Before that, lets try a few things - if you go to “Discover Apps” & the hit “Refresh”, does it work?
If you go to Apps configuration, then unset & afterwards re-set the pool, does it work?
Can you ping github.com ?
Well, I still run like 24.10.
I dont like, how Ix Systems implements (however I think otherwise it is really a great product that I like and use on my full 3-2-1 backup system), and announces (sometimes rather significant ones) changes to their systems, by removing regression or normal switch over between the options.
My wote is for:
I’ll try that again when I get home tonight after work
Yeah I thought about doing that as well. My mobo had slots for nve drives. I will get one for boot and another one for just apps
Any results when you ping github.com ?
yep can ping github.com from the shell in truenas
Alright guys I exported the pool, did a fresh install, and apps will now install! Yeah. Got a plex server up and running. I have a Nvidia 1080 in my server that I want to use for transcode. It found it but when I tell it to use it I get an error message. Any ideas?
Long story short, nvidia no longer supports drivers for your card, but there is a workaround.
@Jake_Hinebaugh what version of TrueNAS? You showed 25.04.2.5 earlier
Still the same version. Just did a fresh install
So either upgrade or don’t use hardware ecleration. We’ll that’s pretty awesome ![]()
Naw, the post I linked to literally has a work around that will let you continue to use your 1080
Yeah I read the post. I kinda understand what I was supposed to do. I’m planning on upgrading. I also am thinking of just getting a Intel a310 card and putting my 1080 in my desktop computer
