#.f..f[.|
00005f30  fc 0e 99 79 82 5a 09 0f  a1 eb d9 6e 13 0f dc bc  |...y.Z.....n....|
00005f40  1b 8f 09 0f d6 c1 62 ca  06 1e 66 60 66 33 db b8  |......b...f`f3..|
00005f50  00 bb cd 1a 66 23 c0 0f  85 bb 00 66 81 fb 54 43  |....f#.....f..TC|
00005f60  50 41 0f 85 b0 00 81 f9  02 01 0f 82 a8 00 66 61  |PA............fa|
00005f70  90 1f 07 06 1e 66 60 67  80 7b 08 00 0f 85 0c 00  |.....f`g.{......|
00005f80  67 66 8d 53 10 67 66 8b  0a eb 25 90 67 66 8d 53  |gf.S.gf...%.gf.S|
00005f90  10 67 66 8b 4a 28 66 81  f9 00 00 08 00 0f 83 0c  |.gf.J(f.........|
00005fa0  00 67 66 8b 42 2c 66 23  c0 0f 84 03 00 66 33 c9  |.gf.B,f#.....f3.|
00005fb0  0e 1f e8 f5 fd 66 23 c9  0f 84 32 00 66 ba 00 80  |.....f#...2.f...|
00005fc0  00 00 66 3b ca 0f 86 1f  00 66 2b ca 06 66 51 66  |..f;.....f+..fQf|
00005fd0  57 66 52 66 8b ca e8 b7  fd e8 fb fd 66 5a 66 5f  |WfRf........fZf_|
00005fe0  66 59 07 66 03 fa eb da  e8 a5 fd e8 e9 fd e8 0b  |fY.f............|
00005ff0  fe 0e 07 66 bb 54 43 50  41 66 bf 00 20 00 00 66  |...f.TCPAf.. ..f|
00006000  b9 14 00 00 00 66 b8 07  bb 00 00 66 ba 0a 00 00  |.....f.....f....|
00006010  00 66 33 f6 cd 1a 66 61  90 1f 07 c3 a0 f9 01 e9  |.f3...fa........|
00006020  4b f1 a0 fa 01 e9 45 f1  00 00 00 00 00 00 00 00  |K.....E.........|
00006030  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00006e00  6b 87 08 38 76 c1 48 4e  b7 ae 04 04 6e 6c c7 52  |k..8v.HN....nl.R|
00006e10  02 00 00 00 01 00 00 00  00 1e 00 00 00 00 00 00  |................|
00006e20  00 1e 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00006e30  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00006e40  81 27 9b bb 28 dc ee 11  a9 f3 10 a5 1d 52 8b 67  |.'..(........R.g|
00006e60  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00007000  50 4b 03 04 14 00 08 08  08 00 c4 88 bc 48 00 00  |PK...........H..|
00007010  00 00 00 00 00 00 00 00  00 00 17 00 00 00 31 5c  |..............1\|
00007020  43 61 6d 65 72 61 52 61  77 52 49 42 53 43 6f 45  |CameraRawRIBSCoE|
00007030  78 69 73 74 2f 03 00 50  4b 07 08 00 00 00 00 02  |xist/..PK.......|
00007040  00 00 00 00 00 00 00 50  4b 03 04 14 00 08 08 08  |.......PK.......|
00007050  00 d7 88 bc 48 00 00 00  00 00 00 00 00 00 00 00  |....H...........|
00007060  00 3e 00 00 00 31 5c 43  61 6d 65 72 61 52 61 77  |.>...1\CameraRaw|
00007070  52 49 42 53 43 6f 45 78  69 73 74 5c 7b 33 45 37  |RIBSCoExist\{3E7|
00007080  46 43 37 35 37 2d 44 34  39 37 2d 34 43 38 39 2d  |FC757-D497-4C89-|
00007090  41 39 33 35 2d 37 44 33  38 45 32 31 36 34 45 38  |A935-7D38E2164E8|
000070a0  35 7d 2f 03 00 50 4b 07  08 00 00 00 00 02 00 00  |5}/..PK.........|
000070b0  00 00 00 00 00 50 4b 03  04 14 00 08 08 08 00 08  |.....PK.........|
000070c0  7c bc 48 00 00 00 00 00  00 00 00 00 00 00 00 49  ||.H............I|
000070d0  00 00 00 31 2f 43 61 6d  65 72 61 52 61 77 52 49  |...1/CameraRawRI|
000070e0  42 53 43 6f 45 78 69 73  74 2f 7b 33 45 37 46 43  |BSCoExist/{3E7FC|
000070f0  37 35 37 2d 44 34 39 37  2d 34 43 38 39 2d 41 39  |757-D497-4C89-A9|
00007100  33 35 2d 37 44 33 38 45  32 31 36 34 45 38 35 7d  |35-7D38E2164E85}|
00007110  2f 4d 65 64 69 61 5f 64  62 2e 64 62 ed bd 69 7c  |/Media_db.db..i||
00007120  2c d9 75 1f d6 0d cc bc  37 43 6a c4 65 48 0e 29  |,.u.....7Cj.eH.)|
00007130  8a 22 f8 48 8a 1c 62 6a  50 f7 d6 ad 8d 7c f3 a8  |.".H..bjP....|..|
00007140  bb 02 8d 1d 8d bd 66 86  60 37 d0 00 1a e8 05 af  |......f.`7......|
00007150  bb b1 92 b4 0d 4a 72 b4  38 8e e3 35 b1 93 28 36  |.....Jr.8..5..(6|
00007160  b3 6f ce 4a 4b b2 13 39  14 6d e9 17 eb 17 79 f9  |.o.JK..9.m....y.|
00007170  c5 bf 7c 70 be 46 56 e2  7c c8 07 3b 1f fc c1 39  |..|p.FV.|..;...9|
00007180  b7 01 74 f7 7b f3 aa a7  ce 68 66 38 24 71 1f ea  |..t.{....hf8$q..|
00007190  a1 d1 55 f7 d4 ad 53 e7  9e f3 3f 77 39 67 79 69  |..U...S...?w9gyi|
000071a0  b6 da a9 8c ed 36 5b f5  52 67 cc cb 3d 95 cb e7  |.....6[.Rg..=...|
000071b0  73 3f 37 36 96 cb e5 9e  83 e3 eb 70 4c c1 f1 32  |s?76.......pL..2|
000071c0  1c ef 87 e3 a9 5c bf e4  73 6f 5e 9e cb 39 7f f8  |.....\..so^..9..|
000071d0  7f 3d 0d 1f 46 46 ff 85  fd fb c3 a3 ff f2 ea c3  |.=..FF..........|
000071e0  6d b9 2d b7 e5 07 58 de  6f bb f7 fb ee d8 ff 6d  |m.-...X.o......m|
000071f0  af ce 7f 28 57 18 fd 97  3f e0 36 bd 17 ca 2f d6  |...(W...?.6.../.|
00007200  f2 4f 6f 7e fa 57 be f5  0d 4f 87 46 86 7e e8 28  |.Oo~.W...O.F.~.(|
00007210  16 87 0e 93 51 ec f0 d8  f3 9d 50 79 91 a6 24 60  |....Q.....Py..$`|
00007220  3a f2 bf c5 e7 56 64 b3  b1 5b dd 5b 54 31 2b af  |:....Vd..[.[T1+.|
00007230  9f ee ed d4 d7 ce b7 69  ed a4 7c e0 56 e7 96 d9  |.......i..|.V...|
00007240  69 a1 2a 6a e5 fa fc 49  32 59 3b 4e 2e dc ea ce  |i.*j...I2Y;N....|
00007250  46 b1 3e bb b2 57 5d bc  60 f3 f2 e0 4c 95 a9 5f  |F.>..W].`...L.._|
00007260  2f ad ef 90 ed ba 71 4b  eb f1 f1 e2 9e 3b 53 90  |/.....qK.....;S.|
00007270  7c af a0 ce 96 36 37 6a  ed 32 35 87 bd ef ae 8e  ||....67j.25.....|
00007280  a8 b0 ec 76 0a 93 c5 5a  52 37 a4 3c 55 14 c9 64  |...v...ZR7.<U..d|
00007290  5c 4d 56 ed 3d 56 f7 92  7a 7c 6e cf 41 3b da 65  |\MV.=V..z|n.A;.e|
000072a0  4f 74 92 75 df 2d 4c ad  5d 24 cb 6c 6f 76 d9 1d  |Ot.u.-L.]$.lov..|
000072b0  57 4b cd bd 1e 2d 75 a6  37 37 8a fb 85 c9 4e ad  |WK...-u.77....N.|
000072c0  b2 e2 56 93 c9 b5 fa e6  c6 5a 7b 47 9b c3 32 9d  |..V......Z{G..2.|
000072d0  ae 2d d1 f8 30 59 2e 8c  2f 51 d3 49 36 a6 f7 37  |.-..0Y../Q.I6..7|
000072e0  c8 f4 fe ce 39 99 2e 37  e6 dd cd f5 b3 76 b2 51  |....9..7.....v.Q|
000072f0  e8 2c ad 17 4f 36 eb 6b  f0 1c c5 da a2 8c bb f4  |.,..O6.k........|
00007300  1e 6f 6f 71 d2 b8 9b cb  a2 95 6c 1c c6 85 c3 b3  |.ooq......l.....|
00007310  a3 4d ba 76 0c 3c 3a 4e  dc 6e 9b ab 8b 87 f3 fb  |.M.v.<:N.n......|
00007320  e5 f5 b5 f3 cd b5 78 79  73 63 bb b3 20 c9 46 69  |......xysc.. .Fi|
00007330  9d 75 8a ae 1b cd ba c5  fd 9d 49 dd 6b 37 dc e3  |.u........I.k7..|
00007340  11 be c8 95 b3 c5 9d c9  fd da 76 55 ec 0f f0 01  |..........vU....|
00007350  ee 93 4a b3 3a bc 7d 6b  4b cb ab f3 bb 4b 6b 62  |..J.:.}kK....Kkb|
00007360  a9 70 e0 2f 95 26 63 b7  ec cd 37 cb 1e df bb e1  |.p./.&c...7.....|
00007370  43 c1 00 1f 2e 4e 4f ba  f5 56 e0 3d 56 7b b4 f6  |C....NO..V.=V{..|
00007380  16 75 b7 bd 7b 25 ba e6  2f 2e 4f 9b 55 5d 53 1b  |.u..{%../.O.U]S.|
00007390  ae 59 5a 35 d1 e9 50 7a  e7 9c cd 1e f0 37 3c ef  |.YZ5..Pz.....7<.|
000073a0  93 de 53 d1 9b de 07 1e  2e 41 dd a3 32 5d aa 2e  |..S......A..2]..|
000073b0  1e e8 d3 39 c5 4f df c0  7f 75 7a b2 e2 15 9b f0  |...9.O...uz.....|
000073c0  9e 2c 3d a0 3d 7f 52 ae  27 47 89 07 7c d9 28 42  |.,=.=.R.'G..|.(B|
000073d0  5d 36 fe 3e 2b f3 d0 ff  47 ff de e8 9f ff 41 77  |]6.>+...G.....Aw|
000073e0  bd db 72 5b 6e 4b 2e 17  3c b5 f9 d9 7c 36 fb b3  |..r[nK..<...|6..|
000073f0  d8 6a ee 1c 6f 77 0a db  cd c6 08 7b 6a f3 d3 19  |.j..ow.....{j...|
00007400  ab f5 cc 56 be 67 ff 3f  fe e8 bf d1 bf 9c f6 ef  |...V.g.?........|
00007410  07 cd 9d 77 a7 24 97 53  77 37 37 3f f9 dc 73 cf  |...w.$.Sw77?..s.|
00007420  65 e3 e8 37 78 a8 5d 19  69 e2 b8 9a 19 87 85 be  |e..7x.].i.......|
00007430  e7 70 11 06 8e f0 04 0f  4d a0 5c c6 a3 6f 1d 1f  |.p......M.\..o..|
00007440  ed b5 4a 3b 15 70 87 7e  15 45 5c 29 a1 a8 af 99  |..J;.p.~.E\)....|
00007450  13 45 4c 3b cc e7 be 13  f9 46 38 24 08 5c 3f 60  |.EL;.....F8$.\?`|
00007460  26 96 da 0c 10 7f 19 45  dc 0d 95 e6 5c 49 47 84  |&......E....\IG.|
00007470  21 05 e2 21 73 78 48 22  27 0a 84 62 94 ca 20 26  |!..!sxH"'..b.. &|
00007480  7e 9f 78 fe 1f a0 88 fb  ae 0c 43 d7 68 87 f3 80  |~.x.......C.h...|
00007490  38 2c 90 d4 89 dc 80 3a  c2 8f 02 e2 f9 5a 32 11  |8,.....:.....Z2.|
000074a0  0e 10 ef e0 d8 42 3c 37  36 d2 75 5c 0a ff 31 8f  |.....B<76.u\..1.|
000074b0  85 c0 6e c9 1c 5f 0a df  44 ca 44 26 1c 60 4b fe  |..n.._..D.D&.`K.|
000074c0  05 14 71 c1 81 84 ef 03  dd 98 c0 55 26 82 96 0b  |..q........U&...|
000074d0  57 3a 46 f8 01 21 91 52  84 0d b0 25 f7 9b 28 e2  |W:F..!.R...%..(.|
000074e0  51 64 44 10 05 c0 73 16  86 f6 0e b1 13 29 17 e4  |QdD...s......)..|
000074f0  26 52 21 a7 44 88 d8 a3  03 c4 5f 47 11 a7 3e 13  |&R!.D....._G..>.|
00007500  be 17 09 47 48 0f 5e a8  c7 89 13 19 45 1d e2 87  |...GH.^.....E...|
00007510  81 f6 84 4b 22 2a 6f 88  df d8 ff fc ef e5 56 de  |...K"*o.......V.|
00007520  f0 ef 2d 96 d7 9f b9 6a  ee c8 3b 21 dd bf 33 f2  |..-....j..;!..3.|
00007530  a5 fc 4f a1 a8 63 84 e4  fb 23 5f ca fd 2d 0c 75  |..O..c...#_..-.u|
00007540  94 94 fc 36 50 ff 1a 86  3a 57 a1 32 ae 00 e1 f0  |...6P...:W.2....|
00007550  23 cb 19 2f 72 b8 eb 85  8e 96 82 48 e0 8c 92 ae  |#../r......H....|
00007560  ee 51 ff 2d 2c df 51 2a  eb 77 41 46 fe 31 86 3a  |.Q.-,.Q*.wAF.1.:|
00007570  4a c4 bf 37 aa 70 9c 09  03 16 53 4d 02 07 f4 8b  |J..7.p....SM....|
00007580  6f 95 16 c8 78 ac b4 e3  49 e5 6a 15 51 23 8d ea  |o...x...I.j.Q#..|
00007590  51 ff db 58 ce a0 b4 d6  df 01 91 47 b5 1d d3 3f  |Q..X.......G...?|
000075a0  73 ff 33 b6 ed 28 75 fe  77 6f ec ff 6d b9 2d b7  |s.3..(u.wo..m.-.|
000075b0  e5 c7 af dc d8 ff db 72  5b 6e cb 8f 5f b1 73 73  |.......r[n.._.ss|
000075c0  a3 a3 ff af fd f8 75 3b  37 77 f5 f1 b6 dc 96 db  |......u;7w......|
000075d0  f2 a3 5a b6 9e 81 ff 26  47 e0 3f 93 b7 f6 ff d9  |..Z....&G.?.....|
000075e0  fc bf ca 8d fc d5 91 28  ff af 46 fe c9 48 73 74  |.......(..F..Hst|
000075f0  71 f4 fb a3 bf 3c fa fc  0f b8 91 b7 e5 dd 28 d1  |q....<........(.|
00007600  d3 9b 1f c8 3a d6 ec ca  fd 52 a3 51 a9 15 1a bb  |....:....R.Q....|
00007610  cd 67 03 a8 98 75 b4 b9  57 51 3d 43 a0 da 47 b3  |.g...u..WQ=C..G.|
00007620  56 9b d5 05 75 f7 cb 50  e3 0b 59 6b f4 a7 63 4b  |V...u..P..Yk..cK|
00007630  9d fd 3b a8 36 2a bd 56  69 b5 ab cd c6 d3 f7 a1  |..;.6*.Vi.......|
00007640  da 78 d6 6a eb cd d6 e1  6e ad 79 7a 5d f9 29 14  |.x.j....n.yz].).|
00007650  43 17 4b e7 b5 66 69 c7  32 74 14 f5 9c 6b a5 5a  |C.K..fi.2t...k.Z|
00007660  75 a7 d4 81 1b 2e 57 f7  46 be 02 55 5f c4 57 b5  |u.....W.F..U_.W.|
00007670  b7 ed 8e ff df c9 7d 3f  97 fb 7e fe cf e6 7f 7b  |......}?..~....{|
00007680  e4 ff 1e fd e2 e8 df fb  41 0b 25 b6 5c ce e4 ef  |........A.%.\...|
00007690  be f0 a9 4f e5 bf 5d ed  94 ca b5 8a 68 95 1a 3b  |...O..].....h..;|
000076a0  d5 c6 de cd ef 11 59 d4  7c 45 8f ad 70 31 ab c7  |......Y.|E..p1..|
000076b0  6e be 1d fb e2 d8 cd e4  89 1a 5b d1 1b 2b 63 f3  |n.........[..+c.|
000076c0  0b 70 ac ce ce 8e 15 b5  d1 45 3d 2f f5 f2 d8 f2  |.p.......E=/....|
000076d0  71 b5 53 69 8f 7d b1 77  e9 8b 2f b5 2a ed e6 71  |q.Si.}.w../.*..q|
000076e0  6b bb b2 d5 39 3f aa 3c  5a b3 7f 0e 38 5c 7a ec  |k...9?.<Z...8\z.|
000076f0  dc 62 b1 30 c7 8b 9b 63  33 7a 73 80 de 4b 63 8f  |.b.0...c3zs..Kc.|
00007700  d0 7b 71 ec c5 89 91 3b  2f c8 4f e5 73 d5 c6 4e  |.{q....;/.O.s..N|
00007710  e5 ac fd b0 06 0d d8 2a  1d 77 9a dd bf b7 6e 9a  |.......*.w....n.|
00007720  bf 45 6e 3e 8d 7e fb f3  a3 77 5f 78 f1 c5 fc 2f  |.En>.~...w_x.../|
00007730  3c dd 7d 7c 55 39 aa c0  a5 8d ed 73 05 8d 78 f4  |<.}|U9.....s..x.|
00007740  af a7 1e 61 c5 a3 e7 80  1f d7 e2 38 84 1f d7 97  |...a.......8....|
00007750  58 8e dc 5c fc e2 4b bd  8f e5 ab 8a 2f bd 91 33  |X..\..K...../..3|
00007760  63 2f 1d 5d 3d f1 d6 6e  a9 5e ad 9d 77 cf be 34  |c/.]=..n.^..w..4|
00007770  76 f3 65 a3 54 af 5c 7f  75 72 d5 91 ae ff 7a 94  |v.e.T.\.ur....z.|
00007780  69 37 f7 19 b8 63 f7 5e  8f 11 7f 69 90 ec 4b d7  |i7...c.^...i..K.|
00007790  04 5f 7c f1 2b 4f dd 79  61 e1 c5 34 c6 3e ca 8c  |._|.+O.ya..4.>..|
000077a0  2d f2 e8 df 4f 5f 8e 3d  7d f7 85 cf 7c 26 ff ed  |-...O_.=}...|&..|
000077b0  f7 77 99 ac 57 67 f9 96  a9 d6 2a ed fe a7 3b 8f  |.w..Wg....*...;.|
000077c0  30 b7 ff fd 17 6f 1e f3  71 c6 be 34 56 2b 35 f6  |0....o..q..4V+5.|
000077d0  64 73 e7 71 31 aa 1c d7  86 4a cf 51 5f 7a 6e 28  |ds.q1....J.Q_zn(|
000077e0  80 e0 78 77 ee bc 30 f9  99 b4 e7 eb b7 67 8b f4  |..xw..0......g..|
000077f0  3f df b5 fd ff 6e ee a7  73 f0 f3 cf f3 2f 8d dc  |?....n..s..../..|
00007800  1d 89 46 3f 38 3a 73 dd  af d6 ee de 7d e1 b3 9f  |..F?8:s.....}...|
00007810  cd 7f bb dd 7d e6 6b a6  5b 76 0c 7c 7c e6 91 a7  |....}.k.[v.||...|
00007820  1e 38 f1 d6 e5 69 a7 59  2f 55 1b 8f 31 e0 b0 72  |.8...i.Y/U..1..r|
00007830  fe d8 37 27 a5 da f1 e3  9c 4b 91 97 b1 2b 92 2f  |..7'.....K...+./|
00007840  8d 01 15 e0 94 ff cc 9d  17 0a 9f 4d e3 d4 c0 33  |...........M...3|
00007850  6c 91 81 3f 9e bd dc 78  b6 ab 67 7e 7e 74 90 1f  |l..?...x..g~~t..|
00007860  ed 9b df 3f f1 24 4e b4  53 d9 00 d2 7f 75 62 b0  |...?.$N.S....ub.|
00007870  4b f4 cf de 9c ec 75 8d  27 54 1c ec 2b 6f ac f9  |K.....u.'T..+o..|
00007880  04 fd f4 64 f6 58 a5 f3  be 61 4a e7 e6 59 7a ec  |...d.X...aJ..Yz.|
00007890  68 3f 77 b9 fa fe bb 2f  7c e1 0b 37 3a b7 ab 27  |h?w..../|..7:..'|
000078a0  6f 4e 3e f2 c7 4f 3e c2  95 47 4e bd 55 0d fc 96  |oN>..O>..GN.U...|
000078b0  f5 54 8a 06 1e 64 44 fc  13 77 5e 98 fb 42 1a 23  |.T...dD..w^..B.#|
000078c0  1e 69 fe 16 79 e4 cf 0f  5c d2 e7 ee be f0 89 4f  |.i..y...\......O|
000078d0  e4 bf fd d5 3e 4b ae 78  d1 fe e0 1b 99 90 fe f4  |....>K.x........|
000078e0  2f 8d ed b5 9a c7 47 4f  7c f3 57 67 9e 28 30 63  |/.....GO|.Wg.(0c|
000078f0  3b d5 f6 51 ad 74 fe c4  7a 4f 7e 74 78 5e db ff  |;..Q.t..zO~tx^..|
00007900  f3 a3 7f 2d 07 3f b7 e5  b6 dc 96 f7 5c 79 2d 7f  |...-.?......\y-.|
00007910  67 73 22 7e fe 13 d9 f0  fd f2 7e a9 55 d9 19 5b  |gs"~......~.U..[|
00007920  a9 6c ef 37 9a b5 e6 de  f9 e2 7e b3 d3 6c ef 37  |.l.7......~..l.7|
00007930  8f c6 24 e8 85 56 69 ac  58 3a 1d 8b a2 97 dd 86  |..$..Vi.X:......|
00007940  5d f2 5f b3 fe 7f 7e f4  7f cb c1 cf 6d b9 2d b7  |]._...~.....m.-.|
00007950  e5 47 a1 7c 69 74 33 e3  70 40 fe ca fe ff f5 1c  |.G.|it3.p@......|
00007960  fc dc 96 db 72 5b de db  65 21 3f ba b9 99 71 21  |....r[..e!?...q!|
00007970  50 a6 ab ae ec ff 6d ff  bf 2d b7 e5 87 a0 2c 3e  |P.....m..-....,>|
00007980  b5 b9 f9 ec db d9 ff af  ec ff 3f ca c1 cf 6d b9  |..........?...m.|
00007990  2d b7 e5 87 bf 8c e7 9f  de cc bc 59 e0 ca fe ff  |-..........Y....|
000079a0  e3 1c fc dc 96 db 72 5b  7e 24 ca 8b a3 59 51 c2  |......r[~$...YQ.|
000079b0  73 f9 4a ee d9 dc f7 72  f9 6a fe 2f 8e 7c 79 e4  |s.J....r.j./.|y.|
000079c0  70 e4 9f 8f be 3c fa 3b  b9 ef e5 d9 0f fa 19 b2  |p....<.;........|
000079d0  96 a3 8f 76 27 e5 2e bd  ee ac cb d1 f6 ce 56 bd  |...v'.........V.|
000079e0  d2 29 dd fc fe c4 23 33  2f 37 df 8e 7d 71 ec 8d  |.)....#3/7..}q..|
000079f0  f3 89 63 4f 9a 50 7c 74  e6 e4 6a fa 70 e2 63 c3  |..cO.P|t..j.p.c.|
00007a00  26 cb 6e ee b1 45 6e 3e  fd 14 b4 f2 a9 f1 9f bc  |&.n..En>........|
00007a10  f3 c2 57 3f 31 74 62 e9  66 46 a9 fd a1 cb cf 7c  |..W?1tb.fF.....||
00007a20  e0 6a 45 c3 47 fb b3 cd  c5 ca ee cd ef e7 df 38  |.jE.G..........8|
00007a30  d3 0c df e2 e7 99 c7 ec  44 f3 d6 7e a9 bd 3f f4  |........D..~..?.|
00007a40  a9 9f 3c dd 3c f1 c1 61  5c b8 69 d4 f5 64 33 7c  |..<.<..a\.i..d3||
00007a50  fa c8 e5 dd 0f dd 7d e1  f3 9f cf 5f 2e f5 1f 4a  |......}...._...J|
00007a60  36 1b 9d 4a a3 33 f8 f9  a3 6f 7c b8 eb 33 5f 4c  |6..J.3...o|..3_L|
00007a70  6d ee f5 05 43 9f a2 57  f9 c5 17 c3 0f df 79 61  |m...C..W......ya|
00007a80  e6 f3 43 9b 7e 4d f1 ba  f9 d7 7f 7d ec f2 63 cf  |..C.~M.....}..c.|
00007a90  5f 3d 42 b3 ff 08 d7 2b  7f 06 3f bf f0 c6 47 b8  |_=B....+..?...G.|
00007aa0  3e 93 fe 08 6b 4f 9c cb  1d 2b 56 da 95 d6 89 1d  |>...kO...+V.....|
00007ab0  d1 7f e3 7a 88 c1 27 fa  c8 9b 3e d1 f5 0d ae 9f  |...z..'...>.....|
00007ac0  e8 fa af 8f df ee ff b9  2d b7 e5 c7 b7 dc ee ff  |........-.......|
00007ad0  b9 2d b7 e5 c7 b7 dc da  ff db 72 5b 7e 7c cb ad  |.-........r[~|..|
00007ae0  fd bf 2d b7 e5 c7 b7 dc  da ff db 72 5b 7e 7c cb  |..-........r[~|.|
00007af0  ad fd bf 2d b7 e5 c7 b7  58 fb 3f 32 fa bf e4 46  |...-....X.?2...F|
00007b00  ff 19 fc 77 5b 6e cb 6d  f9 21 2d 63 23 a3 fa 03  |...w[n.m.!-c#...|
00007b10  ed ed fd 4a bd b4 b5 dd  ac 1f 95 3a d5 72 b5 56  |...J.......:.r.V|
00007b20  ed 9c df 6c 13 25 1f ce  8f be 78 73 c5 f5 77 9e  |...l.%....xs..w.|
00007b30  b5 ff 23 a3 bf 97 1b fd  bd d1 ff e7 07 fd 04 b7  |..#.............|
00007b40  e5 b6 dc 96 b7 5e c6 46  75 7e 98 02 18 f9 f0 e8  |.....^.Fu~......|
00007b50  8b f9 47 fb 7f 37 fe cf  fb 72 ab 39 f8 f9 1b f9  |..G..7...r.9....|
00007b60  8f e4 1f e6 7f 7f e4 a5  91 5f 19 f9 a7 a3 66 f4  |........._....f.|
00007b70  3b 6f b9 21 a5 67 36 9f  fb d4 c4 57 9f cb b8 09  |;o.!.g6....W....|
00007b80  a9 55 79 78 5c 6d 55 76  de b0 77 f1 7a c7 e2 62  |.Uyx\mUv..w.z..b|
00007b90  ab b9 6b 83 15 8c 15 1a  ed 4e a9 56 ab b4 f2 af  |..k......N.V....|
00007ba0  5d 07 45 cd 78 87 6f b8  2e 61 22 66 c6 09 08 75  |].E.x.o..a"f...u|
00007bb0  1d c6 dc d8 89 39 13 4e  a0 04 a1 dc d7 81 e8 87  |.....9.N........|
00007bc0  ba 6d e2 89 2b 1d bb d4  77 62 a9 23 b8 4a 2a 27  |.m..+...wb.#.J*'|
00007bd0  d2 82 3a 91 e1 ca 27 dc  a7 91 d7 8b 30 fc 2a 3a  |..:...'.....0.*:|
00007be0  9c 2b 73 a9 4b 8d ef 50  ca a1 e5 6e e4 3a 71 60  |.+s.K..P...n.:q`|
00007bf0  23 f5 fa 9a f3 58 85 61  48 e3 5e 38 d7 3f 89 6e  |#....X.aH.^8.?.n|
00007c00  7a 18 85 8a 2a e9 50 e5  c2 55 0a 98 13 79 f0 9f  |z...*.P..U...y..|
00007c10  1f 30 2a a9 6b 02 c6 7b  41 7a bd 77 36 12 2d 9a  |.0*.k..{Az.w6.-.|
00007c20  7a 44 3c 23 03 e3 28 05  e7 58 20 6d 04 e0 d8 75  |zD<#..(..X m...u|
00007c30  84 90 46 fa d4 d3 8a f7  a9 ff 59 34 f5 18 de 69  |..F.......Y4...i|
00007c40  18 79 8e 60 c4 c0 55 5e  e0 88 00 de ae 2f 7c 13  |.y.`..U^...../|.|
00007c50  10 19 29 15 f4 a3 46 ff  35 34 db b9 eb c3 5f a1  |..)...F.54...._.|
00007c60  13 18 12 38 4c 08 60 0a  13 c4 f1 18 0b 45 4c 94  |...8L.`......EL.|
00007c70  22 7e 2f be f0 c7 d1 c4  e1 c5 29 3f 08 1c 1a 51  |"~/.......)?...Q|
00007c80  e9 30 0f ee 10 b9 32 74  42 e9 19 11 98 98 85 cc  |.0....2tB.......|
00007c90  bb 21 fe cd ab fe ff 7a  0e 7e 7e 33 ff 42 be 93  |.!.....z.~~3.B..|
00007ca0  ff 07 23 2f 8f fc 2a f4  7f fd 47 e8 ff 37 05 dd  |..#/..*...G..7..|
00007cb0  72 45 02 03 c5 d1 be 8c  1d 16 85 dc 89 95 81 8e  |rE..............|
00007cc0  04 ec d0 9c 50 26 4d 8f  e9 15 34 71 ad 3c 6a 08  |....P&M...4q.<j.|
00007cd0  77 7c 26 b4 c3 b4 01 b6  04 11 77 38 f4 57 02 77  |w|&.......w8.W.w|
00007ce0  80 f7 ca 6e 88 df c1 12  27 2e 8d 42 16 09 87 50  |...n....'..B...P|
00007cf0  c5 41 bf 30 0a 1d 34 90  4e 28 5c 4e 7c 57 a8 38  |.A.0..4.N(\N|W.8|
00007d00  ec 09 e3 17 d1 c4 41 45  09 19 db 68 d4 2e 48 3a  |......AE...h..H:|
00007d10  97 91 13 87 52 3a 86 28  3f 36 91 cf 49 e8 de 10  |....R:.(?6..I...|
00007d20  9f 40 13 f7 8c 02 01 8c  9d 90 d9 4e 2a 29 88 7c  |.@.........N*).||
00007d30  68 84 e3 79 42 ba c2 0f  5c 13 f5 78 fe 1a 9a 78  |h..yB...\..x...x|
00007d40  2c 0c 74 7b e5 50 62 7b  91 62 f0 0c 11 e8 5e e6  |,.t{.Pb{.b....^.|
00007d50  32 aa 14 f3 bc b8 df 47  f7 d1 c4 39 61 5e e4 12  |2......G...9a^..|
00007d60  47 32 06 3c 8f 0c e8 2e  c1 98 43 fd 08 fa ab 4b  |G2.<......C....K|
00007d70  b9 31 bd 30 da 01 9e 38  e5 9a 02 35 c9 43 fb 42  |.1.0...8...5.C.B|
00007d80  b5 76 22 2e a0 c3 12 0f  f4 8d 0a 3c 65 c4 0d f1  |.v"........<e...|
00007d90  4f 60 95 0b 11 da 44 61  4c 1c 16 5a 69 f1 5d 10  |O`....DaL..Zi.].|
00007da0  45 1d 19 27 a4 11 03 b3  44 63 23 fa 01 c0 ff 1c  |E..'....Dc#.....|
00007db0  ba e9 52 4a 2f a6 81 03  cf c0 40 d0 89 70 38 58  |..RJ/.....@..p8X|
00007dc0  28 c7 8f 88 82 0e e4 b9  52 f5 42 a3 9f 77 b3 80  |(.......R.B..w..|
00007dd0  e5 b6 73 a3 bf 36 2a 47  fe 00 7a fe 44 fe 1f e5  |..s..6*G..z.D...|
00007de0  4f f3 9f cc fd 16 7c f9  f6 94 e4 7d b8 4c 1a be  |O.....|....}.L..|
00007df0  0c 7c 26 7d d7 91 c2 07  51 11 d0 8d 22 c2 e1 4d  |.|&}....Q..."..M|
00007e00  48 50 ca 82 aa 40 ab e0  a6 fd c9 b3 38 da 01 bc  |HP...@......8...|
00007e10  56 3f 92 c2 71 09 f4 7f  16 b9 9e 13 7b 8a 3a 61  |V?..q.......{.:a|
00007e20  e8 49 15 c9 30 84 9e da  a3 fd 0c 8e 36 f3 15 95  |.I..0.......6...|
00007e30  02 a4 5b 47 12 68 33 df  77 a0 ff 18 87 1b aa b9  |..[G.h3.w.......|
00007e40  24 ae 1f c7 3d 05 93 dc  45 66 17 51 9c 18 05 bd  |$...=...Ef.Q....|
00007e50  5f 93 c0 ea 74 cd 1d e1  79 60 ec a8 b2 01 e3 8d  |_...t...y`......|
00007e60  17 87 3d 83 91 dc c1 d1  c6 28 c6 e4 69 1c 6d 49  |..=......(..i.mI|
00007e70  39 25 14 24 5d c5 ca a2  17 10 f7 08 8c bf 03 3d  |9%.$]..........=|
00007e80  d7 12 96 01 e7 bd 6e 94  3c 85 cd b8 a2 a4 56 46  |......n.<.....VF|
00007e90  c3 55 4a 01 bf a1 f1 91  0b dc f1 7c 15 13 ed 6b  |.UJ........|...k|
00007ea0  e5 0f f0 64 14 47 1b f4  8a 01 58 41 9d 20 a4 d0  |...d.G....XA. ..|
00007eb0  43 95 07 af 11 cc be e3  c6 dc 0b 09 98 54 c6 fa  |C............T..|
00007ec0  72 32 82 a3 6d a0 7b 7b  3e a8 16 a2 41 fc 98 35  |r2..m.{{>...A..5|
00007ed0  18 f0 1a 63 50 01 3e 8b  4d c8 62 ca 7b f6 79 2b  |...cP.>.M.b.{.y+|
00007ee0  7f f7 0a 4a bf 53 48 fa  aa ff ef e7 46 ff 83 d1  |...J.SH.....F...|
00007ef0  a9 91 7f 36 f2 67 46 58  fe 7f cf 7f 33 3f 96 fb  |...6.gFX....3?..|
00007f00  3e 7c f9 36 96 e4 23 48  26 f9 d0 cd 85 26 0e b5  |>|.6..#H&....&..|
00007f10  e9 11 58 68 51 00 f5 01  4a 72 05 18 c6 33 ee 00  |..XhQ...Jr...3..|
00007f20  a6 4e 9e c7 d1 8e 4c 18  6b 03 ce 80 8a 25 58 25  |.N....L.k....%X%|
00007f30  4a 89 23 62 49 1d e1 6a  d0 96 71 28 84 c7 7b b4  |J.#bI..j..q(..{.|
00007f40  3f 8c a3 0d 1d 29 f6 85  02 28 07 f0 13 04 9e 00  |?....)...(......|
00007f50  e6 f5 0d 18 25 46 dc 48  b8 22 04 35 d3 a3 fd 21  |....%F.H.".5...!|
00007f60  1c ed 30 16 9c 68 0f ba  10 e3 d0 6e 8f 0a 27 f6  |..0..h.....n..'.|
00007f70  dd c8 d1 94 fa dc 15 51  a0 4d 5f e0 3f 88 55 30  |.......Q.M_.?.U0|
00007f80  80 73 39 74 a1 98 08 10  f8 90 68 e0 09 18 3d c2  |.s9t......h...=.|
00007f90  82 c8 63 12 34 db 00 bf  3f 80 a3 4d 80 76 14 07  |..c.4...?..M.v..|
00007fa0  c0 04 62 05 5e c4 01 e8  16 0d be 58 10 06 34 16  |..b.^......X..4.|
00007fb0  d4 04 b4 df ee 9f c4 d1  d6 2a 02 34 1e 47 00 fb  |.........*.4.G..|
00007fc0  19 f8 5e 01 30 3d 8e 3d  80 19 71 ac 48 ec 81 57  |..^.0=.=..q.H..W|
00007fd0  e0 f5 8c 5d f2 1c d2 58  f8 60 12 04 a0 74 21 c1  |...]...X.`...t!.|
00007fe0  7c 82 cf 68 40 06 09 e8  77 cd 7c 50 5f 01 d5 3e  ||..h@...w.|P_..>|
00007ff0  e9 d1 fe 09 a4 9c 80 c3  a2 40 c9 80 3a 34 ca 2a  |.........@..:4.*|
00008000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00009000  bc c3 05 8b b7 30 4b 67  66 b1 50 11 40 ac 6f 6d  |.....0Kgf.P.@.om|
00009010  a4 23 02 03 7d 3e b6 63  d0 e0 98 3b 2e 33 32 8a  |.#..}>.c...;.32.|
00009020  3c 3b 2f d8 1b 97 cb fd  3c 9a ba 88 a4 17 71 b0  |<;/.....<.....q.|
00009030  70 dc ba 8a d0 ed 1d 4e  6c 20 6d 3f 56 d0 3b 03  |p......Nl m?V.;.|
00009040  62 fc fe 1c da bf 83 a6  2e 69 d8 5d 0d e1 7a 1e  |b........i.]..z.|
00009050  d8 66 06 ea 84 83 79 83  fe e3 81 0d 22 91 0e 4c  |.f....y....."..L|
00009060  3f 12 cd 5f 42 b3 1d 11  f9 ef 27 d1 c4 11 5b 68  |?.._B.....'...[h|
00009070  5f c4 f2 c5 b8 c2 44 76  a6 22 a4 da ae e7 14 80  |_.....Dv."......|
00009080  2b 6c 28 30 4f 48 78 0f  5a 0a d3 9f d0 cd fd 47  |+l(0OHx.Z......G|
00009090  68 ea e0 15 c6 2e 01 6f  c2 06 30 02 72 76 33 07  |h......o..0.rv3.|
000090a0  e3 0e 89 28 b1 a1 e4 89  88 fb ce c5 bf 3f 92 b3  |...(.........?..|
000090b0  f6 df b3 72 2f 72 7f 01  3e fc 7f f9 cd fc 6f 8e  |...r/r..>.....o.|
000090c0  7c 72 e4 9b 23 ff c7 e8  83 d1 5f 7b 72 17 41 8f  ||r..#....._{r.A.|
000090d0  90 11 30 89 9c da 21 77  cf 9a 97 d8 4e 49 80 02  |..0...!w....NI..|
000090e0  75 02 13 b9 22 02 09 04  96 f6 1a 75 09 77 f8 24  |u..."......u.w.$|
000090f0  3a 60 bb b4 7b c9 25 c0  56 bb b4 17 74 2b 18 02  |:`..{.%.V...t+..|
00009100  c0 7e 8e 91 e0 98 07 da  0d 78 7f 73 5c ee 6f c0  |.~.......x.s\.o.|
00009110  1d c6 d0 d1 2c 22 70 e9  25 98 b1 10 a4 d8 c2 6f  |....,"p.%......o|
00009120  66 cd 2f 73 7c 19 08 1d  01 2a a1 61 7f 94 ef bf  |f./s|....*.a....|
00009130  83 3b a0 97 85 60 16 ca  73 b8 01 7a 69 08 66 56  |.;...`..s..zi.fV|
00009140  65 07 6e f0 39 f4 0d 10  4b 14 e7 e0 06 af 60 6f  |e.n.9...K.....`o|
00009150  80 99 db 5a 82 1b a0 03  7f 63 26 fd 96 e1 06 2f  |...Z.....c&..../|
00009160  a3 6f 80 98 0d 5d 85 1b  f8 e8 fd 62 88 ad 05 0f  |.o...].....b....|
00009170  6c ff 7f 16 3a 3e 94 af  8c fe da e8 83 dc bf c8  |l...:>..........|
00009180  fd 85 91 7f 32 f2 8d 91  4f e4 7f 3d bf fe 0e 5b  |....2...O..=...[|
00009190  da 21 05 bd d2 1c 13 50  f1 63 70 83 2f a1 17 6d  |.!.....P.cp./..m|
000091a0  20 56 0d 6c c2 0d d0 43  f1 98 d0 61 3f 0b 37 90  | V.l...C...a?.7.|
000091b0  68 a3 86 88 39 35 06 37  f8 32 56 43 2a 80 96 12  |h...95.7.2VC*...|
000091c0  7a 88 85 f7 cc 82 15 e6  44 f6 52 f0 96 e1 b3 d4  |z.......D.R.....|
000091d0  d2 0c ac 26 b4 32 87 ce  56 80 d9 92 eb c3 0d be  |...&.2..V.......|
000091e0  8a 5e 3d 23 b9 2f ed 9e  1f 6e 03 2d 01 4a f1 01  |.^=#./...n.-.J..|
000091f0  0c 41 67 35 61 c0 6d f8  16 3f ea fb e5 b9 7f 1d  |.Ag5a.m..?......|
00009200  ee 80 ce e6 80 d9 c5 1d  c3 0d 7e 16 bf ff 2f fb  |..........~.../.|
00009210  92 e8 e9 9b f5 bf dd d5  bf d7 11 c0 72 df 7d af  |............r.}.|
00009220  cf ff 61 df 6a 18 b0 98  82 57 e5 b8 70 ad cd 44  |..a.j....W..p..D|
00009230  63 73 c5 28 0d 3d 4d b9  80 23 a9 91 fd 55 22 b9  |cs.(.=M..#...U".|
00009240  bf 8d 9e ce b1 5d 47 01  1c 00 33 2d 41 a3 73 3b  |.....]G...3-A.s;|
00009250  b5 2d 04 b8 76 cc 78 6e  18 d1 58 f4 97 ff fd 17  |.-..v.xn..X.....|
00009260  78 ea 80 99 c1 3a 3b ae  b0 06 49 81 6e e0 21 48  |x....:;...I.n.!H|
00009270  8e 2f a3 d0 57 2a 16 64  a0 53 fd 19 b4 35 42 c4  |./..W*.d.S...5B.|
00009280  42 fc 02 9a ed 04 d0 80  52 dd 7d 50 b6 33 45 a1  |B.......R.}P.3E.|
00009290  03 4a 8c c2 5b a0 d0 6a  11 71 e8 02 bd a6 ff f7  |.J..[..j.q......|
000092a0  68 3b 87 18 0e 39 46 13  47 c4 88 f8 0a 5e 1c 7d  |h;...9F.G....^.}|
000092b0  d0 e6 a1 74 94 df 5d b9  ec 83 a6 97 61 60 ef c5  |...t..].....a`..|
000092c0  49 24 6d 3a 86 7e d0 95  bf 89 6e 3a 62 68 71 f7  |I$m:.~....n:bhq.|
000092d0  2a fe df 71 2e 7f fc 43  b4 f7 ef 87 bd e0 41 6f  |*..q...C......Ao|
000092e0  f6 a0 62 2e 9a 38 62 57  31 1a 72 60 42 ad 7f 0a  |..b..8bW1.r`B...|
000092f0  ad bb 10 31 4b 22 34 71  c4 e0 ff 1e 9a 38 22 da  |...1K"4q.....8".|
00009300  1a de c1 40 a4 2d 78 ee  6a fc bf f2 f8 f8 ff a7  |...@.-x.j.......|
00009310  73 df 83 2f df ae 92 5c  22 53 a4 08 50 90 4a da  |s../...\"S..P.J.|
00009320  5d 11 76 56 97 79 76 e5  95 07 80 5b 82 dc 70 4a  |].vV.yv....[..pJ|
00009330  22 97 f7 47 48 92 cb 3c  36 1d 45 f6 b1 88 e4 32  |"..GH..<6.E....2|
00009340  87 ce d1 e1 aa 30 f4 1c  12 84 76 b2 5e d9 a0 94  |.....0....v.^...|
00009350  b1 e7 80 5f 4c 89 89 65  c0 06 e2 ba fc 71 e4 1e  |..._L..e.....q..|
00009360  3d 4a 03 70 a6 01 39 ca  ee 1e 7d cf 42 77 a8 04  |=J.p..9...}.Bw..|
00009370  f8 43 fb 14 14 04 c0 c8  1e ed 3f 86 dc b7 c8 29  |.C........?....)|
00009380  07 71 a1 e0 86 da 58 b7  4a d9 f1 68 78 01 44 8a  |.q....X.J..hx.D.|
00009390  28 a0 3c a2 a1 d7 5f ff  f7 2d e4 3c 1a 62 41 4a  |(.<..._..-.<.bAJ|
000093a0  f2 4d e4 58 37 22 d9 5d  f2 0d e4 dc 02 22 4a 47  |.M.X7".]....."JG|
000093b0  72 81 9c 13 45 04 e9 4a  ce 91 02 8e 48 00 76 d5  |r...E..J....H.v.|
000093c0  ff bf 96 1b fd ce a8 19  f9 43 b0 ff 13 f9 7f 08  |.........C......|
000093d0  58 e0 e3 b9 bf 09 5f be  0d 1d 1f 99 16 25 04 1b  |X....._......%..|
000093e0  44 ec a2 2e 2f 12 76 f3  82 6b a7 73 00 23 09 15  |D.../.v..k.s.#..|
000093f0  10 a3 80 41 20 2e fd be  89 cc 8b d2 5d 27 6f 63  |...A .......]'oc|
00009400  2e 86 9a 80 f3 08 b8 19  ae 02 0e 69 bb e9 92 49  |...........i...I|
00009410  2b a4 fd f5 dc 97 c8 ac  65 8a 42 ef 31 6e e8 68  |+.......e.B.1n.h|
00009420  cf 3a 01 9e af 9d 38 32  a1 e3 fb 4a 44 4a 28 e8  |.:....82...JDJ(.|
00009430  5c 03 2a 0b 99 b6 0c 13  48 37 b9 44 e6 2d 33 b1  |\.*.....H7.D.-3.|
00009440  e7 49 cb 64 6a c0 82 32  9b 99 2a ea 66 18 05 af  |.I.dj..2..*.f...|
00009450  c8 ce cd fb a1 ea 4f cf  5f 22 13 97 61 b6 00 26  |......O._"..a..&|
00009460  97 d8 cc 65 88 dc a8 c9  25 32 75 19 66 09 60 72  |...e....%2u.f.`r|
00009470  89 cc 5d 26 02 00 74 00  30 1c 63 ec 20 3d 89 41  |..]&..t.0.c. =.A|
00009480  25 7a 41 77 d1 5b e0 e9  08 c0 51 df 33 4a 2e 91  |%zAw.[....Q.3J..|
00009490  c9 cb 30 73 46 ef 74 ff  47 a6 45 c1 6c a5 4d 2e  |..0sF.t.G.E.l.M.|
000094a0  91 79 51 30 c3 53 c9 25  32 61 19 26 d4 55 72 89  |.yQ0.S.%2a.&.Ur.|
000094b0  cc 58 86 49 18 99 5c 22  53 96 61 12 e9 26 97 c8  |.X.I..\"S.a..&..|
000094c0  9c 65 1e f8 12 ae 17 80  f1 b1 0b ae 98 b4 b1 3f  |.e.............?|
000094d0  7c bb cf 1d ba 3f a0 dd  d0 80 52 ee 13 47 26 2d  ||....?....R..G&-|
000094e0  c3 0c 8d 24 97 c8 ac 65  98 45 dd c9 25 32 6d 19  |...$...e.E..%2m.|
000094f0  26 ec 5a 72 89 cc 5b 86  19 c3 1c 18 ff 7b 78 bd  |&.Zr..[......{x.|
00009500  fb ff 2a f6 ef 77 ff e8  bd ff 9d 2b e8 81 69 30  |..*..w.....+..i0|
00009510  c0 60 69 a0 bf 47 cc ee  15 e5 5d 8e 08 00 e9 76  |.`i..G....]....v|
00009520  e2 1e fc 53 a9 fb 53 77  bf 83 1e 94 46 c4 fc 98  |...S..Sw....F...|
00009530  47 37 9d 78 e0 c1 49 d7  71 ed 9a 7f e6 31 f0 eb  |G7.x..I.q....1..|
00009540  3c 69 67 1d 6d ea 1f 65  00 63 f4 9b fe 7d 34 75  |<ig.m..e.c...}4u|
00009550  04 6a c9 fd 0a 9a ba 07  d6 c6 d3 b1 5d 19 61 87  |.j..........].a.|
00009560  ec 23 05 02 6e ec 62 77  0a 80 d7 2e 7f 91 fd 61  |.#..n.bw.......a|
00009570  d7 ff 1c cd 76 44 08 ed  2f a1 9b ee 03 06 8f 35  |....vD../......5|
00009580  07 a3 69 f7 8b b8 76 ed  8f dd 62 ac 8c 0b f7 a4  |..i...v...b.....|
00009590  60 a5 fa b3 3d b9 bf 8e  6e 3a c2 db fa 63 68 e2  |`...=...n:...ch.|
000095a0  88 70 ab e1 4d fc af 81  dc df 57 23 80 bf f1 83  |.p..M.....W#....|
000095b0  ee e3 6f 52 d0 cb 22 0c  31 dc e6 d1 e2 c2 2e 46  |..oR..".1......F|
000095c0  89 01 2b 46 ae a2 8e 09  c0 6e fb 32 8e 8d e9 2f  |..+F.....n.2.../|
000095d0  75 f9 4f d0 73 77 88 ad  62 af a3 89 23 d6 14 d7  |u.O.sw..b...#...|
000095e0  d0 c4 11 89 56 3f 82 26  8e 58 c5 79 86 7e a3 08  |....V?.&.X.y.~..|
000095f0  bf 25 f7 4b e8 a6 23 b2  f4 8e a0 89 23 22 f4 a1  |.%.K..#.....#"..|
00009600  97 48 60 c2 16 7e f5 9d  c6 ff c8 b4 48 98 c5 4b  |.H`..~......H..K|
00009610  c9 25 32 2f 12 26 0a 50  72 89 4c 58 8a 89 a4 93  |.%2/.&.Pr.LX....|
00009620  5c 22 33 96 ea 40 87 12  8c 83 13 c7 76 97 2b d7  |\"3..@......v.+.|
00009630  0a fa 11 23 8e ef 71 e6  db 59 47 b0 1e 7d e2 c8  |...#..q..YG..}..|
00009640  94 a5 98 45 80 c9 25 32  67 29 26 7b 51 72 89 4c  |...E..%2g)&{Qr.L|
00009650  5a aa c1 9a 85 11 e8 c4  40 07 70 15 e0 5b 27 d6  |Z.......@.p..['.|
00009660  82 39 76 4a d7 8d 74 48  09 e9 0f a2 5d 22 b3 96  |.9vJ..tH....]"..|
00009670  62 d2 3a 26 97 c8 b4 a5  98 d8 45 c9 25 32 6f 29  |b.:&......E.%2o)|
00009680  66 dd e5 d5 fe bf e4 6a  ff 6f 2b 97 3c e2 03 bc  |f......j.o+.<...|
00009690  ab 06 1a 20 55 18 ba c6  66 ce b0 39 34 02 69 47  |... U...f..94.iG|
000096a0  89 03 eb 2e 46 01 58 68  40 74 a2 bf 29 f2 ef a0  |....F.Xh@t..)...|
000096b0  17 a6 21 f6 b7 1c a0 89  23 12 c5 7d 06 4f 3c 7b  |..!.....#..}.O<{|
000096c0  f6 1c 07 cd 74 ea 85 e0  36 33 10 95 28 b4 51 ae  |....t...63..(.Q.|
000096d0  2c 6a 04 04 03 97 04 be  cd 2b 2c dc fe 3e d7 ff  |,j.......+,..>..|
000096e0  14 4d dd 93 01 b1 6e 97  52 dd 01 57 43 2c ac d0  |.M....n.R..WC,..|
000096f0  0e 09 43 46 98 76 81 6b  7d fc ff df a2 e7 16 11  |..CF.v.k}.......|
00009700  61 1c b6 d1 4d 8f 54 44  22 c0 41 d4 b7 aa 25 86  |a...M.TD".A...%.|
00009710  f7 2a 74 37 a4 1e 85 7f  31 f4 a7 fe 0c 5d ee 37  |.*t7....1....].7|
00009720  d0 4d 97 81 cf a0 95 0e  38 71 60 ff 45 20 9d 88  |.M......8q`.E ..|
00009730  80 56 94 d2 8d 15 c0 0c  80 64 3d dd f2 3e 3c f1  |.V.......d=..><.|
00009740  ec e1 ff 26 df 69 fb 8f  4c 8b 84 09 a4 9b 5c 22  |...&.i..L.....\"|
00009750  f3 22 61 84 3d b9 44 26  2c c5 f8 17 c9 25 36 63  |."a.=.D&,....%6c|
00009760  29 62 c3 78 72 89 4d 59  8a 58 8e 9e 5c 22 73 96  |)b.xr.MY.X..\"s.|
00009770  62 d2 17 27 97 c8 a4 a5  80 b4 14 60 7f cf 31 80  |b..'.......`..1.|
00009780  9e 2d a0 33 4e 4c 15 01  94 14 da 15 8d f0 9a d5  |.-.3NL..........|
00009790  40 cb 91 59 4b 85 e7 31  0d 70 d3 01 6b 6f 91 39  |@..YK..1.p..ko.9|
000097a0  60 69 2e 01 ad db 70 e8  34 a0 d6 88 0e 88 22 32  |`i....p.4....."2|
000097b0  6d 29 74 73 dd dd 03 25  98 dd b6 28 c1 44 0b cb  |m)ts...%...(.D..|
000097c0  16 1f 18 12 10 19 29 15  0c 0c 2e 22 f3 96 6a 12  |......)...."..j.|
000097d0  18 c0 73 80 16 3d 6d 27  b8 ed 02 60 d0 c4 76 3d  |..s..=m'...`..v=|
000097e0  ac 8a 19 27 2e 0b fc 41  fb ff 4c fe 23 b9 81 e8  |...'...A..L.#...|
000097f0  9f 3f 04 d1 ff de d9 82  5e 33 8a 90 94 dc 77 d0  |.?......^3....w.|
00009800  0b 9b 11 bb 95 eb e8 a6  23 e6 a1 72 bf 80 a7 9e  |........#..r....|
00009810  7d 19 47 ee db 68 c6 20  42 44 2f e2 89 67 8f 2b  |}.G..h. BD/..g.+|
00009820  f4 35 34 71 44 f0 df 29  34 d3 b9 89 54 77 9d 98  |.54qD..)4...Tw..|
00009830  5d be c8 0c 30 3d 12 ae  b4 68 20 20 04 34 0b 61  |]...0=...h  .4.a|
00009840  7d 69 fc ed 77 da fe 23  d3 22 61 56 8c 26 97 c8  |}i..w..#."aV.&..|
00009850  bc 48 98 0d 3c c9 25 32  61 29 06 eb 26 97 c8 8c  |.H..<.%2a)..&...|
00009860  a5 98 7c f4 c9 25 32 65  a9 66 f0 dc 44 77 83 ad  |..|..%2e.f..Dw..|
00009870  d8 6d ae dd 25 34 86 d9  48 80 ca d5 00 24 c5 c0  |.m..%4..H....$..|
00009880  f2 9c 4b 64 ce 52 cc 38  7a 72 89 4c 5a 8a 89 a3  |..Kd.R.8zr.LZ...|
00009890  91 5c 62 b3 96 22 32 23  26 97 c8 b4 a5 98 25 e3  |.\b.."2#&.....%.|
000098a0  c9 25 32 6f 29 66 da e5  9d ee ff c8 b4 28 1e 17  |.%2o)f.......(..|
000098b0  24 b0 03 5d f0 6a 85 1d  ff 03 b5 eb 46 d2 f1 34  |$..].j......F..4|
000098c0  e0 3a e9 29 c2 bd 81 5e  84 cc 8b 82 89 8c 9a 5c  |.:.)...^.......\|
000098d0  22 13 16 62 12 46 26 97  d8 8c 85 88 05 e3 c9 25  |"..b.F&........%|
000098e0  36 65 61 e8 6a cf 46 2b  30 9e 5d e9 6a 00 33 82  |6ea.j.F+0.].j.3.|
000098f0  17 c6 9d 00 80 3b 38 49  d2 d7 71 7f 99 db 25 32  |.....;8I..q...%2|
00009900  67 21 c6 8f 4e 2e 91 49  0b 31 c1 8b 92 4b 64 d6  |g!..N..I.1...Kd.|
00009910  42 cc 86 d2 e4 12 99 b6  d0 0b 64 4c c1 09 70 6c  |B.........dL..pl|
00009920  98 d2 6e 28 77 f0 42 95  0b a2 e8 51 c6 95 1f 52  |..n(w.B....Q...R|
00009930  39 a0 b9 90 79 0b 31 e9  c5 2d fe bf 93 ff fb b9  |9...y.1..-......|
00009940  9b bd 3f ef f5 9d 3f b7  65 78 c1 6f 16 cd 1e af  |..?...?.ex.o....|
00009950  e4 04 bd cf 05 b1 18 3a  f7 27 d0 4d 8f 05 87 e6  |.......:.'.M....|
00009960  d9 65 c5 bc 3b 86 0e 0e  af 0f b2 ae 29 f5 b9 2b  |.e..;.......)..+|
00009970  a2 60 60 50 e4 43 78 e2  d9 e3 a1 7e 1d cd 17 c4  |.``P.Cx....~....|
00009980  2a d7 dc 9f 42 37 1d 91  3a cf 0c c4 ff b0 eb 7f  |*...B7..:.......|
00009990  5e ba 8e fe f9 e3 ec ff  a3 c3 5c 20 86 5b 72 7f  |^.........\ .[r.|
000099a0  15 4f 3d fb a2 e5 dc af  a2 b7 04 23 b6 14 fc 71  |.O=........#...q|
000099b0  74 d3 11 8e 45 ee bf 46  37 1d 91 41 97 a1 9b 8e  |t...E..F7..A....|
000099c0  98 70 cd fd bb f8 8d d8  81 22 ca 46 12 b2 de 39  |.p.......".F...9|
000099d0  f4 d0 d8 8e 1a 33 c7 8e  41 bb 5e e0 71 de 4f e8  |.....3..A.^.q.O.|
000099e0  86 0e 84 81 99 14 cd fd  e5 77 1a ff 23 d3 22 61  |.........w..#."a|
000099f0  32 69 24 97 c8 bc 48 98  55 80 c9 25 32 61 a9 1b  |2i$...H.U..%2a..|
00009a00  02 e4 e7 4a 3a 22 b4 01  9d 7d 1b b0 30 24 80 bc  |...J:"...}..0$..|
00009a10  02 a1 ec 5a 97 00 00 69  9f 38 32 63 29 66 6e 34  |...Z...i.82c)fn4|
00009a20  b9 44 a6 2c c5 ac 30 4c  2e 91 39 4b 31 a3 51 c9  |.D.,..0L..9K1.Q.|
00009a30  25 32 69 29 26 31 62 72  89 cc 5a 4a c1 56 fa 60  |%2i)&1br..ZJ.V.`|
00009a40  a0 6d 36 44 db 49 41 c9  44 06 c0 3a f1 c3 40 db  |.m6D.IA.D..:..@.|
00009a50  1c 20 11 1d 58 73 8d 4c  5b 8a d9 90 9e 5c 22 f3  |. ..Xs.L[....\".|
00009a60  96 62 32 a3 58 fb ff f4  c8 4b b9 db c8 5f b7 e5  |.b2.X....K..._..|
00009a70  cd 0a d6 12 61 9c dc dc  77 f1 c1 92 0c 51 11 d0  |....a...w....Q..|
00009a80  04 08 03 3a 31 32 00 bb  7c e8 4c c4 25 00 7f 63  |...:12..|.L.%..c|
00009a90  65 78 7f e1 e2 cf a0 89  03 50 51 9e 4f 9d c0 ee  |ex.......PQ.O...|
00009aa0  5b 64 ca 33 0e 68 5e e9  b8 31 f7 42 e2 c1 65 ac  |[d.3.h^..1.B..e.|
00009ab0  e7 fc 8f a2 f9 82 18 e4  ca fd 4f 78 ea d9 77 5c  |..........Ox..w\|
00009ac0  e4 fe 4d 6b ff f3 23 32  07 3f b7 e5 b6 bc 95 f2  |..Mk..#2.?......|
00009ad0  f3 5f ce df d9 fc c0 8b  7f f2 fd d9 04 d4 5d 2b  |._............]+|
00009ae0  d5 aa 3b a5 4e b5 d9 28  34 76 9b f7 1f fd 73 ec  |..;.N..(4v....s.|
00009af0  a8 74 5e 6b 96 76 0a ea  95 7b d9 e8 dd 7b 70 df  |.t^k.v...{...{p.|
00009b00  54 6b 95 07 f7 0b 8d 76  a7 54 ab 2d 96 3a fb 0f  |Tk.....v.T.-.:..|
00009b10  5e 2d cc 2f af f0 d9 59  55 28 be fe da 62 ed 78  |^-./...YU(...b.x|
00009b20  cf 81 b3 af 49 f9 9a bd  74 cc 34 5b f5 52 07 fe  |....I...t.4[.R..|
00009b30  2e d5 2b ad d2 58 b1 74  fa 72 54 ae de 9f 18 a4  |..+..X.t.rT.....|
00009b40  70 7f b9 ba d7 28 75 8e  5b 95 95 f3 a3 ca 03 55  |p....(u.[......U|
00009b50  dd ab c2 b9 de 97 f7 27  1e 3d df bf dc 3e c5 03  |.......'.=...>..|
00009b60  be d3 2c 57 c6 96 cf db  9d 4a bd 3d 56 68 6c 37  |..,W.....J.=Vhl7|
00009b70  5b 47 cd 56 a9 53 d9 f9  c6 37 bf b5 56 69 55 ed  |[G.V.S...7..ViU.|
00009b80  e5 63 b2 56 6a b7 c7 bc  31 d9 dc 81 8b e1 9b 6a  |.c.Vj...1......j|
00009b90  63 6f 8c ba c4 1d 93 fc  49 d7 2d 1e 97 6b d5 ed  |co......I.-..k..|
00009ba0  b1 c5 56 b5 5e 6a 9d 8f  c9 4a ab 53 dd ad 6e 77  |..V.^j...J.S..nw|
00009bb0  99 37 c6 8f 3b fb cd 56  b5 73 3e e6 8c 4d fa 03  |.7..;..V.s>..M..|
00009bc0  ed eb 36 e8 fe c4 15 93  26 1e 65 f7 83 6e ff cf  |..6.....&.e..n..|
00009bd0  ff 76 0e 7e 6e cb 0f 67  f9 85 2f 8f 40 ff fb c2  |.v.~n..g../.@...|
00009be0  2f 65 84 87 03 fd 0f 44  64 65 f6 b8 bc b9 bc 3c  |/e.....Dde.....<|
00009bf0  53 de 75 37 8e da 73 9d  05 56 9f d8 98 f4 0f d7  |S.u7..s..V......|
00009c00  26 f7 77 a3 a9 bd b9 b5  f1 8b 8b ce c2 52 32 cb  |&.w..........R2.|
00009c10  c4 fc b9 38 9a 9e f5 e6  d5 d2 5a 71 fe 60 76 f2  |...8......Zq.`v.|
00009c20  30 9e 2f 1e 56 d6 a3 b3  cd e4 78 69 d2 3f f6 0e  |0./.V.....xi.?..|
00009c30  cc e1 de ec a1 bf b8 b1  7b 51 9e 9b 6f 97 bd 78  |........{Q..o..x|
00009c40  f9 7c 79 26 da 9f 29 91  99 70 da b8 6e 54 5e ae  |.|y&..)..p..nT^.|
00009c50  aa f3 55 33 bd de ec 14  e3 1d ff 21 df 28 3f dc  |..U3.......!.(?.|
00009c60  d8 0b 77 4c bd 7a 5e f2  c5 84 38 3a 4a 2a 17 3b  |..wL.z^...8:J*.;|
00009c70  47 ab 07 bb 31 9b 6a 1c  34 93 f9 a9 e6 de fa 7a  |G...1.j.4......z|
00009c80  59 6f 36 cb d5 b6 de 9f  2e 3c dc de 69 37 7c 33  |Yo6......<..i7|3|
00009c90  b1 51 8d 0e 2f 56 a6 c6  cb 53 d3 a1 a9 1e 6c 6e  |.Q../V...S....ln|
00009ca0  90 c5 46 b3 a0 56 2b 1b  53 9d a2 de 38 a3 87 e7  |..F..V+.S...8...|
00009cb0  07 fb 81 9a 93 72 66 ca  0b 3b e7 c1 41 32 71 12  |.....rf..;..A2q.|
00009cc0  05 81 38 67 93 ea e4 bc  15 54 8a d3 0f f5 89 ee  |..8g.....T......|
00009cd0  9c 5e d4 4f 97 c3 89 8b  4a 7d 69 7b 61 7b 42 ab  |.^.O....J}i{a{B.|
00009ce0  f2 dc f8 f9 ec 6e fd e1  c3 e5 cd 70 b3 55 2e 95  |.....n.....p.U..|
00009cf0  da 85 38 38 25 93 3b d3  4b d3 64 8f d7 b4 3e ab  |..88%.;.K.d...>.|
00009d00  aa f9 66 71 7f 87 84 b5  da fc 69 79 51 b3 8d f6  |..fq......iyQ...|
00009d10  e9 7c bd 5a af ec ee 1c  c6 9d 6d 51 eb 1c 4e 04  |.|.Z......mQ..N.|
00009d20  07 6a 7c a6 f8 f0 70 ba  a2 76 54 c5 ac 2e 2f 80  |.j|...p..vT.../.|
00009d30  5f bf b1 b0 3d 3b bd 51  6e af ae 14 92 f5 93 99  |_...=;.Qn.......|
00009d40  93 b3 d2 fa ce ca 32 3f  54 c9 64 70 e2 cf c4 8b  |......2?T.dp....|
00009d50  8b 47 ed 25 2a 26 f6 04  a3 73 67 0f 37 aa 6b b5  |.G.%*&...sg.7.k.|
00009d60  f1 a8 be 77 36 37 bb cd  fd 85 e9 b2 2e f3 c3 87  |...w67..........|
00009d70  13 ee ec c5 d4 43 df 1c  f3 13 7a b8 59 7a 48 93  |.....C....z.YzH.|
00009d80  63 75 b6 bc cb c9 69 c1  57 7c ef 8c 6d ef 79 e3  |cu....i.W|..m.y.|
00009d90  a5 42 bd 14 d6 e9 ca 5c  27 d8 69 b6 16 e6 44 c9  |.B.....\'.i...D.|
00009da0  3d dc 2e f2 f2 b4 77 b8  bf 37 bf 5a bc 68 e8 83  |=.....w..7.Z.h..|
00009db0  e9 b9 d3 6b 19 72 e0 28  c0 31 0d c7 a7 e1 f8 0c  |...k.r.(.1......|
00009dc0  1c 9f 83 e3 b3 70 7c 15  8e cf c3 f1 32 1c 5f 80  |.....p|.....2._.|
00009dd0  e3 45 38 5e 82 e3 4b d7  f5 dc 9c 8d 1d 9a cb 05  |.E8^..K.........|
00009de0  70 8c c1 41 e0 f8 32 1c  5f 81 23 84 23 82 c3 c6  |p..A..2._.#.#...|
00009df0  62 1b 87 e3 15 38 6c b0  51 06 87 0d 6e 76 1f 8e  |b....8l.Q...nv..|
00009e00  7b 70 58 f4 f1 45 38 1e  c0 41 e1 f8 39 38 34 1c  |{pX..E8..A..984.|
00009e10  36 ca a5 8d 75 37 01 87  82 e3 93 70 fc 34 1c 9f  |6...u7.....p.4..|
00009e20  82 e3 67 f6 26 89 0b 02  d9 22 71 9b ce 89 64 5b  |..g.&...."q...d[|
00009e30  d7 4b 72 6e 5c 2e 7b b3  fb 45 53 58 5d 9e d6 35  |.Krn\.{..ESX]..5|
00009e40  5e 5f a9 cc 9c 78 e1 c5  44 dd f3 26 82 46 ed 6c  |^_...x..D..&.F.l|
00009e50  dd 7b 38 db 98 5d d8 29  12 bd 7f ca 76 c6 0f 23  |.{8..].)....v..#|
00009e60  be 7d 78 5c 6e ef fb 49  29 ec 3c 64 c6 4f ce 0e  |.}x\n..I).<d.O..|
00009e70  f9 ca d2 ac d9 f4 c4 2a  7f 78 32 bb 7e c1 66 97  |.......*.x2.~.f.|
00009e80  67 8c cb 6b 65 b6 37 b3  e3 ee 77 0e 2f 3a 5e ab  |g..ke.7...w./:^.|
00009e90  44 ea 7a e1 fc 64 a7 34  5e 99 df dd 3f 9e 58 dd  |D.z..d.4^...?.X.|
00009ea0  2e 93 63 19 27 49 c1 6c  b6 9a 27 0f 27 97 3a bc  |..c.'I.l..'.'.:.|
00009eb0  be 77 92 6c e8 e6 c5 51  e9 62 b6 4c dd 53 bf a9  |.w.l...Q.b.L.S..|
00009ec0  fc 0b bf d3 9c 5b 5b 2a  9f 9a 06 2d 2e ae ac 9d  |.....[[*...-....|
00009ed0  cb 0d bf dd d0 9d 76 61  36 59 ac 8c ef ec 03 32  |......va6Y.....2|
00009ee0  5e 5c 5c 5b e2 6c 77 23  50 13 47 d3 d5 b2 54 d5  |^\\[.lw#P.G...T.|
00009ef0  d3 f1 78 bd 52 69 9c 6d  b4 37 a7 aa 8d b3 8b ed  |..x.Ri.m.7......|
00009f00  c4 f3 36 e2 83 c5 c0 9f  d8 d9 9c 9c 61 67 a2 b3  |..6.........ag..|
00009f10  18 56 16 67 36 db e7 8d  55 b7 53 18 3f 6a fa 95  |.V.g6...U.S.?j..|
00009f20  ca e9 de ee f9 c5 fa a4  70 db db e3 53 a5 a9 e5  |........p...S...|
00009f30  66 ed 60 e3 60 8a ee d4  7c 23 f9 f2 5e 79 a7 b9  |f.`.`...|#..^y..|
00009f40  bc fe b0 70 50 d4 e5 bd  c0 5b 31 17 ab 6c bb a5  |...pP....[1..l..|
00009f50  0a 41 52 5b 5b 3c 68 ad  5f 50 b9 3b b7 78 c4 f9  |.AR[[<h._P.;.x..|
00009f60  ee e4 64 e9 70 f5 6c b1  26 0f dd e3 39 7f ae 76  |..d.p.l.&...9..v|
00009f70  5e 5f af 4d 6e 57 1e 7a  33 74 2d 5e af 97 8f a2  |^_.MnW.z3t-^....|
00009f80  63 3a 77 ba b8 36 db 49  d6 f7 77 d5 f8 e2 da 49  |c:w..6.I..w....I|
00009f90  f9 e2 62 a2 30 37 17 76  4e 94 bb e8 2f 17 66 2e  |..b.07.vN.../.f.|
00009fa0  fc bd 4a 61 6e fd 68 9a  2c ab 32 27 d3 93 87 a2  |..Jan.h.,.2'....|
00009fb0  b1 b9 b2 bf a1 a2 f6 ca  f4 4a 2d de 96 0b e3 b3  |.........J-.....|
00009fc0  82 a8 c5 a0 de 3c dd d9  0d 66 16 67 58 fb ac e8  |.....<...f.gX...|
00009fd0  ee ce ac cc 32 b6 3c b3  d6 ac 17 f7 8e 57 2b 64  |....2.<......W+d|
00009fe0  a3 b5 32 53 db f4 3a d1  c3 f9 d3 d2 aa 62 73 b3  |..2S..:......bs.|
00009ff0  4a 9f ad ef b7 5a d5 42  bd 78 34 bd 29 b4 30 0b  |J....Z.B.x4.).0.|
0000a000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000bfd0  00 00 00 00 00 00 00 00  11 7a 0c b1 7a da 10 02  |.........z..z...|
0000bfe0  3f 2a 6e 7f 80 8f f4 97  fc ce aa 58 16 9f 90 af  |?*n........X....|
0000bff0  8b b4 6d ff 57 ea d1 cb  ab 5f 46 0d db 92 c6 6e  |..m.W...._F....n|
0000c000  01 01 00 00 00 00 00 00  00 00 00 01 00 00 00 24  |...............$|
0000c010  00 00 00 20 00 00 00 07  76 65 72 73 69 6f 6e 00  |... ....version.|
0000c020  00 00 00 08 00 00 00 01  00 00 00 00 00 00 13 88  |................|
0000c030  00 00 00 24 00 00 00 20  00 00 00 04 6e 61 6d 65  |...$... ....name|
0000c040  00 00 00 09 00 00 00 01  00 00 00 05 7a 70 6f 6f  |............zpoo|
0000c050  6c 00 00 00 00 00 00 24  00 00 00 20 00 00 00 05  |l......$... ....|
0000c060  73 74 61 74 65 00 00 00  00 00 00 08 00 00 00 01  |state...........|
0000c070  00 00 00 00 00 00 00 01  00 00 00 20 00 00 00 20  |........... ... |
0000c080  00 00 00 03 74 78 67 00  00 00 00 08 00 00 00 01  |....txg.........|
0000c090  00 00 00 00 00 2f 84 21  00 00 00 28 00 00 00 28  |...../.!...(...(|
0000c0a0  00 00 00 09 70 6f 6f 6c  5f 67 75 69 64 00 00 00  |....pool_guid...|
0000c0b0  00 00 00 08 00 00 00 01  f9 73 fb 4e 32 db 2c 34  |.........s.N2.,4|
0000c0c0  00 00 00 24 00 00 00 20  00 00 00 06 65 72 72 61  |...$... ....erra|
0000c0d0  74 61 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |ta..............|
0000c0e0  00 00 00 00 00 00 00 28  00 00 00 28 00 00 00 08  |.......(...(....|
0000c0f0  68 6f 73 74 6e 61 6d 65  00 00 00 09 00 00 00 01  |hostname........|
0000c100  00 00 00 05 54 6f 77 65  72 00 00 00 00 00 00 24  |....Tower......$|
0000c110  00 00 00 28 00 00 00 08  74 6f 70 5f 67 75 69 64  |...(....top_guid|
0000c120  00 00 00 08 00 00 00 01  91 7f 7a 38 19 d8 9e 28  |..........z8...(|
0000c130  00 00 00 20 00 00 00 20  00 00 00 04 67 75 69 64  |... ... ....guid|
0000c140  00 00 00 08 00 00 00 01  85 6a 50 2f 77 a2 8c c0  |.........jP/w...|
0000c150  00 00 00 2c 00 00 00 28  00 00 00 0d 76 64 65 76  |...,...(....vdev|
0000c160  5f 63 68 69 6c 64 72 65  6e 00 00 00 00 00 00 08  |_children.......|
0000c170  00 00 00 01 00 00 00 00  00 00 00 01 00 00 07 10  |................|
0000c180  00 00 00 38 00 00 00 09  76 64 65 76 5f 74 72 65  |...8....vdev_tre|
0000c190  65 00 00 00 00 00 00 13  00 00 00 01 00 00 00 00  |e...............|
0000c1a0  00 00 00 01 00 00 00 24  00 00 00 20 00 00 00 04  |.......$... ....|
0000c1b0  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 05  |type............|
0000c1c0  72 61 69 64 7a 00 00 00  00 00 00 20 00 00 00 20  |raidz...... ... |
0000c1d0  00 00 00 02 69 64 00 00  00 00 00 08 00 00 00 01  |....id..........|
0000c1e0  00 00 00 00 00 00 00 00  00 00 00 20 00 00 00 20  |........... ... |
0000c1f0  00 00 00 04 67 75 69 64  00 00 00 08 00 00 00 01  |....guid........|
0000c200  91 7f 7a 38 19 d8 9e 28  00 00 00 24 00 00 00 20  |..z8...(...$... |
0000c210  00 00 00 07 6e 70 61 72  69 74 79 00 00 00 00 08  |....nparity.....|
0000c220  00 00 00 01 00 00 00 00  00 00 00 01 00 00 00 2c  |...............,|
0000c230  00 00 00 28 00 00 00 0e  6d 65 74 61 73 6c 61 62  |...(....metaslab|
0000c240  5f 61 72 72 61 79 00 00  00 00 00 08 00 00 00 01  |_array..........|
0000c250  00 00 00 00 00 00 00 87  00 00 00 2c 00 00 00 28  |...........,...(|
0000c260  00 00 00 0e 6d 65 74 61  73 6c 61 62 5f 73 68 69  |....metaslab_shi|
0000c270  66 74 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |ft..............|
0000c280  00 00 00 22 00 00 00 24  00 00 00 20 00 00 00 06  |..."...$... ....|
0000c290  61 73 68 69 66 74 00 00  00 00 00 08 00 00 00 01  |ashift..........|
0000c2a0  00 00 00 00 00 00 00 0c  00 00 00 24 00 00 00 20  |...........$... |
0000c2b0  00 00 00 05 61 73 69 7a  65 00 00 00 00 00 00 08  |....asize.......|
0000c2c0  00 00 00 01 00 00 12 31  86 04 00 00 00 00 00 24  |.......1.......$|
0000c2d0  00 00 00 20 00 00 00 06  69 73 5f 6c 6f 67 00 00  |... ....is_log..|
0000c2e0  00 00 00 08 00 00 00 01  00 00 00 00 00 00 00 00  |................|
0000c2f0  00 00 00 28 00 00 00 28  00 00 00 0a 63 72 65 61  |...(...(....crea|
0000c300  74 65 5f 74 78 67 00 00  00 00 00 08 00 00 00 01  |te_txg..........|
0000c310  00 00 00 00 00 00 00 04  00 00 05 6c 00 00 00 c0  |...........l....|
0000c320  00 00 00 08 63 68 69 6c  64 72 65 6e 00 00 00 14  |....children....|
0000c330  00 00 00 05 00 00 00 00  00 00 00 01 00 00 00 20  |............... |
0000c340  00 00 00 20 00 00 00 04  74 79 70 65 00 00 00 09  |... ....type....|
0000c350  00 00 00 01 00 00 00 04  64 69 73 6b 00 00 00 20  |........disk... |
0000c360  00 00 00 20 00 00 00 02  69 64 00 00 00 00 00 08  |... ....id......|
0000c370  00 00 00 01 00 00 00 00  00 00 00 00 00 00 00 20  |............... |
0000c380  00 00 00 20 00 00 00 04  67 75 69 64 00 00 00 08  |... ....guid....|
0000c390  00 00 00 01 87 bb 1d 4a  ca 3c a3 11 00 00 00 28  |.......J.<.....(|
0000c3a0  00 00 00 28 00 00 00 04  70 61 74 68 00 00 00 09  |...(....path....|
0000c3b0  00 00 00 01 00 00 00 09  2f 64 65 76 2f 73 64 63  |......../dev/sdc|
0000c3c0  31 00 00 00 00 00 00 28  00 00 00 28 00 00 00 0a  |1......(...(....|
0000c3d0  77 68 6f 6c 65 5f 64 69  73 6b 00 00 00 00 00 08  |whole_disk......|
0000c3e0  00 00 00 01 00 00 00 00  00 00 00 00 00 00 00 20  |............... |
0000c3f0  00 00 00 20 00 00 00 03  44 54 4c 00 00 00 00 08  |... ....DTL.....|
0000c400  00 00 00 01 00 00 00 00  00 00 01 a9 00 00 00 28  |...............(|
0000c410  00 00 00 28 00 00 00 0a  63 72 65 61 74 65 5f 74  |...(....create_t|
0000c420  78 67 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |xg..............|
0000c430  00 00 00 04 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c440  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c450  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 04  |type............|
0000c460  64 69 73 6b 00 00 00 20  00 00 00 20 00 00 00 02  |disk... ... ....|
0000c470  69 64 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |id..............|
0000c480  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c490  67 75 69 64 00 00 00 08  00 00 00 01 85 6a 50 2f  |guid.........jP/|
0000c4a0  77 a2 8c c0 00 00 00 28  00 00 00 28 00 00 00 04  |w......(...(....|
0000c4b0  70 61 74 68 00 00 00 09  00 00 00 01 00 00 00 09  |path............|
0000c4c0  2f 64 65 76 2f 73 64 64  31 00 00 00 00 00 00 28  |/dev/sdd1......(|
0000c4d0  00 00 00 28 00 00 00 0a  77 68 6f 6c 65 5f 64 69  |...(....whole_di|
0000c4e0  73 6b 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |sk..............|
0000c4f0  00 00 00 00 00 00 00 20  00 00 00 20 00 00 00 03  |....... ... ....|
0000c500  44 54 4c 00 00 00 00 08  00 00 00 01 00 00 00 00  |DTL.............|
0000c510  00 00 01 a8 00 00 00 28  00 00 00 28 00 00 00 0a  |.......(...(....|
0000c520  63 72 65 61 74 65 5f 74  78 67 00 00 00 00 00 08  |create_txg......|
0000c530  00 00 00 01 00 00 00 00  00 00 00 04 00 00 00 00  |................|
0000c540  00 00 00 00 00 00 00 00  00 00 00 01 00 00 00 20  |............... |
0000c550  00 00 00 20 00 00 00 04  74 79 70 65 00 00 00 09  |... ....type....|
0000c560  00 00 00 01 00 00 00 04  64 69 73 6b 00 00 00 20  |........disk... |
0000c570  00 00 00 20 00 00 00 02  69 64 00 00 00 00 00 08  |... ....id......|
0000c580  00 00 00 01 00 00 00 00  00 00 00 02 00 00 00 20  |............... |
0000c590  00 00 00 20 00 00 00 04  67 75 69 64 00 00 00 08  |... ....guid....|
0000c5a0  00 00 00 01 5a 31 9c 07  3e b3 75 44 00 00 00 28  |....Z1..>.uD...(|
0000c5b0  00 00 00 28 00 00 00 04  70 61 74 68 00 00 00 09  |...(....path....|
0000c5c0  00 00 00 01 00 00 00 09  2f 64 65 76 2f 73 64 69  |......../dev/sdi|
0000c5d0  31 00 00 00 00 00 00 28  00 00 00 28 00 00 00 0a  |1......(...(....|
0000c5e0  77 68 6f 6c 65 5f 64 69  73 6b 00 00 00 00 00 08  |whole_disk......|
0000c5f0  00 00 00 01 00 00 00 00  00 00 00 00 00 00 00 20  |............... |
0000c600  00 00 00 20 00 00 00 03  44 54 4c 00 00 00 00 08  |... ....DTL.....|
0000c610  00 00 00 01 00 00 00 00  00 00 01 a7 00 00 00 28  |...............(|
0000c620  00 00 00 28 00 00 00 0a  63 72 65 61 74 65 5f 74  |...(....create_t|
0000c630  78 67 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |xg..............|
0000c640  00 00 00 04 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c650  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c660  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 04  |type............|
0000c670  64 69 73 6b 00 00 00 20  00 00 00 20 00 00 00 02  |disk... ... ....|
0000c680  69 64 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |id..............|
0000c690  00 00 00 03 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c6a0  67 75 69 64 00 00 00 08  00 00 00 01 54 10 ee ac  |guid........T...|
0000c6b0  72 b0 e3 c6 00 00 00 28  00 00 00 28 00 00 00 04  |r......(...(....|
0000c6c0  70 61 74 68 00 00 00 09  00 00 00 01 00 00 00 09  |path............|
0000c6d0  2f 64 65 76 2f 73 64 6a  31 00 00 00 00 00 00 28  |/dev/sdj1......(|
0000c6e0  00 00 00 28 00 00 00 0a  77 68 6f 6c 65 5f 64 69  |...(....whole_di|
0000c6f0  73 6b 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |sk..............|
0000c700  00 00 00 00 00 00 00 28  00 00 00 28 00 00 00 0b  |.......(...(....|
0000c710  6e 6f 74 5f 70 72 65 73  65 6e 74 00 00 00 00 08  |not_present.....|
0000c720  00 00 00 01 00 00 00 00  00 00 00 01 00 00 00 20  |............... |
0000c730  00 00 00 20 00 00 00 03  44 54 4c 00 00 00 00 08  |... ....DTL.....|
0000c740  00 00 00 01 00 00 00 00  00 00 01 a6 00 00 00 28  |...............(|
0000c750  00 00 00 28 00 00 00 0a  63 72 65 61 74 65 5f 74  |...(....create_t|
0000c760  78 67 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |xg..............|
0000c770  00 00 00 04 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c780  00 00 00 01 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c790  74 79 70 65 00 00 00 09  00 00 00 01 00 00 00 04  |type............|
0000c7a0  64 69 73 6b 00 00 00 20  00 00 00 20 00 00 00 02  |disk... ... ....|
0000c7b0  69 64 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |id..............|
0000c7c0  00 00 00 04 00 00 00 20  00 00 00 20 00 00 00 04  |....... ... ....|
0000c7d0  67 75 69 64 00 00 00 08  00 00 00 01 b6 aa 20 be  |guid.......... .|
0000c7e0  b8 3a 21 61 00 00 00 28  00 00 00 28 00 00 00 04  |.:!a...(...(....|
0000c7f0  70 61 74 68 00 00 00 09  00 00 00 01 00 00 00 09  |path............|
0000c800  2f 64 65 76 2f 73 64 6b  31 00 00 00 00 00 00 28  |/dev/sdk1......(|
0000c810  00 00 00 28 00 00 00 0a  77 68 6f 6c 65 5f 64 69  |...(....whole_di|
0000c820  73 6b 00 00 00 00 00 08  00 00 00 01 00 00 00 00  |sk..............|
0000c830  00 00 00 00 00 00 00 20  00 00 00 20 00 00 00 03  |....... ... ....|
0000c840  44 54 4c 00 00 00 00 08  00 00 00 01 00 00 00 00  |DTL.............|
0000c850  00 00 01 a5 00 00 00 28  00 00 00 28 00 00 00 0a  |.......(...(....|
0000c860  63 72 65 61 74 65 5f 74  78 67 00 00 00 00 00 08  |create_txg......|
0000c870  00 00 00 01 00 00 00 00  00 00 00 04 00 00 00 00  |................|
0000c880  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 c8  |................|
0000c890  00 00 00 40 00 00 00 11  66 65 61 74 75 72 65 73  |...@....features|
0000c8a0  5f 66 6f 72 5f 72 65 61  64 00 00 00 00 00 00 13  |_for_read.......|
0000c8b0  00 00 00 01 00 00 00 00  00 00 00 01 00 00 00 2c  |...............,|
0000c8c0  00 00 00 28 00 00 00 16  63 6f 6d 2e 64 65 6c 70  |...(....com.delp|
0000c8d0  68 69 78 3a 68 6f 6c 65  5f 62 69 72 74 68 00 00  |hix:hole_birth..|
0000c8e0  00 00 00 01 00 00 00 00  00 00 00 30 00 00 00 30  |...........0...0|
0000c8f0  00 00 00 19 63 6f 6d 2e  64 65 6c 70 68 69 78 3a  |....com.delphix:|
0000c900  65 6d 62 65 64 64 65 64  5f 64 61 74 61 00 00 00  |embedded_data...|
0000c910  00 00 00 01 00 00 00 00  00 00 00 34 00 00 00 30  |...........4...0|
0000c920  00 00 00 1d 63 6f 6d 2e  6b 6c 61 72 61 73 79 73  |....com.klarasys|
0000c930  74 65 6d 73 3a 76 64 65  76 5f 7a 61 70 73 5f 76  |tems:vdev_zaps_v|
0000c940  32 00 00 00 00 00 00 01  00 00 00 00 00 00 00 00  |2...............|
0000c950  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00019000
sdi
00000000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001c0  02 00 ee ff ff ff 01 00  00 00 ff ff ff ff 00 00  |................|
000001d0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 55 aa  |..............U.|
00000200  45 46 49 20 50 41 52 54  00 00 01 00 5c 00 00 00  |EFI PART....\...|
00000210  f1 1d 54 f7 00 00 00 00  01 00 00 00 00 00 00 00  |..T.............|
00000220  af be c0 d1 01 00 00 00  22 00 00 00 00 00 00 00  |........".......|
00000230  8e be c0 d1 01 00 00 00  37 c1 f9 93 0b fb 8a 47  |........7......G|
00000240  9f ee 0c 69 38 05 70 d8  02 00 00 00 00 00 00 00  |...i8.p.........|
00000250  80 00 00 00 80 00 00 00  94 65 0a eb 00 00 00 00  |.........e......|
00000260  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000400  af 3d c6 0f 83 84 72 47  8e 79 3d 69 d8 47 7d e4  |.=....rG.y=i.G}.|
00000410  ce d7 12 e8 a5 59 82 40  a6 d7 ef c1 f4 b4 b8 91  |.....Y.@........|
00000420  40 00 00 00 00 00 00 00  8e be c0 d1 01 00 00 00  |@...............|
00000430  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00004e00  6a c4 1c 5d 9f 91 0d 3d  9c 45 da 9e ba 63 00 5c  |j..]...=.E...c.\|
00004e10  48 78 c4 19 9f c8 8a 1f  8f a3 7f 83 08 cf 7a 71  |Hx............zq|
00004e20  89 a4 1d cd e7 d2 32 e1  27 ad d4 fa 0e 03 99 eb  |......2.'.......|
00004e30  f7 83 50 50 11 2d 79 be  3c b4 f1 e3 8f d9 3b 9f  |..PP.-y.<.....;.|
00004e40  d9 b0 f3 67 87 90 e0 5d  ff f9 f0 60 61 55 1a 2e  |...g...]...`aU..|
00004e50  81 52 af 73 ee 25 ad c7  01 6e ce 6b 01 8d 49 74  |.R.s.%...n.k..It|
00004e60  9c 9e ed 7e e9 3b f3 a2  8e 45 a0 39 0f cd 96 6b  |...~.;...E.9...k|
00004e70  90 3c a7 b4 5a 6f 72 ba  08 6b 58 1f 35 42 2a c6  |.<..Zor..kX.5B*.|
00004e80  4f f4 51 a2 a1 48 6e 89  e9 36 6d c8 3b 12 ec 3a  |O.Q..Hn..6m.;..:|
00004e90  ad 89 2f 37 ab 1a de 63  2f ef 74 ee c7 a9 51 d1  |../7...c/.t...Q.|
00004ea0  ae 63 ad 92 1b 78 98 f1  b6 40 bb fa 22 07 f3 22  |.c...x...@..".."|
00004eb0  95 b7 46 a3 ca 2b 16 85  40 41 0a c5 f3 61 c7 ad  |..F..+..@A...a..|
00004ec0  53 fb 1b 65 ac c9 55 ee  73 c1 02 a0 29 fe 53 15  |S..e..U.s...).S.|
00004ed0  8f 1f ad 8d 77 de 15 ef  6b f3 1b d8 44 96 e3 aa  |....w...k...D...|
00004ee0  5a 2a dc 10 7b 96 da 3c  8b f2 3d 38 a4 81 f3 2c  |Z*..{..<..=8...,|
00004ef0  58 41 f5 54 73 45 9d 73  c5 fd e8 2a be c6 30 50  |XA.TsE.s...*..0P|
00004f00  9e 4f 8f a0 29 ed 4a e9  2f 32 03 ca 13 d8 5b 7a  |.O..).J./2....[z|
00004f10  ae 9d 58 e6 88 73 22 90  0a 43 6c 41 5b 17 c4 1a  |..X..s"..ClA[...|
00004f20  27 5e f9 ef 63 9f 57 23  6c 27 97 70 f5 a8 5b 7b  |'^..c.W#l'.p..[{|
00004f30  5d a9 0f 37 ae ff 8b b2  c8 ca d9 28 8e 5b b2 46  |]..7.......(.[.F|
00004f40  be 80 40 38 e4 ee bb 2c  d2 82 c1 72 5a 11 4f 4b  |..@8...,...rZ.OK|
00004f50  54 e2 b9 f1 24 96 53 3d  33 81 f1 50 2e 1a 04 71  |T...$.S=3..P...q|
00004f60  80 f9 bf 66 69 9c 6f 22  44 d0 69 bb ad 93 84 98  |...fi.o"D.i.....|
00004f70  74 af 67 32 b9 8f 65 f3  4b 0f f4 85 ef b5 ba ff  |t.g2..e.K.......|
00004f80  e1 da 9e 9e 32 96 a9 19  b8 4f 43 f7 f6 4c 1c 0f  |....2....OC..L..|
00004f90  ce d2 67 b6 e3 e3 8d 27  1e 27 98 4c 73 37 5c ff  |..g....'.'.Ls7\.|
00004fa0  ab 16 ca 64 7d 91 c0 6d  ae 60 f0 1a 43 12 e6 f4  |...d}..m.`..C...|
00004fb0  d6 e8 ba c2 9b 2f e6 ce  07 08 6a 8d 28 62 a7 31  |...../....j.(b.1|
00004fc0  e9 3d 4b 9b 5b 19 18 13  d2 a9 c1 08 ce 62 12 8c  |.=K.[........b..|
00004fd0  12 64 e3 43 bb e3 59 1c  57 7f cd b9 72 65 47 ab  |.d.C..Y.W...reG.|
00004fe0  b8 fe 61 c1 08 c2 ec 25  8e b9 1c 89 df 6d d2 a7  |..a....%.....m..|
00004ff0  36 a7 10 52 2a 21 2d aa  98 31 d1 77 1f d2 cc c6  |6..R*!-..1.w....|
00005000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
0000c140  00 00 00 08 00 00 00 01  5a 31 9c 07 3e b3 75 44  |........Z1..>.uD|
00019000
